[GRASS-SVN] r70135 - in grass-addons/grass7/vector: . v.profile.points
svn_grass at osgeo.org
Mon Dec 26 16:30:29 PST 2016
Author: wenzeslaus
Date: 2016-12-26 16:30:29 -0800 (Mon, 26 Dec 2016)
New Revision: 70135
Added:
grass-addons/grass7/vector/v.profile.points/
grass-addons/grass7/vector/v.profile.points/Makefile
grass-addons/grass7/vector/v.profile.points/v.profile.points.html
grass-addons/grass7/vector/v.profile.points/v.profile.points.py
grass-addons/grass7/vector/v.profile.points/v_profile_points.png
grass-addons/grass7/vector/v.profile.points/v_profile_points_workspace.png
grass-addons/grass7/vector/Makefile
v.profile.points: create point cloud transect
Modified: grass-addons/grass7/vector/Makefile
--- grass-addons/grass7/vector/Makefile 2016-12-26 23:03:23 UTC (rev 70134)
+++ grass-addons/grass7/vector/Makefile 2016-12-27 00:30:29 UTC (rev 70135)
@@ -49,6 +49,7 @@
v.out.png \
v.ply.rectify \
v.profile \
+ v.profile.points \
v.stats \
v.surf.icw \
v.surf.mass \
Added: grass-addons/grass7/vector/v.profile.points/Makefile
--- grass-addons/grass7/vector/v.profile.points/Makefile (rev 0)
+++ grass-addons/grass7/vector/v.profile.points/Makefile 2016-12-27 00:30:29 UTC (rev 70135)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.profile.points
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.profile.points/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/vector/v.profile.points/v.profile.points.html
--- grass-addons/grass7/vector/v.profile.points/v.profile.points.html (rev 0)
+++ grass-addons/grass7/vector/v.profile.points/v.profile.points.html 2016-12-27 00:30:29 UTC (rev 70135)
@@ -0,0 +1,57 @@
+<h2>DESCRIPTION</h2>
+<em>v.profile.points</em> creates profile (transect) from vector point
+map or a lidar point cloud stored in a LAS file.
+<div align="center" style="margin: 10px">
+<img src="v_profile_points.png" alt="r.profile.points sample output">
+<br>
+<i>Figure: Profile (transect) of a lidar point cloud, closer points are
+darker, further points are lighter</i>
+</div>
+d.vect map=profile color=none fill_color=26:26:26 zcolor=grass width=1
+ icon=basic/point size=20
+<h3>Workflow in GUI</h3>
+First Map Display should contain some base layers such as point density
+raster or digital elevation model.
+First Map Display should contain the resulting profile or profiles.
+Optionally a grid overlay can be added.
+The "Zoom to selected map layers" button in the Map Display toolbar
+should be used to zoom to the newly created profile.
+The <b>coordinates</b> option in the Line tab can be activated,
+deactivated, or cleared during the work as need.
+<a href="v_profile_points_workspace.png">
+<img src="v_profile_points_workspace.png" width="600" alt="r.profile.points sample output">
+</a><br>
+<i>Figure: Creating the profile in GUI: running module from the top left
+window; selecting line points in the Map Display in the top right;
+resulting profile in the bottom.</i>
+</div>
+<h2>NOTES</h2>
+ASCII files such as CSV can be profiled after import and raster maps
+can be profiles after conversion to vector points. It is advantageous
+to limit the import or the conversion just to the area of interest
+to avoid unnecessary overhead.
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+v.profile.points input_file=.../points.las output=points_profile width=5 \
+ coord=2090904,731231,2091435,731252
+</pre></div>
+<h2>AUTHOR</h2>
+Vaclav Petras, <a href="https://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a>
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/vector/v.profile.points/v.profile.points.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/vector/v.profile.points/v.profile.points.py
--- grass-addons/grass7/vector/v.profile.points/v.profile.points.py (rev 0)
+++ grass-addons/grass7/vector/v.profile.points/v.profile.points.py 2016-12-27 00:30:29 UTC (rev 70135)
@@ -0,0 +1,190 @@
+#!/usr/bin/env python
+# MODULE: v.profile.points
+# AUTHOR(S): Vaclav Petras
+# PURPOSE: Takes a point map and creates a profile (transect)
+# which is a point map but with x showing distance and y
+# showing height
+# COPYRIGHT: (C) 2016 by Vaclav Petras and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Creates a profile (transect) from points
+#% keyword: vector
+#% keyword: points
+#% keyword: profile
+#% keyword: transect
+#% keyword: lidar
+#% keyword: point cloud
+#%end
+#%option G_OPT_V_INPUT
+#% key: line_input
+#% required: no
+#% label: Vector map with a single line (with 2 points)
+#% description: Vector line prepared ahead
+#% guisection: Line
+#%end
+#%option G_OPT_M_COORDS
+#% required: no
+#% multiple: yes
+#% label: Line coordinates (x,y,x,y)
+#% description: Two pairs of coordinates as an alternative to a vector line
+#%end
+#% key: point_input
+#% required: no
+#% label: Vector map with points
+#% guisection: Points
+#%end
+#%option G_OPT_F_BIN_INPUT
+#% key: file_input
+#% required: no
+#% label: LAS (or LAZ) file with a point cloud
+#% description: File to be imported using v.in.lidar
+#%end
+#%option G_OPT_V_OUTPUT
+#% required: yes
+#% guisection: Output
+#%end
+#%option
+#% key: width
+#% type: double
+#% required: no
+#% label: Width of profile in map units
+#% description: Default with is 5% of the profile length
+#%end
+#%flag
+#% key: z
+#% description: Start the z coordinates at 0 instead of the actual height
+#%end
+#%rules
+#% required: line_input, coordinates
+#% exclusive: line_input, coordinates
+#% required: point_input, file_input
+#% exclusive: point_input, file_input
+#%end
+# TODO: support more than one line with 2 points
+# TODO: shift x coordinates to zero
+# TODO: flags to place the result in region or near the input
+import sys
+import os
+import atexit
+import uuid
+import grass.script as gs
+TMP = []
+def cleanup():
+ if len(TMP):
+ gs.info(_("Cleaning %d temporary maps...") % len(TMP))
+ for rast in TMP:
+ gs.run_command('g.remove', type='vector', name=rast,
+ flags='f', quiet=True)
+def create_tmp_map_name(name):
+ return 'tmp_{mod}_{pid}_{map_}'.format(mod='v_profile_points',
+ pid=os.getpid(),
+ map_=name)
+def main():
+ options, flags = gs.parser()
+ input_line = options['line_input']
+ coords = options['coordinates']
+ input_points = options['point_input']
+ input_file = options['file_input']
+ output = options['output']
+ width = options['width']
+ lidar_flags = ''
+ quiet = True
+ profile_area_output = None
+ profile_points_output = None
+ profile_line_output = None
+ extra_transform_flags = ''
+ if flags['z']:
+ extra_transform_flags = 't'
+ atexit.register(cleanup)
+ if not profile_area_output:
+ profile_area = create_tmp_map_name('profile_area')
+ TMP.append(profile_area)
+ else:
+ profile_area = profile_area_output
+ if not profile_points_output:
+ profile_points = create_tmp_map_name('profile_points')
+ TMP.append(profile_points)
+ else:
+ profile_points = profile_points_output
+ if not input_line:
+ if not profile_line_output:
+ input_line = create_tmp_map_name('input_line')
+ TMP.append(input_line)
+ else:
+ input_line = profile_line_output
+ numbers = coords.split(',')
+ if len(numbers) != 4:
+ gs.fatal(_("Provide exactly two pairs of coordinates"))
+ line_ascii = "L 2 1\n%s %s\n%s %s\n\n1 1\n" % tuple(numbers)
+ gs.write_command('v.in.ascii', input='-', output=input_line,
+ format='standard', flags='n', quiet=quiet,
+ stdin=line_ascii)
+ text = gs.read_command('v.to.db', map=input_line,
+ option='azimuth', flags='p',
+ separator='pipe', quiet=quiet, errors='exit')
+ gs.debug("azimuth: %s" % text.splitlines())
+ rotation = float(text.splitlines()[0].split('|')[1])
+ # north + cw -> x + ccw (v.to.db ignores line dir)
+ rotation = rotation - 90
+ gs.debug("rotation: %s" % rotation)
+ if width:
+ buffer_distance = float(width) / 2
+ else:
+ separator='pipe', quiet=quiet)
+ length = float(text.splitlines()[0].split('|')[1])
+ buffer_distance = 0.025 * length # width 5% of profile length
+ gs.debug("line length: %s" % length)
+ gs.debug("buffer: %s" % buffer_distance)
+ gs.run_command('v.buffer', input=input_line, output=profile_area,
+ flags='c', distance=buffer_distance, quiet=quiet)
+ # TODO: also limit by region
+ if input_file:
+ gs.run_command('v.in.lidar', input=input_file,
+ output=profile_points, flags=lidar_flags,
+ mask=profile_area, quiet=quiet, errors='exit')
+ else:
+ gs.run_command('v.select', ainput=input_points,
+ output=profile_points, flags='c', quiet=quiet)
+ gs.run_command('v.transform', flags='ya' + extra_transform_flags,
+ input=profile_points, output=output, zrotation=rotation)
+if __name__ == "__main__":
+ sys.exit(main())
Property changes on: grass-addons/grass7/vector/v.profile.points/v.profile.points.py
+ text/x-python
+ native
Added: grass-addons/grass7/vector/v.profile.points/v_profile_points.png
(Binary files differ)
Property changes on: grass-addons/grass7/vector/v.profile.points/v_profile_points.png
+ image/png
Added: grass-addons/grass7/vector/v.profile.points/v_profile_points_workspace.png
Property changes on: grass-addons/grass7/vector/v.profile.points/v_profile_points_workspace.png
+ image/png
