[GRASS-SVN] r67878 - grass/trunk/temporal/t.connect/testsuite
svn_grass at osgeo.org
Thu Feb 18 02:40:27 PST 2016
Author: lucadelu
Date: 2016-02-18 02:40:26 -0800 (Thu, 18 Feb 2016)
New Revision: 67878
grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
testsuite: added tests for t.list, t.rast.list, t.vect.list, t.raster3d.list with output parameter
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py 2016-02-18 10:33:00 UTC (rev 67877)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py 2016-02-18 10:40:26 UTC (rev 67878)
@@ -18,6 +18,7 @@
class TestRasterExtraction(TestCase):
mapsets_to_remove = []
+ outfile = 'rastlist.txt'
@classmethod
def setUpClass(cls):
@@ -78,6 +79,20 @@
for a, b in zip(list_string.split("\n"), out.split("\n")):
self.assertEqual(a.strip(), b.strip())
+ t_list = SimpleModule(
+ "t.list", quiet=True,
+ columns=["name", "mapset,start_time", "end_time", "number_of_maps"],
+ type="strds", where='name = "A"', output=self.outfile)
+ self.assertModule(t_list)
+ self.assertFileExists(self.outfile)
+ with open(self.outfile, 'r') as f:
+ read_data = f.read()
+ for a, b in zip(list_string.split("\n"), read_data.split("\n")):
+ self.assertEqual(a.strip(), b.strip())
+ #self.assertLooksLike(reference=read_data, actual=list_string)
+ if os.path.isfile(self.outfile):
+ os.remove(self.outfile)
def test_trast_list(self):
self.runModule("g.mapset", mapset="test1")
@@ -146,6 +161,17 @@
+ trast_list = SimpleModule("t.rast.list", quiet=True, flags="s",
+ input="A at test5", output=self.outfile)
+ self.assertModule(trast_list)
def test_strds_info(self):
self.runModule("g.mapset", mapset="test4")
tinfo_string = """id=A at test1
@@ -265,9 +291,8 @@
info = SimpleModule(
"t.info", flags="g", type="raster", input="a1 at test5")
- self.assertModuleKeyValue(
- module=info, reference=tinfo_string, precision=2, sep="=")
if __name__ == '__main__':
from grass.gunittest.main import test
test()
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py 2016-02-18 10:33:00 UTC (rev 67877)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py 2016-02-18 10:40:26 UTC (rev 67878)
@@ -17,6 +17,7 @@
class testRaster3dExtraction(TestCase):
+ outfile = 'rast3dlist.txt'
@classmethod
@@ -77,6 +78,20 @@
+ type="str3ds", where='name = "A"', output=self.outfile)
self.runModule("g.mapset", mapset="test3d1")
@@ -97,8 +112,6 @@
a2|test3d2|2001-03-01 00:00:00|2001-05-01 00:00:00
a3|test3d2|2001-05-01 00:00:00|2001-07-01 00:00:00"""
- entries = list_string.split("\n")
"t.rast3d.list", quiet=True, flags="s", input="A at test3d2")
@@ -112,8 +125,6 @@
a2|test3d3|2001-04-01 00:00:00|2001-07-01 00:00:00
a3|test3d3|2001-07-01 00:00:00|2001-10-01 00:00:00"""
"t.rast3d.list", quiet=True, flags="s", input="A at test3d3")
@@ -136,6 +147,17 @@
+ trast_list = SimpleModule("t.rast3d.list", quiet=True, flags="s",
+ input="A at test3d4", output=self.outfile)
self.runModule("g.mapset", mapset="test3d4")
tinfo_string = """id=A at test3d1
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py 2016-02-18 10:33:00 UTC (rev 67877)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py 2016-02-18 10:40:26 UTC (rev 67878)
@@ -17,6 +17,7 @@
+ outfile = 'vectlist.txt'
@classmethod
@@ -76,6 +77,20 @@
+ type="stvds", where='name = "A"', output=self.outfile)
def test_tvect_list(self):
self.runModule("g.mapset", mapset="testvect1")
@@ -139,6 +154,18 @@
+ trast_list = SimpleModule("t.vect.list", quiet=True, flags="s",
+ columns=["name", "mapset", "start_time", "end_time"],
+ input="A at testvect4", output=self.outfile)
def test_stvds_info(self):
self.runModule("g.mapset", mapset="testvect4")
tinfo_string = """id=A at testvect1
