[GRASS-SVN] r67865 - grass-addons/grass7/raster/r.futures/r.futures.demand
Wed Feb 17 06:27:28 PST 2016
Author: annakrat
Date: 2016-02-17 06:27:28 -0800 (Wed, 17 Feb 2016)
New Revision: 67865
   grass-addons/grass7/raster/r.futures/r.futures.demand/r.futures.demand.html
   grass-addons/grass7/raster/r.futures/r.futures.demand/r.futures.demand.py
r.futures: add new function for curve fitting
Modified: grass-addons/grass7/raster/r.futures/r.futures.demand/r.futures.demand.html
--- grass-addons/grass7/raster/r.futures/r.futures.demand/r.futures.demand.html	2016-02-17 13:52:55 UTC (rev 67864)
+++ grass-addons/grass7/raster/r.futures/r.futures.demand/r.futures.demand.html	2016-02-17 14:27:28 UTC (rev 67865)
@@ -45,9 +45,10 @@
 <p>
 The <b>method</b> parameter allows to choose the type of relation
 between population and developed area. The available methods
-include linear, logarithmic and exponential relation.
+include linear, logarithmic, exponential and exponential approach relation.
 If more than one method is checked, the best relation is selected
-based on RMSE. Recommended methods are logarithmic or linear.
+based on RMSE. Recommended methods are logarithmic, linear and exponential approach.
+Method exponential approach requires <a href="http://scipy.org/">scipy</a>.
 <p>
 The format of the output <b>demand</b> table is:
@@ -64,7 +65,6 @@
 In case the demand values would be negative (in case of population decrease
 or if the relation is inversely proportional) the values are turned into zeros,
 since FUTURES does not simulate change from developed to undeveloped sites.
-By changing the "Years_to_simulate" number, user can control the simulation.
 <p>
 An optional output <b>plot</b> is a plot of the relations for each subregion.
Modified: grass-addons/grass7/raster/r.futures/r.futures.demand/r.futures.demand.py
--- grass-addons/grass7/raster/r.futures/r.futures.demand/r.futures.demand.py	2016-02-17 13:52:55 UTC (rev 67864)
+++ grass-addons/grass7/raster/r.futures/r.futures.demand/r.futures.demand.py	2016-02-17 14:27:28 UTC (rev 67865)
@@ -56,8 +56,8 @@
 #% multiple: yes
 #% required: yes
 #% description: Relationship between developed cells (dependent) and population (explanatory)
-#% options: linear, logarithmic, exponential
-#% descriptions:linear;y = A + Bx;logarithmic;y = A + Bln(x);exponential;y = Ae^(BX)
+#% options: linear, logarithmic, exponential, exp_approach
+#% descriptions:linear;y = A + Bx;logarithmic;y = A + Bln(x);exponential;y = Ae^(BX);exp_approach;y = (1 - e^(-A(x - B))) + C
 #% answer: linear,logarithmic
 #% guisection: Optional
 #%end
@@ -81,12 +81,21 @@
 import sys
+import math
 import numpy as np
 import grass.script.core as gcore
 import grass.script.utils as gutils
+def exp_approach(x, a, b, c):
+    return (1 - np.exp(-a * (x - b))) + c
+def magnitude(x):
+    return int(math.log10(x))
 def main():
     developments = options['development'].split(',')
     observed_popul_file = options['observed_population']
@@ -97,6 +106,16 @@
     plot = options['plot']
     simulation_times = [float(each) for each in options['simulation_times'].split(',')]
+    for each in methods:
+        if each in ('exp_approach',):
+            try:
+                from scipy.optimize import curve_fit
+            except ImportError:
+                gcore.fatal(_("Importing scipy failed. Method 'exp_approach' is not available"))
+    # exp approach needs at least 3 data points
+    if len(developments) <= 2 and 'exp_approach' in methods:
+        gcore.fatal(_("Not enough data for method 'exp_approach'"))
     observed_popul = np.genfromtxt(observed_popul_file, dtype=float, delimiter=sep, names=True)
     projected_popul = np.genfromtxt(projected_popul_file, dtype=float, delimiter=sep, names=True)
     year_col = observed_popul.dtype.names[0]
@@ -149,29 +168,53 @@
         for method in methods:
             # observed population points for subregion
             reg_pop = observed_popul[subregionId]
-            if method == 'logarithmic':
-                reg_pop = np.log(reg_pop)
-            if method == 'exponential':
-                y = np.log(table_developed[subregionId])
-            else:
-                y = table_developed[subregionId]
-            A = np.vstack((reg_pop, np.ones(len(reg_pop)))).T
-            m, c = np.linalg.lstsq(A, y)[0]  # y = mx + c
-            coeff[method] = m, c
             simulated[method] = np.array(population_for_simulated_times[subregionId])
-                predicted[method] = np.log(simulated[method]) * m + c
-                r = (reg_pop * m + c) - table_developed[subregionId]
-            elif method == 'exponential':
-                predicted[method] = np.exp(m * simulated[method] + c)
-                r = np.exp(m * reg_pop + c) - table_developed[subregionId]
-            else:  # linear
-                predicted[method] = simulated[method] * m + c
-            # RMSE
-            rmse[method] = np.sqrt((np.sum(r * r) / (len(reg_pop) - 2)))
+            if method in ('exp_approach',):
+                # we have to scale it first
+                y = np.array(table_developed[subregionId])
+                magn = float(np.power(10, max(magnitude(np.max(reg_pop)), magnitude(np.max(y)))))
+                x = reg_pop / magn
+                y = y / magn
+                initial = (0.5, np.mean(x), np.mean(y))  # this seems to work best for our data
+                try:
+                    popt, pcov = curve_fit(globals()[method], x, y, p0=initial)
+                except RuntimeError:
+                    rmse[method] = sys.maxsize  # so that other method is selected
+                    gcore.warning(_("Method '{m}' cannot converge for subregion {reg}".format(m=method, reg=subregionId)))
+                    if len(methods) == 1:
+                        gcore.fatal(_("Method '{m}' failed for subregion {reg},"
+                                    " please select at least one other method").format(m=method, reg=subregionId))
+                else:
+                    predicted[method] = globals()[method](simulated[method] / magn, *popt) * magn
+                    r = globals()[method](x, *popt) * magn - table_developed[subregionId]
+                    coeff[method] = popt
+                    rmse[method] = np.sqrt((np.sum(r * r) / (len(reg_pop) - 2)))
+            else:
+                if method == 'logarithmic':
+                    reg_pop = np.log(reg_pop)
+                if method == 'exponential':
+                    y = np.log(table_developed[subregionId])
+                else:
+                    y = table_developed[subregionId]
+                A = np.vstack((reg_pop, np.ones(len(reg_pop)))).T
+                m, c = np.linalg.lstsq(A, y)[0]  # y = mx + c
+                coeff[method] = m, c
+                    predicted[method] = np.log(simulated[method]) * m + c
+                    r = (reg_pop * m + c) - table_developed[subregionId]
+                elif method == 'exponential':
+                    predicted[method] = np.exp(m * simulated[method] + c)
+                    r = np.exp(m * reg_pop + c) - table_developed[subregionId]
+                else:  # linear
+                    predicted[method] = simulated[method] * m + c
+                # RMSE
         method = min(rmse, key=rmse.get)
+        gcore.verbose(_("Method '{meth}' was selected for subregion {reg}").format(meth=method, reg=subregionId))
         # write demand
         demand[subregionId] = predicted[method]
         demand[subregionId] = np.diff(demand[subregionId])
@@ -179,7 +222,7 @@
             gcore.warning(_("Subregion {sub} has negative numbers"
                             " of newly developed cells, changing to zero".format(sub=subregionId)))
             demand[subregionId][demand[subregionId] < 0] = 0
-        if m < 0:
+        if coeff[method][0] < 0:
             demand[subregionId].fill(0)
             gcore.warning(_("For subregion {sub} population and development are inversely proportional,"
                             "will result in zero demand".format(sub=subregionId)))
@@ -187,7 +230,7 @@
         # draw
         if plot:
             ax = fig.add_subplot(n_plots, n_plots, i)
-            ax.set_title(subregionId + ', RMSE: ' + str(rmse[method]))
+            ax.set_title("{sid}, RMSE: {rmse:.3f}".format(sid=subregionId, rmse=rmse[method]))
             ax.set_xlabel('population')
             ax.set_ylabel('developed cells')
             # plot known points
@@ -197,16 +240,20 @@
             # plot predicted curve
             x_pred = np.linspace(np.min(x),
                                  np.max(np.array(population_for_simulated_times[subregionId])), 10)
-            m, c = coeff[method]
+            cf = coeff[method]
             if method == 'linear':
-                line = x_pred * m + c
-                label = "$y = {c:.3f} + {m:.3f} x$".format(m=m, c=c)
+                line = x_pred * cf[0] + cf[1]
+                label = "$y = {c:.3f} + {m:.3f} x$".format(m=cf[0], c=cf[1])
             elif method == 'logarithmic':
-                line = np.log(x_pred) * m + c
-                label = "$y = {c:.3f} + {m:.3f} \ln(x)$".format(m=m, c=c)
-            else:
-                line = np.exp(x_pred * m + c)
-                label = "$y = {c:.3f} e^{{{m:.3f}x}}$".format(m=m, c=np.exp(c))
+                line = np.log(x_pred) * cf[0] + cf[1]
+                label = "$y = {c:.3f} + {m:.3f} \ln(x)$".format(m=cf[0], c=cf[1])
+                line = np.exp(x_pred * cf[0] + cf[1])
+                label = "$y = {c:.3f} e^{{{m:.3f}x}}$".format(m=cf[0], c=np.exp(cf[1]))
+            elif method == 'exp_approach':
+                line = exp_approach(x_pred / magn, *cf) * magn
+                label = "$y = (1 -  e^{{-{A:.3f}(x-{B:.3f})}}) + {C:.3f}$".format(A=cf[0], B=cf[1], C=cf[2])
             ax.plot(x_pred, line, label=label)
             ax.plot(simulated[method], predicted[method], linestyle='', marker='o', markerfacecolor='None')
             plt.legend(loc=0)
