[GRASS-SVN] r70163 - grass/branches/releasebranch_7_2/vector/v.in.ogr
svn_grass at osgeo.org
Wed Dec 28 09:05:55 PST 2016
Author: neteler
Date: 2016-12-28 09:05:55 -0800 (Wed, 28 Dec 2016)
New Revision: 70163
grass/branches/releasebranch_7_2/vector/v.in.ogr/v.in.ogr.html
v.in.ogr manual: hint for Latitude-longitude data (fix trac #1443); subtitles added in NOTES section
Modified: grass/branches/releasebranch_7_2/vector/v.in.ogr/v.in.ogr.html
--- grass/branches/releasebranch_7_2/vector/v.in.ogr/v.in.ogr.html 2016-12-28 17:05:15 UTC (rev 70162)
+++ grass/branches/releasebranch_7_2/vector/v.in.ogr/v.in.ogr.html 2016-12-28 17:05:55 UTC (rev 70163)
@@ -101,6 +101,7 @@
<h2>NOTES</h2>
+<h3>Table column names: supported characters</h3>
The characters which are eligible for table column names are limited
by the SQL standard. Supported are:
@@ -132,14 +133,15 @@
Alternatively, change the local DB with
<em><a href="db.connect.html">db.connect</a></em>.
-<p>
-When importing Esri Shapefiles the OGR library tries to read the
+<h3>File encoding</h3>
+When importing ESRI Shapefiles the OGR library tries to read the
LDID/codepage setting from the .dbf file and use it to translate
string fields to UTF-8. LDID "87 / 0x57" is treated as
ISO8859_1 which may not be appropriate for many
languages. Unfortunately it is not clear what other values may be
appropriate (see example below). To change encoding the user can set
-up <tt>SHAPE_ENCODING</tt> environmental variable or simply to define
+up <tt><a href="https://trac.osgeo.org/gdal/wiki/ConfigOptions#SHAPE_ENCODING">SHAPE_ENCODING</a></tt>
+environmental variable or simply to define
encoding value using <b>encoding</b> parameter. Note that recoding
support is new for GDAL/OGR 1.9.0.
@@ -147,19 +149,23 @@
Value for <b>encoding</b> also affects text recoding when importing
DXF files. For other formats has encoding value no effect.
-<p>
-Option <b>key</b> specifies column name used for feature
+<h3>Defining the key column</h3>
+Option <b>key</b> specifies the column name used for feature
categories. This column must be integer. If not specified, categories
numbers are generated starting with 1 and stored in the column named
"cat".
-<p>
+<h3>Supports of multiple geometry columns</h3>
Starting with GDAL 1.11 the library supports multiple geometry columns
in OGR. By default <em>v.in.ogr</em> reads all geometry columns from
given layer. The user can choose desired geometry column
by <b>geometry</b> option,
see <a href="#multiple-geometry-columns">example below</a>.
+<h3>Latitude-longitude data: Vector postprocessing after import</h3>
+For vector data like a grid, horizontal lines need to be broken at their
+intersections with vertical lines (<b>v.clean ... tool=break</b>).
<h2>EXAMPLES</h2>
The command imports various vector formats:
