[GRASS-SVN] r67558 - grass-addons/grass7/gui/wxpython/wx.mwprecip
svn_grass at osgeo.org
Mon Jan 11 08:47:12 PST 2016
Author: krejcmat
Date: 2016-01-11 08:47:12 -0800 (Mon, 11 Jan 2016)
New Revision: 67558
grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
addons wx.mwprecip: fix db issue with sql data exporter dialog
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2016-01-11 15:44:52 UTC (rev 67557)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2016-01-11 16:47:12 UTC (rev 67558)
@@ -84,9 +84,9 @@
if 'passwd' in self.settings:
self.passwd.SetValue(self.getSettVal('passwd'))
- def saveSettings(self, settings=None):
- if settings is not None:
- self.settings = settings
+ def saveSettings(self, sett=None):
+ if sett is not None:
+ self.settings = sett
self.settings['database'] = self.database.GetValue()
self.settings['schema'] = self.schema.GetValue()
self.settings['host'] = self.host.GetValue()
@@ -144,7 +144,7 @@
class BaselinePanel(wx.ScrolledWindow):
- def __init__(self, parent, settings=dict()):
+ def __init__(self, parent, settings={}):
wx.ScrolledWindow.__init__(self, parent, wx.ID_ANY, wx.DefaultPosition, wx.DefaultSize, wx.HSCROLL|wx.VSCROLL)
self.SetScrollRate( 5, 5 )
@@ -173,10 +173,6 @@
self.loadSettings()
self._layout()
- def onChangeStatistic(self,evt=None):
- if self.baselType.GetValue() == 'avg':
- self.round.Disable()
- self.quantile.Disable()
@@ -608,7 +604,7 @@
self.profilSelection = wx.ComboBox(self.mainPanel,style=wx.CB_READONLY)
self.schema = BaseInput(self.mainPanel, 'Name of new working profile')
self.schema.text.Bind(wx.EVT_TEXT, self.OnSchemeTxtChange)
- self.newScheme = wx.Button(self.mainPanel, label='Save new profile')
+ self.newScheme = wx.Button(self.mainPanel, label='Save profile')
self.newScheme.Bind(wx.EVT_BUTTON, self.OnSaveSettings)
self.newScheme.Disable()
self.profilSelection.Bind(wx.EVT_COMBOBOX, self.OnLoadSettings)
@@ -680,18 +676,17 @@
def OnLoadSettings(self, evt=None):
currSelId = self.profilSelection.GetSelection()
self.schema.SetValue(self.profilSelection.GetValue())
- #print self.settingsLst[currSelId]
self.settings = self.settingsLst[currSelId]
try:
self.dataMgrMW.loadSettings(self.settings)
except:
pass
+ #try:
+ # self.dataMgrRG.loadSettings(self.settings)
+ #except:
+ # pass
try:
- self.dataMgrRG.loadSettings(self.settings)
- except:
- pass
- try:
self.databasePnl.loadSettings(self.settings)
except:
pass
@@ -725,17 +720,17 @@
self.settings['workSchema'] = self.profilSelection.GetValue()
if self.schema.GetValue() is not None:
self.settings['workSchema'] = self.schema.GetValue()
+ tmpPath = os.path.join(self.workPath, 'save', self.settings['workSchema'])
+ profilePath=os.path.join(self.workPath,"logs")
+ if not os.path.exists(profilePath):
+ os.mkdir(profilePath)
+ self.loggerPath = os.path.join(profilePath,"%s.logg"% self.settings['workSchema'])
+ self.initLogger(self.loggerPath)
if toFile:
- tmpPath = os.path.join(self.workPath, 'save', self.settings['workSchema'])
- profilePath=os.path.join(self.workPath,"logs")
- if not os.path.exists(profilePath):
- os.mkdir(profilePath)
- self.loggerPath = os.path.join(profilePath,self.settings['workSchema']+".logg")
- self.initLogger(self.loggerPath)
saveDict(tmpPath, self.settings)
- self.findProject()
+ self.findProject()
def initWorkingFoldrs(self):
savePath = os.path.join(self.workPath, 'save')
@@ -749,8 +744,6 @@
GMessage('Cannot find "save" folder',self)
return
filePathList = getFilesInFoldr(projectDir, True)
- #print filePathList
- # print 'filePathList',filePathList
if filePathList != 0:
self.profilSelection.Clear()
for path in filePathList:
@@ -934,25 +927,29 @@
self.settings['IDtype'] = 'linkid'
interface = Gui2Model(self, self.settings,self.workPath)
+ if not interface.initConnection():
+ return
interface.initVectorGrass()
interface.initTimeWinMW()
interface.initBaseline()
interface.Run()
if interface.connStatus:
conn= interface.dbConn
+ sql = 'SELECT * FROM %s.%s' % (interface.dbConn.schema, interface.dbConn.computedPrecip)
+ res = conn.connection.executeSql(sql, True, True)
- sql = 'SELECT * FROM %s.%s' % (interface.dbConn.schema, interface.dbConn.computedPrecip)
- res = conn.connection.executeSql(sql, True, True)
- lines = ''
- for r in res:
- lines += str(r)[1:][:-1] + '\n'
+ lines = ''
+ for r in res:
+ lines += str(r)[1:][:-1] + '\n'
- print conn.pathworkSchemaDir
- io0 = open(path, "w+")
- io0.writelines(lines)
- io0.close()
- os.remove(os.path.join(interface.dbConn.pathworkSchemaDir, "precip"))
- GMessage('Data exported<%s>' % path,self)
+ print conn.pathworkSchemaDir
+ io0 = open(path, "w+")
+ io0.writelines(lines)
+ io0.close()
+ os.remove(os.path.join(interface.dbConn.pathworkSchemaDir, "precip"))
+ GMessage('Data exported<%s>' % path,self)
+ else:
+ GMessage('Data not exported',self)
self.exportDialog.Destroy()
@@ -1031,7 +1028,10 @@
return False
def initConnection(self, info=False):
+ if self.conninfo is None:
+ self.checkConn()
conninfo = self.conninfo
if 'workSchema' in self.settings:
conninfo['workSchema'] = self.settings['workSchema']
if 'schema' in self.settings:
@@ -1078,15 +1078,18 @@
convertor.grass_vinASCII(linksASCII, self.dbConn.linkVecMapName)
def initPInterpolation(self):
+ run=0
if 'pitypeDist' in self.settings:
pitypeDist = self.settings['pitypeDist']
+ run+=1
if 'pivalue' in self.settings:
pivalue = self.settings['pivalue']
+ run+=1
else:
self.errMsg('Missing value for interpolating points along lines')
+ if run == 2:
+ PointInterpolation(self.dbConn, pivalue, pitypeDist)
- PointInterpolation(self.dbConn, pivalue, pitypeDist)
def initBaseline(self):
baselInit = {}
if 'baselType' in self.settings:
@@ -1166,7 +1169,6 @@
#GMessage(msg)
#self.initgrassManagement()
def initGrassLayerMgr(self):
grassLayerMgr = {}
if 'colorRules' in self.settings:
