[GRASS-SVN] r67839 - grass-addons/grass7/raster/r.futures/r.futures.pga
svn_grass at osgeo.org
Mon Feb 15 18:56:25 PST 2016
Author: wenzeslaus
Date: 2016-02-15 18:56:25 -0800 (Mon, 15 Feb 2016)
New Revision: 67839
grass-addons/grass7/raster/r.futures/r.futures.pga/main.c
r.futures: update size when enlarging list
Fixes segfaut.
Remove special condition for no subregions
which was part of the old code.
It is not needed and harmful now.
Modified: grass-addons/grass7/raster/r.futures/r.futures.pga/main.c
--- grass-addons/grass7/raster/r.futures/r.futures.pga/main.c 2016-02-16 01:29:20 UTC (rev 67838)
+++ grass-addons/grass7/raster/r.futures/r.futures.pga/main.c 2016-02-16 02:56:25 UTC (rev 67839)
@@ -1283,7 +1283,9 @@
if (nToConvert > 0) {
/* if not enough cells to convert then alter number required */
if (nToConvert > pLandscape->num_undevSites[regionID]) {
- G_warning("Not enough undeveloped sites... converting all");
+ G_warning("Not enough undeveloped sites (requested: %d,"
+ " available: %d). Converting all available.",
+ nToConvert, pLandscape->num_undevSites[regionID]);
nToConvert = pLandscape->num_undevSites[regionID];
/* update in stochastic fashion */
@@ -1773,8 +1775,7 @@
sParams.overflowDevDemands[i] = 0;
readDevDemand(&sParams);
- if (sParams.num_Regions > 1)
- readDevPotParams(&sParams, opt.devpotParamsFile->answer);
+ readDevPotParams(&sParams, opt.devpotParamsFile->answer);
if (readParcelSizes(&sLandscape, &sParams)) {
//testDevPressure(&sLandscape, &sParams);
/* do calculation and dump result */
@@ -1874,7 +1875,11 @@
pThis->index_region);
if (pLandscape->num_undevSites[id] >= pLandscape->asUndevs_ns[id]) {
- pLandscape->asUndevs[id] = (t_Undev *) G_realloc(pLandscape->asUndevs[id], pLandscape->asUndevs_ns[id] * 2 * sizeof(t_Undev));
+ size_t new_size = 2 * pLandscape->asUndevs_ns[id];
+ pLandscape->asUndevs[id] =
+ (t_Undev *) G_realloc(pLandscape->asUndevs[id],
+ new_size * sizeof(t_Undev));
+ pLandscape->asUndevs_ns[id] = new_size;
pLandscape->asUndevs[id][pLandscape->num_undevSites[id]].
cellID = i;
