[GRASS-SVN] r67937 - grass/branches/releasebranch_7_0/raster/r.in.xyz
Wed Feb 24 05:28:01 PST 2016
Author: mmetz
Date: 2016-02-24 05:28:01 -0800 (Wed, 24 Feb 2016)
New Revision: 67937
   grass/branches/releasebranch_7_0/raster/r.in.xyz/main.c
   grass/branches/releasebranch_7_0/raster/r.in.xyz/r.in.xyz.html
r.in.xyz: fix scan box calculation for percent < 100
Modified: grass/branches/releasebranch_7_0/raster/r.in.xyz/main.c
--- grass/branches/releasebranch_7_0/raster/r.in.xyz/main.c	2016-02-24 13:04:45 UTC (rev 67936)
+++ grass/branches/releasebranch_7_0/raster/r.in.xyz/main.c	2016-02-24 13:28:01 UTC (rev 67937)
@@ -116,7 +116,7 @@
 	*index_array;
     void *raster_row, *ptr;
     struct Cell_head region;
-    int rows, cols;		/* scan box size */
+    int rows, last_rows, row0, cols;		/* scan box size */
     int row, col;		/* counters */
     int pass, npasses;
@@ -124,7 +124,6 @@
     double x, y, z;
     char **tokens;
     int ntokens;		/* number of tokens */
-    double pass_north, pass_south;
     int arr_row, arr_col;
     unsigned long count, count_total;
@@ -476,7 +475,17 @@
     G_get_window(&region);
-    rows = (int)(region.rows * (percent / 100.0));
+    rows = last_rows = region.rows;
+    npasses = 1;
+    if (percent < 100) {
+	rows = (int)(region.rows * (percent / 100.0));
+	npasses = region.rows / rows;
+	last_rows = region.rows - npasses * rows;
+	if (last_rows)
+	    npasses++;
+	else
+	    last_rows = rows;
     cols = region.cols;
     G_debug(2, "region.n=%f  region.s=%f  region.ns_res=%f", region.north,
@@ -484,8 +493,6 @@
     G_debug(2, "region.rows=%d  [box_rows=%d]  region.cols=%d", region.rows,
 	    rows, region.cols);
-    npasses = (int)ceil(1.0 * region.rows / rows);
     if (!scan_flag->answer) {
 	/* check if rows * (cols + 1) go into a size_t */
 	if (sizeof(size_t) < 8) {
@@ -614,15 +621,13 @@
 	/* figure out segmentation */
-	pass_north = region.north - (pass - 1) * rows * region.ns_res;
-	if (pass == npasses)
-	    rows = region.rows - (pass - 1) * rows;
-	pass_south = pass_north - rows * region.ns_res;
+	row0 = (pass - 1) * rows;
+	if (pass == npasses) {
+	    rows = last_rows;
-	G_debug(2, "pass=%d/%d  pass_n=%f  pass_s=%f  rows=%d",
-		pass, npasses, pass_north, pass_south, rows);
+	G_debug(2, "pass=%d/%d  rows=%d", pass, npasses, rows);
 	if (bin_n) {
 	    G_debug(2, "allocating n_array");
 	    n_array = G_calloc((size_t)rows * (cols + 1), Rast_cell_size(CELL_TYPE));
@@ -704,17 +709,28 @@
 	    if (1 != sscanf(tokens[ycol - 1], "%lf", &y))
 		G_fatal_error(_("Bad y-coordinate line %lu column %d. <%s>"),
 			      line, ycol, tokens[ycol - 1]);
-	    if (y <= pass_south || y > pass_north) {
+	    if (y <= region.south || y > region.north) {
 		G_free_tokens(tokens);
 		continue;
 	    if (1 != sscanf(tokens[xcol - 1], "%lf", &x))
 		G_fatal_error(_("Bad x-coordinate line %lu column %d. <%s>"),
 			      line, xcol, tokens[xcol - 1]);
-	    if (x < region.west || x > region.east) {
+	    if (x < region.west || x >= region.east) {
 		continue;
+	    /* find the bin in the current array box */
+	    arr_row = (int)((region.north - y) / region.ns_res) - row0;
+	    if (arr_row < 0 || arr_row >= rows) {
+		G_free_tokens(tokens);
+		continue;
+	    arr_col = (int)((x - region.west) / region.ew_res);
+	    /* G_debug(5, "arr_row: %d   arr_col: %d", arr_row, arr_col); */
 	    if (1 != sscanf(tokens[zcol - 1], "%lf", &z))
 		G_fatal_error(_("Bad z-coordinate line %lu column %d. <%s>"),
 			      line, zcol, tokens[zcol - 1]);
@@ -746,33 +762,6 @@
 	    /* G_debug(5, "x: %f, y: %f, z: %f", x, y, z); */
-	    /* find the bin in the current array box */
-	    arr_row = (int)((pass_north - y) / region.ns_res);
-	    arr_col = (int)((x - region.west) / region.ew_res);
-	    /* G_debug(5, "arr_row: %d   arr_col: %d", arr_row, arr_col); */
-	    /* The range should be [0,cols-1]. We use (int) to round down,
-	       but if the point exactly on eastern edge arr_col will be /just/
-	       on the max edge .0000000 and end up on the next row.
-	       We could make above bounds check "if(x>=region.east) continue;"
-	       But instead we go to all sorts of trouble so that not one single
-	       data point is lost. GE is too small to catch them all.
-	       We don't try to make y happy as percent segmenting will make some
-	       points happen twice that way; so instead we use the y<= test above.
-	    if (arr_col >= cols) {
-		if (((x - region.west) / region.ew_res) - cols <
-		    10 * GRASS_EPSILON)
-		    arr_col--;
-		else {		/* oh well, we tried. */
-		    G_debug(3,
-			    "skipping extraneous data point [%.3f], column %d of %d",
-			    x, arr_col, cols);
-		    continue;
 	    if (bin_n)
 		update_n(n_array, cols, arr_row, arr_col);
 	    if (bin_min)
Modified: grass/branches/releasebranch_7_0/raster/r.in.xyz/r.in.xyz.html
--- grass/branches/releasebranch_7_0/raster/r.in.xyz/r.in.xyz.html	2016-02-24 13:04:45 UTC (rev 67936)
+++ grass/branches/releasebranch_7_0/raster/r.in.xyz/r.in.xyz.html	2016-02-24 13:28:01 UTC (rev 67937)
@@ -260,15 +260,6 @@
 <h2>KNOWN ISSUES</h2>
 <ul>
-<li> <em>n</em> map sum can be ever-so-slightly more than `<tt>wc -l</tt>`
-  with e.g. <tt>percent=10</tt> or less.
-  <br>Cause unknown.
-<li> <em>n</em> map <tt>percent=100</tt> and <tt>percent=xx</tt> maps
-  differ slightly (point will fall above/below the segmentation line)
-  <br>Investigate with "<tt>r.mapcalc diff = bin_n.100 - bin_n.33</tt>" etc.
 <li> "<tt>nan</tt>" can leak into <em>coeff_var</em> maps.
   <br>Cause unknown. Possible work-around: "<tt>r.null setnull=nan</tt>"
 <!-- Another method:  r.mapcalc 'No_nan = if(map == map, map, null() )' -->
