[GRASS-SVN] r70148 - grass-addons/grass7/imagery/i.superpixels.slic
Tue Dec 27 11:59:01 PST 2016
Author: rashadkm
Date: 2016-12-27 11:59:01 -0800 (Tue, 27 Dec 2016)
New Revision: 70148
   grass-addons/grass7/imagery/i.superpixels.slic/main.c
i.superpixels.slic: version 2
Modified: grass-addons/grass7/imagery/i.superpixels.slic/main.c
--- grass-addons/grass7/imagery/i.superpixels.slic/main.c	2016-12-27 18:01:52 UTC (rev 70147)
+++ grass-addons/grass7/imagery/i.superpixels.slic/main.c	2016-12-27 19:59:01 UTC (rev 70148)
@@ -1,33 +1,34 @@
  * MODULE:       i.superpixels.slic
- * PURPOSE:      Preform superpixel segmenation
+ * AUTHOR(S):    Rashad Kanavath <rashadkm gmail>
+ *               based on the C++ SLIC implmenetation from:
+ *               http://ivrl.epfl.ch/research/superpixels
+ * PURPOSE:      Perform superpixel segmenation
  * This code performs superpixel segmentation as explained in the paper:
  * "SLIC Superpixels", Radhakrishna Achanta, Appu Shaji,
  * Kevin Smith, Aurelien Lucchi, Pascal Fua, and Sabine Susstrunk.
  * EPFL Technical Report no. 149300, June 2010.
  * Below code is ported to grass from original C++ SLIC implmenetation
  * available at:  http://ivrl.epfl.ch/research/superpixels
 #include <grass/config.h>
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
 #include <grass/gis.h>
 #include <grass/raster.h>
 #include <grass/glocale.h>
+#include <grass/imagery.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
 #include <math.h>
 #include <limits.h>
 #include <float.h>
+//#define MY_DEBUG 1
 #ifndef MAX
 #define MAX(x,y) ((x) > (y) ? (x) : (y))
 #endif
@@ -35,839 +36,537 @@
 #define MIN(x,y) ((x) < (y) ? (x) : (y))
 #endif
+void SLIC_EnforceLabelConnectivity(int* labels, int width, int height,
+				     int* nlabels, int numlabels, int K_offset);
-void SLIC_EnforceLabelConnectivity(
-	int*				labels,
-	int					width,
-	int					height,
-	int*	     		nlabels,//new labels
-	int	     			numlabels,
-	int					K)
-//	const int dx8[8] = {-1, -1,  0,  1, 1, 1, 0, -1};
-//	const int dy8[8] = { 0, -1, -1, -1, 0, 1, 1,  1};
-	const int dx4[4] = {-1,  0,  1,  0};
-	const int dy4[4] = { 0, -1,  0,  1};
-	const int sz = width*height;
-	const int SUPSZ = sz/K;
-	//nlabels.resize(sz, -1);
-	int i;
-	for( i = 0; i < sz; i++ ) nlabels[i] = -1;
-	int label = 0; //(0);
-	int* xvec;
-	xvec = G_malloc (sizeof (int) * sz);
-	memset (xvec, 0, sizeof (int) * sz);
-	int* yvec;
-	yvec = G_malloc (sizeof (int) * sz);
-	memset (yvec, 0, sizeof (int) * sz);
-	int oindex=0;
-	int adjlabel=0; ;//adjacent label
-	int j, k;
-	for( j = 0; j < height; j++ )
-		for( k = 0; k < width; k++ )
-			if( 0 > nlabels[oindex] )
-				nlabels[oindex] = label;
-				// Start a new segment
-				xvec[0] = k;
-				yvec[0] = j;
-				// Quickly find an adjacent label for use later if needed
-				{int n; for( n = 0; n < 4; n++ )
-					int x = xvec[0] + dx4[n];
-					int y = yvec[0] + dy4[n];
-					if( (x >= 0 && x < width) && (y >= 0 && y < height) )
-						int nindex = y*width + x;
-						if(nlabels[nindex] >= 0) adjlabel = nlabels[nindex];
-				int count = 1;
-				int c; for( c = 0; c < count; c++ )
-					int n; for( n = 0; n < 4; n++ )
-						int x = xvec[c] + dx4[n];
-						int y = yvec[c] + dy4[n];
-							if( 0 > nlabels[nindex] && labels[oindex] == labels[nindex] )
-								xvec[count] = x;
-								yvec[count] = y;
-								nlabels[nindex] = label;
-								count++;
-				// If segment size is less then a limit, assign an
-				// adjacent label found before, and decrement label count.
-				if(count <= SUPSZ >> 2)
-				{ int c;
-					for( c = 0; c < count; c++ )
-						int ind = yvec[c]*width+xvec[c];
-						nlabels[ind] = adjlabel;
-					label--;
-				label++;
-			oindex++;
-	numlabels = label;
-	if(xvec) G_free(xvec);
-	if(yvec) G_free(yvec);
- * main function
- * it copies raster input raster map, calling the appropriate function for each
- * data type (CELL, DCELL, FCELL)
 int main(int argc, char *argv[])
-    struct Cell_head r_cellhd;	/* it stores region information, */
-struct Cell_head g_cellhd;
- struct Cell_head b_cellhd;
-/*				   and header information of rasters */
+  struct GModule *module;	/* GRASS module for parsing arguments */
-    char *r_mapset;		/* mapset name */
-	char *g_mapset;
-	char *b_mapset;
+  struct Option *grp;        /* imagery group input option */
-    int nrows, ncols;
-    int row, col;
+  struct Option *opt_iteration, *opt_super_pixels, *opt_compactness;
+  struct Option  *output;	/* option for output */
-	void *r_band;
-	void *g_band;
-	void *b_band;
-	int r_fd, g_fd, b_fd;
-    RASTER_MAP_TYPE r_data_type, g_data_type, b_data_type;	/* type of the map (CELL/DCELL/...) */
-    struct History history;	/* holds meta-data (title, comments,..) */
+  /* initialize GIS environment */
+  G_gisinit(argv[0]);
-    struct GModule *module;	/* GRASS module for parsing arguments */
+  /* initialize module */
+  module = G_define_module();
+  G_add_keyword(_("imagery"));
+  G_add_keyword(_("segmentation"));
+  G_add_keyword(_("superpixels"));
+  G_add_keyword(_("SLIC"));
+  module->description = _("SLIC segmenation");
-    struct Option *r_input, *g_input, *b_input, *output;	/* options */
+  grp = G_define_standard_option(G_OPT_I_GROUP);
-    /* initialize GIS environment */
-    G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
+  opt_iteration = G_define_option();
+  opt_iteration->key = "iter";
+  opt_iteration->type = TYPE_INTEGER;
+  opt_iteration->required = NO;
+  opt_iteration->description = _("Maximum number of iterations");
+  opt_iteration->answer = "10";
-    /* initialize module */
-    module = G_define_module();
-    G_add_keyword(_("imagery"));
-    G_add_keyword(_("segmentation"));
-    G_add_keyword(_("superpixels"));
-	G_add_keyword(_("SLIC"));
-    module->description = _("SLIC segmenation");
+  opt_super_pixels = G_define_option();
+  opt_super_pixels->key = "k";
+  opt_super_pixels->type = TYPE_INTEGER;
+  opt_super_pixels->required = NO;
+  opt_super_pixels->description = _("Number of super pixels");
+  opt_super_pixels->answer = "200";
-    /* Define the different options as defined in gis.h */
-    r_input = G_define_standard_option(G_OPT_R_INPUT);
-	r_input->key = "red";
-	r_input->answer = NULL;
-	r_input->description = "Name of raster map to be used for <red>";
-	g_input = G_define_standard_option(G_OPT_R_INPUT);
-	g_input->key = "green";
-	g_input->answer = NULL;
-	g_input->description = "Name of raster map to be used for <green>";
+  opt_compactness = G_define_option();
+  opt_compactness->key = "co";
+  opt_compactness->type = TYPE_INTEGER;
+  opt_compactness->required = NO;
+  opt_compactness->description = _("Compactness");
+  opt_compactness->answer = "20";
-	b_input = G_define_standard_option(G_OPT_R_INPUT);
-	b_input->key = "blue";
-	b_input->answer = NULL;
-	b_input->description = "Name of raster map to be used for <blue>";
+  output = G_define_standard_option(G_OPT_R_OUTPUT);
+  /* options and flags parser */
+  if (G_parser(argc, argv))
+    exit(EXIT_FAILURE);
-	struct Option *opt_iteration, *opt_super_pixels;
-    opt_iteration = G_define_option();
-    opt_iteration->key = "iter";
-    opt_iteration->type = TYPE_INTEGER;
-    opt_iteration->required = NO;
-    opt_iteration->description = _("Maximum number of iterations");
-    opt_iteration->answer = "10";
+  struct Ref group_ref;
+  int nf; // for group_ref.nfiles;
+  int nfiles;
+  char grp_name[INAME_LEN];
+  int nrows, ncols;
+  int row, col;
+  G_strip(grp->answer);
+  strcpy(grp_name, grp->answer);
-    opt_super_pixels = G_define_option();
-    opt_super_pixels->key = "k";
-    opt_super_pixels->type = TYPE_INTEGER;
-    opt_super_pixels->required = NO;
-    opt_super_pixels->description = _("No of super pixels");
-    opt_super_pixels->answer = "200";
+  /* find group */
+  if (!I_find_group(grp_name))
+    G_fatal_error(_("Group <%s> not found"), grp_name);
+  /* get the group ref */
+  if (!I_get_group_ref(grp_name, (struct Ref *)&group_ref))
+    G_fatal_error(_("Could not read REF file for group <%s>"), grp_name);
+  nfiles = group_ref.nfiles;
+  if (nfiles <= 0) {
+    G_important_message(_("Group <%s> contains no raster maps; run i.group"),
+			grp->answer);
+    exit(EXIT_SUCCESS);
-    output = G_define_standard_option(G_OPT_R_OUTPUT);
+  int n_iterations;
+  if (opt_iteration->answer) {
+    if ( sscanf(opt_iteration->answer, "%d", &n_iterations) != 1 ) {
+      G_fatal_error(_("Illegal value for iter (%s)"),  opt_iteration->answer);
+  else {
+    n_iterations = 10;
-    /* options and flags parser */
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
+  int n_super_pixels;
+  if (opt_super_pixels->answer) {
+    if ( sscanf(opt_super_pixels->answer, "%d", &n_super_pixels) != 1 ) {
+      G_fatal_error(_("Illegal value for k (%s)"),  opt_super_pixels->answer);
+  else {
+    n_super_pixels = 200;
-	int n_iterations;
-    if (opt_iteration->answer) {
-		if ( sscanf(opt_iteration->answer, "%d", &n_iterations) != 1 ) {
-			G_fatal_error(_("Illegal value for iter (%s)"),  opt_iteration->answer);
-    else {
-		n_iterations = 10;
-	int n_super_pixels;
-    if (opt_super_pixels->answer) {
-		if ( sscanf(opt_super_pixels->answer, "%d", &n_super_pixels) != 1 ) {
-			G_fatal_error(_("Illegal value for k (%s)"),  opt_super_pixels->answer);
-    else {
-		n_super_pixels = 200;
-    /* stores options and flags to variables */
-	//		char *r_name, g_name, b_name;
-	const char*    r_name = r_input->answer;
-	const char*	   g_name = g_input->answer;
-	const char*	   b_name = b_input->answer;
-	const char*    result = output->answer;
+  int n_compactness;
+  if (opt_compactness->answer) {
+    if ( sscanf(opt_compactness->answer, "%d", &n_compactness) != 1 ) {
+      G_fatal_error(_("Illegal value for co (%s)"),  opt_compactness->answer);
+  else {
+    n_compactness = 20;
+  const char*  result = output->answer;
+  /* Allocate output buffer, use input map data_type */
+  nrows = Rast_window_rows();
+  ncols = Rast_window_cols();
-    /* returns NULL if the map was not found in any mapset,
-     * mapset name otherwise */
-    r_mapset = (char *) G_find_raster2(r_name, "");
-    if (r_mapset == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), r_name);
-    g_mapset = (char *) G_find_raster2(g_name, "");
-    if (g_mapset == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), g_name);
-	b_mapset = (char *) G_find_raster2(b_name, "");
-    if (b_mapset == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), b_name);
+  int sz = nrows * ncols;
-    /* determine the inputmap type (CELL/FCELL/DCELL) */
-    r_data_type = Rast_map_type(r_name, r_mapset);
-	g_data_type = Rast_map_type(g_name, g_mapset);
-	b_data_type = Rast_map_type(b_name, b_mapset);
+  int *pdata[group_ref.nfiles];
+  for (nf = 0; nf < group_ref.nfiles; nf++) {
-    /* Rast_open_old - returns file destriptor (>0) */
-    r_fd = Rast_open_old(r_name, r_mapset);
-	g_fd = Rast_open_old(g_name, g_mapset);
-	b_fd = Rast_open_old(b_name, b_mapset);
-    /* controlling, if we can open input raster */
-    Rast_get_cellhd(r_name, r_mapset, &r_cellhd);
-    G_debug(3, "number of rows in R %d", r_cellhd.rows);
-    Rast_get_cellhd(g_name, g_mapset, &g_cellhd);
-    G_debug(3, "number of rows in G %d", g_cellhd.rows);
-    Rast_get_cellhd(b_name, b_mapset, &b_cellhd);
-    G_debug(3, "number of rows in B %d", b_cellhd.rows);
+    int i_fd;
+    RASTER_MAP_TYPE i_data_type;
+    void *i_band;
-    /* Allocate input buffer */
-    r_band = Rast_allocate_buf(r_data_type);
-	g_band = Rast_allocate_buf(g_data_type);
-	b_band = Rast_allocate_buf(b_data_type);
-    /* Allocate output buffer, use input map data_type */
-    nrows = Rast_window_rows();
-    ncols = Rast_window_cols();
-	int m_size = nrows*ncols;
-	double *L = NULL;
-	double *A = NULL;
-	double *B = NULL;
-	L = G_malloc (sizeof (double) * m_size);
-	memset (L, 0, sizeof (double) * m_size);
-	A = G_malloc (sizeof (double) * m_size);
-	memset (A, 0, sizeof (double) * m_size);
-	B = G_malloc (sizeof (double) * m_size);
-	memset (B, 0, sizeof (double) * m_size);
-	int index = 0;
+    int index = 0;
-    /* for each row */
+    i_fd = Rast_open_old(group_ref.file[nf].name, group_ref.file[nf].mapset);
+    i_data_type = Rast_map_type(group_ref.file[nf].name, group_ref.file[nf].mapset);
+    i_band = Rast_allocate_buf(i_data_type);
+    pdata[nf]  = G_malloc (sizeof (int) * sz);
+    memset (pdata[nf], 0, sizeof (int) * sz);
     for (row = 0; row < nrows; row++) {
-	G_percent(row, nrows, 2);
-	/* read input map */
-	Rast_get_row(r_fd, r_band, row, r_data_type);
-	Rast_get_row(g_fd, g_band, row, g_data_type);
-	Rast_get_row(b_fd, b_band, row, b_data_type);
-	/* process the data */
-	for (col = 0; col < ncols; col++) {
-		//HERE: convert pixel to lab colour space
-		int r = ((int *) r_band)[col];
-		int g = ((int *) g_band)[col];
-		int b = ((int *) b_band)[col];
-		float var_R = (r / 255.0f); //R from 0 to 255
-		float var_G = (g / 255.0f); //G from 0 to 255
-		float var_B = (b / 255.0f); //B from 0 to 255
-		if (var_R > 0.04045f) {
-			var_R = powf(( (var_R + 0.055f) / 1.055f), 2.4f);
-		} else {
-			var_R = var_R / 12.92f;
-		if (var_G > 0.04045) {
-			var_G = powf(( (var_G + 0.055f) / 1.055f), 2.4f);
-		} else {
-			var_G = var_G / 12.92f;
-		if (var_B > 0.04045f) {
-			var_B = powf(( (var_B + 0.055f) / 1.055f), 2.4f);
-		} else {
-			var_B = var_B / 12.92f;
-		var_R = var_R * 100;
-		var_G = var_G * 100;
-		var_B = var_B * 100;
-		//Observer. = 2°, Illuminant = D65
-		double X = var_R * 0.4124f + var_G * 0.3576f + var_B * 0.1805f;
-		double Y = var_R * 0.2126f + var_G * 0.7152f + var_B * 0.0722f;
-		double Z = var_R * 0.0193f + var_G * 0.1192f + var_B * 0.9505f;
-		double ref_X = 95.047;
-		double ref_Y = 100.000;
-		double ref_Z = 108.883;
-		double var_X = X / ref_X;
-		double var_Y = Y / ref_Y;
-		double var_Z = Z / ref_Z;
-		if ( var_X > 0.008856 ) var_X = powf(var_X, 1.0/3.0);
-		else                    var_X = ( 7.787 * var_X ) + ( 16 / 116 );
-		if ( var_Y > 0.008856 ) var_Y = powf(var_Y, 1.0/3.0);
-		else                    var_Y = ( 7.787 * var_Y ) + ( 16 / 116 );
-		if ( var_Z > 0.008856 )
-			var_Z = powf(var_Z, 1.0/3.0);
-		else
-			var_Z = ( 7.787 * var_Z ) + ( 16 / 116 );
-		L[index] = ( 116 * var_Y ) - 16;
-		A[index] = 500 * ( var_X - var_Y );
-		B[index] = 200 *(var_Y - var_Z );
-		index = index + 1;
+      G_percent(row, nrows, 2);
+      Rast_get_row(i_fd, i_band, row, i_data_type);
+      for (col = 0; col < ncols; col++) {
+	pdata[nf][index] = ((int *) i_band)[col];
+	index++;
+    G_free(i_band);
+    Rast_close(i_fd);
-	int g_width = ncols;
-	int g_height = nrows;
+  double compactness = (double) n_compactness;
+  int superpixelsize = 0.5+(double)ncols * (double)nrows / (double)n_super_pixels;
-	//HERE
+  int* klabels = NULL;
-	double compactness = 20;
-	int superpixelsize = 0.5+(double)g_width*(double)g_height/(double)	n_super_pixels;
-	int* klabels = NULL;
-	int sz = nrows * ncols;
+  klabels = G_malloc (sizeof (int) * sz);
+  int s;
+  for( s = 0; s < sz; s++ )
+    klabels[s] = -1;
-	klabels = G_malloc (sizeof (int) * sz);
-	int s;
-	for( s = 0; s < sz; s++ ) klabels[s] = -1;
-	int offset =  sqrt((double)superpixelsize) + 0.5;
-	double* kseedsl;
-	double* kseedsa;
-	double* kseedsb;
-	double* kseedsx;
-	double* kseedsy;
+  int offset =  sqrt((double)superpixelsize) + 0.5;
+  double* kseedsx;
+  double* kseedsy;
-	/* int g_width = ncols; */
-	/* int g_height = nrows; */
+  short perturbseeds = 0;
+  double *edgemag;
-	short perturbseeds = 0;
-	double *edgemag;
-	/////////////////:GetLABXYSeeds_ForGivenStepSize
+  double d_nrows = (double)nrows;
+  double d_ncols = (double)ncols;
+  /////////////////:GetLABXYSeeds_ForGivenStepSize
-	short hexgrid = 0;
-	int xstrips = (0.5+(double)g_width / (double)offset);
-	int ystrips = (0.5+(double)g_height / (double)offset);
+  short hexgrid = 0;
+  int xstrips = (0.5+d_ncols / (double)offset);
+  int ystrips = (0.5+d_nrows / (double)offset);
-    int xerr = g_width  - offset*xstrips;
-	if(xerr < 0)	{		xstrips--;		xerr = g_width - offset*xstrips;	}
-    int yerr = g_height - offset*ystrips;
-	if(yerr < 0)	{		ystrips--;		yerr = g_height - offset*ystrips;	}
+  int xerr = ncols  - offset*xstrips;
+  if(xerr < 0) {
+    xstrips--;
+    xerr = ncols - offset*xstrips;
+  int yerr = nrows - offset*ystrips;
+  if(yerr < 0)  {
+    ystrips--;
+    yerr = nrows - offset*ystrips;
-	#ifdef MY_DEBUG
-	printf("superpixelsize=%d\n", superpixelsize);
-	printf("g_height=%d\n", g_height);
-	printf("g_width=%d\n", g_width);
+  double xerrperstrip = (double)xerr/(double)xstrips;
+  double yerrperstrip = (double)yerr/(double)ystrips;
-	printf("ystrips=%d\n", ystrips);
-	printf("xstrips=%d\n", xstrips);
-	printf("xerr=%d\n", xerr);
-	printf("yerr=%d\n", yerr);
-   #endif
+  int xoff = offset/2;
+  int yoff = offset/2;
+  const int numseeds = xstrips*ystrips;
-	double xerrperstrip = (double)xerr/(double)xstrips;
-	double yerrperstrip = (double)yerr/(double)ystrips;
-	#ifdef MY_DEBUG
-	printf("xerrperstrip=%f\n", xerrperstrip);
-	printf("yerrperstrip=%f\n", yerrperstrip);
-	#endif
+  kseedsx = G_malloc (sizeof (double) * numseeds);
+  memset (kseedsx, 0, sizeof (double) * numseeds);
-	int xoff = offset/2;
-	int yoff = offset/2;
-	const int numseeds = xstrips*ystrips;
+  kseedsy = G_malloc (sizeof (double) * numseeds);
+  memset (kseedsy, 0, sizeof (double) * numseeds);
-	kseedsl = G_malloc (sizeof (double) * numseeds);
-	memset (kseedsl, 0, sizeof (double) * numseeds);
+  int n = 0;
+  int x,y;
-	kseedsa = G_malloc (sizeof (double) * numseeds);
-	memset (kseedsa, 0, sizeof (double) * numseeds);
-	kseedsb = G_malloc (sizeof (double) * numseeds);
-	memset (kseedsb, 0, sizeof (double) * numseeds);
-	kseedsx = G_malloc (sizeof (double) * numseeds);
-	memset (kseedsx, 0, sizeof (double) * numseeds);
-	kseedsy = G_malloc (sizeof (double) * numseeds);
-	memset (kseedsy, 0, sizeof (double) * numseeds);
+#ifdef MY_DEBUG
+  printf("superpixelsize=%d\n", superpixelsize);
+  printf("nrows=%d\n", nrows);
+  printf("ncols=%d\n", ncols);
+  printf("xerrperstrip=%f\n", xerrperstrip);
+  printf("yerrperstrip=%f\n", yerrperstrip);
+  printf("numseeds=%d\n", numseeds);
+#endif
-	int x,y;
-	int n = 0;
+  double* kseeds[group_ref.nfiles];
+    G_percent(nf, group_ref.nfiles, 2);
+    kseeds[nf] = G_malloc (sizeof (double) * numseeds);
+    memset (kseeds[nf], 0, sizeof (double) * numseeds);
-	#ifdef MY_DEBUG
-	 printf("numseeds=%d\n", numseeds);
-	 #endif
-	 //numseeds = numlabels;
-	for(  y = 0; y < ystrips; y++ )
-		 int ye = y*yerrperstrip;
-		for(  x = 0; x < xstrips; x++ )
-			int xe = x*xerrperstrip;
-             int seedx = (x*offset+xoff+xe);
-            if(hexgrid > 0 )
-				seedx = x*offset+(xoff<<(y&0x1))+xe;
-				seedx = MIN(g_width-1,seedx);
-			} //for hex grid sampling
+  for(  y = 0; y < ystrips; y++ ) {
+    int ye = y*yerrperstrip;
+    for(  x = 0; x < xstrips; x++ )  {
+      int xe = x*xerrperstrip;
+      int seedx = (x*offset+xoff+xe);
+      if(hexgrid > 0 ) {
+	seedx = x*offset+(xoff<<(y&0x1))+xe;
+	seedx = MIN(ncols-1,seedx);
+      } //for hex grid sampling
-			int seedy = (y*offset+yoff+ye);
-			int i = seedy*g_width + seedx;
+      int seedy = (y*offset+yoff+ye);
+      int i = seedy*ncols + seedx;
-			//	printf("L[i]=%f where i=%d \n", L[i], i);
-			kseedsl[n] = L[i];
-			kseedsa[n] = A[i];
-			kseedsb[n] = B[i];
-            kseedsx[n] = seedx;
-            kseedsy[n] = seedy;
-			n++;
+	kseeds[nf][n] = pdata[nf][i];
+      kseedsx[n] = seedx;
+      kseedsy[n] = seedy;
+      n++;
-	int numk = numseeds;
+  int numk = numseeds;
-	double *clustersize;
-	clustersize = G_malloc (sizeof (double) * numk);
-	memset (clustersize, 0, sizeof (double) * numk);
+  double *clustersize;
+  clustersize = G_malloc (sizeof (double) * numk);
+  memset (clustersize, 0, sizeof (double) * numk);
-	double *inv;
-	inv = G_malloc (sizeof (double) * numk);
-	memset (inv, 0, sizeof (double) * numk);
-	double *sigmal;
-	sigmal = G_malloc (sizeof (double) * numk);
-	memset (sigmal, 0, sizeof (double) * numk);
+  double *inv;
+  inv = G_malloc (sizeof (double) * numk);
+  memset (inv, 0, sizeof (double) * numk);
-	double *sigmaa;
-	sigmaa = G_malloc (sizeof (double) * numk);
-	memset (sigmaa, 0, sizeof (double) * numk);
+  double* sigma[group_ref.nfiles];
+    sigma[nf] = G_malloc (sizeof (double) * numk);
+    memset (sigma[nf], 0, sizeof (double) * numk);
-	double *sigmab;
-	sigmab = G_malloc (sizeof (double) * numk);
-	memset (sigmab, 0, sizeof (double) * numk);
-	double *sigmax;
-	sigmax = G_malloc (sizeof (double) * numk);
-	memset (sigmax, 0, sizeof (double) * numk);
+  double *sigmax;
+  sigmax = G_malloc (sizeof (double) * numk);
+  memset (sigmax, 0, sizeof (double) * numk);
-	double *sigmay;
-	sigmay = G_malloc (sizeof (double) * numk);
-	memset (sigmay, 0, sizeof (double) * numk);
+  double *sigmay;
+  sigmay = G_malloc (sizeof (double) * numk);
+  memset (sigmay, 0, sizeof (double) * numk);
-	//double *distvec;
-	//	distvec = G_malloc (sizeof (double) * sz);
+  //double *distvec;
+  //	distvec = G_malloc (sizeof (double) * sz);
-	double distvec[sz];
-	int p;
-	for( p = 0; p < sz; p++ ) distvec[p] = 1E+9;
+  double distvec[sz];
+  int p;
+  for( p = 0; p < sz; p++ ) distvec[p] = 1E+9;
-	double invwt = 1.0/((offset/compactness)*(offset/compactness));
+  double invwt = 1.0/((offset/compactness)*(offset/compactness));
-	int x1, y1, x2, y2;
-	double dist;
-	double distxy;
+  int x1, y1, x2, y2;
+  double dist;
+  double distxy;
-	//int n,x,y;
-	int itr;
-	double he = (double)g_height;
-	double wi = (double)g_width;
-	double dbl_offset = (double)offset;
-	for( itr = 0; itr <  n_iterations ; itr++ )
-		int n;
-		for(  n = 0; n < numk; n++ )
-			y1 = (int)MAX(0.0,	 kseedsy[n]-dbl_offset);
-			y2 = (int)MIN(he,   kseedsy[n]+dbl_offset);
-			x1 = (int)MAX(0.0,	 kseedsx[n]-dbl_offset);
-			x2 = (int)MIN(wi,	 kseedsx[n]+dbl_offset);
-			int y;
+  int itr;
-			//	printf("y1= %d y2=%d x1=%d x2=%d \n", y1, y2, x1, x2);
-			for( y = y1; y < y2; y++ )
-				int x;
-				for(  x = x1; x < x2; x++ )
-					int  i = y* g_width + x;
-					double dx = (double)x;
-					double dy = (double)y;
+  double dbl_offset = (double)offset;
+  for( itr = 0; itr <  n_iterations ; itr++ ) {
+      distvec[p] = 1E+9;
+    G_percent(itr, n_iterations, 2);
+    for(  n = 0; n < numk; n++ )  {
+      y1 = (int)MAX(0.0,	 kseedsy[n]-dbl_offset);
+      y2 = (int)MIN(d_nrows,     kseedsy[n]+dbl_offset);
+      x1 = (int)MAX(0.0,	 kseedsx[n]-dbl_offset);
+      x2 = (int)MIN(d_ncols,	 kseedsx[n]+dbl_offset);
+      for( y = y1; y < y2; y++ ) {
+	for(  x = x1; x < x2; x++ ) {
+	  int i = y* ncols + x;
+	  double dx = (double)x;
+	  double dy = (double)y;
+	  dist = 0.0;
+	    dist += ((pdata[nf][i] - kseeds[nf][n]) * (pdata[nf][i] - kseeds[nf][n]));
+	  distxy = (dx - kseedsx[n])*(dx - kseedsx[n]) +
+	    (dy - kseedsy[n])*(dy - kseedsy[n]);
-					dist =	(L[i] - kseedsl[n])*(L[i] - kseedsl[n]) +
-						(A[i] - kseedsa[n])*(A[i] - kseedsa[n]) +
-						(B[i] - kseedsb[n])*(B[i] - kseedsb[n]);
-					distxy =   (dx - kseedsx[n])*(dx - kseedsx[n]) +
-						(dy - kseedsy[n])*(dy - kseedsy[n]);
-					dist += distxy*invwt;//dist = sqrt(dist) + sqrt(distxy*invwt);//this is more exact
-					if( dist < distvec[i] )
-						//	printf("n=%d with i=<%d>\n", n, i);
-						distvec[i] = dist;
-						klabels[i]  = n;
-					else
+	  dist += distxy*invwt;//dist = sqrt(dist) + sqrt(distxy*invwt);//this is more exact
+	  if( dist < distvec[i] ) {
+	    distvec[i] = dist;
+	    klabels[i]  = n;
-						//	printf("distvec[i]=%f and dist=%f with i=<%d>\n", distvec[i], i);
-		int ww;
-	for( ww = 0; ww < sz; ww++ )
-		if( klabels[ww] > -1)
-	   	printf("klabels[%d]=%d\n", ww, klabels[ww]);
+	} //for( x=x1
+      } //for( y=y1
+    } //for (n=0
-		// Recalculate the centroid and store in the seed values
-		//------------------------------------------wi-----------------------
-		//instead of reassigning memory on each iteration, just reset.
-		{int ind = 0;
-		int r,c;
-		for( r = 0; r < g_height; r++ )
-			for(  c = 0; c < g_width; c++ )
-				sigmal[klabels[ind]] += L[ind];
-				sigmaa[klabels[ind]] += A[ind];
-				sigmab[klabels[ind]] += B[ind];
-				sigmax[klabels[ind]] += c;
-				sigmay[klabels[ind]] += r;
-				//edgesum[klabels[ind]] += edgemag[ind];
-				clustersize[klabels[ind]] += 1.0;
-				ind++;
-		{int k;
-		for( k = 0; k < numk; k++ )
-			if( clustersize[k] <= 0 ) clustersize[k] = 1;
-			inv[k] = 1.0/clustersize[k];//computing inverse now to multiply, than divide later
-		{ int k;
-			kseedsl[k] = sigmal[k]*inv[k];
-			kseedsa[k] = sigmaa[k]*inv[k];
-			kseedsb[k] = sigmab[k]*inv[k];
-			kseedsx[k] = sigmax[k]*inv[k];
-			kseedsy[k] = sigmay[k]*inv[k];
-			//edgesum[k] *= inv[k];
+    int k,r,c;
+    int ind = 0;
+    for( r = 0; r < nrows; r++ )	{
+      for(  c = 0; c < ncols; c++ ) {
+	  sigma[nf][klabels[ind]] += pdata[nf][ind];
+	sigmax[klabels[ind]] += c;
+	sigmay[klabels[ind]] += r;
+	//edgesum[klabels[ind]] += edgemag[ind];
+	clustersize[klabels[ind]] += 1.0;
+	ind++;
+    for( k = 0; k < numk; k++ ) {
+      if( clustersize[k] <= 0 )
+	clustersize[k] = 1;
+      /* computing inverse now to multiply, than divide later */
+      inv[k] = 1.0/clustersize[k];
+	kseeds[nf][k] = sigma[nf][k]*inv[k];
+      kseedsx[k] = sigmax[k]*inv[k];
+      kseedsy[k] = sigmay[k]*inv[k];
+      //edgesum[k] *= inv[k];
-	//numlabels = kseedsl.size();
-	int numlabels = numk;
-	#ifdef MY_DEBUG
-	printf("numk=%d\n", numk);
-	#endif
+  //numlabels = kseedsl.size();
+  int numlabels = numk;
+#ifdef MY_DEBUG
+  printf("numk=%d\n", numk);
+#endif
-	int* nlabels;
-	nlabels = G_malloc (sizeof (int) * sz);
-	memset (nlabels, 0, sizeof (int) * sz);
+  int* nlabels;
+  nlabels = G_malloc (sizeof (int) * sz);
+  memset (nlabels, 0, sizeof (int) * sz);
+  int k_offset = (double)sz/((double)(offset*offset));
+  SLIC_EnforceLabelConnectivity(klabels, ncols, nrows, nlabels, numlabels, k_offset);
+  int i, np;
+  for( i = 0; i < sz; i++ )
+    klabels[i] = nlabels[i];
-	SLIC_EnforceLabelConnectivity(klabels, g_width, g_height,
-							 nlabels,
-							 numlabels,
-							 (double)sz/((double)(offset*offset)));
+  if(nlabels)
+    G_free(nlabels);
+  int outfd;
+  int z = 0;
+  outfd = Rast_open_new(result, CELL_TYPE);
+  for (row = 0; row < nrows; row++)	 {
+    CELL *ubuff = Rast_allocate_c_buf();
+    for(col = 0; col < ncols; col++) {
+      ubuff[col] = klabels[z]+1; /* +1 to avoid category value 0*/
+      z++;
+    Rast_put_row(outfd, ubuff, CELL_TYPE);
+    G_free(ubuff);
-	{int i;
-	for( i = 0; i < sz; i++ ) klabels[i] = nlabels[i];}
-	if(nlabels) G_free(nlabels);
+  G_free(kseedsx);
+  G_free(kseedsy);
-	int outfd;
+  G_free(sigmax);
+  G_free(sigmay);
+  G_free(klabels);
-	const int dx8[8] = {-1, -1,  0,  1, 1, 1, 0, -1};
-	const int dy8[8] = { 0, -1, -1, -1, 0, 1, 1,  1};
+    G_free(kseeds[nf]);
+    G_free(sigma[nf]);
-	int mainindex=0;
-	int cind =0;
+  Rast_close(outfd);
-	short *istaken;
-	istaken = G_malloc (sizeof (short) * sz);
-	memset (istaken, 0, sizeof (short) * sz);
-	int *contourx;
-	contourx = G_malloc (sizeof (int) * sz);
-	memset (contourx, 0, sizeof (int) * sz);
-	int *contoury;
-	contoury = G_malloc (sizeof (int) * sz);
-	memset (contoury, 0, sizeof (int) * sz);
-	int j,k;
-	for(  j = 0; j < g_height; j++ )
-		for(  k = 0; k < g_width; k++ )
-			int np = 0;
-			int i;
-			for( i = 0; i < 8; i++ )
-				int x = k + dx8[i];
-				int y = j + dy8[i];
-				if( (x >= 0 && x < g_width) && (y >= 0 && y < g_height) )
-					int index = y*g_width + x;
-					//					if(  istaken[index] < 1 ) //comment this to obtain internal contours
-						if( klabels[mainindex] != klabels[index] ) np++;
-			if( np > 1 )
-				contourx[cind] = k;
-				contoury[cind] = j;
-				istaken[mainindex] = 1;
-				//img[mainindex] = color;
-				cind++;
-			mainindex++;
+				   int    width,
+				   int    height,
+				   int*   nlabels,//new labels
+				   int    numlabels,
+				   int    K_offset)  {
+  const int dx4[4] = {-1,  0,  1,  0};
+  const int dy4[4] = { 0, -1,  0,  1};
-	int r,c;
+  const int sz = width*height;
+  const int SUPSZ = sz/K_offset;
+  //nlabels.resize(sz, -1);
+  int i;
+  for( i = 0; i < sz; i++ ) nlabels[i] = -1;
+  int label = 0; //(0);
+  int* xvec;
+  xvec = G_malloc (sizeof (int) * sz);
+  memset (xvec, 0, sizeof (int) * sz);
+  int* yvec;
+  yvec = G_malloc (sizeof (int) * sz);
+  memset (yvec, 0, sizeof (int) * sz);
+  int oindex=0;
+  int adjlabel=0; ;//adjacent label
+  int j, k, n;
+  for( j = 0; j < height; j++ ) {
+    for( k = 0; k < width; k++ )  {
+      if( 0 > nlabels[oindex] )     {
+	nlabels[oindex] = label;
+	// Start a new segment
+	xvec[0] = k;
+	yvec[0] = j;
+	// Quickly find an adjacent label for use later if needed
-	DCELL *ubuff[nrows];
-	for(  r = 0; r < nrows; r++ )
-		ubuff[r] = Rast_allocate_d_buf();
+	for( n = 0; n < 4; n++ ) {
+	  int x = xvec[0] + dx4[n];
+	  int y = yvec[0] + dy4[n];
+	  if( (x >= 0 && x < width) && (y >= 0 && y < height) ) {
+	    int nindex = y*width + x;
+	    if(nlabels[nindex] >= 0) adjlabel = nlabels[nindex];
-	int numboundpix = cind;//int(contourx.size());
-	for(  j = 0; j < numboundpix; j++ )
-		//		int ii = contoury[j]*g_width + contourx[j];
-		ubuff[ contoury[j] ][ contourx[j] ] = 1;
-		int n;
-		for(  n = 0; n < 8; n++ )
-			int x = contourx[j] + dx8[n];
-			int y = contoury[j] + dy8[n];
-				int ind = y*g_width + x;
-				if(istaken[ind] < 1) {
-					ubuff[y][x] =0;
+	int c, count = 1;
+	for( c = 0; c < count; c++ ) {
+	    int x = xvec[c] + dx4[n];
+	    int y = yvec[c] + dy4[n];
+	      if( 0 > nlabels[nindex] && labels[oindex] == labels[nindex] ) {
+		xvec[count] = x;
+		yvec[count] = y;
+		nlabels[nindex] = label;
+		count++;
-    outfd = Rast_open_new(result, DCELL_TYPE);
-	int z;
-	for (z = 0; z < nrows; z++)
-	Rast_put_row(outfd, ubuff[z], DCELL_TYPE);
+	// If segment size is less then a limit, assign an
+	// adjacent label found before, and decrement label count.
+	if(count <= SUPSZ >> 2) {
+	    int ind = yvec[c]*width+xvec[c];
+	    nlabels[ind] = adjlabel;
+	  label--;
-		G_free(ubuff[z]);
-    /* memory cleanup */
-	G_free(kseedsl);
-	G_free(kseedsa);
-	G_free(kseedsb);
-	G_free(kseedsx);
-	G_free(kseedsy);
-	G_free(sigmal);
-	G_free(sigmaa);
-	G_free(sigmab);
-	G_free(sigmax);
-	G_free(sigmay);
-	G_free(klabels);
-	G_free(L);
-	G_free(A);
-	G_free(B);
-    G_free(r_band);
-	G_free(g_band);
-	G_free(b_band);
-    /* closing raster maps */
-    Rast_close(r_fd);
-	Rast_close(g_fd);
-	Rast_close(b_fd);
-	Rast_close(outfd);
-    exit(EXIT_SUCCESS);
+	label++;
+      oindex++;
+  numlabels = label;
+  if(xvec) G_free(xvec);
+  if(yvec) G_free(yvec);
