[GRASS-SVN] r67728 - grass-addons/grass7/raster/r.traveltime
svn_grass at osgeo.org
Fri Feb 5 05:53:42 PST 2016
Author: mlennert
Date: 2016-02-05 05:53:42 -0800 (Fri, 05 Feb 2016)
New Revision: 67728
grass-addons/grass7/raster/r.traveltime/main.c
grass-addons/grass7/raster/r.traveltime/r.traveltime.html
Improved version by Kristian F?\195?\182rster
Modified: grass-addons/grass7/raster/r.traveltime/main.c
--- grass-addons/grass7/raster/r.traveltime/main.c 2016-02-05 13:49:48 UTC (rev 67727)
+++ grass-addons/grass7/raster/r.traveltime/main.c 2016-02-05 13:53:42 UTC (rev 67728)
@@ -1,4 +1,4 @@
-/* main.c for r.traveltime, December 2007
+/* main.c for r.traveltime, December 2007, updated September 2014
@@ -6,11 +6,11 @@
* # AUTHOR(S): Kristian Foerster
- * # PURPOSE: This programm calculates traveltimes from a digital
+ * # PURPOSE: This program calculates traveltimes from a digital
* # terrain model, a roughness grid and some output
- * # files from r.watershed. The aim of this tool is to
+ * # files from r.watershed. This tool is designed to
* # estimate a unit hydrograph for precipitation-runoff
- * # prediction
+ * # prediction.
* # COPYRIGHT: (c) 2007 Kristian Foerster
@@ -32,7 +32,7 @@
#include <grass/config.h>
* global declarations
extern CELL f_c(CELL);
@@ -46,10 +46,10 @@
RASTER_MAP_TYPE data_type_accu, data_type_dtm, data_type_n, data_type_dir; /* type of the map (CELL/DCELL/...) */
double **array_out;
int ac_thres;
-double nc, b, ep, fdis;
+double nc, b, dis, slope_min;
- * the function inflow checks if an adjacent cell discharges in the active cell
+ * the function inflow checks if an adjacent cell discharges into the active cell
int inflow(int loc_x, int loc_y, int vec_x, int vec_y)
@@ -62,78 +62,85 @@
value = ((CELL *) inrast_dir)[loc_x];
// conversions of the flow direction classification to vectors
+ // Note: the flow directions categories have been changed to "agnps" format!
switch (value) {
- case 1:
- x_exp = 1;
- y_exp = -1;
- break;
- case 2:
- x_exp = 0;
- y_exp = -1;
- break;
- case 3:
- x_exp = -1;
- y_exp = -1;
- break;
- case 4:
- x_exp = -1;
- y_exp = 0;
- break;
- case 5:
- x_exp = -1;
- y_exp = 1;
- break;
- case 6:
- x_exp = 0;
- y_exp = 1;
- break;
- case 7:
- x_exp = 1;
- y_exp = 1;
- break;
- case 8:
- x_exp = 1;
- y_exp = 0;
- break;
- default:
- x_exp = 1;
- y_exp = 0;
- break;
+ case 1:
+ x_exp = 0;
+ y_exp = -1;
+ break;
+ case 2:
+ x_exp = 1;
+ y_exp = -1;
+ break;
+ case 3:
+ x_exp = 1;
+ y_exp = 0;
+ break;
+ case 4:
+ x_exp = 1;
+ y_exp = 1;
+ break;
+ case 5:
+ x_exp = 0;
+ y_exp = 1;
+ break;
+ case 6:
+ x_exp = -1;
+ y_exp = 1;
+ break;
+ case 7:
+ x_exp = -1;
+ y_exp = 0;
+ break;
+ case 8:
+ x_exp = -1;
+ y_exp = -1;
+ break;
+ default:
+ x_exp = 1;
+ y_exp = 0;
+ break;
if ((vec_x == x_exp * (-1)) & (vec_y == y_exp * (-1)))
- return 1;
+ return 1;
else
- return 0;
+ return 0;
- * traveltime calculates traveltimes from one cell to another
+ * traveltime calculates travel times from one cell to another (time of concentration)
double traveltime(double length, double slope, double manning,
double drainage)
- double slope_min = 0.001;
+ // double slope_min = 0.001;
double t;
double Q;
if (slope < slope_min)
- slope = slope_min;
+ slope = slope_min;
- /* for areas with drainage accumulation < threshold surface runoff will be calculated
- * areas with larger drainage accumulation the channel formula is used instead
+ /* for areas with drainage accumulation < threshold surface runoff will be calculated,
+ * for areas with larger drainage accumulation the channel formula is used instead
if (drainage < ac_thres) {
- t = pow(length, 0.6) * pow(manning, 0.6) / pow(ep / 1000.0 / 3600.0, 0.4) / pow(slope, 0.3); //surface runoff
+ /* overland flow according to
+ * Woolhiser and Liggetts (1967)
+ * Muzik (1996)
+ * Melesse and Graham (2004)
+ * please note: this formula expects effective rain / surface runoff input in m/s
+ t = pow(length, 0.6) * pow(manning, 0.6) / pow(dis, 0.4) / pow(slope, 0.3); //surface runoff
else {
- Q = fdis * drainage * res_x * res_y * ep / 1000.0 / 3600.0; //equilibrium runoff
- t = length / pow(sqrt(slope) / nc * pow(Q / b, (2.0 / 3.0)), 0.6); // channel runoff
+ // channel runoff
+ // specific discharge l/s/km^2
+ Q = dis * drainage * res_x * res_y; //equilibrium runoff, ! changed !
+ t = length / pow(sqrt(slope) / nc * pow(Q / b, (2.0 / 3.0)), 0.6);
- return t / 60.0; //seconds to minutes
+ return t;
@@ -150,71 +157,92 @@
double z1, z2;
double manningsn;
+ // get flow direction
Rast_get_row(in_dir, inrast_dir, y, data_type_dir);
dir = ((CELL *) inrast_dir)[x];
+ // get flow accumulation
Rast_get_row(in_accu, inrast_accu, y, data_type_accu);
- accu = ((CELL *) inrast_accu)[x];
+ /* $kf 2014-09-25: check input of accumulation map...
+ * Older versions of r.watershed generate CELL type
+ * maps whereas the newer versions write FCELL maps.
+ switch(data_type_accu)
+ case CELL_TYPE:
+ accu = ((CELL *) inrast_accu)[x];
+ break;
+ case DCELL_TYPE:
+ accu = (int) ((DCELL *) inrast_accu)[x];
+ break;
+ case FCELL_TYPE:
+ accu = (int) ((FCELL *) inrast_accu)[x];
+ break;
+ // get roughness
Rast_get_row(in_n, inrast_n, y, data_type_n);
switch (data_type_n) {
case DCELL_TYPE:
- manningsn = (double)((DCELL *) inrast_n)[x];
- break;
+ manningsn = (double)((DCELL *) inrast_n)[x];
+ break;
case FCELL_TYPE:
- manningsn = (double)((FCELL *) inrast_n)[x];
- break;
+ manningsn = (double)((FCELL *) inrast_n)[x];
+ break;
+ // get elevation 2
Rast_get_row(in_dtm, inrast_dtm, y, data_type_dtm);
switch (data_type_dtm) {
case CELL_TYPE:
- z2 = (double)((CELL *) inrast_dtm)[x];
- break;
+ z2 = (double)((CELL *) inrast_dtm)[x];
+ break;
case DCELL_TYPE:
- z2 = (double)((DCELL *) inrast_dtm)[x];
- break;
+ z2 = (double)((DCELL *) inrast_dtm)[x];
+ break;
case FCELL_TYPE:
- z2 = (double)((FCELL *) inrast_dtm)[x];
- break;
+ z2 = (double)((FCELL *) inrast_dtm)[x];
+ break;
+ // get elevation 1
Rast_get_row(in_dtm, inrast_dtm, y - dy, data_type_dtm);
case CELL_TYPE:
- z1 = (double)((CELL *) inrast_dtm)[x - dx];
- break;
+ z1 = (double)((CELL *) inrast_dtm)[x - dx];
+ break;
case DCELL_TYPE:
- z1 = (double)((DCELL *) inrast_dtm)[x - dx];
- break;
+ z1 = (double)((DCELL *) inrast_dtm)[x - dx];
+ break;
case FCELL_TYPE:
- z1 = (double)((FCELL *) inrast_dtm)[x - dx];
- break;
+ z1 = (double)((FCELL *) inrast_dtm)[x - dx];
+ break;
for (i = -1; i < 2; i++) {
- for (j = -1; j < 2; j++) {
- if (inflow(x + i, y + j, i, j) > 0) {
- L = sqrt(pow(i * res_x, 2.0) + pow(j * res_y, 2.0));
- J = 1.0 * (z2 - z1) / L;
- // time from here to outlet
- thist = ftime + traveltime(L, J, manningsn, accu);
- array_out[y + j][x + i] = thist;
- int r = ttime(thist, x + i, y + j, i, j);
+ for (j = -1; j < 2; j++) {
+ if (inflow(x + i, y + j, i, j) > 0) {
+ L = sqrt(pow(i * res_x, 2.0) + pow(j * res_y, 2.0));
+ J = 1.0 * (z2 - z1) / L;
+ // time from here to outlet
+ thist = ftime + traveltime(L, J, manningsn, accu);
+ array_out[y + j][x + i] = thist;
+ int r = ttime(thist, x + i, y + j, i, j);
- v = 1;
- else {
- v = 0;
+ v = 1;
+ else {
+ v = 0;
return v;
- * main function
+ * main function of r.traveltime
int main(int argc, char *argv[])
@@ -233,7 +261,7 @@
int row, col;
int verbose;
int cx, cy, x, y;
- double factor;
+ double discharge;
struct Cell_head window;
@@ -242,8 +270,10 @@
/* options */
struct Option *input_dir, *input_accu, *input_dtm, *input_n, *output,
*input_outlet_x, *input_outlet_y, *input_thres, *input_nc, *input_b,
- *input_ep, *input_fdis;
+ *input_dis, *input_slmin;
+ struct Flag *flag1; /* flags */
/* initialize GIS environment */
G_gisinit(argv[0]); /* reads grass env, stores program name to G_program_name() */
@@ -311,30 +341,33 @@
input_nc->description = "Channel roughness (Manning's n)";
input_nc->gisprompt = "old,cell,raster";
- input_ep = G_define_option();
- input_ep->key = "ep";
- input_ep->type = TYPE_STRING;
- input_ep->required = YES;
- input_ep->description = "Excess precipitation [mm/h]";
- input_ep->gisprompt = "old,cell,raster";
+ input_dis = G_define_option();
+ input_dis->key = "dis";
+ input_dis->type = TYPE_STRING;
+ input_dis->required = YES;
+ input_dis->description="Specific discharge [l/s/km**2]";
+ input_dis->gisprompt ="old,cell,raster";
- input_fdis = G_define_option();
- input_fdis->key = "fdis";
- input_fdis->type = TYPE_STRING;
- input_fdis->required = YES;
- input_fdis->description =
- "Reduction factor for equilibrium discharge, 0.0 < f <= 1.0 (default=1)";
- input_fdis->gisprompt = "old,cell,raster";
+ input_slmin = G_define_option();
+ input_slmin->key = "slopemin";
+ input_slmin->type = TYPE_STRING;
+ input_slmin->required = NO;
+ input_slmin->description="Minimum slope for flat areas [m/m]";
+ input_slmin->gisprompt ="old,cell,raster";
output = G_define_standard_option(G_OPT_R_OUTPUT);
output->key = "out";
- output->description = "Output travel time map [minutes]";
+ output->description = "Output travel time map [seconds]";
+ /* Define the different flags */
+ flag1 = G_define_flag();
+ flag1->key = 'q';
+ flag1->description = _("Quiet");
/* options and flags pareser */
if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
+ exit(EXIT_FAILURE);
/* stores options and flags to variables */
map_accu = input_accu->answer;
map_dir = input_dir->answer;
@@ -345,17 +378,19 @@
sscanf(input_thres->answer, "%d", &ac_thres);
sscanf(input_b->answer, "%lf", &b);
sscanf(input_nc->answer, "%lf", &nc);
- sscanf(input_ep->answer, "%lf", &ep);
- sscanf(input_fdis->answer, "%lf", &factor);
+ sscanf(input_dis->answer,"%lf",&discharge);
+ result = output->answer;
- result = output->answer;
+ // options
+ if (input_slmin->answer == NULL)
+ slope_min = 0.001;
+ else
+ sscanf(input_slmin->answer,"%lf",&slope_min);
- if (factor > 0 & factor <= 1.0)
- fdis = factor;
- else {
- G_fatal_error("Reduction factor is not valid!");
+ verbose = (!flag1->answer);
+ dis = discharge * 1.0E-9; // l/s/km^2 => m/s
mapset = G_find_raster2(map_dir, "");
mapset = G_find_raster2(map_accu, "");
mapset = G_find_raster2(map_dtm, "");
@@ -393,22 +428,21 @@
outfd = Rast_open_new(result, FCELL_TYPE);
/* output array */
array_out = (double **)malloc(nrows * sizeof(double *));
if ((NULL == array_out))
- G_fatal_error("Out of memory ... !");
+ G_fatal_error("Out of memory ... !");
int i, j;
for (i = 0; i < nrows; i++) {
- array_out[i] = (double *)malloc(ncols * sizeof(double));
- if ((NULL == array_out[i]))
+ array_out[i] = (double *)malloc(ncols * sizeof(double));
+ if ((NULL == array_out[i]))
- for (j = 0; j < ncols; j++) {
- array_out[i][j] = DBL_MAX;
+ for (j = 0; j < ncols; j++) {
+ array_out[i][j] = DBL_MAX;
@@ -423,27 +457,27 @@
cy = G_scan_northing(*input_outlet_y->answers, &outy, G_projection());
if (!cx) {
- array_out[y][x] = 0.0;
+ array_out[y][x] = 0.0;
- fprintf(stderr, "Illegal east coordinate <%s>\n",
- *input_outlet_y->answer);
- G_usage();
+ fprintf(stderr, "Illegal east coordinate <%s>\n",
+ *input_outlet_y->answer);
+ G_usage();
if (!cy) {
- fprintf(stderr, "Illegal north coordinate <%s>\n",
- G_usage();
+ fprintf(stderr, "Illegal north coordinate <%s>\n",
+ G_usage();
if (outx < window.west || outx > window.east || outy < window.south ||
- outy > window.north) {
- fprintf(stderr, "Warning, ignoring point outside window: \n");
- fprintf(stderr, " %.4f,%.4f\n", outx, outy);
+ outy > window.north) {
+ fprintf(stderr, "Warning, ignoring point outside window: \n");
+ fprintf(stderr, " %.4f,%.4f\n", outx, outy);
@@ -453,28 +487,30 @@
cy = (window.north - outy) / res_y;
cx = (outx - window.west) / res_x;
if (verbose)
- printf
- ("\ngrid location of outlet x=%d, y=%d\n(resolution %.0fx%.0f map units, meters expected)\n",
+ printf("\ngrid location of outlet x=%d, y=%d\n(resolution %.0fx%.0f map units, meters expected)\n",
cx, cy, res_x, res_y);
+ printf("minimum slope=%7.5f\n",slope_min);
+ printf("surface runoff: %f l/s/km**2 = %e m/s = %f mm/h\n", discharge, dis, (discharge * 1E-6 * 3600));
x = cx;
y = cy;
* first call of traveltime function
- int m = ttime(0, x, y, 0, 0);
+ int m = ttime(0.0, x, y, 0, 0);
/* output */
for (row = 0; row < nrows; row++) {
- for (col = 0; col < ncols; col++) {
- ((CELL *) outrast)[col] = array_out[row][col];
- /* write raster row to output raster file */
- Rast_put_row(outfd, outrast, CELL_TYPE);
+ for (col = 0; col < ncols; col++) {
+ ((CELL *) outrast)[col] = array_out[row][col];
+ /* write raster row to output raster file */
+ Rast_put_row(outfd, outrast, CELL_TYPE);
/* closing raster files */
@@ -484,9 +520,9 @@
// Rast_close(inrast_n);
Rast_close(in_dir);
- Rast_close(in_accu);
- Rast_close(in_n);
- Rast_close(in_dtm);
+ Rast_close(in_accu);
+ Rast_close(in_n);
+ Rast_close(in_dtm);
Rast_close(outfd);
return 0;
Modified: grass-addons/grass7/raster/r.traveltime/r.traveltime.html
--- grass-addons/grass7/raster/r.traveltime/r.traveltime.html 2016-02-05 13:49:48 UTC (rev 67727)
+++ grass-addons/grass7/raster/r.traveltime/r.traveltime.html 2016-02-05 13:53:42 UTC (rev 67728)
@@ -1,17 +1,14 @@
<h2>DESCRIPTION</h2>
<em>r.traveltime</em> computes the travel time of surface runoff to an
outlet. The program starts at the basin outlet and calculates the travel
-time at each raster cell recursively. A drainage area related threhold
-considers even surface and also channel runoff. Travel times are
+time for each raster cell recursively. A drainage area related threshold
+considers either surface runoff or channel runoff. Travel times are
derived by assuming kinematic wave approximation.<br>
-To derive channel flow velocities an equilibrium discharge for each
-cell is calculated (Q=Area*Excess_Prcipitation, Assumption: storm
-duration >= time of concentration). This assumption may result
-in overestimated velocities. Therefor a factor is implemented to reduce
-velocities biased towards too large values.<br>
+In order to derive channel flow velocities, an equilibrium discharge
+for each cell is calculated (Q=Area*specific discharge).<br>
The results can be used to derive a time-area function. This might be
-usefull for precipitation-runoff calculations (estimation of flood
-predictions) with a lumped hydrologic model (user-specified unit
+useful for precipitation-runoff calculations (estimation of flood
+predictions) with a lumped hydrological model (user-specified unit
hydrograph).
<h2>REMARKS</h2>
@@ -19,6 +16,14 @@
recursive. Maybe it will not work with extensive datasets. It is
assumed that the minimum slope is 0.001. For smaller gradients the
program uses this value.
+<br>
+Please not that the flow accumulation map must be defined as single
+direction. Multiple flow directions are not supported. Thus, the
+"SFD (D8) flow" option has to be set if, e.g., the r.watershed
+module is used to generate the input files (parameter s). The flow
+accumulation map should include positive values only (-a of
+r.watershed). Flow direction definitions are in accordance to the
+r.fill.dir program using the "agnps" format option.
<h2>KNOWN ISSUES</h2>
The program does not work correctly if Manning's roughness grid is
@@ -28,20 +33,19 @@
The region has to be set one row and column larger than the elevation
map. See the example below to see how to do that with g.region.
<h2>EXAMPLE</h2>
<i>This example uses the North Carolina sample dataset.</i>
<p>
<div class="code"><pre>
-g.region raster=elev_lid792_1m n=n+1 s=s-1 w=w-1 e=e+1 -p
-r.watershed elev_lid792_1m thresh=5000 accum=accum_5K drain=draindir_5K
-r.fill.dir elev_lid792_1m output=elev_filled outdir=elev_dir
-r.mapcalc "rough = 0.1f"
-r.traveltime dir=draindir_5K at user1 accu=accum_5K at user1 \
- dtm=elev_filled at user1 manningsn=rough out_x=638741.43125 \
- out_y=220269.7 threshold=1 b=1 nchannel=0.1 ep=40 fdis=1 \
- out=travel_time
-r.colors travel_time col=gyr
+g.region raster=elevation
+r.mapcalc "n=0.1f"
+r.fill.dir input=elevation output=fill outdir=flowdir format=agnps
+r.fill.dir input=fill output=fill2 outdir=flowdir2 format=agnps
+r.watershed -a -s elevation=fill2 accumulation=accu
+r.traveltime --overwrite dir=flowdir2 accu=accu dtm=fill2 manningsn=n
+ out_x=634613 out_y=217014 threshold=250 b=3 nchannel=0.03 slopemin=0.01
+ dis=900 out=ttime
</pre></div>
<h2>SEE ALSO</h2>
@@ -70,4 +74,4 @@
<h2>AUTHOR</h2>
Kristian Foerster<br>
-<p><i>Last changed: $Date$</i>
+<p><i>Last changed: $Date 2014-09-26$</i>
