[GRASS-SVN] r67523 - grass-addons/grass7/imagery/i.spec.sam
Fri Jan 8 12:47:30 PST 2016
Author: ychemin
Date: 2016-01-08 12:47:30 -0800 (Fri, 08 Jan 2016)
New Revision: 67523
   grass-addons/grass7/imagery/i.spec.sam/global.h
   grass-addons/grass7/imagery/i.spec.sam/main.c
   grass-addons/grass7/imagery/i.spec.sam/open.c
modifying process for non-squared input spectral matrix
Modified: grass-addons/grass7/imagery/i.spec.sam/global.h
--- grass-addons/grass7/imagery/i.spec.sam/global.h	2016-01-08 11:34:43 UTC (rev 67522)
+++ grass-addons/grass7/imagery/i.spec.sam/global.h	2016-01-08 20:47:30 UTC (rev 67523)
@@ -14,7 +14,9 @@
 #define MAXFILES 255
 extern vec_struct *b, *Avector;
-extern int matrixsize;
+extern int signature;
+extern int signaturecount;
+extern int spectralcount;
 extern float curr_angle;
 extern char *group;
Modified: grass-addons/grass7/imagery/i.spec.sam/main.c
--- grass-addons/grass7/imagery/i.spec.sam/main.c	2016-01-08 11:34:43 UTC (rev 67522)
+++ grass-addons/grass7/imagery/i.spec.sam/main.c	2016-01-08 20:47:30 UTC (rev 67523)
@@ -41,7 +41,8 @@
 struct GModule *module;
-int matrixsize;
+int signaturecount;
+int spectralcount;
 struct Ref Ref;
@@ -65,7 +66,7 @@
     int nrows, ncols;
     int row, col;
-    int band;
+    int band, signature;
     int i, j, error=0;
     /*Assumes max 255 spectral signatures in input matrix*/
     float anglefield[255][255];
@@ -75,7 +76,6 @@
     } parm;
     mat_struct *A; /*first use in open.c G_matrix_set()*/
-    mat_struct *AT; /*first use in open.c G_matrix_set()*/
     char *group;
     float spectangle; /*numerical value of the spectral angle*/
@@ -149,7 +149,7 @@
       for (j = 0; j < A->cols ; j++)
          if (j !=i)
-         	G_message("  Angle between row %i and row %i: %g\n", (i+1), (j+1), anglefield[i][j]);
+         	G_message("  Angle between signature at row %i and signature at row %i: %g\n", (i+1), (j+1), anglefield[i][j]);
     G_message("\n");
@@ -157,14 +157,13 @@
    for (i = 0; i < A->cols ; i++)
        if (j !=i)
-         if (anglefield[i][j] < 10.0)
-	     G_message("ERROR: Spectral entries row %i|%i in your matrix are linear dependent!\n",i,j);
-	     error=1;
-    if (!error)
-	G_message("Spectral matrix is o.k. Proceeding...\n");
+         if (anglefield[i][j] < 10.0){
+	     G_verbose_message("WARNING: Spectral entries row %i|%i in your matrix are linear dependent!\n",i,j);
+             error=1;
+    if(error==1) G_message("Similarity of input signatures detected, use verbose mode for details");
+    G_message("Proceeding...\n");
     /* check singular values of Matrix A
      * Ref: Boardman, J.W. 1989: Inversion of imaging spectrometry data
@@ -184,69 +183,65 @@
     G_verbose_message("Singular values of Matrix A: run svdval");
     if(G_math_svdval(svdvalues, Avals, A->cols, A->rows))
-        G_fatal_error("Error in singular value decomposition, exiting...\n");
-    G_verbose_message("/*display values (replace v_output() in original version)*/");
-    /*display values (replace v_output() in original version)*/
+        G_verbose_message("Error in singular value decomposition, exiting...\n");
+    G_verbose_message("Display svd values");
+    /*display svd values*/
     for(i=0;i<A->cols;i++)
-        G_message("%f", svdvalues[i]);
+        G_verbose_message("%f", svdvalues[i]);
     G_verbose_message("/* alright, start Spectral angle mapping */");
     nrows = Rast_window_rows();
     ncols = Rast_window_cols();
     G_verbose_message("Calculating for %i x %i = %i pixels:\n",nrows,ncols, (ncols * ncols));
     G_verbose_message("%s ... ", G_program_name());
-    G_message("%s ... ", G_program_name());
-    for (row = 0; row < nrows; row++)                 /* rows loop*/
+    for (row = 0; row < nrows; row++)
 	G_percent(row, nrows, 2);
-	for (band = 0; band < Ref.nfiles; band++)     /* get row for all bands*/
+        /* get row for all bands*/
+	for (band = 0; band < Ref.nfiles; band++)
 	    Rast_get_d_row (cellfd[band], cell[band], row);
-	for (col = 0; col < ncols; col++)             /* cols loop, work pixelwise for all bands */
+        /* cols loop, work pixelwise for all bands */
+	for (col = 0; col < ncols; col++)
 	    /* get pixel values of each band and store in b vector: */
-            /* Yann: b is a spectral signature extracted for a given pixel */
-	    /*b = v_get(A->m); //m=rows; dim of vector=matrix size=Ref.nfiles*/
-            b = G_vector_init(A->cols,A->cols,CVEC);
+            /* b is a spectral signature extracted for a given pixel */
+            b = G_vector_init(A->cols,A->cols,RVEC);
+            /*Roll through spectral bands*/
-                 b->vals[band] = cell[band][col];  /* read input vector */
+             b->vals[band] = cell[band][col];  /* read input vector */
             /* calculate spectral angle for current pixel
              * between pixel spectrum and reference spectrum
              * and write result in full degree */
-             for (i = 0; i < Ref.nfiles; i++) /* Ref.nfiles = matrixsize*/
-              Avector = G_matvect_get_column(A, i);  /* go row-wise through matrix*/
-              G_verbose_message("Av: %f %f %f %f",Avector->vals[0],Avector->vals[1],Avector->vals[2],Avector->vals[3]);
-              G_verbose_message("b: %f %f %f %f",b->vals[0],b->vals[1],b->vals[2],b->vals[3]);
-	      spectangle = spectral_angle(Avector, b, CVEC);
-	      result_cell[i][col] = myround (spectangle);
-	      G_vector_free(Avector);
-	     G_vector_free(b);
-	 } /* columns loop */
+            for (signature=0;signature<signaturecount;signature++)
+             G_verbose_message("row[%i] col[%i] signature[%i]", row,col,signature);
+             /* go row-wise through matrix*/
+             Avector = G_matvect_get_row(A, signature);
+             G_verbose_message("Av: %f %f %f %f",Avector->vals[0],Avector->vals[1],Avector->vals[2],Avector->vals[3]);
+             G_verbose_message("b: %f %f %f %f",b->vals[0],b->vals[1],b->vals[2],b->vals[3]);
+	     spectangle = spectral_angle(Avector, b, RVEC);
+	     result_cell[signature][col] = myround (spectangle);
+	     G_vector_free(Avector);
+	    G_vector_free(b);
+	} /* columns loop */
 	/* write the resulting rows: */
-          Rast_put_d_row (resultfd[i], result_cell[i]);
+        for (signature=0; signature<signaturecount; signature++)
+         Rast_put_d_row (resultfd[signature], result_cell[signature]);
     } /* rows loop */
    /* close files */
-	  Rast_close (resultfd[i]);
-	  Rast_unopen(cellfd[i]);
-	  /* make grey scale color table */
-	  /*sprintf(result_name, "%s.%d", result_prefix, (i+1));
-          sprintf(command, "r.colors map=%s color=grey >/dev/null", result_name);
-          system(command);*/ /*Commented by Yann*/
-          /* write a color table */
+	  Rast_close (resultfd[signature]);
+	  Rast_unopen(cellfd[signature]);
     G_matrix_free(A);
     make_history(result_name, parm.group->answer, parm.matrixfile->answer);
Modified: grass-addons/grass7/imagery/i.spec.sam/open.c
--- grass-addons/grass7/imagery/i.spec.sam/open.c	2016-01-08 11:34:43 UTC (rev 67522)
+++ grass-addons/grass7/imagery/i.spec.sam/open.c	2016-01-08 20:47:30 UTC (rev 67523)
@@ -51,7 +51,8 @@
         G_verbose_message("\n");
-    matrixsize=A->rows;
+    signaturecount=A->cols;
+    spectralcount=A->rows;
     G_verbose_message("/* open input files from group */");
@@ -69,11 +70,11 @@
 	    G_message("only has 1 file\n");
 	G_fatal_error("The group must have at least 2 files\n");
-    /* Error check: input file number must be equal to matrix size */
-    if (Ref.nfiles != matrixsize)
+    /* Error check: input file number must be equal to spectral count */
+    if (Ref.nfiles != spectralcount)
 	G_message("Error: Number of %i input files in group <%s>\n", Ref.nfiles, img_grp);
- 	G_fatal_error("       does not match matrix size (%i cols).\n", A->cols);
+ 	G_fatal_error("       does not match spectral count (%i cols).\n", A->cols);
     G_verbose_message("/* get memory for input files */");
@@ -92,14 +93,14 @@
     G_verbose_message("/* open files for results*/");
-    result_cell = (DCELL **) G_malloc (Ref.nfiles * sizeof (DCELL *));
-    resultfd = (int *) G_malloc (Ref.nfiles * sizeof (int));
-    for (i=0; i < Ref.nfiles; i++)
+    result_cell = (DCELL **) G_malloc (signaturecount * sizeof (DCELL *));
+    resultfd = (int *) G_malloc (signaturecount * sizeof (int));
+    for (signature=0; signature < signaturecount; signature++)
-	sprintf(result_name, "%s.%d", result_prefix, (i+1));
+	sprintf(result_name, "%s.%d", result_prefix, (signature+1));
 	G_verbose_message("Opening output file [%s]\n", result_name);
-	result_cell[i] = Rast_allocate_d_buf();
-	resultfd[i] = Rast_open_new (result_name, DCELL_TYPE);
+	result_cell[signature] = Rast_allocate_d_buf();
+	resultfd[signature] = Rast_open_new (result_name, DCELL_TYPE);
     G_verbose_message("open.c: Returning A");
