[GRASS-SVN] r67876 - grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.economic
svn_grass at osgeo.org
Thu Feb 18 02:27:30 PST 2016
Author: Giulia
Date: 2016-02-18 02:27:30 -0800 (Thu, 18 Feb 2016)
New Revision: 67876
grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.economic/r.green.biomassfor.economic.py
r.green: new module for biomass financial analysis of the harvesting
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.economic/r.green.biomassfor.economic.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.economic/r.green.biomassfor.economic.py 2016-02-18 10:16:03 UTC (rev 67875)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.economic/r.green.biomassfor.economic.py 2016-02-18 10:27:30 UTC (rev 67876)
@@ -6,7 +6,9 @@
# MODULE: r.green.biomassfor.economic
# AUTHOR(S): Sandro Sacchelli, Francesco Geri
-# Converted to Python by Pietro Zambelli and Francesco Geri, reviewed by Marco Ciolli
+# Converted to Python by Pietro Zambelli, Francesco Geri,
+# reviewed by Marco Ciolli
+# Last version rewritten by Giulia Garegnani, Gianluca Grilli
# PURPOSE: Calculates the economic value of a forests in terms of bioenergy assortments
# COPYRIGHT: (C) 2013 by the GRASS Development Team
@@ -31,33 +33,6 @@
#% required : yes
#%end
#%option G_OPT_V_INPUT
-#% key: boundaries
-#% type: string
-#% description: Name of vector boundaries map (boolean map)
-#% label: Name of vector boundaries map (boolean map)
-#% required : yes
-#%end
-#%option
-#% key: forest_column_price
-#% type: string
-#% description: Vector field of wood typologies
-#% required : yes
-#%end
-#%option
-#% key: conditions
-#% type: string
-#% description: List of wood assorments:price
-#% required : yes
-#%end
-#%option
-#% key: output_basename
-#% type: string
-#% description: Basename for economic bioenergy (HF,CC and total)
-#% gisprompt: new
-#% key_desc : name
-#% required : yes
-#%end
-#%option G_OPT_V_INPUT
#% key: dhp
#% type: string
#% description: Name of vector district heating points
@@ -76,7 +51,7 @@
#% description: Vector field of stand surface (ha)
#% required : yes
#%end
-#%option
+#%option
#% key: forest_column_management
#% type: string
#% description: Vector field of forest management (1: high forest, 2:coppice)
@@ -88,6 +63,12 @@
#% description: Vector field of forest treatment (1: final felling, 2:thinning)
#% required : yes
#%end
+#%option
+#% key: forest_column_wood_price
+#% type: string
+#% description: Vector field of wood prices
+#% required : yes
+#%end
#% key: forest_roads
#% type: string
@@ -102,13 +83,31 @@
#% label: Vector map of main roads
#% required : yes
#%end
+#%option G_OPT_R_ELEV
+#% required: yes
+#%end
#%option G_OPT_R_INPUT
-#% key: dtm2
+#% key: technical_bioenergy
#% type: string
-#% description: Name of Digital terrain model map
-#% required : yes
+#% description: Total technical biomass potential [MWh/year]
+#% guisection: Opt files
+#% required : no
#%end
+#% key: tech_bioc
+#% type: string
+#% description: Technical biomass potential for coppices [MWh/year]
+#% required : no
+#%end
+#%option G_OPT_R_INPUT
+#% key: tech_biohf
+#% type: string
+#% description: Technical biomass potential in high forest [MWh/year]
+#% required : no
+#%end
#% key: soilp2_map
#% type: string
#% description: Soil production map
@@ -271,594 +270,789 @@
#% guisection: Costs
#%end
#%option
-#% key: energy_tops_hf
+#% key: ton_tops_hf
#% type: double
-#% description: Energy for tops and branches in high forest in MWh/m³
-#% answer: 0.49
-#% guisection: Energy
+#% description: BEF for tops and branches in high forest [ton/m3]
+#% answer: 0.25
+#% guisection: Forest
#%end
#%option
-#% key: energy_cormometric_vol_hf
+#% key: ton_vol_hf
#% type: double
-#% description: Energy for the whole tree in high forest (tops, branches and stem) in MWh/m³
-#% answer: 1.97
+#% description: BEF for the whole tree in high forest (tops, branches and stem) in ton/m³
+#% answer: 1
+#% guisection: Plant
#%end
#%option
-#% key: energy_tops_cop
+#% key: ton_tops_cop
#% type: double
-#% description: Energy for tops and branches for Coppices in MWh/m³
-#% answer: 0.55
+#% description: BEF for tops and branches for Coppices in ton/m³
+#% answer: 0.30
#%end
#%flag
#% key: r
#% description: Remove all operational maps
#%end
+#%option G_OPT_R_OUTPUT
+#% key: econ_bioenergy
+#% type: string
+#% key_desc: name
+#% description: Name of raster map with the financial potential of bioenergy [Mwh/year]
+#% required: yes
+#% guisection: Output maps
+#%end
+#% key: net_revenues
+#% type: string
+#% key_desc: name
+#% description: Name of raster map with the net present value [€/year]
+#% required: yes
+#% answer: net_revenues
+#%end
+#% key: total_revenues
+#% type: string
+#% key_desc: name
+#% description: Name of raster map with the total revenues [€/year]
+#% required: no
+#%end
+#% key: total_cost
+#% type: string
+#% key_desc: name
+#% description: Name of raster map with the total cost [€/year]
+#% required: no
+#%end
+#% key: econ_bioenergyhf
+#% type: string
+#% key_desc: name
+#% description: Name of raster map with the financial potential of bioenergy in high forest [Mwh/year]
+#% required: no
+#%end
+#% key: econ_bioenergyc
+#% type: string
+#% key_desc: name
+#% description: Name of raster map with the financial potential of bioenergy for coppices[Mwh/year]
+#% required: no
+#%end
import grass.script as grass
-from grass.script.core import run_command, parser,overwrite
+from grass.script.core import run_command, parser, overwrite, warning
from grass.pygrass.raster import RasterRow
+from grass.pygrass.modules.shortcuts import raster as r
import numpy as np
+import os
+import atexit
+from grass.pygrass.utils import set_path
+set_path('r.green', 'libhydro', '..')
+set_path('r.green', 'libgreen', os.path.join('..', '..'))
+# finally import the module in the library
+from libgreen.utils import cleanup
ow = overwrite()
+def conmbination(management, treatment):
+ pid = os.getpid()
+ # set combination to avoid several if
+ m1t1 = "tmprgreen_%i_m1t1" % pid
+ exp = ("{combination}=if(({management}=={c1} && ({treatment}=={c2}"
+ "||{treatment}==99999)),1,0)")
+ r.mapcalc(exp.format(combination=m1t1,
+ management=management,
+ c1=1,
+ treatment=treatment,
+ c2=1),
+ overwrite=ow)
+ run_command("r.null", map=m1t1, null=0)
+ m1t2 = "tmprgreen_%i_m1t2" % pid
+ exp = ("{combination}=if(({management}=={c1} && {treatment}=={c2}),1,0)")
+ r.mapcalc(exp.format(combination=m1t2,
+ c1=1,
+ c2=2),
+ overwrite=ow)
+ run_command("r.null", map=m1t2, null=0)
+ m2 = "tmprgreen_%i_m2" % pid
+ exp = ("{combination}=if({management}=={c1},1,0)")
+ r.mapcalc(exp.format(combination=m2,
+ c1=2),
+ overwrite=ow)
+ run_command("r.null", map=m2, null=0)
+ m1 = "tmprgreen_%i_m1" % pid
+ r.mapcalc(exp.format(combination=m1,
+ c1=1),
+ overwrite=ow)
+ run_command("r.null", map=m1, null=0)
+ not2 = "tmprgreen_%i_not2" % pid
+ exp = ("{combination}=if(({treatment}=={c1} && {treatment}=={c2}),1,0)")
+ r.mapcalc(exp.format(combination=not2,
+ c1=1,
+ c2=99999),
+ overwrite=ow)
+ run_command("r.null", map=not2, null=0)
+ #TODO: try to remove all the r.nulle, since I
+ # have done it at the beginning
+ return m1t1, m1t2, m1, m2, not2
-def remove_map(opts, flgs):
+def slope_computation(opts):
+ pid = os.getpid()
+ tmp_slope = 'tmprgreen_%i_slope' % pid
+ tmp_slope_deg = 'tmprgreen_%i_slope_deg' % pid
+ run_command("r.slope.aspect", overwrite=ow,
+ elevation=opts['elevation'], slope=tmp_slope, format="percent")
+ elevation=opts['elevation'], slope=tmp_slope_deg)
- prf_yield = opts['field_prefix']
- pricelist=opts['prices'].split(',')
+def yield_pix_process(opts, vector_forest, yield_, yield_surface,
+ rivers, lakes, forest_roads, m1, m2,
+ m1t1, m1t2, roughness):
+ pid = os.getpid()
+ technical_surface = "tmprgreen_%i_technical_surface" % pid
+ cable_crane_extraction = "cable_crane_extraction"
+ forwarder_extraction = "forwarder_extraction"
+ other_extraction = "other_extraction"
- run_command("g.remove", type="raster", flags="f", name="tot_roads")
- run_command("g.remove", type="raster", flags="f", name="tot_roads_neg")
- run_command("g.remove", type="raster", flags="f", name="frict_surf_tr1")
- run_command("g.remove", type="raster", flags="f", name="frict_surf_tr")
- run_command("g.remove", type="raster", flags="f", name="transp_dist")
- run_command("g.remove", type="raster", flags="f", name="transport_prod")
- run_command("g.remove", type="raster", flags="f", name="fell_costHFtr1")
- run_command("g.remove", type="raster", flags="f", name="chipp_cost")
- run_command("g.remove", type="raster", flags="f", name="fell_costHFtr2")
- run_command("g.remove", type="raster", flags="f", name="fell_proc_costC")
- run_command("g.remove", type="raster", flags="f", name="proc_costHFtr1")
- run_command("g.remove", type="raster", flags="f", name="proc_costHFtr2")
- run_command("g.remove", type="raster", flags="f", name="extr_cost_cablehf")
- run_command("g.remove", type="raster", flags="f", name="extr_cost_forw")
- run_command("g.remove", type="raster", flags="f", name="extr_cost_other")
- run_command("g.remove", type="raster", flags="f", name="transport_cost")
- run_command("g.remove", type="raster", flags="f", name="prod_costs")
- run_command("g.remove", type="raster", flags="f", name="direction_cost")
- run_command("g.remove", type="raster", flags="f", name="administrative_cost")
- run_command("g.remove", type="raster", flags="f", name="total_costs")
- run_command("g.remove", type="raster", flags="f", name="interests")
- run_command("g.remove", type="raster", flags="f", name="net_revenues")
- run_command("g.remove", type="raster", flags="f", name="positive_net_revenues")
- run_command("g.remove", type="raster", flags="f", name="net_rev_pos")
- run_command("g.remove", type="raster", flags="f", name="economic_surface")
- run_command("g.remove", type="raster", flags="f", name="chipp_prod")
- run_command("g.remove", type="raster", flags="f", name="chipp_prodHF")
- run_command("g.remove", type="raster", flags="f", name="chipp_prodC")
- run_command("g.remove", type="raster", flags="f", name="extr_cost_cableC")
- run_command("g.remove", type="raster", flags="f", name="cable_crane_extraction")
- run_command("g.remove", type="raster", flags="f", name="extr_dist")
- run_command("g.remove", type="raster", flags="f", name="extr_product_other")
- run_command("g.remove", type="raster", flags="f", name="extr_cableHF_em")
- run_command("g.remove", type="raster", flags="f", name="extr_product_cableC")
- run_command("g.remove", type="raster", flags="f", name="extr_product_cableHF")
- run_command("g.remove", type="raster", flags="f", name="extr_product_forw")
- run_command("g.remove", type="raster", flags="f", name="fell_proc_costHFtr1")
- run_command("g.remove", type="raster", flags="f", name="fell_proc_costHFtr2")
- run_command("g.remove", type="raster", flags="f", name="fell_proc_productC")
- run_command("g.remove", type="raster", flags="f", name="fell_proc_productHFtr1")
- run_command("g.remove", type="raster", flags="f", name="fell_proc_productHFtr2")
- run_command("g.remove", type="raster", flags="f", name="fell_productHFtr1")
- run_command("g.remove", type="raster", flags="f", name="fell_productHFtr2")
- run_command("g.remove", type="raster", flags="f", name="forwarder_extraction")
- run_command("g.remove", type="raster", flags="f", name="frict_surf_extr")
- run_command("g.remove", type="raster", flags="f", name="other_extraction")
- run_command("g.remove", type="raster", flags="f", name="pix_cross")
- run_command("g.remove", type="raster", flags="f", name="proc_productHFtr1")
- run_command("g.remove", type="raster", flags="f", name="techn_pix_comp")
- run_command("g.remove", type="raster", flags="f", name="technical_surface")
- run_command("g.remove", type="raster", flags="f", name="tot_dist")
- run_command("g.remove", type="raster", flags="f", name="total_revenues")
- run_command("g.remove", type="raster", flags="f", name="total_revenues1")
- run_command("g.remove", type="raster", flags="f", name="total_revenues2")
- run_command("g.remove", type="raster", flags="f", name="yield_pix")
- run_command("g.remove", type="raster", flags="f", name="yield_pix1")
- run_command("g.remove", type="raster", flags="f", name="yield_pix2")
- run_command("g.remove", type="raster", flags="f", name="yield_pixp")
- run_command("g.remove", type="raster", flags="f", name="technical_bioenergy")
- run_command("g.remove", type="raster", flags="f", name="slope__")
- run_command("g.remove", type="raster", flags="f", name="slope___")
- run_command("g.remove", type="raster", flags="f", name="slope_deg__")
- for x in range(1,len(pricelist)+1):
- mapvol1=prf_yield+'_vol_typ'+str(x)+'pix'
- mapvol2=prf_yield+'_vol_typ'+str(x)+'pix2'
- run_command("g.remove", type="raster", flags="f", name=mapvol1)
- run_command("g.remove", type="raster", flags="f", name=mapvol2)
-def yield_pix_process(opts, flgs,vector_forest,yield_,yield_surface,rivers,lakes,forest_roads,management,treatment,roughness):
- run_command("r.slope.aspect", overwrite=ow,elevation=opts['dtm2'], slope="slope__", format="percent")
- run_command("r.slope.aspect", overwrite=ow,elevation=opts['dtm2'], slope="slope_deg__")
run_command("r.param.scale", overwrite=ow,
- input=opts['dtm2'], output="morphometric_features",
+ input=opts['elevation'], output="morphometric_features",
size=3, method="feature")
+ # peaks have an higher cost/distance in order not to change the valley
+ expr = "{pix_cross} = ((ewres()+nsres())/2)/ cos({tmp_slope_deg})"
+ r.mapcalc(expr.format(pix_cross=('tmprgreen_%i_pix_cross' % pid),
+ tmp_slope_deg=tmp_slope_deg),
+ overwrite=ow)
+ #FIXME: yield surface is a plan surface and not the real one of the forest
+ #unit, do I compute the real one?#
+ # if yield_pix1 == 0 then yield is 0, then I can use yield or
+ # use yeld_pix but I will compute it only once in the code
run_command("r.mapcalc", overwrite=ow,
- expression='pix_cross = ((ewres()+nsres())/2)/ cos(slope_deg__)')
+ expression=('yield_pix1 = (' + yield_+'/' +
+ yield_surface+')*((ewres()*nsres())/10000)'))
- run_command("r.mapcalc", overwrite=ow,
- expression='yield_pix1 = ('+yield_+'/'+yield_surface+')*((ewres()*nsres())/10000)')
run_command("r.null", map="yield_pix1", null=0)
run_command("r.null", map="morphometric_features", null=0)
- exprmap='frict_surf_extr = pix_cross + if(yield_pix1<=0, 99999) + if(morphometric_features==6, 99999)'
+# FIXME: initial control on the yield in order to verify if it is positive
+# exprmap = ("{frict_surf_extr} = {pix_cross} + if(yield_pix1<=0, 99999)"
+# "+ if({morphometric_features}==6, 99999)")
- if rivers!='':
- run_command("v.to.rast", input=rivers,output="rivers", use="val", overwrite=True)
- rivers="rivers"
+ exprmap = ("{frict_surf_extr} = {pix_cross}"
+ "+ if({morphometric_features}==6, 99999)")
+ if rivers:
+ run_command("v.to.rast", input=rivers, output=('tmprgreen_%i_rivers'
+ % pid),
+ use="val", value=99999, overwrite=True)
run_command("r.null", map=rivers, null=0)
- exprmap+='+ if('+rivers+'>=1, 99999)'
+ exprmap += "+ %s" % ('tmprgreen_%i_rivers' % pid)
- if lakes!='':
- run_command("v.to.rast", input=lakes,output="lakes", use="val", overwrite=True)
- lakes="lakes"
+ if lakes:
+ run_command("v.to.rast", input=lakes, output=('tmprgreen_%i_lakes'
+ % pid),
run_command("r.null", map=lakes, null=0)
- exprmap+='+ if('+lakes+'>=1, 99999)'
+ exprmap += '+ %s' % ('tmprgreen_%i_lakes' % pid)
+ frict_surf_extr = 'tmprgreen_%i_frict_surf_extr' % pid
+ extr_dist = 'tmprgreen_%i_extr_dist' % pid
+ r.mapcalc(exprmap.format(frict_surf_extr=frict_surf_extr,
+ pix_cross=('tmprgreen_%i_pix_cross' % pid),
+ morphometric_features='morphometric_features',
+ overwrite=ow)
- run_command("r.mapcalc",overwrite=ow,expression=exprmap)
run_command("r.cost", overwrite=ow,
- input="frict_surf_extr", output="extr_dist",
- stop_points=vector_forest, start_rast=forest_roads,
- max_cost=1500)
+ input=frict_surf_extr, output=extr_dist,
+ stop_points=vector_forest,
+ start_rast='tmprgreen_%i_forest_roads' % pid,
+ max_cost=1500)
+ slp_min_cc = opts['slp_min_cc']
+ slp_max_cc = opts['slp_max_cc']
+ dist_max_cc = opts['dist_max_cc']
+ ccextr = ("{cable_crane_extraction} = if({yield_} >0 && {tmp_slope}"
+ "> {slp_min_cc} && {tmp_slope} <= {slp_max_cc} && {extr_dist}<"
+ "{dist_max_cc} , 1)")
+ r.mapcalc(ccextr.format(cable_crane_extraction=cable_crane_extraction,
+ yield_=yield_, tmp_slope=tmp_slope,
+ slp_min_cc=slp_min_cc, slp_max_cc=slp_max_cc,
+ dist_max_cc=dist_max_cc,
+ extr_dist=extr_dist),
+ overwrite=ow)
- CCEXTR = 'cable_crane_extraction = if('+yield_+'>0 && slope__>'+opts['slp_min_cc']+' && slope__<='+opts['slp_max_cc']+' && extr_dist<'+opts['dist_max_cc']+', 1)'
+ fwextr = ("{forwarder_extraction} = if({yield_}>0 && {tmp_slope}<="
+ "{slp_max_fw} && ({roughness} ==0 ||"
+ "{roughness}==1 || {roughness}==99999) &&"
+ "{extr_dist}<{dist_max_fw}, {m1}*1)")
- FWEXTR = 'forwarder_extraction = if('+yield_+'>0 && slope__<='+opts['slp_max_fw']+' && '+management+'==1 && ('+roughness+'==0 || '+roughness+'==1 || '+roughness+'==99999) && extr_dist<'+opts['dist_max_fw']+', 1)'
- OEXTR = 'other_extraction = if('+yield_+'>0 && slope__<='+opts['slp_max_cop']+' && '+management+'==2 && ('+roughness+'==0 || '+roughness+'==1 || '+roughness+'==99999) && extr_dist<'+opts['dist_max_cop']+', 1)'
+ r.mapcalc(fwextr.format(forwarder_extraction=forwarder_extraction,
+ slp_max_fw=opts['slp_max_fw'],
+ m1=m1,
+ roughness=roughness,
+ dist_max_fw=opts['dist_max_fw'],
+ overwrite=ow)
+ oextr = ("{other_extraction} = if({yield_}>0 &&"
+ "{tmp_slope}<={slp_max_cop} &&"
+ "({roughness}==0 || {roughness}==1 ||"
+ "{roughness}==99999) && {extr_dist}< {dist_max_cop}, {m2}*1)")
- run_command("r.mapcalc", overwrite=ow,expression=CCEXTR)
- run_command("r.mapcalc", overwrite=ow,expression=FWEXTR)
- run_command("r.mapcalc", overwrite=ow,expression=OEXTR)
+ r.mapcalc(oextr.format(other_extraction=other_extraction,
+ slp_max_cop=opts['slp_max_cop'],
+ m2=m2, roughness=roughness,
+ dist_max_cop=opts['dist_max_cop'],
+ overwrite=ow)
+ run_command("r.null", map=cable_crane_extraction, null=0)
+ run_command("r.null", map=forwarder_extraction, null=0)
+ run_command("r.null", map=other_extraction, null=0)
+# FIXME: or instead of plus
+ expression = ("{technical_surface} = {cable_crane_extraction} +"
+ "{forwarder_extraction} + {other_extraction}")
+ r.mapcalc(expression.format(technical_surface=technical_surface,
+ cable_crane_extraction=cable_crane_extraction,
+ forwarder_extraction=forwarder_extraction,
+ other_extraction=other_extraction),
+ overwrite=ow)
- run_command("r.null", map="cable_crane_extraction", null=0)
- run_command("r.null", map="forwarder_extraction", null=0)
- run_command("r.null", map="other_extraction", null=0)
+ run_command("r.null", map=technical_surface, null=0)
+# FIXME: in my opinion we cannot sum two different energy coefficients
+# is the energy_vol_hf including the energy_tops?
+ ehf = ("{tech_bioHF} = {technical_surface}*{yield_pix}*"
+ "({m1t1}*{ton_tops_hf}+"
+ "{m1t2}*({ton_vol_hf}+{ton_tops_hf}))")
+ tech_bioHF = ('tmprgreen_%i_tech_bioenergyHF' % pid)
+ r.mapcalc(ehf.format(tech_bioHF=tech_bioHF,
+ technical_surface=technical_surface,
+ m1t1=m1t1, m1t2=m1t2,
+ yield_pix='yield_pix1',
+ ton_tops_hf=opts['ton_tops_hf'],
+ ton_vol_hf=opts['ton_vol_hf']),
+ overwrite=ow)
+ tech_bioC = 'tmprgreen_%i_tech_bioenergyC' % pid
+ ecc = ("{tech_bioC} = {technical_surface}*{m2}*{yield_pix}"
+ "*{ton_tops_cop}")
+ r.mapcalc(ecc.format(tech_bioC=tech_bioC,
+ m2=m2,
+ ton_tops_cop=opts['ton_tops_cop']),
+ overwrite=ow)
+ technical_bioenergy = "tmprgreen_%i_techbio" % pid
+ exp = "{technical_bioenergy}={tech_bioHF}+{tech_bioC}"
+ r.mapcalc(exp.format(technical_bioenergy=technical_bioenergy,
+ tech_bioC=tech_bioC,
+ tech_bioHF=tech_bioHF),
+ overwrite=ow)
+ run_command("r.null", map=technical_bioenergy, null=0)
- run_command("r.mapcalc", overwrite=ow,expression='technical_surface = cable_crane_extraction + forwarder_extraction + other_extraction')
- run_command("r.null", map="technical_surface", null=0)
- EHF = 'tech_bioenergyHF = technical_surface*(if('+management+'==1 && '+treatment+'==1 || '+management+'==1 && '+treatment+'==99999, yield_pix*'+opts['energy_tops_hf']+', if('+management+'==1 && '+treatment+'==2, yield_pix *'+opts['energy_tops_hf']+' + yield_pix * '+opts['energy_cormometric_vol_hf']+')))'
- ECC = 'tech_bioenergyC = technical_surface*(if('+management+' == 2, yield_pix*'+opts['energy_tops_cop']+'))'
- ET='technical_bioenergy=tech_bioenergyHF+tech_bioenergyC'
- # run_command("r.stats.zonal", overwrite=ow,
- # base="compartment", cover="technical_surface", method="sum",
- # output="techn_pix_comp")
- # run_command("r.mapcalc", overwrite=ow,
- # expression='yield_pix2 = yield/(technical_surface*techn_pix_comp)')
- # YPIX = 'yield_pix = yield_pix1*%d + yield_pix2*%d'
- # expression=YPIX % (1 if flgs['u'] else 0, 0 if flgs['u'] else 1,))
- run_command("r.mapcalc", overwrite=ow,expression="yield_pix=yield_pix1")
- # run_command("r.mapcalc", overwrite=ow,expression=YPIX)
- run_command("r.mapcalc", overwrite=ow,expression=EHF)
- run_command("r.mapcalc", overwrite=ow,expression=ECC)
- run_command("r.mapcalc", overwrite=ow,expression=ET)
- run_command("g.remove", type="raster", flags="f", name="tech_bioenergyHF,tech_bioenergyC")
- run_command("r.null", map="technical_bioenergy", null=0)
- tech_bioenergy="technical_bioenergy"
- with RasterRow(tech_bioenergy) as pT:
+ with RasterRow(technical_bioenergy) as pT:
T = np.array(pT)
- print ("Tech bioenergy stimated (Mwh): %.2f" % np.nansum(T))
+ print ("Tech bioenergy stimated (ton): %.2f" % np.nansum(T))
+ return technical_bioenergy, tech_bioC, tech_bioHF
-def revenues(opts, flgs,yield_surface,management,treatment,forest,yield_):
+def revenues(opts, yield_surface, m1t1, m1t2, m1, m2,
+ forest, yield_, technical_bioenergy):
# Calculate revenues
- fieldprice=opts['forest_column_price']
- fieldcond=opts['conditions']
+ pid = os.getpid()
+ #FIXME: tmp_yield is the raster yield in the other sections of the module
+ tmp_yield = 'tmprgreen_%i_yield' % pid
+ tmp_wood = 'tmprgreen_%i_wood_price' % pid
+ tmp_rev_wood = 'tmprgreen_%i_rev_wood' % pid
+ exprpix = '%s=%s*%s/%s*(ewres()*nsres()/10000)' % (tmp_rev_wood, tmp_wood,
+ tmp_yield,
+ yield_surface)
+ run_command("r.mapcalc", overwrite=ow, expression=exprpix)
+ # FIXME: Does the coppice produces timber?
+ tr1 = ("{total_revenues} ="
+ "{technical_surface}*(({m1t1}|||{m2})*({tmp_rev_wood} +"
+ "{technical_bioenergy}*{price_energy_woodchips})+"
+ "{m1t2}*{technical_bioenergy}*{price_energy_woodchips})")
- # pricelist=opts['prices'].split(',') #convert the string in list of string
+ r.mapcalc(tr1.format(total_revenues=("tmprgreen_%i_total_revenues" % pid),
+ technical_surface=('tmprgreen_%i_technical_surface'
+ % pid),
+ m1t1=m1t1, m2=m2, m1t2=m1t2,
+ tmp_rev_wood=tmp_rev_wood,
+ technical_bioenergy=technical_bioenergy,
+ price_energy_woodchips=opts['price_energy_woodchips']
+ overwrite=ow)
+ return ("tmprgreen_%i_total_revenues" % pid)
- # for x in range(1,len(pricelist)+1):
- # price_field=prf_yield+"_voltyp"+str(x)
- # run_command("r.mapcalc", overwrite=ow,expression=prf_yield+'_vol_typ'+str(x)+'pix = ('+price_field+'/'+yield_surface+')*(ewres()*nsres()/10000)')
- # run_command("r.null", map=prf_yield+'_vol_typ'+str(x)+'pix', null=0)
+def productivity(opts,
+ m1t1, m1t2, m1, m2, not2, soilp2_map,
+ tree_diam, tree_vol, forest_roads, main_roads):
+ # return a dictionary with the productivity maps as key and
+ # the cost form the GUI as value
+# if tree_diam == '':
+# tree_diam="99999"
+# if tree_vol == '':
+# tree_vol="9.999"
+# if soilp2_map == '':
+# soilp2_map="99999"
+ pid = os.getpid()
+ dhp = opts['dhp']
+ fell_productHFtr1 = "tmprgreen_%i_fell_productHFtr1" % pid
+ fell_productHFtr2 = "tmprgreen_%i_fell_productHFtr2" % pid
+ fell_proc_productC = "tmprgreen_%i_fell_proc_productC" % pid
+ proc_productHFtr1 = "tmprgreen_%i_proc_productHFtr1" % pid
+ fell_proc_productHFtr1 = "tmprgreen_%i_fell_proc_productHFtr1" % pid
+ fell_proc_productHFtr2 = "tmprgreen_%i_fell_proc_productHFtr2" % pid
+ chipp_prod = "tmprgreen_%i_chipp_prod" % pid
+ extr_dist = "tmprgreen_%i_extr_dist" % pid
+ extr_product_cableHF = "tmprgreen_%i_extr_product_cableHF" % pid
+ extr_product_cableC = "tmprgreen_%i_extr_product_cableC" % pid
+ extr_product_forw = "tmprgreen_%i_extr_product_forw" % pid
+ extr_product_other = "tmprgreen_%i_extr_product_other" % pid
+ transport_prod = "tmprgreen_%i_transport_prod" % pid
+ dic1 = {fell_productHFtr1: opts['cost_chainsaw'],
+ fell_productHFtr2: opts['cost_chainsaw'],
+ fell_proc_productC: opts['cost_chainsaw'],
+ proc_productHFtr1: opts['cost_processor'],
+ fell_proc_productHFtr1: opts['cost_harvester'],
+ fell_proc_productHFtr2: opts['cost_harvester'],
+ extr_product_cableHF: opts['cost_cablehf'],
+ extr_product_cableC: opts['cost_cablec'],
+ extr_product_forw: opts['cost_forwarder'],
+ extr_product_other: opts['cost_skidder']}
+ dic2 = {chipp_prod: opts['cost_chipping'],
+ transport_prod: opts['cost_transport']}
+ # Calculate productivity
+ #FIXME:in my opinion is better to exclude area with negative slope!!!
+ expression = "{tmp_slope}=if({tmp_slope}<=100,{tmp_slope},100)"
+ r.mapcalc(expression.format(tmp_slope="tmprgreen_%i_slope" % pid),
+ overwrite=ow)
+ #view the paper appendix for the formulas
+ expr = ("{fell_productHFtr1} = {mt}*{cable_crane_extraction}"
+ "*(42-2.6*{tree_diam})/(-20.0)*1.65*(1-{slope___}/100.0)")
+ r.mapcalc(expr.format(fell_productHFtr1=fell_productHFtr1,
+ mt=m1t1,
+ cable_crane_extraction="cable_crane_extraction",
+ tree_diam="tmprgreen_%i_tree_diam" % pid,
+ slope___='tmprgreen_%i_slope' % pid), overwrite=ow)
+ run_command("r.null", map=fell_productHFtr1, null=0)
- listwoods=fieldcond.split(',')
+ expr = ("{fell_productHFtr2} = {mt}*{cable_crane_extraction}*"
+ "(42-2.6*{tree_diam})/(-20)*1.65*(1-(1000-90*{slope}/(-80))/100)")
+ r.mapcalc(expr.format(fell_productHFtr2=fell_productHFtr2,
+ mt=m1t2,
+ slope='tmprgreen_%i_slope' % pid), overwrite=ow)
+ run_command("r.null", map=fell_productHFtr2, null=0)
+ #FIXME: it is different from the paper, to check
+ expr = ("{fell_proc_productC} = {m2}*"
+ "(0.3-1.1*{soilp2_map})/(-4)*(1-{slope}/100)")
+ r.mapcalc(expr.format(fell_proc_productC=fell_proc_productC,
+ m2=m2,
+ soilp2_map="tmprgreen_%i_soilp2_map" % pid,
+ run_command("r.null", map=fell_proc_productC, null=0)
- prices=''
- for wood in listwoods:
- #import ipdb; ipdb.set_trace()
- woodprice=wood.split('=')
- where_cond=fieldprice+" like "+"'"+woodprice[0]+"'"
- run_command("v.to.rast",input=forest,output='forest_'+woodprice[0],use="attr", attrcolumn=yield_, where=where_cond)
- exprpix='forest_'+woodprice[0]+'_pix=(forest_'+woodprice[0]+"/"+yield_surface+')*(ewres()*nsres()/10000)'
- run_command("r.mapcalc", overwrite=ow, expression=exprpix)
- nullmap='forest_'+woodprice[0]+'_pix'
- run_command("r.null", map=nullmap,null=0)
- prices+=nullmap+'*'+woodprice[1]+"+"
- prices=prices[:-1]
- #prices = '+'.join(["vol_typ%dpix*%f" % (i+1, price) for i, price in enumerate(opts['prices'])])
- #prices = '+'.join([prf_yield+"_vol_typ%dpix*%f" % (i+1, float(price)) for i, price in enumerate(pricelist)])
- price_energy_woodchips=float(opts['price_energy_woodchips'])
- TR1='total_revenues1 = technical_surface*(if('+management+' == 1 && '+treatment+'==1 || '+management+' == 1 && '+treatment+'==99999 || '+management+' == 2,('+prices+'+(technical_bioenergy*'+str(price_energy_woodchips)+')), if('+management+' == 1 && '+treatment+'==2, technical_bioenergy*'+str(price_energy_woodchips)+')))'
- run_command("r.mapcalc", overwrite=ow, expression=TR1)
- run_command("r.mapcalc",overwrite=ow,expression='total_revenues=total_revenues1')
-def productivity(opts, flgs,management,treatment,soilp2_map,tree_diam,tree_vol,forest_roads,main_roads):
- if tree_diam == '':
- tree_diam="99999"
- if tree_vol == '':
- tree_vol="9.999"
- if soilp2_map == '':
- soilp2_map="99999"
- dhp=opts['dhp']
- expression="slope___=if(slope__<=100,slope__,100)")
- # Calculate productivity
- #view the paper appendix for the formulas
- expression='fell_productHFtr1 = if('+management+' ==1 && ('+treatment+' ==1 || '+treatment+' ==99999) && '+tree_diam+' <99999,(cable_crane_extraction*(42-(2.6*'+tree_diam+'))/(-20))*1.65*(1-(slope___/100)), if('+management+' ==1 && ('+treatment+' ==1 || '+treatment+' ==99999) && '+tree_diam+' == 99999,(cable_crane_extraction*(42-(2.6*35))/(-20))*1.65*(1-(slope___/100))))')
- run_command("r.null", map="fell_productHFtr1", null=0)
- expression='fell_productHFtr2 = if('+management+' ==1 && '+treatment+' ==2 && '+tree_diam+' <99999,(cable_crane_extraction*(42-(2.6*'+tree_diam+'))/(-20))*1.65*(1-((1000-(90*slope___)/(-80))/100)), if('+management+' ==1 && '+treatment+' ==2 && '+tree_diam+' == 99999,(cable_crane_extraction*(42-(2.6*35))/(-20))*1.65*(1-((1000-(90*slope___)/(-80))/100))))')
- run_command("r.null", map="fell_productHFtr2", null=0)
- expression='fell_proc_productC = if('+management+' ==2 && '+soilp2_map+' <99999,((0.3-(1.1*'+soilp2_map+'))/(-4))*(1-(slope___/100)), if('+management+' ==2 && '+soilp2_map+' == 99999,((0.3-(1.1*3))/(-4))*(1-(slope___/100))))')
- run_command("r.null", map="fell_proc_productC", null=0)
###### check fell_proc_productC ######
+ #9999: default value, if is present take into the process
+ #the average value (in case of fertility is 33) Giulia is it 3?
- #9999: default value, if is present take into the process the average value (in case of fertility is 33)
+ expr = ("{proc_productHFtr1} = {mt}*{cable_crane_extraction}"
+ "*0.363*{tree_diam}^1.116")
+ r.mapcalc(expr.format(proc_productHFtr1=proc_productHFtr1,
+ mt=m1t1,
+ tree_diam="tmprgreen_%i_tree_diam" % pid),
+ overwrite=ow)
+ run_command("r.null", map=proc_productHFtr1, null=0)
+ expr = ("{out} = {mt}*{extraction}"
+ "*60/({k}*"
+ "exp(0.1480-0.3894*{st}+0.0002*({slope}^2)-0.2674*{sb})"
+ "+1.0667+0.3094/{tree_vol}-0.1846*{perc})")
+ r.mapcalc(expr.format(out=fell_proc_productHFtr1,
+ mt=m1t1,
+ extraction="forwarder_extraction",
+ k=1.5, st=2, sb=2.5,
+ tree_vol="tmprgreen_%i_tree_vol" % pid,
+ slope="tmprgreen_%i_slope" % pid,
+ perc=1),
+ overwrite=ow)
+ r.mapcalc(expr.format(out=fell_proc_productHFtr2,
+ mt=m1t2,
+ perc=0.8),
+ overwrite=ow)
+ run_command("r.null", map=fell_proc_productHFtr1, null=0)
+ run_command("r.null", map=fell_proc_productHFtr2, null=0)
+ expr = ("{chipp_prod} = {m1t1}*{yield_pix}/{num11}"
+ "+{m1t2}*{yield_pix}/{num12}"
+ "+{m2}*{yield_pix}/{num2}")
+ r.mapcalc(expr.format(chipp_prod=chipp_prod,
+ yield_pix="yield_pix1",
+ m1t1=m1t1,
+ num11=34,
+ m1t2=m1t2,
+ num12=20.1,
+ m2=m2,
+ num2=45.9
+ overwrite=ow)
+ run_command("r.null", map=chipp_prod, null=0)
+ extr_product = {}
+ extr_product[extr_product_cableHF] = [m1, 'cable_crane_extraction',
+ 149.33, extr_dist,
+ -1.3438, 0.75]
+ extr_product[extr_product_cableC] = [m2, 'cable_crane_extraction',
+ -1.3438, 0.75]
+ extr_product[extr_product_forw] = [1, 'forwarder_extraction',
+ 36.293, extr_dist,
+ -1.1791, 0.6]
+ extr_product[extr_product_other] = [1, 'other_extraction',
+ -1.1791, 0.6]
+ expr = ("{extr_product} = {m}*{extraction}"
+ "*{coef1}*({extr_dist}^{expo})* {extr_dist}/8*{coef2}")
+ for key, val in extr_product.items():
+ r.mapcalc(expr.format(extr_product=key,
+ m=val[0],
+ extraction=val[1],
+ coef1=val[2],
+ extr_dist=val[3],
+ expo=val[4],
+ coef2=val[5]),
+ overwrite=ow)
+ run_command("r.null", map=key, null=0)
- expression='proc_productHFtr1 = if('+management+' == 1 && ('+treatment+' == 1 || '+treatment+' ==99999) && '+tree_diam+'==99999, cable_crane_extraction*0.363*35^1.116, if('+management+' == 1 && ('+treatment+' == 1 || '+treatment+' ==99999) && '+tree_diam+'<99999, cable_crane_extraction*0.363*'+tree_diam+'^1.116))')
- run_command("r.null", map="proc_productHFtr1", null=0)
- expression='fell_proc_productHFtr1 = if('+management+' == 1 && ('+treatment+' == 1 || '+treatment+' ==99999) && '+tree_vol+'<9.999, forwarder_extraction*60/(1.5*(2.71^(0.1480-0.3894*2+0.0002*(slope___^2)-0.2674*2.5))+(1.0667+(0.3094/'+tree_vol+')-0.1846*1)), if('+management+' == 1 && ('+treatment+' == 1 || '+treatment+' ==99999) && '+tree_vol+'==9.999, forwarder_extraction*60/(1.5*(2.71^(0.1480-0.3894*2+0.0002*(slope___^2)-0.2674*2.5))+(1.0667+(0.3094/0.7)-0.1846*1))))')
- run_command("r.null", map="fell_proc_productHFtr1", null=0)
- expression='fell_proc_productHFtr2 = if('+management+' == 1 && '+treatment+' == 2 && '+tree_vol+'<9.999, forwarder_extraction*60/(1.5*(2.71^(0.1480-0.3894*2+0.0002*(slope___^2)-0.2674*2.5))+(1.0667+(0.3094/'+tree_vol+')-0.1846*1))*0.8, if('+management+' == 1 && '+treatment+' == 2 && '+tree_vol+'==9.999, forwarder_extraction*60/(1.5*(2.71^(0.1480-0.3894*2+0.0002*(slope___^2)-0.2674*2.5))+(1.0667+(0.3094/0.7)-0.1846*1))*0.8))')
- run_command("r.null", map="fell_proc_productHFtr2", null=0)
- expression='chipp_prodHF = if('+management+' ==1 && ('+treatment+' == 1 || '+treatment+' == 99999), yield_pix/34, if('+management+' ==1 && '+treatment+' == 2, yield_pix/20.1))')
- run_command("r.null", map="chipp_prodHF", null=0)
- expression='chipp_prodC = if('+management+' ==2, yield_pix/45.9)')
- run_command("r.null", map="chipp_prodC", null=0)
- expression='chipp_prod = chipp_prodHF + chipp_prodC')
- run_command("r.null", map="chipp_prod", null=0)
- expression='extr_product_cableHF = if('+management+' ==1, cable_crane_extraction*149.33*(extr_dist^-1.3438)* extr_dist/8*0.75)')
- run_command("r.null", map="extr_product_cableHF", null=0)
- expression='extr_product_cableC = if('+management+' ==2, cable_crane_extraction*149.33*(extr_dist^-1.3438)* extr_dist/8*0.75)')
- run_command("r.null", map="extr_product_cableC", null=0)
- expression='extr_product_forw = forwarder_extraction*36.293*(extr_dist^-1.1791)* extr_dist/8*0.6')
- run_command("r.null", map="extr_product_forw", null=0)
- expression='extr_product_other = other_extraction*36.293*(extr_dist^-1.1791)* extr_dist/8*0.6')
- run_command("r.null", map="extr_product_other", null=0)
#cost of the transport distance
#this is becouse the wood must be sell to the collection point
#instead the residual must be brung to the heating points
+ tot_roads = "tmprgreen_%i_tot_roads" % pid
- expression='tot_roads = '+forest_roads+' ||| '+main_roads)
- run_command("r.null", map="tot_roads", null=0)
- expression='tot_roads_neg = if(tot_roads==1,0,1)')
- run_command("r.null", map="tot_roads_neg", null=1)
- expression='frict_surf_tr1 = frict_surf_extr*tot_roads_neg')
- expression='frict_surf_tr = frict_surf_tr1+(tot_roads*((ewres()+nsres())/2))')
+ expression=('%s = %s ||| %s' % (tot_roads,
+ forest_roads, main_roads)))
+ run_command("r.null", map=tot_roads, null=0)
+ expr = ("{frict_surf_tr}={frict_surf_extr}*not({tot_roads})"
+ "*{tot_roads}*((ewres()+nsres())/2)")
+ r.mapcalc(expr.format(frict_surf_tr="tmprgreen_%i_frict_surf_tr" % pid,
+ frict_surf_extr='tmprgreen_%i_frict_surf_extr' % pid,
+ tot_roads=tot_roads
+ overwrite=ow)
+ transp_dist = "tmprgreen_%i_transp_dist" % pid
try:
- run_command("r.cost", overwrite=ow, input="frict_surf_tr",
- output="tot_dist", stop_points=opts['forest'], start_points=dhp,
+ tot_dist = "tmprgreen_%i_tot_dist" % pid
+ run_command("r.cost", overwrite=ow,
+ input=("tmprgreen_%i_frict_surf_tr" % pid),
+ output=tot_dist,
+ stop_points=opts['forest'],
+ start_points=dhp,
max_cost=100000)
- expression='transp_dist = tot_dist - extr_dist')
+ expression=("%s = %s - %s"
+ % (transp_dist, tot_dist, extr_dist)))
except:
- expression='transp_dist = extr_dist')
+ expression=('% = %s' % (transp_dist, extr_dist)))
- expression='transport_prod = if(('+treatment+' == 1 || '+treatment+' == 99999), ((transp_dist/1000/30)*(yield_pix*1/32)*2), if('+management+' ==1 && '+treatment+' == 2, ((transp_dist/1000/30)*(yield_pix*2.7/32)*2)))')
+ expr = ("{transport_prod} = {transp_dist}/30000"
+ "*({not2}*({yield_pix}/32)*2 +{m1t2}*({yield_pix}*2.7/32)*2)")
- #the cost of distance transport derived by the negative of the friction surface
+ r.mapcalc(expr.format(transport_prod=transport_prod,
+ not2=not2,
+ m1t2=m1t2,
+ transp_dist="tmprgreen_%i_transp_dist" % pid
+ overwrite=ow)
+ #the cost of distance transport derived by the negative of the
+ # friction surface
#the DHP must be inside the study area and connected with the road network
+ #FIXME: move the DHP on the closest road
+ return dic1, dic2
-def costs(opts, flgs):
+def costs(opts, dic1, dic2, total_revenues, yield_pix):
# Calculate costs
+ pid = os.getpid()
+ expr = "{out} = {cost}/{productivity}*{yield_pix}"
+ command = "tmprgreen_%i_prod_cost = " % pid
+ for key, val in dic1.items():
+ r.mapcalc(expr.format(out="tmprgreen_%i_cost_%s" % (pid, key),
+ cost=val,
+ productivity=key
+ overwrite=ow)
+ map=("tmprgreen_%i_cost_%s" % (pid, key)),
+ null=0)
+ command += "tmprgreen_%i_cost_%s+" % (pid, key)
+ expr = "{out} = {cost}*{productivity}"
+ for key, val in dic2.items():
+ cost=val,
+ productivity=key
+ overwrite=ow)
+ null=0)
- expression='fell_costHFtr1 = '+opts['cost_chainsaw']+'/fell_productHFtr1*yield_pix')
- run_command("r.null", map="fell_costHFtr1", null=0)
- expression='fell_costHFtr2 = '+opts['cost_chainsaw']+'/fell_productHFtr2*yield_pix')
- run_command("r.null", map="fell_costHFtr2", null=0)
- expression='fell_proc_costC = '+opts['cost_chainsaw']+'/fell_proc_productC*yield_pix')
- run_command("r.null", map="fell_proc_costC", null=0)
- expression='proc_costHFtr1 = '+opts['cost_processor']+'/proc_productHFtr1*yield_pix')
- run_command("r.null", map="proc_costHFtr1", null=0)
- expression='fell_proc_costHFtr1 = '+opts['cost_harvester']+'/fell_proc_productHFtr1*yield_pix')
- run_command("r.null", map="fell_proc_costHFtr1", null=0)
- expression='fell_proc_costHFtr2 = '+opts['cost_harvester']+'/fell_proc_productHFtr2*yield_pix')
- run_command("r.null", map="fell_proc_costHFtr2", null=0)
- expression='chipp_cost = '+opts['cost_chipping']+'*chipp_prod')
- expression='extr_cost_cableHF = '+opts['cost_cablehf']+'/extr_product_cableHF*yield_pix')
- run_command("r.null", map="extr_cost_cableHF", null=0)
- expression='extr_cost_cableC = '+opts['cost_cablec']+'/extr_product_cableC*yield_pix')
- run_command("r.null", map="extr_cost_cableC", null=0)
- expression='extr_cost_forw ='+opts['cost_forwarder']+'/extr_product_forw*yield_pix')
- run_command("r.null", map="extr_cost_forw", null=0)
- expression='extr_cost_other = '+opts['cost_skidder']+'/extr_product_other*yield_pix')
- run_command("r.null", map="extr_cost_other", null=0)
- expression='transport_cost = '+opts['cost_transport']+'*transport_prod')
- expression='prod_costs1 = fell_costHFtr1 + fell_costHFtr2+ fell_proc_costC + proc_costHFtr1 + fell_proc_costHFtr1 + fell_proc_costHFtr2 + chipp_cost + extr_cost_cableHF + extr_cost_cableC + extr_cost_forw + extr_product_other + transport_cost')
+ expression=command[:-1])
+ #FIXME: the correction about negative cost have to be done in
+ # the productivity single map in my opinion
######## patch to correct problem of negative costs #######
- run_command("r.mapcalc", overwrite=ow,expression='prod_costs = prod_costs1>=0 ? prod_costs1 : 0')
+ prod_costs = "tmprgreen_%i_prod_cost" % pid
+ expr = '{prod_costs} = {prod_costs}>=0 ? {prod_costs} : 0'
+ r.mapcalc(expr.format(prod_costs=prod_costs,
+ overwrite=ow)
######## end patch ##############
+ direction_cost = "tmprgreen_%i_direction_cost" % pid
+ administrative_cost = "tmprgreen_%i_administrative_cost" % pid
+ interests = "tmprgreen_%i_interests" % pid
- expression='direction_cost = prod_costs *0.05')
+ expression='%s = %s *0.05' % (direction_cost,
+ prod_costs))
- expression='administrative_cost = total_revenues*0.07')
+ expression=('%s = %s*0.07' % (administrative_cost,
+ total_revenues)))
- expression='interests = (prod_costs + administrative_cost)*0.03/4')
+ expression=('%s= (%s + %s)*0.03/4'
+ % (interests, prod_costs, administrative_cost)))
#management and administration costs
- # patch for solve the absence of some optional maps
- map_prodcost=grass.find_file('prod_costs',element='cell')
- map_admcost=grass.find_file('administrative_cost',element='cell')
- map_dircost=grass.find_file('direction_cost',element='cell')
- listcost=''
- if map_admcost['fullname']!='':
- listcost+=map_admcost['fullname']
- if map_dircost['fullname']!='':
- listcost+="+"+map_dircost['fullname']
- if map_prodcost['fullname']!='':
- listcost+="+"+map_prodcost['fullname']
- # end of patch
- expression='total_costs = %s' % listcost)
+ # patch for solve the absence of some optional mapss
+ map_prodcost = grass.find_file(prod_costs, element='cell')
+ map_admcost = grass.find_file(administrative_cost, element='cell')
+ map_dircost = grass.find_file(direction_cost, element='cell')
-def net_revenues(opts, flgs,management,treatment):
+ listcost = ''
+ if map_admcost['fullname'] != '':
+ listcost += map_admcost['fullname']
+ if map_dircost['fullname'] != '':
+ listcost += "+" + map_dircost['fullname']
+ if map_prodcost['fullname'] != '':
+ listcost += "+" + map_prodcost['fullname']
+ # end of patch
+ total_cost = "tmprgreen_%i_total_cost" % pid
+ expression='%s = %s' % (total_cost, listcost))
+ return total_cost
- output = opts['output_basename']
- econ_bioenergyHF=output+'_econ_bioenergyHF'
- econ_bioenergyC=output+'_econ_bioenergyC'
- econ_bioenergy=output+'_econ_bioenergy'
+def net_revenues(opts, technical_bioenergy, tech_bioC,
+ tech_bioHF, total_revenues, total_costs):
+ pid = os.getpid()
+ #TODO: I will split the outputs
+ # each maps is an output:
+ # mandatory maps: econ_bioenergy, net_revenues
+ # optional: econ_bioenergyHF, econ_bioenergyC
+ # : total_revenues, total_cost
+ econ_bioenergy = opts['econ_bioenergy']
+ econ_bioenergyC = (opts['econ_bioenergyc'] if opts['econ_bioenergyc']
+ else "tmprgreen_%i_econ_bioenergyc" % pid)
+ econ_bioenergyHF = (opts['econ_bioenergyhf'] if opts['econ_bioenergyhf']
+ else "tmprgreen_%i_econ_bioenergyhf" % pid)
+ net_revenues = opts['net_revenues']
# Calculate net revenues and economic biomass
- expression='net_revenues = total_revenues - total_costs')
+ expression='%s = %s - %s' % (net_revenues, total_revenues,
+ total_costs))
+ positive_net_revenues = "tmprgreen_%i_positive_net_revenues" % pid
- expression='positive_net_revenues = if(net_revenues<=0,0,1)')
- expression='net_rev_pos = net_revenues*positive_net_revenues')
- #per evitare che vi siano pixel con revenues>0 sparsi si riclassifica la mappa
- #in order to avoid pixel greater than 0 scattered the map must be reclassified
+ expression=('%s = if(%s<=0,0,1)' % (positive_net_revenues,
+ net_revenues)))
+ #per evitare che vi siano pixel con revenues>0 sparsi
+ #si riclassifica la mappa
+ #in order to avoid pixel greater than 0 scattered
+ #the map must be reclassified
#considering only the aree clustered greater than 1 hectares
+ economic_surface = "tmprgreen_%i_economic_surface" % pid
run_command("r.reclass.area", overwrite=ow,
- input="positive_net_revenues",
- output="economic_surface", value=1, mode="greater")
+ input=positive_net_revenues,
+ output=economic_surface, value=1, mode="greater")
- ECONHF=econ_bioenergyHF+' = economic_surface*(if('+management+' == 1 && '+treatment+'==1 || '+management+' == 1 && '+treatment+'== 99999,yield_pix*'+opts['energy_tops_hf']+', if('+management+' == 1 && '+treatment+'==2, yield_pix*'+opts['energy_tops_hf']+'+yield_pix*'+opts['energy_cormometric_vol_hf']+')))'
- ECONC=econ_bioenergyC+'= economic_surface*(if('+management+' == 2, yield_pix*'+opts['energy_tops_cop']+'))'
- ECONTOT=econ_bioenergy+' = ('+econ_bioenergyHF+' + '+econ_bioenergyC+')'
+ expr = "{econ_bioenergy} = {economic_surface}*{tech_bio}"
+ r.mapcalc(expr.format(econ_bioenergy=econ_bioenergyHF,
+ economic_surface=economic_surface,
+ tech_bio=tech_bioHF
+ overwrite=ow)
+ r.mapcalc(expr.format(econ_bioenergy=econ_bioenergyC,
+ economic_surface="economic_surface",
+ tech_bio=tech_bioC
+ overwrite=ow)
+ econtot = ("%s = %s + %s" % (econ_bioenergy, econ_bioenergyC,
+ econ_bioenergyHF))
+ run_command("r.mapcalc", overwrite=ow, expression=econtot)
- run_command("r.mapcalc", overwrite=ow, expression=ECONHF)
+def sel_columns(element):
+ if len(element) > 0:
+ return (element[:13] == 'forest_column')
+ return False
- run_command("r.mapcalc", overwrite=ow, expression=ECONC)
- run_command("r.mapcalc", overwrite=ow, expression=ECONTOT)
def main(opts, flgs):
+ pid = os.getpid()
+ pat = "tmprgreen_%i_*" % pid
+ DEBUG = False
+ #FIXME: debug from flag
+ atexit.register(cleanup,
+ pattern=pat,
+ debug=DEBUG)
+ forest = opts['forest']
+ forest_roads = opts['forest_roads']
+ main_roads = opts['main_roads']
- forest=opts['forest']
- boundaries=opts['boundaries']
- yield_=opts['forest_column_yield']
- management=opts['forest_column_management']
- treatment=opts['forest_column_treatment']
- yield_surface=opts['forest_column_yield_surface']
- roughness=opts['forest_column_roughness']
- forest_roads=opts['forest_roads']
- main_roads=opts['main_roads']
- rivers=opts['rivers']
- lakes=opts['lakes']
- tree_diam=opts['tree_diam']
- tree_vol=opts['tree_vol']
- soilp2_map=opts['soilp2_map']
######## start import and convert ########
- run_command("g.region",vect=boundaries)
- run_command("v.to.rast", input=forest,output="yield", use="attr", attrcolumn=yield_,overwrite=True)
- run_command("v.to.rast", input=forest,output="yield_surface", use="attr", attrcolumn=yield_surface,overwrite=True)
- run_command("v.to.rast", input=forest,output="treatment", use="attr", attrcolumn=treatment,overwrite=True)
- run_command("v.to.rast", input=forest,output="management", use="attr", attrcolumn=management,overwrite=True)
+ for key in filter(sel_columns, opts.keys()):
+ try:
+ input=forest,
+ output=('tmprgreen_%i_%s' % (pid, key[14:])),
+ use="attr",
+ attrcolumn=opts[key], overwrite=True)
+ run_command("r.null", map=('tmprgreen_%i_%s' % (pid, key[14:])),
+ null=0)
+ except Exception:
+ warning('no column %s selectd, values set to 0' % key)
+ expression=('%s=0' % 'tmprgreen_%i_%s'
+ % (pid, key[14:])))
- run_command("v.to.rast", input=forest_roads,output="forest_roads", use="val", overwrite=True)
- run_command("v.to.rast", input=main_roads,output="main_roads", use="val", overwrite=True)
- run_command("r.null", map='yield',null=0)
- run_command("r.null", map='yield_surface',null=0)
- run_command("r.null", map='treatment',null=0)
- run_command("r.null", map='management',null=0)
+ run_command("v.to.rast", input=forest_roads,
+ output=('tmprgreen_%i_forest_roads' % pid),
+ use="val", overwrite=True)
+ run_command("v.to.rast", input=main_roads,
+ output=('tmprgreen_%i_main_roads' % pid),
+# FIXME: yiel surface can be computed by the code, plan surface or real?
+# FIXME: this map can be create here
+ yield_pix = 'tmprgreen_%i_yield_pix' % pid
+ expr = ("{pix} = {yield_}/{yield_surface}*"
+ "((ewres()*nsres())/10000)")
+ r.mapcalc(expr.format(pix=yield_pix,
+ yield_=('tmprgreen_%i_yield' % pid),
+ yield_surface='tmprgreen_%i_yield_surface' % pid),
+ overwrite=True)
+ # TODO: add r.null
######## end import and convert ########
+ dic = {'tree_diam': 35, 'tree_vol': 3, 'soilp2_map': 0.7}
+ for key, val in dic.items():
+ if not(opts[key]):
+ warning("Not %s map, value set to %f" % (key, val))
+ output = 'tmprgreen_%i_%s' % (pid, key)
+ expression=('%s=%f' % (output, val)))
+ # create combination maps to avoid if construction
+ m1t1, m1t2, m1, m2, not2 = conmbination(management=
+ ('tmprgreen_%i_management' % pid),
+ treatment=('tmprgreen_%i_treatment'
+ % pid))
+ slope_computation(opts)
- ######## temp patch to link map and fields ######
- management="management"
- treatment="treatment"
- yield_surface="yield_surface"
- yield_="yield"
- forest_roads="forest_roads"
- main_roads="main_roads"
- ######## end temp patch to link map and fields ######
- if roughness=='':
- run_command("r.mapcalc",overwrite=ow,expression='roughness=0')
- roughness='roughness'
+ if (opts['technical_bioenergy'] and opts['tech_bioc']
+ and opts['tech_biohf']):
+ technical_bioenergy = opts['technical_bioenergy']
+ tech_bioC = opts['tech_bioc']
+ tech_bioHF = opts['tech_biohf']
+ technical_surface = 'tmprgreen_%i_technical_surface' % pid
+ expr = "{technical_surface} = if({technical_bioenergy}, 1, 0)"
+ r.mapcalc(expr.format(technical_surface=technical_surface,
+ overwrite=ow)
else:
- run_command("v.to.rast", input=forest,output="roughness", use="attr", attrcolumn=roughness,overwrite=True)
- run_command("r.null", map='roughness',null=0)
+ out = yield_pix_process(opts=opts, vector_forest=forest,
+ yield_surface=('tmprgreen_%i_yield_surface' % pid),
+ rivers=opts['rivers'],
+ lakes=opts['lakes'],
+ forest_roads=('tmprgreen_%i_forest_roads' % pid),
+ m1t1=m1t1, m1t2=m1t2, m1=m1, m2=m2,
+ roughness=('tmprgreen_%i_roughness' % pid))
+ technical_bioenergy, tech_bioC, tech_bioHF = out
- if tree_diam=='':
- run_command("r.mapcalc",overwrite=ow,expression='tree_diam=99999')
- tree_diam='tree_diam'
+ total_revenues = revenues(opts=opts,
+ % pid),
+ forest=forest,
+ technical_bioenergy=technical_bioenergy)
- if tree_vol=='':
- run_command("r.mapcalc",overwrite=ow,expression='tree_vol=9.999')
- tree_diam='tree_vol'
+ dic1, dic2 = productivity(opts=opts,
+ m1t1=m1t1, m1t2=m1t2, m1=m1, m2=m2, not2=not2,
+ soilp2_map=('tmprgreen_%i_soilp2_map' % pid),
+ tree_diam=('tmprgreen_%i_tree_diam' % pid),
+ tree_vol=('tmprgreen_%i_tree_vol' % pid),
+ main_roads=('tmprgreen_%i_main_roads' % pid))
+ total_costs = costs(opts, total_revenues=total_revenues,
+ dic1=dic1, dic2=dic2, yield_pix="yield_pix1")
+ net_revenues(opts=opts,
+ total_revenues=total_revenues,
+ tech_bioC=tech_bioC, tech_bioHF=tech_bioHF,
+ total_costs=total_costs)
- if soilp2_map=='':
- run_command("r.mapcalc",overwrite=ow,expression='soil_map=99999')
- soilp2_map='soil_map'
+#TODO: create a function based on r.univar or delete it
+# with RasterRow(econ_bioenergy) as pT:
+# T = np.array(pT)
+# print "Resulted maps: "+output+"_econ_bioenergyHF, "+output+"_econ_bioenergyC, "+output+"_econ_bioenergy"
+# print ("Total bioenergy stimated (Mwh): %.2f" % np.nansum(T))
- yield_pix_process(opts,flgs,forest,yield_,yield_surface,rivers,lakes,forest_roads,management,treatment,roughness)
- revenues(opts, flgs,yield_surface,management,treatment,forest,yield_)
- productivity(opts, flgs,management,treatment,soilp2_map,tree_diam,tree_vol,forest_roads,main_roads)
- costs(opts, flgs)
- net_revenues(opts, flgs,management,treatment)
- if flgs['r'] == True:
- remove_map(opts, flgs)
- with RasterRow(econ_bioenergy) as pT:
- T = np.array(pT)
- print "Resulted maps: "+output+"_econ_bioenergyHF, "+output+"_econ_bioenergyC, "+output+"_econ_bioenergy"
- print ("Total bioenergy stimated (Mwh): %.2f" % np.nansum(T))
if __name__ == "__main__":
main(*parser())
