[GRASS-SVN] r67873 - grass/trunk/gui/wxpython/datacatalog
svn_grass at osgeo.org
Thu Feb 18 01:19:53 PST 2016
Author: martinl
Date: 2016-02-18 01:19:53 -0800 (Thu, 18 Feb 2016)
New Revision: 67873
grass/trunk/gui/wxpython/datacatalog/tree.py
wxGUI: fix various datalog issues (copying, renaming, deleting)
Modified: grass/trunk/gui/wxpython/datacatalog/tree.py
--- grass/trunk/gui/wxpython/datacatalog/tree.py 2016-02-18 06:44:33 UTC (rev 67872)
+++ grass/trunk/gui/wxpython/datacatalog/tree.py 2016-02-18 09:19:53 UTC (rev 67873)
@@ -236,20 +236,23 @@
self.selected_layer = item
type = 'element'
item = item.parent
if type == 'element':
self.selected_type = item
type = 'mapset'
item = item.parent
if type == 'mapset':
self.selected_mapset = item
type = 'location'
item = item.parent
if type == 'location':
self.selected_location = item
def OnSelChanged(self, event):
self.selected_layer = None
def OnRightClick(self, node):
"""Display popup menu."""
self.DefineItems(node)
@@ -316,6 +319,12 @@
self.copy_mapset = None
self.copy_location = None
+ def _runCommand(self, prog, **kwargs):
+ cmdString = ' '.join(gscript.make_command(prog, **kwargs))
+ ret = RunCommand(prog, parent=self, **kwargs)
+ return ret, cmdString
def InitTreeItems(self):
"""Add locations, mapsets and layers to the tree."""
self._initTreeItems()
@@ -326,8 +335,9 @@
self.copy_type = self.selected_type
self.copy_mapset = self.selected_mapset
self.copy_location = self.selected_location
- label = _("Layer {layer} copied to clipboard."
- "You can paste it to selected mapset.".format(layer=self.copy_layer.label))
+ label = _("Map <{layer}> marked for copying. "
+ "You can paste it to the current mapset "
+ "<{mapset}>.".format(layer=self.copy_layer.label, mapset=self.gmapset))
self.showNotification.emit(message=label)
def OnRename(self, event):
@@ -360,20 +370,19 @@
string = self.old_name + ',' + self.new_name
gisrc, env = getEnvironment(self.gisdbase, self.selected_location.label, self.selected_mapset.label)
renamed = 0
- label = _("Renaming {name}...").format(name=string)
+ label = _("Renaming map <{name}>...").format(name=string)
if self.selected_type.label == 'vector':
- renamed = RunCommand('g.rename', vector=string, env=env)
+ renamed, cmd = self._runCommand('g.rename', vector=string, env=env)
elif self.selected_type.label == 'raster':
- renamed = RunCommand('g.rename', raster=string, env=env)
+ renamed, cmd = self._runCommand('g.rename', raster=string, env=env)
else:
- renamed = RunCommand('g.rename', raster3d=string, env=env)
+ renamed, cmd = self._runCommand('g.rename', raster3d=string, env=env)
if renamed == 0:
self.selected_layer.label = self.new_name
self.selected_layer.data['name'] = self.new_name
self.RefreshNode(self.selected_layer)
- label = "g.rename " + self.selected_type.label + "=" + string + _(" -- completed")
- self.showNotification.emit(message=label)
+ self.showNotification.emit(message=_("{cmd} -- completed").format(cmd=cmd))
Debug.msg(1, "LAYER RENAMED TO: " + self.new_name)
gscript.try_remove(gisrc)
@@ -381,8 +390,10 @@
"""Paste layer or mapset"""
# copying between mapsets of one location
if not self.copy_layer:
+ GMessage(_("No map selected for copying."), parent=self)
return
- if self.selected_location == self.copy_location and self.selected_mapset:
+ if self.selected_location == self.copy_location and \
+ self.selected_mapset.data['name'] == gscript.gisenv()['MAPSET']:
if self.selected_type:
if self.copy_type.label != self.selected_type.label: # copy raster to vector or vice versa
GError(_("Failed to copy map: invalid map type "
@@ -393,42 +404,63 @@
if not self.new_name:
return
if self.copy_layer.label == self.new_name:
- GMessage(_("Layer was not copied: new layer has the same name"), parent=self)
+ GMessage(_("Failed to copy map: new map has the same name"), parent=self)
return
+ if not self.selected_type:
+ found = self._model.SearchNodes(parent=self.selected_mapset, type='element', name=self.copy_type.label)
+ self.selected_type = found[0] if found else None
+ overwrite = False
+ if self.selected_type:
+ found = self._model.SearchNodes(parent=self.selected_type, type=self.copy_type.label, name=self.new_name)
+ if found and found[0]:
+ dlg = wx.MessageDialog(parent=self,
+ message = _("Map <{map}> already exists "
+ "in the current mapset. "
+ "Do you want to overwrite it?").format(map=self.new_name),
+ caption = _("Overwrite?"),
+ style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+ ret = dlg.ShowModal()
+ dlg.Destroy()
+ if ret == wx.ID_YES:
+ overwrite = True
string = self.copy_layer.label + '@' + self.copy_mapset.label + ',' + self.new_name
pasted = 0
- label = _("Copying {name}...").format(name=string)
+ label = _("Copying <{name}>...").format(name=string)
if self.copy_type.label == 'vector':
- pasted = RunCommand('g.copy', vector=string, env=env)
+ pasted, cmd = self._runCommand('g.copy', vector=string, overwrite=overwrite, env=env)
node = 'vector'
elif self.copy_type.label == 'raster':
- pasted = RunCommand('g.copy', raster=string, env=env)
+ pasted, cmd = self._runCommand('g.copy', raster=string, overwrite=overwrite, env=env)
node = 'raster'
else:
- pasted = RunCommand('g.copy', raster_3d=string, env=env)
+ pasted, cmd = self._runCommand('g.copy', raster_3d=string, overwrite=overwrite, env=env)
node = 'raster_3d'
if pasted == 0:
- found = self._model.SearchNodes(parent=self.selected_mapset, type=node)
- self.selected_type = found[0] if found else None
- if not self.selected_type:
- # add type node if not exists
- self.selected_type = self._model.AppendNode(parent=self.selected_mapset, label=node,
- data=dict(type='element', name=node))
- self._model.AppendNode(parent=self.selected_type, label=self.new_name,
- data=dict(type=node, name=self.new_name))
- self._model.SortChildren(self.selected_type)
- self.RefreshNode(self.selected_type, recursive=True)
+ # add type node if not exists
+ self.selected_type = self._model.AppendNode(parent=self.selected_mapset, label=node,
+ data=dict(type='element', name=node))
+ if not overwrite:
+ self._model.AppendNode(parent=self.selected_type, label=self.new_name,
+ data=dict(type=node, name=self.new_name))
+ self._model.SortChildren(self.selected_type)
+ self.RefreshNode(self.selected_type, recursive=True)
Debug.msg(1, "COPIED TO: " + self.new_name)
- label = "g.copy " + self.copy_type.label + "=" + string + _(" -- completed") # generate this message (command) automatically?
+ self.showNotification.emit(message= _("{cmd} -- completed").format(cmd=cmd))
else:
- GError(_("Failed to copy layer: action is allowed only within the same location."),
- parent=self)
+ if self.selected_location != self.copy_location:
+ GError(_("Failed to copy map: action is allowed only within the same location."),
+ parent=self)
+ else:
+ GError(_("Failed to copy map: action is allowed only within the current mapset."),
+ parent=self)
# expand selected mapset
self.ExpandNode(self.selected_mapset, recursive=True)
@@ -444,20 +476,19 @@
label = _("Deleting {name}...").format(name=string)
- removed = RunCommand('g.remove', flags='f', type='vector',
+ removed, cmd = self._runCommand('g.remove', flags='f', type='vector',
name=string, env=env)
- removed = RunCommand('g.remove', flags='f', type='raster',
+ removed, cmd = self._runCommand('g.remove', flags='f', type='raster',
else:
- removed = RunCommand('g.remove', flags='f', type='raster_3d',
+ removed, cmd = self._runCommand('g.remove', flags='f', type='raster_3d',
if removed == 0:
self._model.RemoveNode(self.selected_layer)
Debug.msg(1, "LAYER " + string + " DELETED")
- label = "g.remove -f type=" + self.selected_type.label + " name=" + string + _(" -- completed") # generate this message (command) automatically?
def OnDisplayLayer(self, event):
@@ -538,12 +569,6 @@
menu.AppendItem(item)
self.Bind(wx.EVT_MENU, self.OnCopy, item)
- item = wx.MenuItem(menu, wx.NewId(), _("&Paste"))
- menu.AppendItem(item)
- self.Bind(wx.EVT_MENU, self.OnPaste, item)
- if not current_mapset:
- item.Enable(False)
item = wx.MenuItem(menu, wx.NewId(), _("&Delete"))
self.Bind(wx.EVT_MENU, self.OnDelete, item)
@@ -557,7 +582,7 @@
item.Enable(False)
if not isinstance(self._giface, StandaloneGrassInterface):
- item = wx.MenuItem(menu, wx.NewId(), _("&Display layer"))
+ item = wx.MenuItem(menu, wx.NewId(), _("&Display"))
self.Bind(wx.EVT_MENU, self.OnDisplayLayer, item)
