[GRASS-SVN] r67768 - grass/branches/releasebranch_7_0/scripts/v.rast.stats
svn_grass at osgeo.org
Sun Feb 7 13:13:00 PST 2016
Author: annakrat
Date: 2016-02-07 13:13:00 -0800 (Sun, 07 Feb 2016)
New Revision: 67768
grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.py
v.rast.stats: remove unnecessary code related to mask (merge from trunk, r67455)
Modified: grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.py
--- grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.py 2016-02-07 21:09:58 UTC (rev 67767)
+++ grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.py 2016-02-07 21:13:00 UTC (rev 67768)
@@ -72,19 +72,12 @@
if rastertmp:
grass.run_command('g.remove', flags='f', type='raster',
name=rastertmp, quiet=True)
- grass.run_command('g.remove', flags='f', type='raster',
- name='MASK', quiet=True, stderr=nuldev)
- if mask_found:
- grass.message(_("Restoring previous MASK..."))
- grass.run_command('g.rename', raster=(tmpname + "_origmask", 'MASK'),
- quiet=True)
# for f in [tmp, tmpname, sqltmp]:
# grass.try_remove(f)
def main():
- global tmp, sqltmp, tmpname, nuldev, vector, mask_found, rastertmp
- mask_found = False
+ global tmp, sqltmp, tmpname, nuldev, vector, rastertmp
rastertmp = False
#### setup temporary files
tmp = grass.tempfile()
@@ -123,13 +116,6 @@
if not grass.find_file(raster, 'cell')['file']:
grass.fatal(_("Raster map <%s> not found") % raster)
- # check presence of raster MASK, put it aside
- mask_found = bool(grass.find_file('MASK', 'cell', mapset)['file'])
- if mask_found:
- grass.message(_("Raster MASK found, temporarily disabled"))
- grass.run_command('g.rename', raster=('MASK', tmpname + "_origmask"),
- quiet=True)
# save current settings:
grass.use_temp_region()
@@ -137,7 +123,6 @@
# keep boundary settings
grass.run_command('g.region', align=raster)
- # prepare raster MASK
grass.message(_("Preprocessing input data..."))
try:
grass.run_command('v.to.rast', input=vector, layer=layer, output=rastertmp,
@@ -293,9 +278,6 @@
except CalledModuleError:
grass.warning(_("Failed to upload statistics to attribute table of vector map <%s>.") % vector)
exitcode = 1
- finally:
sys.exit(exitcode)
