[GRASS-SVN] r67482 - grass/trunk/gui/wxpython/rlisetup
svn_grass at osgeo.org
Mon Jan 4 13:12:40 PST 2016
Author: hellik
Date: 2016-01-04 13:12:40 -0800 (Mon, 04 Jan 2016)
New Revision: 67482
grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html
g.gui.rlisetup.html: fix description where config files are stored
Modified: grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html
--- grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html 2016-01-04 19:36:57 UTC (rev 67481)
+++ grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html 2016-01-04 21:12:40 UTC (rev 67482)
@@ -62,8 +62,8 @@
and other notes (disposition of sample areas etc).
Configuration files are saved in the folder
- <tt>C:\Users\userxy\.r.li\history\my_conf</tt> (MS-Windows) or
- <tt>$HOME/.r.li/history/my_conf</tt> (GNU/Linux) (the file name can be
+ <tt>C:\Users\userxy\AppData\Roaming\GRASS7\r.li\</tt> (MS-Windows) or
+ <tt>$HOME/.r.li/</tt> (GNU/Linux) (the file name can be
defined by the user). The output or an analysis can either be a new raster
map (in case of using a "moving window" analysis) or be an ASCII text file
(when not performing a "moving window" analysis) containing the result.
