[GRASS-SVN] r67820 - grass-addons/grass7/vector/v.neighborhoodmatrix
svn_grass at osgeo.org
Sat Feb 13 07:15:04 PST 2016
Author: mlennert
Date: 2016-02-13 07:15:04 -0800 (Sat, 13 Feb 2016)
New Revision: 67820
grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py
v.neighborhoodmatrix: Better uniquification of results, better cleanup of tempmaps, rename grass. to gscript.
Modified: grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py
--- grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py 2016-02-12 22:34:26 UTC (rev 67819)
+++ grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py 2016-02-13 15:15:04 UTC (rev 67820)
@@ -38,25 +38,32 @@
#%end
import sys
-import grass.script as grass
+import os
+import atexit
+import grass.script as gscript
+from grass.script.utils import separator
+def cleanup():
+ gscript.run_command('g.remove', flags='f', type='vector',
+ pat=tempmapname, quiet=True)
def main():
# if no output filename, output to stdout
input = options['input']
player = int(options['player'])
output = options['output']
- sep = grass.utils.separator(options['separator'])
+ sep = separator(options['separator'])
bidirectional = flags['b']
- tempmapname='neighborhoodmatrix_tempmap'
+ global tempmapname
+ tempmapname='neighborhoodmatrix_tempmap_%d' % os.getpid()
#TODO: automatically determine the first available layer in file
blayer = player+1
- grass.run_command('v.category', input=input, output=tempmapname,
+ gscript.run_command('v.category', input=input, output=tempmapname,
option='add', layer=blayer, type='boundary', quiet=True,
overwrite=True)
- vtodb_results=grass.read_command('v.to.db', flags='p', map=tempmapname,
+ vtodb_results=gscript.read_command('v.to.db', flags='p', map=tempmapname,
type='boundary', option='sides', layer=blayer, qlayer=player, quiet=True)
- grass.run_command('g.remove', flags='f', type='vector', name=tempmapname, quiet=True)
#put result into a list of integer pairs
temp_neighbors=[]
@@ -64,27 +71,17 @@
if line.split('|')[1]<>'-1' and line.split('|')[2]<>'-1':
temp_neighbors.append([int(line.split('|')[1]), int(line.split('|')[2])])
- #uniqify the list of integer pairs
- n = len(temp_neighbors)
- t=list(temp_neighbors)
- t.sort()
- assert n > 0
- last = t[0]
- lasti = i = 1
- while i < n:
- if t[i] != last:
- t[lasti] = last = t[i]
- lasti += 1
- i += 1
- neighbors=t[:lasti]
+ #temp_neighbors.sort()
#if user wants bidirectional matrix, add the inversed pairs to the original
if bidirectional:
neighbors_reversed=[]
- for pair in neighbors:
+ for pair in temp_neighbors:
neighbors_reversed.append([pair[1], pair[0]])
- neighbors += neighbors_reversed
+ temp_neighbors += neighbors_reversed
+ #uniqify the list of integer pairs
+ neighbors = [list(x) for x in set(tuple(x) for x in temp_neighbors)]
neighbors.sort()
if output and output != '-':
@@ -101,5 +98,6 @@
sys.exit()
if __name__ == "__main__":
- options, flags = grass.parser()
+ options, flags = gscript.parser()
+ atexit.register(cleanup)
main()
