[GRASS-SVN] r67529 - in grass/trunk/gui/wxpython: mapdisp mapwin vdigit
svn_grass at osgeo.org
Sat Jan 9 08:24:13 PST 2016
Author: annakrat
Date: 2016-01-09 08:24:13 -0800 (Sat, 09 Jan 2016)
New Revision: 67529
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/mapwin/buffered.py
grass/trunk/gui/wxpython/vdigit/toolbars.py
wxGUI: fix digitizer when used second time
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2016-01-09 14:00:01 UTC (rev 67528)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2016-01-09 16:24:13 UTC (rev 67529)
@@ -505,8 +505,8 @@
:param destroy True to destroy otherwise toolbar is only hidden
self._mgr.DetachPane(self.toolbars[name])
- self._toolSwitcher.RemoveToolbarFromGroup('mouseUse', self.toolbars[name])
if destroy:
+ self._toolSwitcher.RemoveToolbarFromGroup('mouseUse', self.toolbars[name])
self.toolbars[name].Destroy()
self.toolbars.pop(name)
else:
Modified: grass/trunk/gui/wxpython/mapwin/buffered.py
--- grass/trunk/gui/wxpython/mapwin/buffered.py 2016-01-09 14:00:01 UTC (rev 67528)
+++ grass/trunk/gui/wxpython/mapwin/buffered.py 2016-01-09 16:24:13 UTC (rev 67529)
@@ -77,6 +77,8 @@
self.SetBackgroundColour("white")
self._properties = properties
+ # this class should not ask for digit, this is a hack
+ self.digit = None
# flags
self.resize = False # indicates whether or not a resize event has taken place
@@ -222,7 +224,7 @@
def OnContextMenu(self, event):
"""Show Map Display context menu"""
- if hasattr(self, "digit"):
+ if self.digit:
event.Skip()
return
@@ -525,7 +527,7 @@
self.pdc.DrawToDCClipped(dc, rgn)
# draw vector map layer
+ if self.digit:
# decorate with GDDC (transparency)
try:
gcdc = wx.GCDC(dc)
@@ -540,7 +542,7 @@
# draw to the dc
self.pdc.DrawToDC(dc)
+ if self.digit:
try:
gcdc = wx.GCDC(dc)
@@ -678,7 +680,7 @@
# probably does nothing, removed from wxPython 2.9
# self.PrepareDC(dc)
- if self.pdcVector:
+ if self.digit:
self.pdcVector.DrawToDC(dc)
ibuffer.SaveFile(self._fileName, self._fileType)
@@ -875,7 +877,7 @@
# render vector map layer
- if renderVector and hasattr(self, "digit"):
+ if renderVector and self.digit:
self._updateMap()
@@ -954,7 +956,7 @@
self.Draw(self.pdc, pdctype = 'clear')
+ if self.digit:
self.Draw(self.pdcVector, pdctype = 'clear')
self.Draw(self.pdcTransparent, pdctype='clear')
@@ -1317,7 +1319,7 @@
move = (current[0] - previous[0],
current[1] - previous[1])
+ if self.digit:
digitToolbar = self.toolbar
else:
digitToolbar = None
@@ -1357,7 +1359,7 @@
# vector digizer
if self.mouse["use"] == "pointer" and \
- hasattr(self, "digit"):
+ self.digit:
if event.ControlDown():
self.OnLeftDownUndo(event)
else:
@@ -1411,7 +1413,7 @@
self.mapQueried.emit(x=self.mouse['end'][0], y=self.mouse['end'][1])
elif self.mouse["use"] == "pointer" and \
+ self.digit:
self._onLeftUp(event)
elif (self.mouse['use'] == 'pointer' and
@@ -1480,7 +1482,7 @@
Debug.msg (5, "BufferedWindow.OnRightDown(): use=%s" % \
self.mouse["use"])
+ if self.digit:
self._onRightDown(event)
event.Skip()
@@ -1491,7 +1493,7 @@
Debug.msg (5, "BufferedWindow.OnRightUp(): use=%s" % \
self.mouse["use"])
+ if self.digit:
self._onRightUp(event)
self.redrawAll = True
@@ -1536,7 +1538,7 @@
"""Motion event and no mouse buttons were pressed
+ self.digit:
self._onMouseMoving(event)
event.Skip()
@@ -1690,7 +1692,7 @@
for k in ('n', 's', 'e', 'w'):
self.Map.region[k] = newreg[k]
- if hasattr(self, "digit") and \
+ if self.digit and \
hasattr(self, "moveInfo"):
self._zoom(None)
@@ -1815,7 +1817,7 @@
elif l.type == '3d-raster':
rast3d = l.GetName()
elif l.type == 'vector':
self.toolbar.GetLayer() == l:
w, s, b, e, n, t = self.digit.GetDisplay().GetMapBoundingBox()
self.Map.GetRegion(n = n, s = s, w = w, e = e,
Modified: grass/trunk/gui/wxpython/vdigit/toolbars.py
--- grass/trunk/gui/wxpython/vdigit/toolbars.py 2016-01-09 14:00:01 UTC (rev 67528)
+++ grass/trunk/gui/wxpython/vdigit/toolbars.py 2016-01-09 16:24:13 UTC (rev 67529)
@@ -77,7 +77,7 @@
# list of available vector maps
self.UpdateListOfLayers(updateTool = True)
for tool in ('addPoint', 'addLine', 'addBoundary', 'addCentroid', 'addArea',
'addVertex', 'deleteLine', 'deleteArea', 'displayAttr', 'displayCats',
'editLine', 'moveLine', 'moveVertex', 'removeVertex', 'additionalTools'):
@@ -1005,8 +1005,8 @@
self.parent.dialogs[dialog].Close()
self.parent.dialogs[dialog] = None
- del self.digit
- del self.MapWindow.digit
+ self.digit = None
+ self.MapWindow.digit = None
self.editingStopped.emit(layerItem = item)
