[GRASS-SVN] r67580 - grass/trunk/temporal/t.vect.observe.strds
Thu Jan 14 15:10:46 PST 2016
Author: neteler
Date: 2016-01-14 15:10:46 -0800 (Thu, 14 Jan 2016)
New Revision: 67580
   grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.html
t.vect.observe.strds manual: remove reference to t_where parameter deleted in r64560
Modified: grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.html
--- grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.html	2016-01-13 21:09:58 UTC (rev 67579)
+++ grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.html	2016-01-14 23:10:46 UTC (rev 67580)
@@ -8,9 +8,8 @@
 input is one or several space time raster datasets (STRDS) that should
 be sampled over time at the vector point positions. The space time
 raster dataset will be sampled over its whole temporal extent (from
-start to end). The range can be adjusted using the temporal where
-condition <em>t_where</em>. A column name must be specified for each
-input space time raster dataset.
+start to end). A column name must be specified for each input space
+time raster dataset.
 <p>
 As results  a new space time vector dataset is generated that contains
 a single (new) vector map that links to as many time stamped attribute
