[GRASS-SVN] r67942 - in grass/trunk/temporal: t.rast.neighbors	t.rast.neighbors/testsuite t.rast.to.vect t.rast.to.vect/testsuite
    svn_grass at osgeo.org
    Wed Feb 24 12:45:01 PST 2016
Author: lucadelu
Date: 2016-02-24 12:45:01 -0800 (Wed, 24 Feb 2016)
New Revision: 67942
Added:
   grass/trunk/temporal/t.rast.neighbors/testsuite/
   grass/trunk/temporal/t.rast.neighbors/testsuite/test_neighbors.py
   grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
   grass/trunk/temporal/t.rast.to.vect/t.rast.to.vect.py
   grass/trunk/temporal/t.rast.to.vect/testsuite/test_to_vect.py
t.rast.neighbors, t.rast.to.vect: added suffix option
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2016-02-24 19:28:23 UTC (rev 67941)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2016-02-24 20:45:01 UTC (rev 67942)
@@ -62,6 +62,15 @@
 #%end
 #%option
+#% key: suffix
+#% type: string
+#% description: Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'num' for numerical suffix with a specific number of digits (default %05)
+#% answer: gran
+#% required: no
+#% multiple: no
+#%end
+#%option
 #% key: nprocs
 #% type: integer
 #% description: Number of r.neighbor processes to run in parallel
@@ -94,6 +103,7 @@
     register_null = flags["n"]
     method = options["method"]
     nprocs = options["nprocs"]
+    time_suffix = options["suffix"]
     # Make sure the temporal database exists
     tgis.init()
@@ -130,7 +140,16 @@
     # run r.neighbors all selected maps
     for map in maps:
         count += 1
-        map_name = "%s_%i" % (base, count)
+        if sp.get_temporal_type() == 'absolute' and time_suffix == 'gran':
+            suffix = tgis.create_suffix_from_datetime(map.temporal_extent.get_start_time(),
+                                                      sp.get_granularity())
+            map_name = "{ba}_{su}".format(ba=base, su=suffix)
+        elif sp.get_temporal_type() == 'absolute' and time_suffix == 'time':
+            suffix = tgis.create_time_suffix(map)
+        else:
+            map_name = tgis.create_numeric_suffic(base, count, time_suffix)
         new_map = tgis.open_new_map_dataset(map_name, None, type="raster",
                                             temporal_extent=map.get_temporal_extent(),
                                             overwrite=overwrite, dbif=dbif)
Added: grass/trunk/temporal/t.rast.neighbors/testsuite/test_neighbors.py
--- grass/trunk/temporal/t.rast.neighbors/testsuite/test_neighbors.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast.neighbors/testsuite/test_neighbors.py	2016-02-24 20:45:01 UTC (rev 67942)
@@ -0,0 +1,86 @@
+# -*- coding: utf-8 -*-
+Created on Wed Feb 17 19:53:04 2016
+ at author: lucadelu
+import os
+import grass.temporal as tgis
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestAggregationAbsolute(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """Initiate the temporal GIS and set the region
+        os.putenv("GRASS_OVERWRITE",  "1")
+        tgis.init()
+        cls.use_temp_region()
+        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,
+                      t=50,  res=10,  res3=10)
+        cls.runModule("r.mapcalc", expression="a1 = rand(1,10)", flags=['s'],
+                      overwrite=True)
+        cls.runModule("r.mapcalc", expression="a2 = rand(1,10)", flags=['s'],
+                      overwrite=True)
+        cls.runModule("r.mapcalc", expression="a3 = rand(1,10)", flags=['s'],
+                      overwrite=True)
+        cls.runModule("t.create", type="strds", temporaltype="absolute",
+                      output="A", title="A test", description="A test",
+                      overwrite=True)
+        cls.runModule("t.register", flags="i",  type="raster",  input="A",
+                      maps="a1,a2,a3", start="2001-01-01 00:00:00",
+                      increment="1 month", overwrite=True)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the temporary region
+        cls.del_temp_region()
+        cls.runModule("t.remove", flags="rf", type="strds", inputs="A")
+    def tearDown(self):
+        """Remove generated data"""
+        self.runModule("t.remove", flags="rf", type="strds", inputs="B")
+    def test_where(self):
+        """Test simple t.rast.neighbors"""
+        trast_list = SimpleModule("t.rast.neighbors", quiet=True, input="A",
+                                  output="B", basename='b', overwrite=True,
+                                  size="5", where="start_time <= '2001-02-01 00:00:00'")
+        self.assertModule(trast_list)
+        self.assertRasterExists('b_2001_01')
+        self.assertRasterMinMax('b_2001_02', 1, 10)
+        self.assertRasterDoesNotExist('b_2001_03')
+    def test_simple(self):
+                                  output="B", size="5", basename='b',
+                                  overwrite=True)
+        self.assertRasterMinMax('b_2001_01', 1, 10)
+    def test_time_suffix(self):
+                                  suffix="time", overwrite=True)
+        self.assertRasterExists('b_2001_01_01T00_00_00')
+    def test_num_suffix(self):
+                                  suffix="num%03", overwrite=True)
+        self.assertRasterExists('b_001')
+if __name__ == '__main__':
+    from grass.gunittest.main import test
+    test()
Modified: grass/trunk/temporal/t.rast.to.vect/t.rast.to.vect.py
--- grass/trunk/temporal/t.rast.to.vect/t.rast.to.vect.py	2016-02-24 19:28:23 UTC (rev 67941)
+++ grass/trunk/temporal/t.rast.to.vect/t.rast.to.vect.py	2016-02-24 20:45:01 UTC (rev 67942)
@@ -52,6 +52,15 @@
 #%end
 #%option
+#% key: suffix
+#% type: string
+#% answer: gran
+#% required: no
+#% multiple: no
+#%end
+#%option
 #% key: column
 #% type: string
 #% description: Name of attribute column to store value
@@ -120,6 +129,7 @@
     method = options["type"]
     nprocs = int(options["nprocs"])
     column = options["column"]
     t_flag = flags["t"]
@@ -185,7 +195,15 @@
     # run r.to.vect all selected maps
     for map in maps:
         count += 1
+        else:
         new_map = tgis.open_new_map_dataset(map_name, None, type="vector",
Modified: grass/trunk/temporal/t.rast.to.vect/testsuite/test_to_vect.py
--- grass/trunk/temporal/t.rast.to.vect/testsuite/test_to_vect.py	2016-02-24 19:28:23 UTC (rev 67941)
+++ grass/trunk/temporal/t.rast.to.vect/testsuite/test_to_vect.py	2016-02-24 20:45:01 UTC (rev 67942)
@@ -131,6 +131,21 @@
         info = SimpleModule("t.info", flags="g", type="stvds", input="result")
         self.assertModuleKeyValue(module=info, reference=tinfo_string, precision=2, sep="=")
+        self.assertModule("t.rast.to.vect",  input="A", output="result",
+                          type="point", flags="t", column="values",
+                          basename="test", suffix="num%03",
+                          nprocs=4, overwrite=True, verbose=True)
+        self.assertVectorExists("test_001")
+                          basename="test", suffix="time",
+        self.assertVectorExists("test_2001_01_01T00_00_00")
 class TestRasterToVectorFails(TestCase):
     @classmethod
