[GRASS-SVN] r67711 - grass/trunk/raster/r.li
svn_grass at osgeo.org
Mon Feb 1 10:54:26 PST 2016
Author: wenzeslaus
Date: 2016-02-01 10:54:26 -0800 (Mon, 01 Feb 2016)
New Revision: 67711
grass/trunk/raster/r.li/r.li.html
r.li: highlight GUI and configuration file in manual
Modified: grass/trunk/raster/r.li/r.li.html
--- grass/trunk/raster/r.li/r.li.html 2016-01-31 03:54:13 UTC (rev 67710)
+++ grass/trunk/raster/r.li/r.li.html 2016-02-01 18:54:26 UTC (rev 67711)
@@ -25,6 +25,11 @@
as well as measures that produce a distribution of values as output
(e.g. frequency distribution of patch sizes in the sampling area). The
results are stored as raster maps.
+<p>
+All modules require configuration file which can be created by the
+<em>g.gui.rlisetup</em> module which is a GUI tool providing a convenient
+way to set all necessary parameters. This file can be used repetitively
+saving user from the need to specify all parameters over and over again.
<h2>NOTES</h2>
@@ -111,10 +116,9 @@
<h2>SEE ALSO</h2>
-<b>Core modules</b>:
+<b>GUI tools</b>:
<ul>
- <li> <a href="r.li.daemon.html">r.li.daemon</a>: job launch daemon (not visible to the user)</li>
- <li> <a href="g.gui.rlisetup.html">g.gui.rlisetup</a>: Configuration editor for r.li.'index'</li>
+ <li> <a href="g.gui.rlisetup.html">g.gui.rlisetup</a>: Configuration editor for the <tt>r.li.*</tt> module where <tt>*</tt> is name of the index</li>
</ul>
<b>Patch indices</b>:
@@ -161,6 +165,10 @@
<li> <a href="r.li.simpson.html">r.li.simpson</a>: Calculates Simpson diversity index on a raster map</li>
</ul>
+<b>Core library</b>:
+<ul>
+ <li> <a href="r.li.daemon.html">r.li.daemon</a>: library with common functionality (not visible to the user)</li>
+</ul>
<h2>ADDING NEW INDICES</h2>
