[GRASS-SVN] r67940 - in grass/trunk: lib/python/temporal temporal/t.rast.extract temporal/t.rast.extract/testsuite temporal/t.rast3d.extract temporal/t.rast3d.extract/testsuite temporal/t.vect.extract temporal/t.vect.extract/testsuite
Wed Feb 24 07:26:55 PST 2016
Author: lucadelu
Date: 2016-02-24 07:26:55 -0800 (Wed, 24 Feb 2016)
New Revision: 67940
Added:
   grass/trunk/temporal/t.vect.extract/testsuite/
   grass/trunk/temporal/t.vect.extract/testsuite/test_vect_extract.py
   grass/trunk/lib/python/temporal/extract.py
   grass/trunk/temporal/t.rast.extract/t.rast.extract.py
   grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py
   grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
   grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py
   grass/trunk/temporal/t.vect.extract/t.vect.extract.py
temporal extract: added suffix option
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py	2016-02-24 15:09:50 UTC (rev 67939)
+++ grass/trunk/lib/python/temporal/extract.py	2016-02-24 15:26:55 UTC (rev 67940)
@@ -12,6 +12,9 @@
 from grass.script.utils import get_num_suffix
 from space_time_datasets import *
 from open_stds import *
+from datetime_math import create_suffix_from_datetime
+from datetime_math import create_time_suffix
+from datetime_math import create_numeric_suffic
 from multiprocessing import Process
 import grass.script as gscript
 from grass.exceptions import CalledModuleError
@@ -19,9 +22,9 @@
-def extract_dataset(input, output, type, where, expression, base, nprocs=1,
-                    register_null=False, layer=1,
-                    vtype="point,line,boundary,centroid,area,face"):
+def extract_dataset(input, output, type, where, expression, base, time_suffix,
+                    nprocs=1, register_null=False, layer=1,
+                    vtype="point,line,boundary,centroid,area,face", ):
     """Extract a subset of a space time raster, raster3d or vector dataset
        A mapcalc expression can be provided to process the temporal extracted
@@ -37,6 +40,8 @@
                          statement
        :param base: The base name of the new created maps in case a mapclac
                    expression is provided
+       :param time_suffix: string to choose which suffix to use: gran, time, num%*
+                          (where * are digits)
        :param nprocs: The number of parallel processes to be used for mapcalc
                      processing
        :param register_null: Set this number True to register empty maps
@@ -85,9 +90,19 @@
                 if count % 10 == 0:
                     msgr.percent(count, num_rows, 1)
-                map_name = "{base}_{suffix}".format(base=base,
-                                                    suffix=get_num_suffix(count,
-        num_rows))
+                if sp.get_temporal_type() == 'absolute' and time_suffix == 'gran':
+                    old_map = sp.get_new_map_instance(row["id"])
+                    old_map.select(dbif)
+                    suffix = create_suffix_from_datetime(old_map.temporal_extent.get_start_time(),
+                                                         sp.get_granularity())
+                    map_name = "{ba}_{su}".format(ba=base, su=suffix)
+                elif sp.get_temporal_type() == 'absolute' and time_suffix == 'time':
+                    suffix = create_time_suffix(old_map)
+                else:
+                    map_name = create_numeric_suffic(base, count, time_suffix)
                 # We need to modify the r(3).mapcalc expression
                 if type != "vector":
Modified: grass/trunk/temporal/t.rast.extract/t.rast.extract.py
--- grass/trunk/temporal/t.rast.extract/t.rast.extract.py	2016-02-24 15:09:50 UTC (rev 67939)
+++ grass/trunk/temporal/t.rast.extract/t.rast.extract.py	2016-02-24 15:26:55 UTC (rev 67940)
@@ -50,6 +50,15 @@
 #%end
 #%option
+#% key: suffix
+#% type: string
+#% description: Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'num' for numerical suffix with a specific number of digits (default %05)
+#% answer: gran
+#% required: no
+#% multiple: no
+#%end
+#%option
 #% key: nprocs
 #% type: integer
 #% description: Number of r.mapcalc processes to run in parallel
@@ -63,9 +72,9 @@
 #% description: Register Null maps
 #%end
 import grass.script as grass
 import grass.temporal as tgis
-from multiprocessing import Process
@@ -80,12 +89,13 @@
     base = options["basename"]
     nprocs = int(options["nprocs"])
     register_null = flags["n"]
+    time_suffix = options["suffix"]
     # Make sure the temporal database exists
     tgis.init()
     tgis.extract_dataset(input, output, "raster", where, expression,
-                         base, nprocs, register_null)
+                         base, time_suffix, nprocs, register_null)
Modified: grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py
--- grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py	2016-02-24 15:09:50 UTC (rev 67939)
+++ grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py	2016-02-24 15:26:55 UTC (rev 67940)
@@ -22,7 +22,20 @@
         cls.use_temp_region()
         cls.runModule("g.gisenv",  set="TGIS_USE_CURRENT_MAPSET=1")
         cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,  t=50,  res=10,  res3=10)
+        cls.runModule("r.mapcalc", expression="prec_1 = 100",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="prec_2 = 200",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="prec_3 = 300",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="prec_4 = 400",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="prec_5 = 500",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="prec_6 = 600",  overwrite=True)
+        cls.runModule("t.create", type="strds", temporaltype="absolute",
+                      output="precip_abs1", title="A test",
+                      description="A test", overwrite=True)
+        cls.runModule("t.register", flags="i", type="raster", input="precip_abs1",
+                      maps="prec_1,prec_2,prec_3,prec_4,prec_5,prec_6",
+                      start="2001-01-01", increment="3 months", overwrite=True)
     @classmethod
     def tearDownClass(cls):
         """Remove the temporary region
@@ -49,7 +62,7 @@
     def tearDown(self):
         """Remove generated data"""
         self.runModule("t.remove",  flags="rf",  type="strds",
-                                   inputs="precip_abs1,precip_abs2")
+                                   inputs="precip_abs2")
     def test_selection(self):
         """Perform a simple selection by datetime"""
@@ -147,6 +160,27 @@
         info = SimpleModule("t.info", flags="g", input="precip_abs2")
         self.assertModuleKeyValue(module=info, reference=tinfo_string, precision=2, sep="=")
+    def test_time_suffix_with_expression(self):
+        """Perform extract with time suffix support and test if maps exists"""
+        self.assertModule("t.rast.extract",  flags="n",  input="precip_abs1",
+                          output="precip_abs2", basename="new_prec",
+                          nprocs=2,  overwrite=True, suffix="time",
+                          expression="if(precip_abs1 > 400, precip_abs1, null())")
+        self.assertRasterExists('new_prec_2001_01_01T00_00_00')
+        self.assertRasterDoesNotExist('new_prec_2001_01')
+    def test_num_suffix_with_expression(self):
+                          nprocs=2,  overwrite=True, suffix='num%03',
+        self.assertRasterExists('new_prec_001')
+        self.assertRasterDoesNotExist('new_prec_00001')
 class TestRasterExtractionFails(TestCase):
     @classmethod
Modified: grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
--- grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py	2016-02-24 15:09:50 UTC (rev 67939)
+++ grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py	2016-02-24 15:26:55 UTC (rev 67940)
@@ -49,6 +49,15 @@
 #%end
 #%option
+#% key: suffix
+#% type: string
+#% answer: gran
+#% required: no
+#% multiple: no
+#%end
+#%option
 #% key: nprocs
 #% type: integer
 #% description: Number of r3.mapcalc processes to run in parallel
@@ -78,12 +87,13 @@
     tgis.init()
     tgis.extract_dataset(input, output, "raster3d", where, expression,
 if __name__ == "__main__":
     options, flags = grass.parser()
Modified: grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py
--- grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py	2016-02-24 15:09:50 UTC (rev 67939)
+++ grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py	2016-02-24 15:26:55 UTC (rev 67940)
@@ -116,6 +116,23 @@
         info = SimpleModule("t.info", flags="g", type="str3ds", input="B")
+        self.assertModule("t.rast3d.extract",  flags="n",  input="A", nprocs=2,
+                          output="B", basename="b", overwrite=True,
+                          suffix="time", expression="if(A > 400, A, null())")
+        self.assertRaster3dExists('b_2001_01_01T00_00_00')
+        self.assertRaster3dDoesNotExist('b_2001_01')
+                          suffix='num%03', expression="if(A > 400, A, null())")
+        self.assertRaster3dExists('b_001')
+        self.assertRaster3dDoesNotExist('b_00001')
 class TestRaster3dExtractionFails(TestCase):
     @classmethod
Modified: grass/trunk/temporal/t.vect.extract/t.vect.extract.py
--- grass/trunk/temporal/t.vect.extract/t.vect.extract.py	2016-02-24 15:09:50 UTC (rev 67939)
+++ grass/trunk/temporal/t.vect.extract/t.vect.extract.py	2016-02-24 15:26:55 UTC (rev 67940)
@@ -52,6 +52,15 @@
 #%end
 #%option
+#% key: suffix
+#% type: string
+#% answer: gran
+#% required: no
+#% multiple: no
+#%end
+#%option
 #% key: nprocs
 #% type: integer
 #% description: The number of v.extract processes to run in parallel. Use only if database backend is used which supports concurrent writing
@@ -67,7 +76,6 @@
@@ -84,12 +92,13 @@
     tgis.init()
     tgis.extract_dataset(input, output, "vector", where, expression,
-                         base, nprocs, register_null, layer, type)
+                         base, time_suffix, nprocs, register_null, layer, type)
Added: grass/trunk/temporal/t.vect.extract/testsuite/test_vect_extract.py
--- grass/trunk/temporal/t.vect.extract/testsuite/test_vect_extract.py	                        (rev 0)
+++ grass/trunk/temporal/t.vect.extract/testsuite/test_vect_extract.py	2016-02-24 15:26:55 UTC (rev 67940)
@@ -0,0 +1,107 @@
+"""Test t.vector.extract
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Luca Delucchi
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestVectorExtraction(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """Initiate the temporal GIS and set the region
+        cls.use_temp_region()
+        cls.runModule("g.region", s=0, n=80, w=0, e=120, res=10)
+        # Use always the current mapset as temporal database
+        for i in range(1, 11):
+            cls.runModule("v.random", output="a{c}".format(c=i), npoints=20,
+                          overwrite=True)
+            cls.runModule("v.db.addtable", map="a{c}".format(c=i),
+                          columns="value integer")
+            cls.runModule("v.db.update",  map="a{c}".format(c=i),
+                          column="value", value="'random()'")
+        # Create the temporal database
+        cls.runModule("t.connect", flags="d")
+        cls.runModule("t.info", flags="s")
+        cls.runModule("t.create", type="stvds", temporaltype="absolute",
+                      output="A", title="A testvect", description="A testvect",
+                      overwrite=True)
+        cls.runModule("t.register", flags="i", type="vector", input="A",
+                      maps="a1,a2,a3,a4,a5,a6,a7,a8,a9,a10", start="2001-01-01",
+                      increment="3 months", overwrite=True)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the temporary region
+        cls.del_temp_region()
+        cls.runModule("t.remove", flags="rf", type="stvds", inputs="A")
+    def test_selection(self):
+        """Perform a simple selection by datetime"""
+        self.assertModule("t.vect.extract", input="A", output="B",
+                          where="start_time > '2001-06-01'", overwrite=True)
+        tinfo_string="""start_time=2001-07-01 00:00:00
+        end_time=2003-07-01 00:00:00
+        granularity=3 months
+        map_time=interval
+        number_of_maps=8
+        primitives=160
+        points=160"""
+        info = SimpleModule("t.info", flags="g", type="stvds", input="B")
+        self.assertModuleKeyValue(module=info, reference=tinfo_string,
+                                  precision=2, sep="=")
+    def test_selection_no_suffix(self):
+                          where="start_time > '2001-06-01'", basename="b",
+                          overwrite=True)
+        self.assertVectorDoesNotExist('b_2001_07')
+        self.runModule("t.remove", flags="rf", type="stvds", inputs="B")
+    def test_selection_suffix(self):
+                          expression="value > 0", basename="b",
+                          overwrite=True)
+    def test_selection_time_suffix(self):
+                          expression="value > 0", basename="b", suffix="time",
+                          overwrite=True)
+        self.assertVectorExists('b_2001_01_01T00_00_00')
+    def test_selection_num_suffix(self):
+                          expression="value > 0", basename="b", suffix="num",
+                          overwrite=True)
+        self.assertVectorExists('b_00001')
+    def test_selection_num3_suffix(self):
+                          suffix="num%03", overwrite=True)
+        self.assertVectorExists('b_001')
+if __name__ == '__main__':
+    from grass.gunittest.main import test
+    test()
