[GRASS-SVN] r67934 - grass-addons/grass7/raster/r.green/r.green.install
svn_grass at osgeo.org
Wed Feb 24 01:35:56 PST 2016
Author: zarch
Date: 2016-02-24 01:35:56 -0800 (Wed, 24 Feb 2016)
New Revision: 67934
grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
r.green: fix automagic installation of scipy and numexpr libraries for windows platforms
Modified: grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
--- grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py 2016-02-24 09:25:09 UTC (rev 67933)
+++ grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py 2016-02-24 09:35:56 UTC (rev 67934)
@@ -32,9 +32,11 @@
from __future__ import print_function
import os
from os.path import join
+from urllib2 import build_opener
import sys
import imp
-import tempfile
+from tempfile import gettempdir
+import time
import subprocess
import shutil
@@ -59,6 +61,8 @@
CHECK_RGREENLIB = [('libgreen', '..'),
('libhydro', os.path.join('..', 'r.green.hydro'))]
+UAGENT = ('Mozilla/5.0 (Windows NT 6.3; WOW64; rv:44.0) '
+ 'Gecko/20100101 Firefox/44.0')
PATHSYSXML = []
PATHLOCXML = []
@@ -159,9 +163,23 @@
return decorator
+def get_vals(string):
+ """Extract values to decript url from a string
+ >>> string = ('javascript:dl([105,121,76,112,51,111,45,50,108,99,104,'
+ ... '101,116,46,122,110,87,47,114,55,73,52,119,67,48,69,72]'
+ ... ', "BD at C>2IJAG1<:5?6H=74=E6937C6?5?;6F0?47=F:8")')
+ >>> get_vals(string)
+ ([105,121,76,112,51,111,45,50,108,99,104,101,116,46,122,110,87,47,114,55,73,52,119,67,48,69,72],
+ 'BD at C>2IJAG1<:5?6H=74=E6937C6?5?;6F0?47=F:8')
+ nums, chars = string[string.find('(')+1:string.find(')')].split(', ')
+ return [int(n) for n in nums[1:-1].split(',')], chars.strip('"')
class PkgHTMLParser(HTMLParser):
"""Extract all the <li> ... </li> elements from a webpage"""
- tag = 'li'
+ tag = 'a'
values = []
value = None
packages = {}
@@ -176,10 +194,16 @@
if self.value is not None and len(self.value['data']) > 1:
pname = ''.join(self.value['data'])
pkey = pname.split('-')[0]
- plist = self.packages.get(pkey, [])
- plist.append(pname)
- self.values.append(self.value)
- self.packages[pkey] = plist
+ pdict = self.packages.get(pkey, {})
+ dval = dict(self.value['attrs'])
+ # save only if onclick is in the attrs
+ if 'onclick' in dval:
+ nums, chars = get_vals(dval['onclick'])
+ self.value['url'] = get_decripted_url(nums, chars)
+ pdict[pname] = self.value['url']
+ self.values.append(self.value)
+ self.packages[pkey] = pdict
self.value = None
@value_not_none
@@ -217,6 +241,145 @@
join(os.getenv('HOME'), '.grass%d' % 7))
+def download(url, filepath, overwrite=False):
+ """Download a pkg from URLWHL"""
+ if os.path.exists(filepath):
+ print('The file: %s already exist!' % filepath)
+ if overwrite:
+ print('Removing previous downloaded version')
+ os.remove(filepath)
+ else:
+ return filepath
+ print('Downloading from:', url)
+ print('Saving to:', filepath)
+ opener = build_opener()
+ opener.addheaders = [('User-agent', UAGENT)]
+ response = opener.open(url)
+ with open(filepath, mode='wb') as fpath:
+ fpath.write(response.read())
+ print('Done!')
+ return filepath
+def get_decripted_url(nums, chars):
+ """Return the decripted url
+ Example
+ >>> nums = [50, 99, 108, 117, 101, 106, 51, 109, 45, 121, 103,
+ ... 113, 114, 47, 110, 56, 116, 55, 115, 46, 112, 111,
+ ... 105, 119, 104]
+ >>> chars = ("@3:9<H;E=BF7D245BE>86C?C081D"
+ ... "0A81D0A78GF>60CGH2")
+ >>> get_decripted_url(nums, chars)
+ "tugyrhqo/simplejson-3.8.2-cp27-cp27m-win32.whl"
+ Javascript code
+ function dl(ml,mi){
+ mi=mi.replace('<','<');
+ mi=mi.replace('>','>');
+ mi=mi.replace('&','&')
+ setTimeout(function(){dl1(ml,mi)},1500);
+ function dl1(ml,mi){
+ var ot="";
+ for(var j=0;j<mi.length;j++)
+ ot+=String.fromCharCode(ml[mi.charCodeAt(j)-48]);
+ location.href=ot;
+ javascript:dl([99,113,118,117,116,52,51,121,46,103,114,
+ 119,110,97,105,45,47,101,108,49,112,109,111,104,50],
+ "4397:G1F at D7E2D=H?H858C?0D65?<F<A?;><6H8;GB")
+ def transform(chars):
+ chars = chars.replace('<', '<')
+ chars = chars.replace('>', '>')
+ return chars.replace('&', '&')
+ return ''.join([chr(nums[ord(c)-48]) for c in transform(chars)])
+def get_url(lib, _parser=[None, ]):
+ """Return the complete url to download the wheel file for windows"""
+ urlwin = 'http://www.lfd.uci.edu/~gohlke/pythonlibs/'
+ def match():
+ """Match platform with available wheel files on the web page"""
+ pkgs = sorted(parser.packages[lib].keys())
+ cppy = 'cp%d%d' % (sys.version_info.major, sys.version_info.minor)
+ pltf = ('win_amd64.whl'
+ if platform.architecture()[0] == '64bit' else 'win32.whl')
+ result = None
+ for pki in pkgs[::-1]:
+ pkk = Pkg(*pki.split('-'))
+ if pkk.py == cppy and pkk.platform == pltf:
+ result = pki
+ break
+ if result is None:
+ print('=> Library not found for your system', cppy, pltf[:-4])
+ sys.exit(1)
+ return result, parser.packages[lib][result]
+ # check the cache
+ if _parser[0] is None:
+ # read and parse the HTML page
+ response = opener.open(urlwin)
+ parser = PkgHTMLParser()
+ parser.feed(response.read())
+ # save the instance to the cache
+ _parser[0] = parser
+ else:
+ # load the instance from the cache
+ parser = _parser[0]
+ if lib not in parser.packages:
+ print(lib, 'not in the package list:')
+ from pprint import pprint
+ pprint(sorted(parser.packages))
+ sys.exit(1)
+ pkg, pkgurl = match()
+ return (urlwin + pkgurl, pkg)
+def get_pip_win_env():
+ """Add pip path to the windows environmental variable"""
+ os_pth = os.__file__.split(os.path.sep)
+ script_pth = os.path.join(*(os_pth[:-2] + ['Scripts', ]))
+ if not os.path.exists(script_pth):
+ msg = "The directory containing python scripts does not exist!"
+ raise Exception(msg)
+ env = os.environ.copy()
+ path = env['PATH'].split(';')
+ if script_pth not in path:
+ path.append(script_pth)
+ env['PATH'] = ';'.join(path)
+ return env
+def pip_install(whl, *pipargs):
+ """Install a whl using pip"""
+ cmd = ['pip', 'install', whl]
+ cmd.extend(pipargs)
+ popen_pip = subprocess.Popen(cmd, shell=True, env=get_pip_win_env())
+ if popen_pip.wait():
+ print(('Something went wrong during the installation, '
+ 'of {whl} please fix this '
+ 'manually. Running: ').format(whl=whl))
+ print(' '.join(cmd))
+ sys.exit(1)
def check_install_pip(install=False):
"""Check if pip is available"""
# run pip and check return code
@@ -227,11 +390,8 @@
if install:
print('Downloading pip')
# download get_pip.py
- response = urllib2.urlopen('https://bootstrap.pypa.io/get-pip.py')
- dst = os.path.join(tempfile.gettempdir(), 'get_pip.py')
- with open(dst, mode='w') as getpip:
- getpip.write(response.read())
+ dst = download('https://bootstrap.pypa.io/get-pip.py',
+ os.path.join(gettempdir(), 'get_pip.py'))
# install pip
print('Installing pip')
popen_py = subprocess.Popen([sys.executable, dst])
@@ -242,105 +402,26 @@
print('pip is available on the sys path')
-def fix_missing_libraries(install=False):
- """Check if the external libraries used by r.green are
- available in the current path."""
+def win_install(libs):
+ """Download and install missing libraries under windows"""
+ dlibs = {lib: get_url(lib) for lib in libs}
+ msg = "- {lib}: {pkg}\n from: {urlwhl}"
+ print("Downloading:")
+ for lib in libs:
+ print(msg.format(lib=lib, urlwhl=dlibs[lib][0], pkg=dlibs[lib][1]))
- urlwin = 'http://www.lfd.uci.edu/~gohlke/pythonlibs'
- urlwhl = 'http://www.lfd.uci.edu/~gohlke/pythonlibs/bofhrmxk/'
+ for lib in libs:
+ urlwhl, pkg = dlibs[lib]
+ # download wheel file
+ whlpath = download(urlwhl, os.path.join(gettempdir(), pkg))
+ pip_install(whlpath, '--user', '--upgrade')
- def get_url(lib, _parser=[None, ]):
- """Return the complete url to download the wheel file for windows"""
+ print("\n\nMissiging libreries %s installed!\n" % ', '.join(libs))
- def match():
- """Match platform with available wheel files on the web page"""
- pkgs = parser.packages[lib]
- cppy = 'cp%d%d' % (sys.version_info.major, sys.version_info.minor)
- pltf = ('win_amd64.whl'
- if platform.architecture()[0] == '64bit' else 'win32.whl')
- result = None
- for pki in pkgs[::-1]:
- pkk = Pkg(*pki.split('-'))
- if pkk.py == cppy and pkk.platform == pltf:
- result = pki
- break
- if result is None:
- print('=> Library not found for your system', cppy, pltf[:-4])
- sys.exit(1)
- return result
- # check the cache
- if _parser[0] is None:
- # read and parse the HTML page
- response = urllib2.urlopen(urlwin)
- parser = PkgHTMLParser()
- parser.feed(response.read())
- # save the instance to the cache
- _parser[0] = parser
- else:
- # load the instance from the cache
- parser = _parser[0]
- if lib not in parser.packages:
- print(lib, 'not in the package list:')
- from pprint import pprint
- pprint(sorted(parser.packages))
- sys.exit(1)
- pkg = match()
- return (urlwhl + pkg, pkg)
- def win_install(libs):
- """Download and install missing libraries under windows"""
- def get_user_input():
- """Ask what to do to the user"""
- key = raw_input("press ENTER to continue or q to exit.\n")
- if key in ('', 'q'):
- return key
- else:
- print("{key} is not supported!\n".format(key=key))
- return get_user_input()
- def pip_install(whl, *pipargs):
- """Install a whl using pip"""
- cmd = ['pip', 'install', whl]
- cmd.extend(pipargs)
- popen_pip = subprocess.Popen(cmd, shell=True)
- if popen_pip.wait():
- print(('Something went wrong during the installation, '
- 'of {whl} please fix this '
- 'manually. Running: ').format(whl=whl))
- print(' '.join(cmd))
- sys.exit(1)
- # dst = os.path.join(tempfile.gettempdir(), pkg)
- dst = os.environ['GISBASE']
- print("Please download:")
- dlibs = {lib: get_url(lib) for lib in libs}
- get_url('numpy')
- msg = """- {lib}: {pkg}
- for lib in dlibs:
- print(msg.format(lib=lib, urlwhl=dlibs[lib][1], pkg=dlibs[lib][0]))
- print(('\nDownload the aforementioned files with your browser'
- ' and save them in the following directory:\n '
- '{dst}\n').format(dst=dst))
- print("\nOnce you have done ", end='')
- key = get_user_input()
- if key == 'q':
- sys.exit()
- for lib in libs:
- whlpath = join(dst, dlibs[lib][1])
- if not os.path.exists(whlpath):
- print("Wheel file: {whl} not found! Exit.".format(whl=whlpath))
- sys.exit(1)
- pip_install(whlpath, '--user', '--upgrade')
+def fix_missing_libraries(install=False):
+ """Check if the external libraries used by r.green are
+ available in the current path."""
to_be_installed = []
for lib in CHECK_LIBRARIES:
try:
@@ -357,7 +438,7 @@
if install:
if 'win' in sys.platform:
# download precompiled wheel and install them
- print('Download the wheel file manually for your platform from:')
+ print('Download the wheel file for your platform from:')
# add numpy+mkl
to_be_installed.insert(0, 'numpy')
win_install(to_be_installed)
