[GRASS-SVN] r70058 - grass/branches/releasebranch_7_2/lib/gis
svn_grass at osgeo.org
Sun Dec 11 11:36:11 PST 2016
Author: neteler
Date: 2016-12-11 11:36:11 -0800 (Sun, 11 Dec 2016)
New Revision: 70058
grass/branches/releasebranch_7_2/lib/gis/gisinit.c
libgis: transfer zlib compression levels comments from r69388 (completes r69387)
Modified: grass/branches/releasebranch_7_2/lib/gis/gisinit.c
--- grass/branches/releasebranch_7_2/lib/gis/gisinit.c 2016-12-11 18:59:46 UTC (rev 70057)
+++ grass/branches/releasebranch_7_2/lib/gis/gisinit.c 2016-12-11 19:36:11 UTC (rev 70058)
@@ -119,6 +119,10 @@
G__.little_endian = G_is_little_endian();
zlib = getenv("GRASS_ZLIB_LEVEL");
+ /* Valid zlib compression levels -1 - 9 */
+ /* zlib default: Z_DEFAULT_COMPRESSION = -1, equivalent to 6
+ * level 0 means no compression
+ * as used here, 1 gives the best compromise between speed and compression */
G__.compression_level = (zlib && *zlib && isdigit(*zlib)) ? atoi(zlib) : 1;
if (G__.compression_level < -1 || G__.compression_level > 9)
G__.compression_level = 1;
