[GRASS-SVN] r67831 - grass-addons/grass7/raster/r.green/r.green.install
svn_grass at osgeo.org
Mon Feb 15 03:22:20 PST 2016
Author: zarch
Date: 2016-02-15 03:22:20 -0800 (Mon, 15 Feb 2016)
New Revision: 67831
grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
r.green: Add x flag to modify the GRASS main GUI and add an Energy menu
Modified: grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
--- grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py 2016-02-15 10:48:23 UTC (rev 67830)
+++ grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py 2016-02-15 11:22:20 UTC (rev 67831)
@@ -27,11 +27,15 @@
#% key: m
#% description: Move r.green libraries in the right place
#%end
+#%flag
+#% key: x
+#% description: Add r.green menu to the GRASS GUI
+#%end
# import system libraries
from __future__ import print_function
import os
+from os.path import join
import sys
import imp
import tempfile
@@ -41,6 +45,7 @@
from HTMLParser import HTMLParser
from htmlentitydefs import name2codepoint
import urllib2
+import xml.etree.ElementTree as ET
from collections import namedtuple
import platform
@@ -58,7 +63,91 @@
CHECK_RGREENLIB = [('libgreen', '..'),
('libhydro', os.path.join('..', 'r.green.hydro'))]
+PATHSYSXML = []
+PATHLOCXML = []
+XMLMAINMENU = "Energy"
+XMLENERGYTOOLBOX = """<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE toolboxes SYSTEM "toolboxes.dtd">
+<toolboxes>
+ <toolbox name="{XMLMAINMENU}">
+ <label>&Energy</label>
+ <items>
+ <subtoolbox name="Biomass"/>
+ <subtoolbox name="Hydro"/>
+ </items>
+ </toolbox>
+ <toolbox name="Biomass">
+ <label>Biomass</label>
+ <items>
+ <subtoolbox name="Forestry"/>
+ </items>
+ </toolbox>
+ <toolbox name="Forestry">
+ <label>Forestry biomass potential</label>
+ <items>
+ <module-item name="r.green.biomassfor.theoretical">
+ <label>Theoretical potential</label>
+ </module-item>
+ <module-item name="r.green.biomassfor.legal">
+ <label>Legal constraints</label>
+ </module-item>
+ <module-item name="r.green.biomassfor.technical">
+ <label>Technical constraints</label>
+ </module-item>
+ <module-item name="r.green.biomassfor.recommended">
+ <label>Extra constraints</label>
+ </module-item>
+ <module-item name="r.green.biomassfor.economic">
+ <label>Financial constraints</label>
+ </module-item>
+ <separator/>
+ <module-item name="r.green.biomassfor.impact">
+ <label>Impact on Ecosystem Services</label>
+ </module-item>
+ <module-item name="r.green.biomassfor.co2">
+ <label>CO2 balance</label>
+ </module-item>
+ </items>
+ </toolbox>
+ <toolbox name="Hydro">
+ <label>Hydro-power potential</label>
+ <items>
+ <module-item name="r.green.hydro.theoretical">
+ </module-item>
+ <module-item name="r.green.hydro.recommended">
+ <label>Legal and extra constraints</label>
+ </module-item>
+ <module-item name="r.green.hydro.technical">
+ </module-item>
+ <module-item name="r.green.hydro.financial">
+ </module-item>
+ <separator/>
+ <module-item name="r.green.hydro.closest">
+ <label>Move power plants to the closest river's point</label>
+ </module-item>
+ <module-item name="r.green.hydro.discharge">
+ <label>Compute natural discharge and minimal flow</label>
+ </module-item>
+ <module-item name="r.green.hydro.optimal">
+ <label>Identify optimal river segment</label>
+ </module-item>
+ <module-item name="r.green.hydro.structure">
+ <label>Compute channels and penstocks</label>
+ </module-item>
+ <module-item name="r.green.hydro.delplants">
+ <label>Delete segments where there is an existing plant</label>
+ </module-item>
+ </items>
+ </toolbox>
+</toolboxes>
+""".format(XMLMAINMENU=XMLMAINMENU)
def value_not_none(method):
"""Check if the attribute 'value' of the instance is not null before call
the instance method"""
@@ -121,6 +210,16 @@
self.value['decl'].append(data)
+def get_settings_path():
+ """Get full path to the settings directory
+ # TODO: remove this function once the GetSettingsPath function is moved in
+ # grass.script.utils or similia
+ return (join(os.getenv('APPDATA'), 'GRASS%d' % 7)
+ if sys.platform.startswith('win') else
+ join(os.getenv('HOME'), '.grass%d' % 7))
def check_install_pip(install=False):
"""Check if pip is available"""
# run pip and check return code
@@ -166,7 +265,7 @@
break
if result is None:
print('=> Library not found for your system', cppy, pltf[:-4])
- sys.exit()
+ sys.exit(1)
return result
# check the cache
@@ -185,7 +284,7 @@
print(lib, 'not in the package list:')
from pprint import pprint
pprint(sorted(parser.packages))
- sys.exit()
+ sys.exit(1)
pkg = match()
return ('http://www.lfd.uci.edu/~gohlke/pythonlibs/bofhrmxk/' + pkg,
@@ -206,7 +305,7 @@
print('Something went wrong during the installation, '
'please fix this manually')
print(cmd)
- sys.exit()
+ sys.exit(1)
to_be_installed = []
for lib in CHECK_LIBRARIES:
@@ -236,7 +335,7 @@
print(cmd)
- sys.exit()
+ sys.exit(1)
def fix_rgreen_libraries(move=False):
@@ -255,7 +354,7 @@
"""Move r.green libraries directories into the GRASS addons
standard directory"""
wrongpath = os.path.join(gaddons, lib)
- greendir = os.path.join(gaddons, 'etc', 'r.green')
+ greendir = os.path.join(gaddons, 'etc', 'r.green', lib)
if os.path.exists(wrongpath):
if not os.path.exists(greendir):
os.makedirs(greendir)
@@ -290,9 +389,69 @@
print('- ', path)
+def add_rgreen_menu():
+ """Add/Update the xml used to define the GRASS GUI"""
+ def toolboxes2dict(toolboxes):
+ """Trnsform a list of toolbox elements into a dictionary"""
+ return {toolbox.find('label').text: toolbox for toolbox in toolboxes}
+ main = 'main_menu.xml'
+ tool = 'toolboxes.xml'
+ grass_toolboxes_path = join(os.getenv('GISBASE'), 'gui', 'wxpython', 'xml')
+ user_toolboxes_path = join(get_settings_path(), 'toolboxes')
+ # check if XML files already exist
+ main_path = join(user_toolboxes_path, main)
+ tool_path = join(user_toolboxes_path, tool)
+ if not os.path.exists(main_path):
+ print('Copying %s to %s' % (join(grass_toolboxes_path, main),
+ main_path))
+ shutil.copyfile(join(grass_toolboxes_path, main), main_path)
+ if not os.path.exists(tool_path):
+ print('Copying %s to %s' % (join(grass_toolboxes_path, tool),
+ tool_path))
+ shutil.copyfile(join(grass_toolboxes_path, tool), tool_path)
+ # read XML input files
+ main_tree = ET.parse(main_path)
+ main_root = main_tree.getroot()
+ tool_tree = ET.parse(tool_path)
+ tool_root = tool_tree.getroot()
+ # check if the update of the main xml it is necessary
+ main_items = main_root.find('items')
+ update_main = True
+ for item in main_items:
+ if item.attrib['name'] == XMLMAINMENU:
+ update_main = False
+ if update_main:
+ print("Updating", main_path)
+ menrg = main_items[0].copy()
+ menrg.attrib['name'] = XMLMAINMENU
+ main_items.append(menrg)
+ main_tree.write(main_path)
+ toolboxes = toolboxes2dict(tool_root.findall('toolbox'))
+ enrg_tools = toolboxes2dict(ET.fromstring(XMLENERGYTOOLBOX))
+ # update the energy toolboxes
+ print("Updating", tool_path)
+ for key in enrg_tools:
+ if key in toolboxes:
+ tool_root.remove(toolboxes[key])
+ tool_root.append(enrg_tools[key])
+ tool_tree.write(tool_path)
if __name__ == "__main__":
opts, flgs = gcore.parser()
check_install_pip(flgs['i'])
fix_missing_libraries(flgs['i'])
fix_rgreen_libraries(flgs['m'])
+ if flgs['x']:
+ add_rgreen_menu()
