[GRASS-SVN] r67976 - grass-addons/grass7/raster/r.fidimo
svn_grass at osgeo.org
Mon Feb 29 06:18:08 PST 2016
Author: jradinger
Date: 2016-02-29 06:18:08 -0800 (Mon, 29 Feb 2016)
New Revision: 67976
grass-addons/grass7/raster/r.fidimo/r.fidimo.py
cat -> barriers_cat to avoid confusion
Modified: grass-addons/grass7/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2016-02-29 04:39:53 UTC (rev 67975)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2016-02-29 14:18:08 UTC (rev 67976)
@@ -422,7 +422,7 @@
columns="adj_X DOUBLE, adj_Y DOUBLE")
grass.run_command("v.distance",
overwrite = True,
- _from="barriers_tmp_%d" % os.getpid(),
+ from_="barriers_tmp_%d" % os.getpid(),
to="river_vector_tmp_%d" % os.getpid(),
upload="to_x,to_y",
column="adj_X,adj_Y")
@@ -915,7 +915,7 @@
for l in barriers_list:
- cat = int(l[0])
+ barrier_cat = int(l[0])
adj_X = float(l[1])
adj_Y = float(l[2])
dist = float(l[3])
@@ -946,7 +946,7 @@
if univar_upstream_barrier_density:
sum_upstream_barrier_density = float(univar_upstream_barrier_density.split('\n')[d['sum']].split(':')[1])
else:
- # if no upstream density to allocate than stop that "barrier-loop" and contiue with next barrier
+ # if no upstream density to allocate than stop that "barrier-loop" and continue with next barrier
grass.message(_("No upstream denisty to allocate downstream for that barrier: "+coors_barriers))
continue
