[GRASS-SVN] r67799 - in grass-addons/grass7/raster/r.green: . r.green.install
svn_grass at osgeo.org
Wed Feb 10 06:08:55 PST 2016
Author: zarch
Date: 2016-02-10 06:08:55 -0800 (Wed, 10 Feb 2016)
New Revision: 67799
Added:
grass-addons/grass7/raster/r.green/r.green.install/
grass-addons/grass7/raster/r.green/r.green.install/Makefile
grass-addons/grass7/raster/r.green/r.green.install/r.green.install.html
grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
grass-addons/grass7/raster/r.green/Makefile
r.green: Add module to check missing python libraries and paths
Modified: grass-addons/grass7/raster/r.green/Makefile
--- grass-addons/grass7/raster/r.green/Makefile 2016-02-10 09:24:31 UTC (rev 67798)
+++ grass-addons/grass7/raster/r.green/Makefile 2016-02-10 14:08:55 UTC (rev 67799)
@@ -5,6 +5,7 @@
SUBDIRS = r.green.hydro/libhydro \
r.green.biomassfor \
r.green.hydro \
+ r.green.install \
libgreen
include $(MODULE_TOPDIR)/include/Make/Dir.make
Added: grass-addons/grass7/raster/r.green/r.green.install/Makefile
--- grass-addons/grass7/raster/r.green/r.green.install/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.green/r.green.install/Makefile 2016-02-10 14:08:55 UTC (rev 67799)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../..
+PGM = r.green.install
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.green/r.green.install/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/raster/r.green/r.green.install/r.green.install.html
--- grass-addons/grass7/raster/r.green/r.green.install/r.green.install.html (rev 0)
+++ grass-addons/grass7/raster/r.green/r.green.install/r.green.install.html 2016-02-10 14:08:55 UTC (rev 67799)
@@ -0,0 +1,10 @@
+<h2>DESCRIPTION</h2>
+<em>r.green.install</em> check that all the necessary python libraries like scipy and numexpr are present in the python path. The module also check post-installation troubles that sometimes may occur.
+<h2>AUTHORS</h2>
+Pietro Zambelli (Eurac Research, Bolzano, Italy)
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster/r.green/r.green.install/r.green.install.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
--- grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py (rev 0)
+++ grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py 2016-02-10 14:08:55 UTC (rev 67799)
@@ -0,0 +1,295 @@
+#!/usr/bin/env python
+# -- coding: utf-8 --
+# MODULE: r.green.install
+# AUTHOR(S): Pietro Zambelli
+# PURPOSE: Check missing python libraries and wrong paths and fix them
+# COPYRIGHT: (C) 2014 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Check if evrything is corectly installed and configured
+#% keywords: raster
+#%end
+#%flag
+#% key: i
+#% description: Install missing libraries
+#%end
+#%flag
+#% key: m
+#% description: Move r.green libraries in the right place
+#%end
+# import system libraries
+from __future__ import print_function
+import os
+import sys
+import imp
+import tempfile
+import subprocess
+import shutil
+from HTMLParser import HTMLParser
+from htmlentitydefs import name2codepoint
+import urllib2
+from collections import namedtuple
+import platform
+# import grass libraries
+from grass.script import core as gcore
+from grass.pygrass.utils import set_path
+Pkg = namedtuple('Pkg', ['name', 'version', 'py', 'un', 'platform'])
+CHECK_LIBRARIES = ['scipy', 'numexpr']
+CHECK_RGREENLIB = [('libgreen', '..'),
+ ('libhydro', os.path.join('..', 'r.green.hydro'))]
+def value_not_none(method):
+ """Check if the attribute 'value' of the instance is not null before call
+ the instance method"""
+ def decorator(*args, **kwargs):
+ """If the value is not null call the method"""
+ self = args[0]
+ if self.value is not None:
+ method(*args, **kwargs)
+ else:
+ return
+ return decorator
+class PkgHTMLParser(HTMLParser):
+ """Extract all the <li> ... </li> elements from a webpage"""
+ tag = 'li'
+ values = []
+ value = None
+ packages = {}
+ def handle_starttag(self, tag, attrs):
+ if tag == self.tag:
+ self.value = dict(attrs=attrs, data=[], comment=[],
+ entityref={}, charref={}, decl=[])
+ def handle_endtag(self, tag):
+ if self.value is not None and len(self.value['data']) > 1:
+ pname = ''.join(self.value['data'])
+ pkey = pname.split('-')[0]
+ plist = self.packages.get(pkey, [])
+ plist.append(pname)
+ self.values.append(self.value)
+ self.packages[pkey] = plist
+ self.value = None
+ @value_not_none
+ def handle_data(self, data):
+ self.value['data'].append(data)
+ @value_not_none
+ def handle_comment(self, data):
+ self.value['comment'].append(data)
+ @value_not_none
+ def handle_entityref(self, name):
+ nlist = self.value['entityref'].get(name, [])
+ nlist.append(unichr(name2codepoint[name]))
+ self.value['entityref'][name] = nlist
+ @value_not_none
+ def handle_charref(self, name):
+ self.value['data'].append(unichr(int(name[1:], 16))
+ if name.startswith('x') else
+ unichr(int(name)))
+ @value_not_none
+ def handle_decl(self, data):
+ self.value['decl'].append(data)
+def check_install_pip(install=False):
+ """Check if pip is available"""
+ # run pip and check return code
+ popen_pip = subprocess.Popen(['pip', '--help'], stdout=subprocess.PIPE)
+ if popen_pip.wait():
+ print('pip is not available')
+ if install:
+ print('Downloading pip')
+ # download get_pip.py
+ response = urllib2.urlopen('https://bootstrap.pypa.io/get-pip.py')
+ with open('get_pip.py', mode='w') as getpip:
+ getpip.write(response.read())
+ # install pip
+ print('Installing pip')
+ popen_py = subprocess.Popen([sys.executable, 'get_pip.py'])
+ if popen_py.returncode:
+ print('Something wrong during the installation of pip,'
+ ' perhaps permissions')
+ else:
+ print('pip is available on the sys path')
+def fix_missing_libraries(install=False):
+ """Check if the external libraries used by r.green are
+ available in the current path."""
+ urlwin = 'http://www.lfd.uci.edu/~gohlke/pythonlibs'
+ def get_url(lib, _parser=[None, ]):
+ """Return the complete url to download the wheel file for windows"""
+ def match():
+ """Match platform with available wheel files on the web page"""
+ pkgs = parser.packages[lib]
+ cppy = 'cp' + str(sys.version_info.major) + str(sys.version_info.minor)
+ pltf = 'win_amd64.whl' if platform.architecture() == '64bit' else 'win32.whl'
+ result = None
+ for pki in pkgs[::-1]:
+ pkk = Pkg(*pkg.split('-'))
+ if pkk.py == cppy and pkk.platform == pltf:
+ result = pki
+ break
+ if result is None:
+ print('=> Library not found for your system', cppy, pltf[:-4])
+ sys.exit()
+ return result
+ # check the cache
+ if _parser[0] is None:
+ # read and parse the HTML page
+ response = urllib2.urlopen(urlwin)
+ parser = PkgHTMLParser()
+ parser.feed(response.read())
+ # save the instance to the cache
+ _parser[0] = parser
+ else:
+ # load the instance from the cache
+ parser = _parser[0]
+ if lib not in parser.packages:
+ print(lib, 'not in the package list:')
+ from pprint import pprint
+ pprint(sorted(parser.packages))
+ sys.exit()
+ pkg = match()
+ return ('http://www.lfd.uci.edu/~gohlke/pythonlibs/bofhrmxk/' + pkg,
+ pkg)
+ def win_install(lib):
+ """Download and install missing libraries under windows"""
+ # get wheel url
+ urlwhl, pkg = get_url(lib)
+ dst = os.path.join(tempfile.gettempdir(), pkg)
+ print('Downloading:', urlwhl, 'file in:', dst)
+ response = urllib2.urlopen(urlwhl)
+ with open(dst, mode='w') as getwhl:
+ getwhl.write(response.read())
+ cmd = ['pip', 'install', dst, '--user']
+ popen_pip = subprocess.Popen(cmd)
+ print('Something went wrong during the installation, '
+ 'please fix this manually')
+ print(cmd)
+ sys.exit()
+ to_be_installed = []
+ for lib in CHECK_LIBRARIES:
+ try:
+ imp.find_module(lib)
+ print(lib, 'available in the sys path')
+ except ImportError:
+ to_be_installed.append(lib)
+ if to_be_installed:
+ print('the following libraries are missing:')
+ for lib in to_be_installed:
+ print('- ', lib)
+ if install:
+ if sys.platform.startswith('win') or sys.platform.startswith('cyg'):
+ # download precompiled wheel and install them
+ print('Download the wheel file manually for your platform from:')
+ # http://www.lfd.uci.edu/~gohlke/pythonlibs/bofhrmxk/numexpr-2.4.6-cp27-none-win_amd64.whl
+ win_install(lib)
+ else:
+ cmd = ['pip', 'install'].extend(to_be_installed)
+ cmd.append('--user')
+ print(cmd)
+ sys.exit()
+def fix_rgreen_libraries(move=False):
+ """Check if r.green libraries are correctly positioned
+ move from addos into etc/r.green directory:
+ ~/.grass7/addons/libgreen => ~/.grass7/addons/etc/r.green/libgreen
+ ~/.grass7/addons/libhydro => ~/.grass7/addons/etc/r.green/libhydro
+ gaddons = os.environ['GRASS_ADDON_BASE']
+ if not gaddons:
+ print('Environmental variable GRASS_ADDON_BASE not set!')
+ return
+ def mvlibs(lib):
+ """Move r.green libraries directories into the GRASS addons
+ standard directory"""
+ wrongpath = os.path.join(gaddons, lib)
+ greendir = os.path.join(gaddons, 'etc', 'r.green')
+ if os.path.exists(wrongpath):
+ if not os.path.exists(greendir):
+ os.makedirs(greendir)
+ msg = 'Moving r.green library (%s) from: %s to: %s'
+ print(msg % (lib, wrongpath, greendir))
+ if move:
+ shutil.move(wrongpath, greendir)
+ else:
+ if os.path.exists(greendir):
+ print(lib, 'already in the right place:', greendir)
+ mvlibs('libgreen')
+ mvlibs('libhydro')
+ path_problems = False
+ # finally import the module in the library
+ for lib, relativepath in CHECK_RGREENLIB:
+ set_path('r.green', lib, relativepath)
+ try:
+ print('Not able to import %s' % lib)
+ path_problems = True
+ if path_problems:
+ print('Some libraries seem not available in the current path:')
+ for path in sys.path:
+ print('- ', path)
+if __name__ == "__main__":
+ opts, flgs = gcore.parser()
+ check_install_pip(flgs['i'])
+ fix_missing_libraries(flgs['i'])
+ fix_rgreen_libraries(flgs['m'])
Property changes on: grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
+ text/x-python
+ native
