[GRASS-SVN] r67815 - grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge
svn_grass at osgeo.org
Thu Feb 11 05:33:16 PST 2016
Author: Giulia
Date: 2016-02-11 05:33:16 -0800 (Thu, 11 Feb 2016)
New Revision: 67815
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py
r.green: fix bugs on discharge piedmont module
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py 2016-02-11 11:38:50 UTC (rev 67814)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py 2016-02-11 13:33:16 UTC (rev 67815)
@@ -303,24 +303,23 @@
command = 'q_spec =0.0086*%s+0.03416*%s-24.5694' % (rain, h_mean)
q_spec = 'q_spec'
mapcalc(command)
- else:
- command = '%s = %s * %s/1000.0' % (q_river, q_spec, a_river)
- mapcalc(command)
+ command = '%s = %s * %s/1000.0' % (q_river, q_spec, a_river)
+ mapcalc(command)
# compute MVF with Regione Veneto Formula
+ min_flow = options['mfd']
if options['k_b']:
msgr.warning("Regione Veneto plan")
k_b = options['k_b'] # raster
k_n = options['k_n'] # raster
- min_flow = options['mfd']
regione_veneto(a_river, q_spec, k_b, k_n,
min_flow)
elif k_mat:
msgr.warning("Piedmont Plan")
command = '%s=%s*%s*%s*%s*%s/1000.0' % (min_flow, k_mat, a_river,
- q_spec, m_mat, a_mat)
+ q_spec, m_mat, a_mat)
mapcalc(command, overwrite=True)
else:
- msgr.warning("No formula fot the MVF")
+ msgr.warning("No formula for the MVF")
if corr_fact:
# if corr_fact coumpute the environemtal flow else the minimum flow"
command = '%s=if(not(%s), %s, %s*%s)' % (env_area, min_flow,
