[GRASS-SVN] r70179 - grass/branches/releasebranch_7_2/vector/v.out.postgis
svn_grass at osgeo.org
Sat Dec 31 14:06:28 PST 2016
Author: martinl
Date: 2016-12-31 14:06:28 -0800 (Sat, 31 Dec 2016)
New Revision: 70179
grass/branches/releasebranch_7_2/vector/v.out.postgis/main.c
v.out.postgis doesn't export attribute table (see #2460)
(relbr72: merge r69672 from trunk)
Modified: grass/branches/releasebranch_7_2/vector/v.out.postgis/main.c
--- grass/branches/releasebranch_7_2/vector/v.out.postgis/main.c 2016-12-31 21:59:38 UTC (rev 70178)
+++ grass/branches/releasebranch_7_2/vector/v.out.postgis/main.c 2016-12-31 22:06:28 UTC (rev 70179)
@@ -134,18 +134,19 @@
G_fatal_error(_("Unable to create PostGIS layer <%s>"),
olayer);
G_add_error_handler(output_handler, &Out);
+ /* copy attributes (must be done before checking output type
+ otherwise attributes are not copied) */
+ field = Vect_get_field_number(&In, params.layer->answer);
+ if (!flags.table->answer)
+ Vect_copy_map_dblinks(&In, &Out, TRUE);
/* check output type */
if (otype > 0) { /* type is not 'auto' */
if (Vect_write_line(&Out, otype, NULL, NULL) < 0)
G_fatal_error(_("Feature type %d is not supported"), otype);
- /* copy attributes */
- field = Vect_get_field_number(&In, params.layer->answer);
- if (!flags.table->answer)
- Vect_copy_map_dblinks(&In, &Out, TRUE);
/* copy vector features & create PostGIS table */
if (Vect_copy_map_lines_field(&In, field, &Out) != 0)
G_fatal_error(_("Copying features failed"));
