[GRASS-SVN] r70090 - in grass-addons/grass7/imagery: . i.superpixels.slic
svn_grass at osgeo.org
Sun Dec 18 04:54:37 PST 2016
Author: rashadkm
Date: 2016-12-18 04:54:37 -0800 (Sun, 18 Dec 2016)
New Revision: 70090
Added:
grass-addons/grass7/imagery/i.superpixels.slic/
grass-addons/grass7/imagery/i.superpixels.slic/Makefile
grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html
grass-addons/grass7/imagery/i.superpixels.slic/main.c
add: i.superpixels.slic
Added: grass-addons/grass7/imagery/i.superpixels.slic/Makefile
--- grass-addons/grass7/imagery/i.superpixels.slic/Makefile (rev 0)
+++ grass-addons/grass7/imagery/i.superpixels.slic/Makefile 2016-12-18 12:54:37 UTC (rev 70090)
@@ -0,0 +1,12 @@
+# fix this relative to include/
+# or use absolute path to the GRASS source code
+MODULE_TOPDIR = ../..
+PGM = i.superpixels.slic
+LIBES = $(IMAGERYLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(IMAGERYDEP) $(RASTERDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html
--- grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html (rev 0)
+++ grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html 2016-12-18 12:54:37 UTC (rev 70090)
@@ -0,0 +1,24 @@
+<H2>DESCRIPTION</H2>
+<EM>i.superpixels.slic</EM> performs superpixel segmentation
+<H2>NOTES</H2>
+This code performs superpixel segmentation as explained in the paper:
+"SLIC Superpixels", Radhakrishna Achanta, Appu Shaji, Kevin Smith, Aurelien Lucchi, Pascal Fua, and Sabine Susstrunk.
+EPFL Technical Report no. 149300, June 2010.
+<p>
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<H2>AUTHORS</H2>
+Rashad Kanavath, India <BR>
+<p>
+<i>Last changed: $Date: 2016-12-18 10:08:17 +0100 (Sun, 18 Dec 2016) $</i>
Added: grass-addons/grass7/imagery/i.superpixels.slic/main.c
--- grass-addons/grass7/imagery/i.superpixels.slic/main.c (rev 0)
+++ grass-addons/grass7/imagery/i.superpixels.slic/main.c 2016-12-18 12:54:37 UTC (rev 70090)
@@ -0,0 +1,866 @@
+ * MODULE: i.superpixels.slic
+ * PURPOSE: Preform superpixel segmenation
+ * This code performs superpixel segmentation as explained in the paper:
+ * "SLIC Superpixels", Radhakrishna Achanta, Appu Shaji,
+ * Kevin Smith, Aurelien Lucchi, Pascal Fua, and Sabine Susstrunk.
+ * EPFL Technical Report no. 149300, June 2010.
+ * Below code is ported to grass from original C++ SLIC implmenetation
+ * available at: http://ivrl.epfl.ch/research/superpixels
+#include <grass/config.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+#include <math.h>
+#include <limits.h>
+#include <float.h>
+void SLIC_EnforceLabelConnectivity(
+ int* labels,
+ int width,
+ int height,
+ int* nlabels,//new labels
+ int numlabels,
+ int K)
+// const int dx8[8] = {-1, -1, 0, 1, 1, 1, 0, -1};
+// const int dy8[8] = { 0, -1, -1, -1, 0, 1, 1, 1};
+ const int dx4[4] = {-1, 0, 1, 0};
+ const int dy4[4] = { 0, -1, 0, 1};
+ const int sz = width*height;
+ const int SUPSZ = sz/K;
+ //nlabels.resize(sz, -1);
+ int i;
+ for( i = 0; i < sz; i++ ) nlabels[i] = -1;
+ int label = 0; //(0);
+ int* xvec;
+ xvec = G_malloc (sizeof (int) * sz);
+ memset (xvec, 0, sizeof (int) * sz);
+ int* yvec;
+ yvec = G_malloc (sizeof (int) * sz);
+ memset (yvec, 0, sizeof (int) * sz);
+ int oindex=0;
+ int adjlabel=0; ;//adjacent label
+ int j, k;
+ for( j = 0; j < height; j++ )
+ for( k = 0; k < width; k++ )
+ if( 0 > nlabels[oindex] )
+ nlabels[oindex] = label;
+ // Start a new segment
+ xvec[0] = k;
+ yvec[0] = j;
+ // Quickly find an adjacent label for use later if needed
+ {int n; for( n = 0; n < 4; n++ )
+ int x = xvec[0] + dx4[n];
+ int y = yvec[0] + dy4[n];
+ if( (x >= 0 && x < width) && (y >= 0 && y < height) )
+ int nindex = y*width + x;
+ if(nlabels[nindex] >= 0) adjlabel = nlabels[nindex];
+ int count = 1;
+ int c; for( c = 0; c < count; c++ )
+ int n; for( n = 0; n < 4; n++ )
+ int x = xvec[c] + dx4[n];
+ int y = yvec[c] + dy4[n];
+ if( 0 > nlabels[nindex] && labels[oindex] == labels[nindex] )
+ xvec[count] = x;
+ yvec[count] = y;
+ nlabels[nindex] = label;
+ count++;
+ // If segment size is less then a limit, assign an
+ // adjacent label found before, and decrement label count.
+ if(count <= SUPSZ >> 2)
+ { int c;
+ for( c = 0; c < count; c++ )
+ int ind = yvec[c]*width+xvec[c];
+ nlabels[ind] = adjlabel;
+ label--;
+ label++;
+ oindex++;
+ numlabels = label;
+ if(xvec) G_free(xvec);
+ if(yvec) G_free(yvec);
+ * main function
+ * it copies raster input raster map, calling the appropriate function for each
+ * data type (CELL, DCELL, FCELL)
+int main(int argc, char *argv[])
+ struct Cell_head r_cellhd; /* it stores region information, */
+struct Cell_head g_cellhd;
+ struct Cell_head b_cellhd;
+/* and header information of rasters */
+ char *r_mapset; /* mapset name */
+ char *g_mapset;
+ char *b_mapset;
+ int nrows, ncols;
+ int row, col;
+ void *r_band;
+ void *g_band;
+ void *b_band;
+ int r_fd, g_fd, b_fd;
+ RASTER_MAP_TYPE r_data_type, g_data_type, b_data_type; /* type of the map (CELL/DCELL/...) */
+ struct History history; /* holds meta-data (title, comments,..) */
+ struct GModule *module; /* GRASS module for parsing arguments */
+ struct Option *r_input, *g_input, *b_input, *output; /* options */
+ /* initialize GIS environment */
+ G_gisinit(argv[0]); /* reads grass env, stores program name to G_program_name() */
+ /* initialize module */
+ module = G_define_module();
+ G_add_keyword(_("imagery"));
+ G_add_keyword(_("segmentation"));
+ G_add_keyword(_("superpixels"));
+ G_add_keyword(_("SLIC"));
+ module->description = _("SLIC segmenation");
+ /* Define the different options as defined in gis.h */
+ r_input = G_define_standard_option(G_OPT_R_INPUT);
+ r_input->key = "red";
+ r_input->answer = NULL;
+ r_input->description = "Name of raster map to be used for <red>";
+ g_input = G_define_standard_option(G_OPT_R_INPUT);
+ g_input->key = "green";
+ g_input->answer = NULL;
+ g_input->description = "Name of raster map to be used for <green>";
+ b_input = G_define_standard_option(G_OPT_R_INPUT);
+ b_input->key = "blue";
+ b_input->answer = NULL;
+ b_input->description = "Name of raster map to be used for <blue>";
+ struct Option *opt_iteration, *opt_super_pixels;
+ opt_iteration = G_define_option();
+ opt_iteration->key = "iter";
+ opt_iteration->type = TYPE_INTEGER;
+ opt_iteration->required = NO;
+ opt_iteration->description = _("Maximum number of iterations");
+ opt_iteration->answer = "10";
+ opt_super_pixels = G_define_option();
+ opt_super_pixels->key = "k";
+ opt_super_pixels->type = TYPE_INTEGER;
+ opt_super_pixels->required = NO;
+ opt_super_pixels->description = _("No of super pixels");
+ opt_super_pixels->answer = "200";
+ output = G_define_standard_option(G_OPT_R_OUTPUT);
+ /* options and flags parser */
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ int n_iterations;
+ if (opt_iteration->answer) {
+ if ( sscanf(opt_iteration->answer, "%d", &n_iterations) != 1 ) {
+ G_fatal_error(_("Illegal value for iter (%s)"), opt_iteration->answer);
+ else {
+ n_iterations = 10;
+ int n_super_pixels;
+ if (opt_super_pixels->answer) {
+ if ( sscanf(opt_super_pixels->answer, "%d", &n_super_pixels) != 1 ) {
+ G_fatal_error(_("Illegal value for k (%s)"), opt_super_pixels->answer);
+ else {
+ n_super_pixels = 200;
+ /* stores options and flags to variables */
+ // char *r_name, g_name, b_name;
+ const char* r_name = r_input->answer;
+ const char* g_name = g_input->answer;
+ const char* b_name = b_input->answer;
+ const char* result = output->answer;
+ /* returns NULL if the map was not found in any mapset,
+ * mapset name otherwise */
+ r_mapset = (char *) G_find_raster2(r_name, "");
+ if (r_mapset == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), r_name);
+ g_mapset = (char *) G_find_raster2(g_name, "");
+ if (g_mapset == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), g_name);
+ b_mapset = (char *) G_find_raster2(b_name, "");
+ if (b_mapset == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), b_name);
+ /* determine the inputmap type (CELL/FCELL/DCELL) */
+ r_data_type = Rast_map_type(r_name, r_mapset);
+ g_data_type = Rast_map_type(g_name, g_mapset);
+ b_data_type = Rast_map_type(b_name, b_mapset);
+ /* Rast_open_old - returns file destriptor (>0) */
+ r_fd = Rast_open_old(r_name, r_mapset);
+ g_fd = Rast_open_old(g_name, g_mapset);
+ b_fd = Rast_open_old(b_name, b_mapset);
+ /* controlling, if we can open input raster */
+ Rast_get_cellhd(r_name, r_mapset, &r_cellhd);
+ G_debug(3, "number of rows in R %d", r_cellhd.rows);
+ Rast_get_cellhd(g_name, g_mapset, &g_cellhd);
+ G_debug(3, "number of rows in G %d", g_cellhd.rows);
+ Rast_get_cellhd(b_name, b_mapset, &b_cellhd);
+ G_debug(3, "number of rows in B %d", b_cellhd.rows);
+ /* Allocate input buffer */
+ r_band = Rast_allocate_buf(r_data_type);
+ g_band = Rast_allocate_buf(g_data_type);
+ b_band = Rast_allocate_buf(b_data_type);
+ /* Allocate output buffer, use input map data_type */
+ nrows = Rast_window_rows();
+ ncols = Rast_window_cols();
+ int m_size = nrows*ncols;
+ double *L = NULL;
+ double *A = NULL;
+ double *B = NULL;
+ L = G_malloc (sizeof (double) * m_size);
+ memset (L, 0, sizeof (double) * m_size);
+ A = G_malloc (sizeof (double) * m_size);
+ memset (A, 0, sizeof (double) * m_size);
+ B = G_malloc (sizeof (double) * m_size);
+ memset (B, 0, sizeof (double) * m_size);
+ int index = 0;
+ /* for each row */
+ for (row = 0; row < nrows; row++) {
+ G_percent(row, nrows, 2);
+ /* read input map */
+ Rast_get_row(r_fd, r_band, row, r_data_type);
+ Rast_get_row(g_fd, g_band, row, g_data_type);
+ Rast_get_row(b_fd, b_band, row, b_data_type);
+ /* process the data */
+ for (col = 0; col < ncols; col++) {
+ //HERE: convert pixel to lab colour space
+ int r = ((int *) r_band)[col];
+ int g = ((int *) g_band)[col];
+ int b = ((int *) b_band)[col];
+ float var_R = (r / 255.0f); //R from 0 to 255
+ float var_G = (g / 255.0f); //G from 0 to 255
+ float var_B = (b / 255.0f); //B from 0 to 255
+ if (var_R > 0.04045f) {
+ var_R = powf(( (var_R + 0.055f) / 1.055f), 2.4f);
+ } else {
+ var_R = var_R / 12.92f;
+ if (var_G > 0.04045) {
+ var_G = powf(( (var_G + 0.055f) / 1.055f), 2.4f);
+ } else {
+ var_G = var_G / 12.92f;
+ if (var_B > 0.04045f) {
+ var_B = powf(( (var_B + 0.055f) / 1.055f), 2.4f);
+ } else {
+ var_B = var_B / 12.92f;
+ var_R = var_R * 100;
+ var_G = var_G * 100;
+ var_B = var_B * 100;
+ //Observer. = 2°, Illuminant = D65
+ double X = var_R * 0.4124f + var_G * 0.3576f + var_B * 0.1805f;
+ double Y = var_R * 0.2126f + var_G * 0.7152f + var_B * 0.0722f;
+ double Z = var_R * 0.0193f + var_G * 0.1192f + var_B * 0.9505f;
+ double ref_X = 95.047;
+ double ref_Y = 100.000;
+ double ref_Z = 108.883;
+ double var_X = X / ref_X;
+ double var_Y = Y / ref_Y;
+ double var_Z = Z / ref_Z;
+ if ( var_X > 0.008856 ) var_X = powf(var_X, 1.0/3.0);
+ else var_X = ( 7.787 * var_X ) + ( 16 / 116 );
+ if ( var_Y > 0.008856 ) var_Y = powf(var_Y, 1.0/3.0);
+ else var_Y = ( 7.787 * var_Y ) + ( 16 / 116 );
+ if ( var_Z > 0.008856 )
+ var_Z = powf(var_Z, 1.0/3.0);
+ else
+ var_Z = ( 7.787 * var_Z ) + ( 16 / 116 );
+ L[index] = ( 116 * var_Y ) - 16;
+ A[index] = 500 * ( var_X - var_Y );
+ B[index] = 200 *(var_Y - var_Z );
+ index = index + 1;
+ int g_width = ncols;
+ int g_height = nrows;
+ //HERE
+ double compactness = 20;
+ int superpixelsize = 0.5+(double)g_width*(double)g_height/(double) n_super_pixels;
+ int* klabels = NULL;
+ int sz = nrows * ncols;
+ klabels = G_malloc (sizeof (int) * sz);
+ int s;
+ for( s = 0; s < sz; s++ ) klabels[s] = -1;
+ int offset = sqrt((double)superpixelsize) + 0.5;
+ double* kseedsl;
+ double* kseedsa;
+ double* kseedsb;
+ double* kseedsx;
+ double* kseedsy;
+ /* int g_width = ncols; */
+ /* int g_height = nrows; */
+ short perturbseeds = 0;
+ double *edgemag;
+ /////////////////:GetLABXYSeeds_ForGivenStepSize
+ short hexgrid = 0;
+ int xstrips = (0.5+(double)g_width / (double)offset);
+ int ystrips = (0.5+(double)g_height / (double)offset);
+ int xerr = g_width - offset*xstrips;
+ if(xerr < 0) { xstrips--; xerr = g_width - offset*xstrips; }
+ int yerr = g_height - offset*ystrips;
+ if(yerr < 0) { ystrips--; yerr = g_height - offset*ystrips; }
+ #ifdef MY_DEBUG
+ printf("superpixelsize=%d\n", superpixelsize);
+ printf("g_height=%d\n", g_height);
+ printf("g_width=%d\n", g_width);
+ printf("ystrips=%d\n", ystrips);
+ printf("xstrips=%d\n", xstrips);
+ printf("xerr=%d\n", xerr);
+ printf("yerr=%d\n", yerr);
+ #endif
+ double xerrperstrip = (double)xerr/(double)xstrips;
+ double yerrperstrip = (double)yerr/(double)ystrips;
+ #ifdef MY_DEBUG
+ printf("xerrperstrip=%f\n", xerrperstrip);
+ printf("yerrperstrip=%f\n", yerrperstrip);
+ #endif
+ int xoff = offset/2;
+ int yoff = offset/2;
+ const int numseeds = xstrips*ystrips;
+ kseedsl = G_malloc (sizeof (double) * numseeds);
+ memset (kseedsl, 0, sizeof (double) * numseeds);
+ kseedsa = G_malloc (sizeof (double) * numseeds);
+ memset (kseedsa, 0, sizeof (double) * numseeds);
+ kseedsb = G_malloc (sizeof (double) * numseeds);
+ memset (kseedsb, 0, sizeof (double) * numseeds);
+ kseedsx = G_malloc (sizeof (double) * numseeds);
+ memset (kseedsx, 0, sizeof (double) * numseeds);
+ kseedsy = G_malloc (sizeof (double) * numseeds);
+ memset (kseedsy, 0, sizeof (double) * numseeds);
+ int x,y;
+ int n = 0;
+ #ifdef MY_DEBUG
+ printf("numseeds=%d\n", numseeds);
+ #endif
+ //numseeds = numlabels;
+ for( y = 0; y < ystrips; y++ )
+ int ye = y*yerrperstrip;
+ for( x = 0; x < xstrips; x++ )
+ int xe = x*xerrperstrip;
+ int seedx = (x*offset+xoff+xe);
+ if(hexgrid > 0 )
+ seedx = x*offset+(xoff<<(y&0x1))+xe;
+ seedx = min(g_width-1,seedx);
+ } //for hex grid sampling
+ int seedy = (y*offset+yoff+ye);
+ int i = seedy*g_width + seedx;
+ // printf("L[i]=%f where i=%d \n", L[i], i);
+ kseedsl[n] = L[i];
+ kseedsa[n] = A[i];
+ kseedsb[n] = B[i];
+ kseedsx[n] = seedx;
+ kseedsy[n] = seedy;
+ n++;
+ int numk = numseeds;
+ double *clustersize;
+ clustersize = G_malloc (sizeof (double) * numk);
+ memset (clustersize, 0, sizeof (double) * numk);
+ double *inv;
+ inv = G_malloc (sizeof (double) * numk);
+ memset (inv, 0, sizeof (double) * numk);
+ double *sigmal;
+ sigmal = G_malloc (sizeof (double) * numk);
+ memset (sigmal, 0, sizeof (double) * numk);
+ double *sigmaa;
+ sigmaa = G_malloc (sizeof (double) * numk);
+ memset (sigmaa, 0, sizeof (double) * numk);
+ double *sigmab;
+ sigmab = G_malloc (sizeof (double) * numk);
+ memset (sigmab, 0, sizeof (double) * numk);
+ double *sigmax;
+ sigmax = G_malloc (sizeof (double) * numk);
+ memset (sigmax, 0, sizeof (double) * numk);
+ double *sigmay;
+ sigmay = G_malloc (sizeof (double) * numk);
+ memset (sigmay, 0, sizeof (double) * numk);
+ //double *distvec;
+ // distvec = G_malloc (sizeof (double) * sz);
+ double distvec[sz];
+ int p;
+ for( p = 0; p < sz; p++ ) distvec[p] = 1E+9;
+ double invwt = 1.0/((offset/compactness)*(offset/compactness));
+ int x1, y1, x2, y2;
+ double dist;
+ double distxy;
+ //int n,x,y;
+ int itr;
+ double he = (double)g_height;
+ double wi = (double)g_width;
+ double dbl_offset = (double)offset;
+ for( itr = 0; itr < n_iterations ; itr++ )
+ int n;
+ for( n = 0; n < numk; n++ )
+ y1 = (int)fmax(0.0, kseedsy[n]-dbl_offset);
+ y2 = (int)fmin(he, kseedsy[n]+dbl_offset);
+ x1 = (int)fmax(0.0, kseedsx[n]-dbl_offset);
+ x2 = (int)fmin(wi, kseedsx[n]+dbl_offset);
+ int y;
+ // printf("y1= %d y2=%d x1=%d x2=%d \n", y1, y2, x1, x2);
+ for( y = y1; y < y2; y++ )
+ int x;
+ for( x = x1; x < x2; x++ )
+ int i = y* g_width + x;
+ double dx = (double)x;
+ double dy = (double)y;
+ dist = (L[i] - kseedsl[n])*(L[i] - kseedsl[n]) +
+ (A[i] - kseedsa[n])*(A[i] - kseedsa[n]) +
+ (B[i] - kseedsb[n])*(B[i] - kseedsb[n]);
+ distxy = (dx - kseedsx[n])*(dx - kseedsx[n]) +
+ (dy - kseedsy[n])*(dy - kseedsy[n]);
+ dist += distxy*invwt;//dist = sqrt(dist) + sqrt(distxy*invwt);//this is more exact
+ if( dist < distvec[i] )
+ // printf("n=%d with i=<%d>\n", n, i);
+ distvec[i] = dist;
+ klabels[i] = n;
+ else
+ // printf("distvec[i]=%f and dist=%f with i=<%d>\n", distvec[i], i);
+ int ww;
+ for( ww = 0; ww < sz; ww++ )
+ if( klabels[ww] > -1)
+ printf("klabels[%d]=%d\n", ww, klabels[ww]);
+ // Recalculate the centroid and store in the seed values
+ //------------------------------------------wi-----------------------
+ //instead of reassigning memory on each iteration, just reset.
+ {int ind = 0;
+ int r,c;
+ for( r = 0; r < g_height; r++ )
+ for( c = 0; c < g_width; c++ )
+ sigmal[klabels[ind]] += L[ind];
+ sigmaa[klabels[ind]] += A[ind];
+ sigmab[klabels[ind]] += B[ind];
+ sigmax[klabels[ind]] += c;
+ sigmay[klabels[ind]] += r;
+ //edgesum[klabels[ind]] += edgemag[ind];
+ clustersize[klabels[ind]] += 1.0;
+ ind++;
+ {int k;
+ for( k = 0; k < numk; k++ )
+ if( clustersize[k] <= 0 ) clustersize[k] = 1;
+ inv[k] = 1.0/clustersize[k];//computing inverse now to multiply, than divide later
+ { int k;
+ kseedsl[k] = sigmal[k]*inv[k];
+ kseedsa[k] = sigmaa[k]*inv[k];
+ kseedsb[k] = sigmab[k]*inv[k];
+ kseedsx[k] = sigmax[k]*inv[k];
+ kseedsy[k] = sigmay[k]*inv[k];
+ //edgesum[k] *= inv[k];
+ //numlabels = kseedsl.size();
+ int numlabels = numk;
+ #ifdef MY_DEBUG
+ printf("numk=%d\n", numk);
+ #endif
+ int* nlabels;
+ nlabels = G_malloc (sizeof (int) * sz);
+ memset (nlabels, 0, sizeof (int) * sz);
+ SLIC_EnforceLabelConnectivity(klabels, g_width, g_height,
+ nlabels,
+ numlabels,
+ (double)sz/((double)(offset*offset)));
+ {int i;
+ for( i = 0; i < sz; i++ ) klabels[i] = nlabels[i];}
+ if(nlabels) G_free(nlabels);
+ int outfd;
+ const int dx8[8] = {-1, -1, 0, 1, 1, 1, 0, -1};
+ const int dy8[8] = { 0, -1, -1, -1, 0, 1, 1, 1};
+ int mainindex=0;
+ int cind =0;
+ short *istaken;
+ istaken = G_malloc (sizeof (short) * sz);
+ memset (istaken, 0, sizeof (short) * sz);
+ int *contourx;
+ contourx = G_malloc (sizeof (int) * sz);
+ memset (contourx, 0, sizeof (int) * sz);
+ int *contoury;
+ contoury = G_malloc (sizeof (int) * sz);
+ memset (contoury, 0, sizeof (int) * sz);
+ int j,k;
+ for( j = 0; j < g_height; j++ )
+ for( k = 0; k < g_width; k++ )
+ int np = 0;
+ int i;
+ for( i = 0; i < 8; i++ )
+ int x = k + dx8[i];
+ int y = j + dy8[i];
+ if( (x >= 0 && x < g_width) && (y >= 0 && y < g_height) )
+ int index = y*g_width + x;
+ // if( istaken[index] < 1 ) //comment this to obtain internal contours
+ if( klabels[mainindex] != klabels[index] ) np++;
+ if( np > 1 )
+ contourx[cind] = k;
+ contoury[cind] = j;
+ istaken[mainindex] = 1;
+ //img[mainindex] = color;
+ cind++;
+ mainindex++;
+ int r,c;
+ DCELL *ubuff[nrows];
+ for( r = 0; r < nrows; r++ )
+ ubuff[r] = Rast_allocate_d_buf();
+ int numboundpix = cind;//int(contourx.size());
+ for( j = 0; j < numboundpix; j++ )
+ // int ii = contoury[j]*g_width + contourx[j];
+ ubuff[ contoury[j] ][ contourx[j] ] = 1;
+ int n;
+ for( n = 0; n < 8; n++ )
+ int x = contourx[j] + dx8[n];
+ int y = contoury[j] + dy8[n];
+ int ind = y*g_width + x;
+ if(istaken[ind] < 1) {
+ ubuff[y][x] =0;
+ outfd = Rast_open_new(result, DCELL_TYPE);
+ int z;
+ for (z = 0; z < nrows; z++)
+ Rast_put_row(outfd, ubuff[z], DCELL_TYPE);
+ G_free(ubuff[z]);
+ /* memory cleanup */
+ G_free(kseedsl);
+ G_free(kseedsa);
+ G_free(kseedsb);
+ G_free(kseedsx);
+ G_free(kseedsy);
+ G_free(sigmal);
+ G_free(sigmaa);
+ G_free(sigmab);
+ G_free(sigmax);
+ G_free(sigmay);
+ G_free(klabels);
+ G_free(L);
+ G_free(A);
+ G_free(B);
+ G_free(r_band);
+ G_free(g_band);
+ G_free(b_band);
+ /* closing raster maps */
+ Rast_close(r_fd);
+ Rast_close(g_fd);
+ Rast_close(b_fd);
+ Rast_close(outfd);
+ exit(EXIT_SUCCESS);
