[GRASS-SVN] r70106 - grass/trunk/mswindows
svn_grass at osgeo.org
Tue Dec 20 14:03:52 PST 2016
Author: martinl
Date: 2016-12-20 14:03:52 -0800 (Tue, 20 Dec 2016)
New Revision: 70106
grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
wingrass: attempt to fix standalone installer to download and execute vcredist exe files
Modified: grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
--- grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2016-12-20 22:03:29 UTC (rev 70105)
+++ grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2016-12-20 22:03:52 UTC (rev 70106)
@@ -802,12 +802,25 @@
SetShellVarContext current
InitPluginsDir
NSISdl::download "$HTTP_PATH/$ARCHIVE_NAME" "$TEMP\$ARCHIVE_NAME"
+ !if ${PLATFORM} == "x86"
+ NSISdl::download "$HTTP_PATH/msvcrt2005/$ARCHIVE_NAME2005" "$TEMP\$ARCHIVE_NAME2005"
+ !endif
+ NSISdl::download "$HTTP_PATH/msvcrt2008/$ARCHIVE_NAME2008" "$TEMP\$ARCHIVE_NAME2008"
+ NSISdl::download "$HTTP_PATH/msvcrt2010/$ARCHIVE_NAME2010" "$TEMP\$ARCHIVE_NAME2010"
+ NSISdl::download "$HTTP_PATH/msvcrt2013/$ARCHIVE_NAME2013" "$TEMP\$ARCHIVE_NAME2013"
Pop $0
StrCmp $0 "success" download_ok download_failed
download_ok:
InitPluginsDir
untgz::extract "-d" "$TEMP\$ORIGINAL_UNTAR_FOLDER" "-zbz2" "$TEMP\$ARCHIVE_NAME"
+ untgz::extract "-d" "$TEMP\$ORIGINAL_UNTAR_FOLDER" "-zbz2" "$TEMP\$ARCHIVE_NAME2005"
+ !endif
+ untgz::extract "-d" "$TEMP\$ORIGINAL_UNTAR_FOLDER" "-zbz2" "$TEMP\$ARCHIVE_NAME2008"
+ untgz::extract "-d" "$TEMP\$ORIGINAL_UNTAR_FOLDER" "-zbz2" "$TEMP\$ARCHIVE_NAME2010"
+ untgz::extract "-d" "$TEMP\$ORIGINAL_UNTAR_FOLDER" "-zbz2" "$TEMP\$ARCHIVE_NAME2013"
Pop $0
StrCmp $0 "success" untar_ok untar_failed
@@ -825,12 +838,23 @@
untar_ok:
DetailPrint "Archive successfully unzipped."
- DetailPrint "Installing vcredist_2005_x86.exe ..."
- ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2005_x86.exe" /q'
- DetailPrint "Installing vcredist_2008_x86.exe ..."
- ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2008_x86.exe" /q'
- DetailPrint "Installing vcredist_2010_x86.exe ..."
- ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2010_x86.exe" /q'
+ DetailPrint "Installing vcredist_2005_x86.exe ..."
+ ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2005_x86.exe" /q'
+ DetailPrint "Installing vcredist_2008_x86.exe ..."
+ ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2008_x86.exe" /q'
+ DetailPrint "Installing vcredist_2010_x86.exe ..."
+ ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2010_x86.exe" /q'
+ DetailPrint "Installing vcredist_2013_x86.exe ..."
+ !else
+ DetailPrint "Installing vcredist_2008_x64.exe ..."
+ ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist-2008-sp1-x64.exe" /q'
+ DetailPrint "Installing vcredist_2010_x64.exe ..."
+ ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist-2010-x64.exe" /q'
+ DetailPrint "Installing vcredist_2013_x64.exe ..."
+ ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist-2013-x64.exe" /q'
+ !endif
DetailPrint "Copying runtime files ..."
CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" "$INSTALL_DIR\extrabin"
DetailPrint "MS runtime files installed."
@@ -843,7 +867,7 @@
Section "Important Microsoft Runtime DLLs" SecMSRuntime
;Set the size (in KB) of the archive file
- StrCpy $ARCHIVE_SIZE_KB 12521
+ StrCpy $ARCHIVE_SIZE_KB 18512
;Set the size (in KB) of the unpacked archive file
AddSize 13500
@@ -851,8 +875,15 @@
StrCpy $HTTP_PATH "http://download.osgeo.org/osgeo4w/${PLATFORM}/release/msvcrt/"
!if ${PLATFORM} == "x86_64"
StrCpy $ARCHIVE_NAME "msvcrt-1.0.1-8.tar.bz2"
+ StrCpy $ARCHIVE_NAME2008 "msvcrt2008-1.0.0-1.tar.bz2"
+ StrCpy $ARCHIVE_NAME2010 "msvcrt2010-1.0.0-1.tar.bz2"
+ StrCpy $ARCHIVE_NAME2013 "msvcrt2013-1.0.0-1.tar.bz2"
!else
- StrCpy $ARCHIVE_NAME "msvcrt-1.0.1-12.tar.bz2"
+ StrCpy $ARCHIVE_NAME "msvcrt-1.0.1-13.tar.bz2"
+ StrCpy $ARCHIVE_NAME2005 "msvcrt2005-1.0-1.tar.bz2"
+ StrCpy $ARCHIVE_NAME2008 "msvcrt2008-1.0-1.tar.bz2"
+ StrCpy $ARCHIVE_NAME2010 "msvcrt2010-1.0-1.tar.bz2"
+ StrCpy $ARCHIVE_NAME2013 "msvcrt2013-1.0-1.tar.bz2"
!endif
StrCpy $EXTENDED_ARCHIVE_NAME "Microsoft Visual C++ Redistributable Packages"
StrCpy $ORIGINAL_UNTAR_FOLDER "install_msruntime"
@@ -882,6 +913,7 @@
InitPluginsDir
Pop $0
