[GRASS-SVN] r67749 - grass-addons/grass7/gui/wxpython/wx.metadata/mdlib
svn_grass at osgeo.org
Sat Feb 6 12:15:01 PST 2016
Author: krejcmat
Date: 2016-02-06 12:15:01 -0800 (Sat, 06 Feb 2016)
New Revision: 67749
grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswlib.py
addons wx.metadata: remove import GDAL dialog,fix wx.Config()
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswlib.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswlib.py 2016-02-06 20:07:31 UTC (rev 67748)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswlib.py 2016-02-06 20:15:01 UTC (rev 67749)
@@ -35,7 +35,6 @@
from owslib.ows import ExceptionReport
from gui_core.forms import GUI
from core.gcmd import GError, GMessage, GWarning
-from modules.import_export import GdalImportDialog
from subprocess import PIPE
from grass.pygrass.modules import Module
from grass.script import parse_key_val
@@ -83,18 +82,18 @@
class CSWBrowserPanel(wx.Panel):
def __init__(self, parent, main, giface=None):
+ wx.Panel.__init__(self, parent)
self.context = StaticContext()
self.giface = giface
- self.config = wx.Config('g.gui.cswbrowser')
- wx.Panel.__init__(self, parent)
+ self.config = main.config
self.parent = main
self.constraintsWidgets = []
self.constraintsWidgets1 = []
self.constraintsAdvanced = False
self.idResults = []
self.constString = ''
- self.outpoutschema='dc'
- self.warns=True
+ self.outpoutschema = 'dc'
+ self.warns = True
sizeConst = 55
self.splitterBrowser = SplitterWindow(self, style=wx.SP_3D | wx.SP_LIVE_UPDATE | wx.SP_BORDER)
@@ -194,15 +193,6 @@
self.refreshNavigationButt()
self._layout()
- def OnTypeBB(self,evt):
- raw_value = evt.GetValue().strip()
- # numeric check
- print raw_value
- if all(x in '0123456789.+-' for x in raw_value):
- evt.ChangeValue(raw_value)
def OnKeywordDialog(self, evt):
if self.advanceChck.GetValue():
self.geDialog = wx.Dialog(self, id=wx.ID_ANY,
@@ -265,8 +255,8 @@
self.Fit()
def OnShowReguest(self, evt):
- #request_html = encodeString(highlight_xml(self.context, self.catalog.request,False))
- path = os.path.join(tempfile.gettempdir(),'htmlRequest.xml')
+ # request_html = encodeString(highlight_xml(self.context, self.catalog.request,False))
+ path = os.path.join(tempfile.gettempdir(), 'htmlRequest.xml')
if os.path.exists(path): os.remove(path)
f = open(path, 'w')
f.writelines(self.catalog.request)
@@ -277,8 +267,8 @@
self.htmlView.SetPage((renderXML(self.context, self.catalog.request)))
def OnShowResponse(self, evt):
- #response_html = encodeString(highlight_xml(self.context, self.catalog.response,False))
- path = os.path.join(tempfile.gettempdir(),'htmlResponse.xml')
+ # response_html = encodeString(highlight_xml(self.context, self.catalog.response,False))
+ path = os.path.join(tempfile.gettempdir(), 'htmlResponse.xml')
f = open(path, 'w')
f.write(self.catalog.response)
@@ -288,6 +278,10 @@
else:
self.htmlView.SetPage((renderXML(self.context, self.catalog.response)))
+ def getTmpConnection(self, name):
+ key = '/connections/%s/url' % name
+ return self.config.Read(key)
def OnRecord(self, evt):
"""show record metadata"""
@@ -299,16 +293,13 @@
return
if self.outpoutschema == 'gmd':
- startfr=self.startfrom+idx+1
- #identifier = self.get_item_data(idx, 'identifier')
+ startfr = self.startfrom + idx + 1
cat = CatalogueServiceWeb(self.catalog_url, timeout=self.timeout)
try:
- cat.getrecords2(constraints=self.constraints,
- maxrecords=1,
- startposition=startfr,
- outputschema='http://www.isotc211.org/2005/gmd')
+ cat.getrecords2(constraints=self.constraints,
+ maxrecords=1,
+ startposition=startfr,
+ outputschema='http://www.isotc211.org/2005/gmd')
except ExceptionReport, err:
GWarning('Error getting response: %s' % err)
return
@@ -317,24 +308,17 @@
return
if self.catalog:
- md=cat.records.values()[0]
+ md = cat.records.values()[0]
path = 'record_metadata_gmd.html'
- metadata = render_template('en', self.context,md,path)
+ metadata = render_template('en', self.context, md, path)
- #try:
- # record = self.catalog.records[identifier]
- #except KeyError, err:
- # GWarning('@!Record parsing error, unable to locate record identifier')
- # return
self.htmlView.SetPage(metadata)
- #self.findServices(record, idx)
else:
try:
- cat.getrecordbyid([self.catalog.records[identifier].identifier])
+ cat.getrecordbyid([self.catalog.records[identifier].identifier])
return
@@ -480,7 +464,7 @@
try:
self.catalog.getrecords2(constraints=self.constraints,
- maxrecords=self.maxrecords, esn='full',startposition=self.startfrom,
+ maxrecords=self.maxrecords, esn='full', startposition=self.startfrom,
else:
@@ -571,23 +555,6 @@
continue
self.constraints[x] = PropertyIsLike('csw:AnyText', constraint)
- def gdalImport(self, ogr, url, type, evt):
- serviceDialog = GdalImportDialog(self, None, ogr=ogr, link=True)
- dns = serviceDialog.dsnInput
- dns.source.SetSelection(3)
- dns.SetSourceType('pro')
- if type == 'wms':
- dns.protocolWidgets['format'].SetSelection(2)
- if type == 'wcs':
- dns.protocolWidgets['format'].SetSelection(1)
- if type == 'wfs':
- dns.SetExtension(dns.protocolWidgets['format'].GetStringSelection())
- dns.protocolWidgets['text'].SetValue(url)
- dns.OnUpdate(evt)
- serviceDialog.Show()
def _openWebServiceDiag(self, data_url):
from web_services.dialogs import AddWSDialog
if self.giface:
@@ -608,7 +575,7 @@
exec (item_data)
if name == "Add WMS":
data_url = item_data['wms']
- service = ['r.in.gdal', 'r.in.wms', 'Add web service layer']
+ service = ['r.in.wms', 'Add web service layer']
dlg = wx.SingleChoiceDialog(
self, 'Choice of module for WMS ', 'Web Service selection',
service,
@@ -617,19 +584,17 @@
if dlg.ShowModal() == wx.ID_OK:
selected_module = dlg.GetStringSelection()
if selected_module == service[0]:
- self.gdalImport(False, data_url, type='wms', evt=evt)
- elif selected_module == service[1]:
cmd.append('r.in.wms')
cmd.append('url=%s' % data_url)
GUI(parent=self, show=True, modal=True).ParseCommand(cmd=cmd)
- elif selected_module == service[2]:
+ elif selected_module == service[1]:
self._openWebServiceDiag(data_url)
dlg.Destroy()
elif name == "Add WFS":
data_url = item_data['wfs']
- service = ['v.in.ogr', 'v.in.wfs', 'Add web service layer']
+ service = ['v.in.wfs', 'Add web service layer']
self, 'Choice of module for WFS ', 'Web Service selection',
service,
@@ -639,18 +604,15 @@
- self.gdalImport(True, data_url, type='wfs', evt=evt)
cmd.append('v.in.wfs')
dlg.Destroy()
elif name == "Add WCS":
- data_url = item_data['wcs']
- self.gdalImport(False, data_url, type='wcs', evt=evt)
+ GMessage("Not implemented")
def GetQtype(self): # TODO need to implement
val = self.qtypeCb.GetValue()
@@ -661,6 +623,7 @@
def OnSearch(self, evt):
"""execute search"""
self.refreshResultList()
self.catalog = None
self.loadConstraints()
@@ -672,9 +635,9 @@
if current_text == '':
GMessage('Please set catalog')
return
- key = '/connections/%s' % current_text
- self.catalog_url = self.config.Read('%s/url' % key)
+ self.catalog_url = self.getTmpConnection(current_text)
# start position and number of records to return
self.startfrom = 0
self.maxrecords = self.numResultsSpin.GetValue()
@@ -692,8 +655,6 @@
if bbox != ['-180', '-90', '180', '90']:
self.constraints.append(BBox(bbox))
- # (a && b)
- # build requestprint
if not self._get_csw():
return
@@ -702,23 +663,25 @@
try:
maxrecords=self.maxrecords, esn='full')
GError('Search error: %s' % err)
return
except Exception, err:
GError('Connection error: %s' % err)
return
- #work around for GMD records
- if len(self.catalog.records)==0 and self.catalog.results['matches'] != 0:
+ ###work around for GMD records
+ if len(self.catalog.records) == 0 and self.catalog.results['matches'] != 0:
try:
- self.outpoutschema='gmd'
+ self.outpoutschema = 'gmd'
if self.warns:
- GWarning("Endopoint of service is not setup properly. Server returns ISO metadata(http://www.isotc211.org/2005/gmd) instead of CSW records(http://schemas.opengis.net/csw/2.0.2/record.xsd). CSW browser may work incorrectly.")
- self.warns=False
+ GWarning(
+ "Endopoint of service is not setup properly. Server returns ISO metadata(http://www.isotc211.org/2005/gmd) instead of CSW records(http://schemas.opengis.net/csw/2.0.2/record.xsd). CSW browser may work incorrectly.")
+ self.warns = False
@@ -726,6 +689,7 @@
return
+ ###work around for GMD records- END
if self.catalog.results['matches'] == 0:
self.findResNumLbl.SetLabel('0 results')
@@ -733,7 +697,7 @@
return
self.refreshNavigationButt(True)
- #parsing for another html template(GMD)
+ # parsing for another html template(GMD)
self.displyResultsGMD()
return
@@ -781,7 +745,8 @@
if self.catalog.records[rec].identification.identtype:
item = wx.ListItem()
- self.resultList.InsertStringItem(index, normalize_text(self.catalog.records[rec].identification.identtype))
+ self.resultList.InsertStringItem(index,
+ normalize_text(self.catalog.records[rec].identification.identtype))
else:
self.resultList.SetStringItem(index, 0, 'unknown')
if self.catalog.records[rec].identification.title:
@@ -946,7 +911,7 @@
def __init__(self, parent, main, cswBrowser=True):
self.parent = main
self.cswBrowser = cswBrowser
self.splitterConn = SplitterWindow(self, style=wx.SP_3D |
@@ -983,7 +948,7 @@
self._layout()
- def OnHtmlKeyDown(self,event):
+ def OnHtmlKeyDown(self, event):
if self._is_copy(event):
self._add_selection_to_clipboard()
self.textMetadata.Parent.OnKey(event)
@@ -997,7 +962,6 @@
wx.TheClipboard.SetData(wx.TextDataObject(self.textMetadata.SelectionToText()))
wx.TheClipboard.Close()
def onNewconnection(self, evt=None, cancel=False):
if self.newBtt.GetLabel() == "New":
self.newBtt.SetLabel('Save')
@@ -1094,10 +1058,8 @@
GMessage('Please select catalog')
return
current_text = self.connectionLBox.GetString(self.connectionLBox.GetSelection())
return
@@ -1135,9 +1097,8 @@
return
if self.cswBrowser:
self.parent.BrowserPanel.loadSettings()
@@ -1170,6 +1131,7 @@
def addDefaultConnections(self, path=None):
"""add default connections from file"""
if path is not None:
self.connectionFilePath = path
if yesNo(self, "Do you want to remove temporary connections?", "Remove tmp connections"):
@@ -1181,27 +1143,33 @@
if doc is None:
return
- self.config.SetPath('/connections')
for server in doc.findall('csw'):
name = server.attrib.get('name')
url = server.attrib.get('url')
- key = '/connections/%s' % name
- self.config.Write('%s/url' % key, url)
+ self.addTmpConnection(name, url)
self.updateConnectionList()
+ def addTmpConnection(self, name, url):
+ self.config.SetPath('/connections')
+ self.config.Write(key, url)
def addConection(self, name, url):
conns = [self.connectionLBox.GetString(i) for i in range(self.connectionLBox.GetCount())]
if name in conns:
GMessage("Name of catalog is exists, new catalog is not saved")
n = self.connectionLBox.FindString(name)
self.connectionLBox.SetSelection(n)
return False
- self.updateConnectionList()
if yesNo(self, "Do you want to add connection to default configuration file", "Default connection"):
tree = ET.parse(self.connectionFilePath)
root = tree.getroot()
@@ -1212,7 +1180,6 @@
return True
def updateConnectionList(self):
"""populate select box with connections"""
self.connectionLBox.Clear()
