[GRASS-SVN] r70176 - sandbox/martinl
svn_grass at osgeo.org
Fri Dec 30 07:34:07 PST 2016
Author: martinl
Date: 2016-12-30 07:34:07 -0800 (Fri, 30 Dec 2016)
New Revision: 70176
Added:
sandbox/martinl/tiles-rast-stats.py
(sandbox) draft of script to calculate univar statistics for overlapping tiles
Added: sandbox/martinl/tiles-rast-stats.py
--- sandbox/martinl/tiles-rast-stats.py (rev 0)
+++ sandbox/martinl/tiles-rast-stats.py 2016-12-30 15:34:07 UTC (rev 70176)
@@ -0,0 +1,255 @@
+#!/usr/bin/env python
+# MODULE: tiles.rast.stats
+# AUTHOR(S): Markus Neteler
+# PURPOSE: Calculates univariate statistics from a raster map based
+# on vector tiles.
+# COPYRIGHT: (C) 2016 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Calculates univariate statistics from a raster map based on vector tiles.
+#% keyword: vector
+#% keyword: statistics
+#% keyword: raster
+#% keyword: univariate statistics
+#% keyword: zonal statistics
+#% keyword: sampling
+#% keyword: querying
+#% overwrite: yes
+#%end
+#%option
+#% key: dsn
+#% description: Data source name
+#%end
+#%option G_OPT_V_LAYER
+#% key: layer
+#% description: Name of input layer
+#% required: yes
+#%end
+#%option G_OPT_DB_COLUMN
+#% key: keycolumn
+#% description: Name of key column used for input
+#%end
+#% key: olayer
+#% description: Name for output layer
+#% required: yes
+#%end
+#%option G_OPT_R_INPUT
+#% key: raster
+#% description: Name of input raster map to calculate statistics from
+#%end
+#%option G_OPT_V_MAP
+#% key: mask
+#% description: Name of input vector map to used as mask (otherwise current region bbox is used)
+#% required: no
+#%end
+#%option
+#% key: column_prefix
+#% type: string
+#% description: Column prefix for new attribute columns
+#% required : yes
+#%end
+#%option
+#% key: method
+#% type: string
+#% description: The methods to use
+#% required: no
+#% multiple: yes
+#% options: number,minimum,maximum,range,average,stddev,variance,coeff_var,sum,first_quartile,median,third_quartile,percentile
+#% answer: number,minimum,maximum,range,average,stddev,variance,coeff_var,sum,first_quartile,median,third_quartile,percentile
+#%end
+#%option
+#% key: percentile
+#% type: integer
+#% description: Percentile to calculate
+#% options: 0-100
+#% answer: 90
+#% required : no
+#%end
+#%option
+#% key: nprocs
+#% description: Number of processes
+#% answer: 1
+#% type: integer
+#%end
+import os
+import sys
+import atexit
+import copy
+import time
+from subprocess import PIPE
+import grass.script as grass
+from grass.pygrass.modules import Module, MultiModule, ParallelModuleQueue
+from grass.pygrass.gis.region import Region
+from grass.exceptions import CalledModuleError
+from osgeo import ogr
+def cleanup():
+ if basename:
+ grass.message("Cleaning...")
+ Module('g.remove', type='vector', pattern='{}*'.format(basename), flags='f', quiet=True)
+def import_tiles(dsn, layer_name, keycolumn, mask):
+ ds = ogr.Open(dsn, True) # write
+ if ds is None:
+ grass.fatal("Unable to open '{}'".format(dsn))
+ layer = ds.GetLayerByName(layer_name)
+ if layer is None:
+ grass.fatal("Unable to get <{}> layer".format(layer_name))
+ if not mask:
+ reg = Region()
+ wkt = 'POLYGON(({w} {s}, {e} {s}, {e} {n}, {w} {n}, {w} {s}))'.format(n=reg.north, s=reg.south, e=reg.east, w=reg.west)
+ else:
+ try:
+ wkt_module = Module('v.out.ascii', input=mask, format='wkt', stdout_ = PIPE)
+ wkt = wkt_module.outputs.stdout.splitlines()[0] # TODO: only first feature is used
+ except CalledModuleError:
+ sys.exit(1)
+ print wkt
+ layer.SetSpatialFilter(ogr.CreateGeometryFromWkt(wkt))
+ basename = 'tiles_rast_stats_{}'.format(os.getpid())
+ tiles = []
+ try:
+ for feature in layer:
+ tiles.append(feature.GetField(keycolumn))
+ except ValueError:
+ grass.fatal("Column <{}> not found".format(keycolumn))
+ grass.message("{} tiles filtered".format(len(tiles)))
+ # database for each map is required since we call v.rast.stats in paralell
+ Module('db.connect', database='$GISDBASE/$LOCATION_NAME/$MAPSET/$MAP/sqlite.db')
+ grass.message("Importing tiles...")
+ start = time.time()
+ import_module = Module('v.in.ogr', input=dsn, layer=layer_name, quiet=True, overwrite=True, run_=False)
+ maps = []
+ for tile in tiles:
+ out_name = '{}_{}'.format(basename, tile)
+ maps.append(out_name)
+ new_import = copy.deepcopy(import_module)
+ queue.put(new_import(input=dsn, where="{}={}".format(keycolumn, tile),
+ output=out_name))
+ queue.wait()
+ grass.message("... done in {:.1f} sec".format(time.time() - start))
+ return maps, ds, layer
+def perform_statistics(maps, raster, column_prefix, method, percentile):
+ region_module = Module("g.region", flags='a', raster=raster, run_=False)
+ stats_module = Module('v.rast.stats', raster=raster, column_prefix=column_prefix, method=method.split(','),
+ percentile=percentile, quiet=True, run_=False)
+ grass.message("Performing statistics...")
+ for map_name in maps:
+ new_region = copy.deepcopy(region_module)
+ new_stats = copy.deepcopy(stats_module)
+ mm = MultiModule([new_region(vector=map_name),
+ new_stats(map=map_name)],
+ sync=False, set_temp_region=True)
+ queue.put(mm)
+ queue.wait()
+def write_output(maps, ds, ilayer, column_prefix, methods, percentile, output):
+ # create new layer
+ olayer = ds.CreateLayer(output, ilayer.GetSpatialRef(),
+ ilayer.GetGeomType())
+ if olayer is None:
+ grass.fatal("Unable to create output layer")
+ # copy attributes
+ feat_defn = ilayer.GetLayerDefn()
+ for i in range(feat_defn.GetFieldCount()):
+ ifield = feat_defn.GetFieldDefn(i)
+ ofield = ogr.FieldDefn(ifield.GetNameRef(), ifield.GetType())
+ ofield.SetWidth(ifield.GetWidth())
+ olayer.CreateField(ofield)
+ # add stats attributes
+ stats_cols = []
+ for method in methods.split(','):
+ fname = '{}_{}'.format(column_prefix, method)
+ if method == 'percentile':
+ fname += '_{}'.format(percentile)
+ stats_cols.append(fname)
+ ofield = ogr.FieldDefn(fname, ogr.OFTReal)
+ # copy features
+ ofeat_defn = olayer.GetLayerDefn()
+ ilayer.ResetReading() # features are already filtered
+ idx = 0
+ for feature in ilayer:
+ ofeature = ogr.Feature(ofeat_defn)
+ ofeature.SetGeometry(feature.GetGeometryRef().Clone())
+ for i in range(0, feat_defn.GetFieldCount()):
+ ofeature.SetField(feat_defn.GetFieldDefn(i).GetNameRef(), feature.GetField(i))
+ # append feature stats
+ stats = Module('v.db.select', map=maps[idx], columns=stats_cols, flags='c',
+ separator=';', stdout_=PIPE)
+ fidx = feat_defn.GetFieldCount()
+ for field in stats.outputs.stdout.rstrip(os.linesep).split(';'):
+ if len(field) > 0:
+ ofeature.SetField(ofeat_defn.GetFieldDefn(fidx).GetNameRef(), float(field))
+ fidx += 1
+ olayer.CreateFeature(ofeature)
+ idx += 1
+def main():
+ if not grass.find_file(options['raster'], element='raster')['fullname']:
+ grass.fatal("Raster map <{}> not found".format(options['raster']))
+ # import tiles
+ maps, ds, ilayer = import_tiles(options['dsn'], options['layer'], options['keycolumn'], options['mask'])
+ # Remove output if it already exists
+ if ds.GetLayerByName(options['olayer']):
+ if os.getenv('GRASS_OVERWRITE', '0') == '1':
+ ds.DeleteLayer(options['olayer'])
+ else:
+ grass.fatal("option <output>: <{}> exists. To overwrite, "
+ "use the --overwrite flag".format(options['olayer']))
+ # perform statistics
+ perform_statistics(maps, options['raster'], options['column_prefix'], options['method'],
+ options['percentile'])
+ # write output
+ write_output(maps, ds, ilayer, options['column_prefix'], options['method'], options['percentile'],
+ options['olayer'])
+ grass.message("Done in {:.1f} sec".format(time.time() - start))
+ # close datasource
+ ds.Destroy()
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ basename = None
+ # queue for parallel jobs
+ queue = ParallelModuleQueue(int(options['nprocs']))
+ atexit.register(cleanup)
+ sys.exit(main())
Property changes on: sandbox/martinl/tiles-rast-stats.py
___________________________________________________________________
Added: svn:executable
