[GRASS-SVN] r67841 - grass/trunk/temporal/t.list
svn_grass at osgeo.org
Mon Feb 15 23:09:20 PST 2016
Author: lucadelu
Date: 2016-02-15 23:09:20 -0800 (Mon, 15 Feb 2016)
New Revision: 67841
grass/trunk/temporal/t.list/t.list.py
t.list: added output option, started working on #2319
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2016-02-16 05:05:07 UTC (rev 67840)
+++ grass/trunk/temporal/t.list/t.list.py 2016-02-16 07:09:20 UTC (rev 67841)
@@ -71,6 +71,10 @@
#% guisection: Formatting
#%end
+#%option G_OPT_F_OUTPUT
+#% required: no
+#%end
#%flag
#% key: c
#% description: Print the column names as first row
@@ -93,6 +97,7 @@
order = options["order"]
where = options["where"]
separator = gscript.separator(options["separator"])
+ outpath = options["output"]
colhead = flags['c']
# Make sure the temporal database exists
@@ -103,7 +108,7 @@
dbif.connect()
first = True
- if gscript.verbosity() > 0:
+ if gscript.verbosity() > 0 and not outpath:
sys.stderr.write("----------------------------------------------\n")
for ttype in temporal_type.split(","):
@@ -117,6 +122,9 @@
# Use the correct order of the mapsets, hence first the current mapset, then
# alphabetic ordering
mapsets = tgis.get_tgis_c_library_interface().available_mapsets()
+ if outpath:
+ outfile = open(outpath, 'w')
# Print for each mapset separately
for key in mapsets:
@@ -124,7 +132,7 @@
rows = stds_list[key]
if rows:
if issubclass(sp.__class__, tgis.AbstractMapDataset):
sys.stderr.write(_("Time stamped %s maps with %s available in mapset <%s>:\n")%\
(sp.get_type(), time, key))
@@ -142,7 +150,10 @@
else:
output += str(key)
count += 1
- print output
+ if outpath:
+ outfile.write("{st}\n".format(st=output))
+ else:
+ print output
first = False
for row in rows:
@@ -154,8 +165,10 @@
else:
output += str(col)
count += 1
- print output
+ if outpath:
+ else:
+ print output
dbif.close()
