[GRASS-SVN] r67944 - in grass/trunk: lib/python/temporal temporal/t.rast.aggregate temporal/t.rast.aggregate/testsuite temporal/t.rast.aggregate.ds
svn_grass at osgeo.org
Wed Feb 24 14:23:50 PST 2016
Author: lucadelu
Date: 2016-02-24 14:23:50 -0800 (Wed, 24 Feb 2016)
New Revision: 67944
grass/trunk/lib/python/temporal/aggregation.py
grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py
t.rast.aggregate*: replace -s flag with suffix option
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py 2016-02-24 22:02:53 UTC (rev 67943)
+++ grass/trunk/lib/python/temporal/aggregation.py 2016-02-24 22:23:50 UTC (rev 67944)
@@ -18,6 +18,9 @@
from space_time_datasets import *
+from datetime_math import create_suffix_from_datetime
+from datetime_math import create_time_suffix
+from datetime_math import create_numeric_suffic
import grass.script as gscript
from grass.exceptions import CalledModuleError
@@ -276,13 +279,16 @@
"start": str(granule.temporal_extent.get_start_time()),
"end": str(granule.temporal_extent.get_end_time())}))
- if granule.is_time_absolute() is True and time_suffix is True:
+ if granule.is_time_absolute() is True and time_suffix == 'gran':
suffix = create_suffix_from_datetime(granule.temporal_extent.get_start_time(),
granularity)
+ output_name = "{ba}_{su}".format(ba=basename, su=suffix)
+ elif granule.is_time_absolute() is True and time_suffix == 'time':
+ suffix = create_time_suffix(granule)
else:
- suffix = gscript.get_num_suffix(count + int(offset),
- len(granularity_list) + int(offset))
- output_name = "%s_%s" % (basename, suffix)
+ output_name = create_numeric_suffic(basename, count + int(offset),
+ time_suffix)
map_layer = RasterDataset("%s@%s" % (output_name,
get_current_mapset()))
Modified: grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
--- grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py 2016-02-24 22:02:53 UTC (rev 67943)
+++ grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py 2016-02-24 22:23:50 UTC (rev 67944)
@@ -39,6 +39,15 @@
#%end
#%option
+#% key: suffix
+#% type: string
+#% description: Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'num' for numerical suffix with a specific number of digits (default %05)
+#% answer: gran
+#% required: no
+#% multiple: no
+#%end
+#%option
#% key: granularity
#% type: string
#% description: Aggregation granularity, format absolute time "x years, x months, x weeks, x days, x hours, x minutes, x seconds" or an integer value for relative time
@@ -96,11 +105,6 @@
#% description: Register Null maps
#%end
-#%flag
-#% key: s
-#% description: Use start time - truncated according to granularity - as suffix (overrides offset option)
-#%end
import grass.script as gcore
import grass.temporal as tgis
@@ -120,7 +124,7 @@
offset = options["offset"]
nprocs = options["nprocs"]
file_limit = options["file_limit"]
- time_suffix = flags["s"]
+ time_suffix = options["suffix"]
topo_list = sampling.split(",")
Modified: grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py 2016-02-24 22:02:53 UTC (rev 67943)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py 2016-02-24 22:23:50 UTC (rev 67944)
@@ -82,7 +82,7 @@
self.assertModule("t.rast.aggregate", input="A", output="B",
basename="b", granularity="1 months",
method="maximum", sampling=["contains"],
- file_limit=0, nprocs=3, flags="s")
+ file_limit=0, nprocs=3)
tinfo_string="""start_time=2001-01-01 00:00:00
end_time=2001-04-01 00:00:00
@@ -110,12 +110,20 @@
"b_2001_03" + os.linesep
self.assertEqual(maps, lister.outputs.stdout)
+ def test_aggregation_1month_time(self):
+ """Aggregation one month time suffix"""
+ self.assertModule("t.rast.aggregate", input="A", output="B",
+ basename="b", granularity="1 months",
+ method="maximum", sampling=["contains"],
+ file_limit=0, nprocs=3, suffix='time')
+ self.assertRasterExists('b_2001_01_01T00_00_00')
def test_aggregation_2months(self):
"""Aggregation two month"""
basename="b", granularity="2 months",
method="minimum", sampling=["contains"],
- nprocs=4, offset=10)
+ nprocs=4, offset=10, suffix='num%02')
end_time=2001-05-01 00:00:00
@@ -147,7 +155,8 @@
basename="b", granularity="3 months",
method="sum", sampling=["contains"],
- file_limit=0, nprocs=9, offset=100)
+ file_limit=0, nprocs=9, offset=100,
+ suffix='num%03')
Modified: grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py 2016-02-24 22:02:53 UTC (rev 67943)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py 2016-02-24 22:23:50 UTC (rev 67944)
@@ -57,7 +57,7 @@
basename="b", granularity="12 hours",
- nprocs=9, flags="s", file_limit=2)
+ nprocs=9, file_limit=2)
@@ -82,7 +82,7 @@
basename="b", granularity="1 day",
- nprocs=4, flags="s")
+ nprocs=4)
end = datetime.now()
delta = end - start
@@ -107,7 +107,7 @@
- nprocs=3, flags="s")
+ nprocs=3)
delta = end - start
@@ -125,7 +125,7 @@
max_min=21.0
max_max=3225.0"""
- info = SimpleModule("t.info", flags="g", input="B")
+ info = SimpleModule("t.info", input="B", flags="g")
#info.run()
#print info.outputs.stdout
self.assertModuleKeyValue(module=info, reference=tinfo_string,
@@ -137,7 +137,7 @@
- nprocs=2, flags="s")
+ nprocs=2)
delta = end - start
Modified: grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
--- grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2016-02-24 22:02:53 UTC (rev 67943)
+++ grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2016-02-24 22:23:50 UTC (rev 67944)
@@ -48,6 +48,15 @@
#%end
#%option
+#% key: suffix
+#% type: string
+#% answer: gran
+#% required: no
+#% multiple: no
+#%end
+#%option
#% key: method
#% type: string
#% description: Aggregate operation to be performed on the raster maps
@@ -88,11 +97,6 @@
#%end
-#%flag
-#% key: s
-#%end
@@ -112,7 +116,7 @@
sampling = options["sampling"]
type = options["type"]
