[GRASS-SVN] r70033 - grass-addons/grass7/raster/r.catchment
svn_grass at osgeo.org
Wed Dec 7 10:02:36 PST 2016
Author: isaacullah
Date: 2016-12-07 10:02:35 -0800 (Wed, 07 Dec 2016)
New Revision: 70033
grass-addons/grass7/raster/r.catchment/r.catchment.py
Fixing a rogue tab indent and removing superfluous whitespaces.
Modified: grass-addons/grass7/raster/r.catchment/r.catchment.py
--- grass-addons/grass7/raster/r.catchment/r.catchment.py 2016-12-07 16:12:13 UTC (rev 70032)
+++ grass-addons/grass7/raster/r.catchment/r.catchment.py 2016-12-07 18:02:35 UTC (rev 70033)
@@ -170,42 +170,42 @@
w_coefs = a + ',' + b + ',' + c + ',' + d
if "MASK" in grass.list_grouped('rast')[grass.gisenv()['MAPSET']] and \
bool(options["sigma"]) is True:
- grass.message(_('There is already a MASK in place, and you have also'
+ grass.message('There is already a MASK in place, and you have also'
' selected to mask slope values above %s.\n The high slope areas'
' (slope mask) will be temporarily added to current MASKED areas for'
' the calcualtion of the catchment geometry.\n The original MASK will'
- ' be restored when the module finishes' % sigma))
+ ' be restored when the module finishes' % sigma)
ismask = 2
tempmask = "temporary.mask.%s" % pid
grass.run_command('g.rename', quiet=True, overwrite=grass.overwrite(),
raster="MASK,%s" % tempmask)
elif "MASK" in grass.list_grouped('rast')[grass.gisenv()['MAPSET']]:
- grass.message(_('There is a MASK in place. The areas MASKed out will'
- ' be ignored while calculating catchment geometry.'))
+ grass.message('There is a MASK in place. The areas MASKed out will'
+ ' be ignored while calculating catchment geometry.')
ismask = 1
else:
ismask = 0
- grass.message(_("Wanted buffer area=%s\n" % int(area)))
+ grass.message("Wanted buffer area=%s\n" % int(area))
if bool(options["in_cost"]) is True:
- grass.verbose(_('Using input cost surface'))
+ grass.verbose('Using input cost surface')
cost = options["in_cost"]
else:
- grass.verbose(_('step 1 of 4: Calculating cost surface'))
+ grass.verbose('step 1 of 4: Calculating cost surface')
cost = 'temporary.cost.%s' % pid
if bool(options["friction"]) is True:
- grass.verbose(_('Calculating costs using input friction map'))
+ grass.verbose('Calculating costs using input friction map')
friction = options["friction"]
else:
- grass.verbose(_('Calculating for time costs only'))
+ grass.verbose('Calculating for time costs only')
friction = "temporary.friction.%s" % pid
grass.mapcalc("${out} = if(isnull(${rast1}), null(), 0)",
overwrite=grass.overwrite(), quiet=True, out=friction,
rast1=elevation)
if flags["k"] is True:
- grass.verbose(_('Using Knight\'s move'))
+ grass.verbose('Using Knight\'s move')
# NOTE! because "lambda" is an internal python variable, it is
# impossible to enter the value for key "lambda" in r.walk.
# It ends up with a python error.
@@ -225,7 +225,7 @@
name=friction)
if bool(options["sigma"]) is True:
- grass.verbose(_('Creating optional slope mask'))
+ grass.verbose('Creating optional slope mask')
slope = "temporary.slope.%s" % pid
grass.run_command('r.slope.aspect', quiet=True,
overwrite=grass.overwrite(), elevation=elevation,
@@ -239,11 +239,11 @@
overwrite=grass.overwrite(), quiet=True, sigma=sigma,
rast1=slope)
else:
- grass.verbose(_('No slope mask created'))
+ grass.verbose('No slope mask created')
if flags["l"] is True:
- grass.message(_('Calculating list of possible catchment'
- ' configurations...\ncost value | catchment area'))
+ grass.message('Calculating list of possible catchment'
+ ' configurations...\ncost value | catchment area')
areadict = {}
out2dictnum('r.stats -Aani input=' + cost +
' separator=, nv=* nsteps=255', ',', areadict)
@@ -257,37 +257,37 @@
grass.run_command('g.rename', overwrite=grass.overwrite(),
quiet=True, rast='temporary.cost.%s,%s_cost_surface'
% (pid, buff))
- grass.verbose(_('Cleaning up...(keeping cost map)'))
+ grass.verbose('Cleaning up...(keeping cost map)')
grass.run_command('g.remove', quiet=True, flags='f',
type='raster', name='cost.reclass.%s' % pid)
else:
- grass.verbose(_('Cleaning up...1'))
+ grass.verbose('Cleaning up...1')
else:
if bool(options["in_cost"]) is False:
- grass.verbose(_('Cleaning up...2'))
+ grass.verbose('Cleaning up...2')
type='raster',
name='cost.reclass.%s,temporary.cost.%s' %
(pid, pid))
else:
- grass.verbose(_('Cleaning up...3'))
+ grass.verbose('Cleaning up...3')
type='raster', name=slope)
if ismask == 2:
- grass.message(_('Reinstating original MASK...'))
+ grass.message('Reinstating original MASK...')
quiet="True", rast=tempmask + ',MASK')
elif ismask == 0 and bool(options["sigma"]) is True:
type='raster', name='MASK')
elif ismask == 1:
- grass.message(_('Keeping original MASK'))
- grass.verbose(_(' DONE!'))
+ grass.message('Keeping original MASK')
+ grass.verbose(' DONE!')
return
else:
areadict = {}
@@ -297,9 +297,9 @@
for key in sorted(areadict):
tot_area = tot_area + int(float(areadict[key]))
maxcost = key
- grass.message(_("Maximum cost distance value %s covers an area of %s"
- " square map units" % (int(maxcost), tot_area)))
- grass.verbose(_("Commencing to find a catchment configuration....."))
+ grass.message("Maximum cost distance value %s covers an area of %s"
+ " square map units" % (int(maxcost), tot_area))
+ grass.verbose("Commencing to find a catchment configuration.....")
testarea = 0
lastarea = 0
lastkey = 0
@@ -316,13 +316,13 @@
else:
cutoff = lastkey
displayarea = lastarea
- grass.verbose(_("Catchment configuration found!"))
- grass.message(_("Cost cutoff %s produces a catchment of %s square map "
- "units." % (int(cutoff), displayarea)))
+ grass.verbose("Catchment configuration found!")
+ grass.message("Cost cutoff %s produces a catchment of %s square map "
+ "units." % (int(cutoff), displayarea))
- grass.verbose(_('Creating output map'))
+ grass.verbose('Creating output map')
t = grass.tempfile()
- temp = file(t, 'w+')
+ temp = file(t, 'w+')
temp.write('0 thru %s = %s\n' % (int(cutoff), mapval))
temp.flush()
grass.run_command('r.reclass', overwrite=grass.overwrite(), input=cost,
@@ -331,44 +331,44 @@
grass.mapcalc("${out}=if(isnull(${cost}), null(), ${cost})",
cost="cost.reclass.%s" % pid, out=buff)
- grass.verbose(_("The output catchment map will be named %s" % buff))
+ grass.verbose("The output catchment map will be named %s" % buff)
grass.run_command('r.colors', quiet=True, map=buff, color='ryb')
if flags["c"] is True:
% (pid, buff))
else:
else:
type='raster',
(pid, pid))
else:
if ismask == 2:
elif ismask == 1:
return
# here is where the code in "main" actually gets executed.
