[GRASS-SVN] r67961 - in grass/trunk: lib/python/temporal temporal/t.rast.export temporal/t.rast.export/testsuite
svn_grass at osgeo.org
Fri Feb 26 05:45:17 PST 2016
Author: lucadelu
Date: 2016-02-26 05:45:16 -0800 (Fri, 26 Feb 2016)
New Revision: 67961
Added:
grass/trunk/temporal/t.rast.export/testsuite/
grass/trunk/temporal/t.rast.export/testsuite/test_rast_export.py
grass/trunk/lib/python/temporal/stds_export.py
grass/trunk/temporal/t.rast.export/t.rast.export.py
t.rast.export: added type option to propagate in r.out.gdal
Modified: grass/trunk/lib/python/temporal/stds_export.py
--- grass/trunk/lib/python/temporal/stds_export.py 2016-02-26 12:24:50 UTC (rev 67960)
+++ grass/trunk/lib/python/temporal/stds_export.py 2016-02-26 13:45:16 UTC (rev 67961)
@@ -52,7 +52,8 @@
-def _export_raster_maps_as_gdal(rows, tar, list_file, new_cwd, fs, format_):
+def _export_raster_maps_as_gdal(rows, tar, list_file, new_cwd, fs, format_,
+ type_):
for row in rows:
name = row["name"]
start = row["start_time"]
@@ -70,7 +71,7 @@
if format_ == "GTiff":
# Export the raster map with r.out.gdal as tif
out_name = name + ".tif"
- if datatype == "CELL":
+ if datatype == "CELL" and not type_:
nodata = max_val + 1
if nodata < 256 and min_val >= 0:
gdal_type = "Byte"
@@ -83,6 +84,10 @@
gscript.run_command("r.out.gdal", flags="c", input=name,
output=out_name, nodata=nodata,
type=gdal_type, format="GTiff")
+ elif type_:
+ gscript.run_command("r.out.gdal", flags="cf", input=name,
+ output=out_name,
+ type=type_, format="GTiff")
else:
input=name, output=out_name,
@@ -227,7 +232,7 @@
def export_stds(input, output, compression, directory, where, format_="pack",
- type_="strds"):
+ type_="strds", datatype=None):
"""Export space time datasets as tar archive with optional compression
This method should be used to export space time datasets
@@ -259,6 +264,7 @@
- "strds" Space time raster dataset
- "str3ds" Space time 3D raster dataset
- "stvds" Space time vector dataset
+ :param datatype: Force the output datatype for r.out.gdal
# Save current working directory path
@@ -295,7 +301,7 @@
if type_ == "strds":
if format_ == "GTiff" or format_ == "AAIGrid":
- rows, tar, list_file, new_cwd, fs, format_)
+ rows, tar, list_file, new_cwd, fs, format_, datatype)
else:
_export_raster_maps(rows, tar, list_file, new_cwd, fs)
elif type_ == "stvds":
Modified: grass/trunk/temporal/t.rast.export/t.rast.export.py
--- grass/trunk/temporal/t.rast.export/t.rast.export.py 2016-02-26 12:24:50 UTC (rev 67960)
+++ grass/trunk/temporal/t.rast.export/t.rast.export.py 2016-02-26 13:45:16 UTC (rev 67961)
@@ -57,6 +57,16 @@
#% answer: GTiff
#%end
+#%option
+#% key: type
+#% type: string
+#% label: Data type
+#% description: Supported only for GTiff
+#% required: no
+#% multiple: no
+#% options: Byte,Int16,UInt16,Int32,UInt32,Float32,Float64,CInt16,CInt32,CFloat32,CFloat64
+#%end
#%option G_OPT_T_WHERE
#%end
@@ -74,12 +84,15 @@
directory = options["directory"]
where = options["where"]
_format = options["format"]
+ _type = options["type"]
+ if _type and _format in ["pack", "AAIGrid"]:
+ grass.warning(_("Type options is not working with pack format, it will be skipped"))
# Make sure the temporal database exists
tgis.init()
# Export the space time raster dataset
- tgis.export_stds(
- _input, output, compression, directory, where, _format, "strds")
+ tgis.export_stds(_input, output, compression, directory, where, _format,
+ "strds", _type)
if __name__ == "__main__":
Added: grass/trunk/temporal/t.rast.export/testsuite/test_rast_export.py
--- grass/trunk/temporal/t.rast.export/testsuite/test_rast_export.py (rev 0)
+++ grass/trunk/temporal/t.rast.export/testsuite/test_rast_export.py 2016-02-26 13:45:16 UTC (rev 67961)
@@ -0,0 +1,74 @@
+Test t.rast.export
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author: lucadelu
+from grass.gunittest.case import TestCase
+import grass.script as gscript
+import os
+class TestRasterExport(TestCase):
+ tmp = gscript.tempdir()
+ float_ = os.path.join(tmp, "geotiffloat")
+ int_ = os.path.join(tmp, "geotifint")
+ grid = os.path.join(tmp, "grid")
+ pack = os.path.join(tmp, "pack")
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ cls.use_temp_region()
+ cls.runModule("g.gisenv", set="TGIS_USE_CURRENT_MAPSET=1")
+ cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0, t=50, res=10,
+ res3=10)
+ maps = []
+ for i in range(10):
+ cls.runModule("r.mapcalc", expression="a_{id_} = rand(0.1,1.0)".format(id_=i),
+ flags="s", overwrite=True)
+ maps.append("a_{id_}".format(id_=i))
+ cls.runModule("t.create", type="strds", temporaltype="absolute",
+ output="A", title="A test", description="A test",
+ overwrite=True)
+ cls.runModule("t.register", flags="i", type="raster", input="A",
+ maps=maps, start="2001-01-01",
+ increment="4 months", overwrite=True)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.del_temp_region()
+ cls.runModule("t.remove", flags="rf", inputs="A")
+ def test_simple_geotif(self):
+ self.assertModule("t.rast.export", input="A", output=self.float_,
+ overwrite=True)
+ self.assertFileExists(self.float_)
+ def test_simple_geotif_int(self):
+ self.assertModule("t.rast.export", input="A", output=self.int_,
+ overwrite=True, type="Int16")
+ self.assertFileExists(self.int_)
+ def test_simple_grid(self):
+ self.assertModule("t.rast.export", input="A", output=self.grid,
+ overwrite=True, format="AAIGrid")
+ self.assertFileExists(self.grid)
+ def test_simple_pack(self):
+ self.assertModule("t.rast.export", input="A", output=self.pack,
+ overwrite=True, format="pack")
+ self.assertFileExists(self.pack)
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
