[GRASS-SVN] r67918 - grass/trunk/vector/v.to.rast
svn_grass at osgeo.org
Mon Feb 22 01:20:45 PST 2016
Author: mmetz
Date: 2016-02-22 01:20:45 -0800 (Mon, 22 Feb 2016)
New Revision: 67918
grass/trunk/vector/v.to.rast/do_areas.c
grass/trunk/vector/v.to.rast/main.c
grass/trunk/vector/v.to.rast/v.to.rast.html
grass/trunk/vector/v.to.rast/vect2rast.c
v.to.rast: fix #2239
Modified: grass/trunk/vector/v.to.rast/do_areas.c
--- grass/trunk/vector/v.to.rast/do_areas.c 2016-02-21 11:05:12 UTC (rev 67917)
+++ grass/trunk/vector/v.to.rast/do_areas.c 2016-02-22 09:20:45 UTC (rev 67918)
@@ -80,7 +80,8 @@
return -1;
- G_plot_polygon(Points->x, Points->y, Points->n_points);
+ if (G_plot_polygon(Points->x, Points->y, Points->n_points) != 0)
+ G_warning(_("Failed to plot polygon"));
G_percent(1, 1, 1);
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c 2016-02-21 11:05:12 UTC (rev 67917)
+++ grass/trunk/vector/v.to.rast/main.c 2016-02-22 09:20:45 UTC (rev 67918)
@@ -52,7 +52,7 @@
field_opt = G_define_standard_option(G_OPT_V_FIELD);
type_opt = G_define_standard_option(G_OPT_V_TYPE);
- type_opt->options = "point,line,area";
+ type_opt->options = "point,line,boundary,area";
type_opt->answer = "point,line,area";
type_opt->guisection = _("Selection");
Modified: grass/trunk/vector/v.to.rast/v.to.rast.html
--- grass/trunk/vector/v.to.rast/v.to.rast.html 2016-02-21 11:05:12 UTC (rev 67917)
+++ grass/trunk/vector/v.to.rast/v.to.rast.html 2016-02-22 09:20:45 UTC (rev 67918)
@@ -1,12 +1,18 @@
<h2>DESCRIPTION</h2>
<em>v.to.rast</em> transforms GRASS vector map layers into GRASS raster map
-layer format. Optionally, attributes can be converted into raster category
+layer format. Optionally, attributes can be converted to raster category
labels.
<h2>NOTES</h2>
+In order to avoid unexpected results, the type of vector features
+should always be specified. The default is to convert all vector
+features, but if only e.g. areas should be converted use
+<em>type=area</em> rather than <em>type=point,line,area</em>.
+<p>
<em>v.to.rast</em> will only affect data in areas lying
inside the boundaries of the current geographic region.
A grid cell belongs to the area where the grid cell center falls into.
@@ -55,8 +61,13 @@
<p><p><b>Flow directions</b> are given in degrees counterclockwise from east.
<p><p>Raster category labels are supported for all of <em>use=</em> except <em>use=z</em>.
<p>
-The <b>-d</b> flag applies only to lines, the default is only those on the
-render path (thin line).
+The <b>-d</b> flag applies only to lines and boundaries, the default is
+to set only those cells on the render path (thin line).
+<p>
+Boundaries (usually without categories) can be rasterized with
+<div class="code"><pre>
+v.to.rast type=boundary layer=-1 use=val
+</pre></div>
<h2>EXAMPLES</h2>
@@ -72,7 +83,7 @@
</pre></div>
-v.to.rast input=vect_map output=raster_map attribute_column=SPEED
+v.to.rast input=vect_map output=raster_map attribute_column=SPEED type=line
</pre></div>
<h3>Calculate stream directions from a river vector map (Spearfish)</h3>
Modified: grass/trunk/vector/v.to.rast/vect2rast.c
--- grass/trunk/vector/v.to.rast/vect2rast.c 2016-02-21 11:05:12 UTC (rev 67917)
+++ grass/trunk/vector/v.to.rast/vect2rast.c 2016-02-22 09:20:45 UTC (rev 67918)
@@ -133,8 +133,13 @@
G_debug(1, "%d areas sorted", nareas);
+ if (nareas > 0 && dense) {
+ G_warning(_("Area conversion and line densification are mutually exclusive, disabling line densification."));
+ dense = 0;
- nlines = 1;
+ nlines = Vect_get_num_primitives(&Map, ftype);
+ nplines_all = nlines;
npasses = begin_rasterization(cache_mb, format, dense);
pass = 0;
@@ -227,7 +232,7 @@
* actual number of lines, currently unknown:
* number of lines are within cat constraint
* and overlap with current region */
- if (nplines_all > 0)
+ if (nlines > 0 && nplines_all > 0)
G_message(_("Converted points/lines: %d of %d"), nlines, nplines_all);
#endif
