[GRASS-SVN] r67577 - grass/trunk/lib/vector/vedit
svn_grass at osgeo.org
Wed Jan 13 04:24:08 PST 2016
Author: mlennert
Date: 2016-01-13 04:24:07 -0800 (Wed, 13 Jan 2016)
New Revision: 67577
grass/trunk/lib/vector/vedit/break.c
vedit vector lib: forward port r58512 and r58516 (fixing #719: unexpected line with v.edit tool=break)
Modified: grass/trunk/lib/vector/vedit/break.c
--- grass/trunk/lib/vector/vedit/break.c 2016-01-13 09:36:29 UTC (rev 67576)
+++ grass/trunk/lib/vector/vedit/break.c 2016-01-13 12:24:07 UTC (rev 67577)
@@ -85,6 +85,7 @@
G_debug(3, "Vedit_split_lines(): line=%d", line);
/* copy first line part */
+ Vect_reset_line(Points2);
for (l = 0; l < seg; l++) {
Vect_append_point(Points2, x[l], y[l], z[l]);
@@ -93,7 +94,10 @@
Vect_append_point(Points2, px, py, 0.0);
/* rewrite the line */
- newline = Vect_rewrite_line(Map, line, type, Points2, Cats);
+ if (j == 0)
+ newline = Vect_rewrite_line(Map, line, type, Points2, Cats);
+ else
+ newline = Vect_write_line(Map, type, Points2, Cats);
if (newline < 0) {
return -1;
