[GRASS-SVN] r67604 - grass-addons/grass7/raster/r.sample.category
Mon Jan 18 18:50:20 PST 2016
Author: annakrat
Date: 2016-01-18 18:50:20 -0800 (Mon, 18 Jan 2016)
New Revision: 67604
   grass-addons/grass7/raster/r.sample.category/r.sample.category.py
r.sample.category: add labels from sample map; type of column is now based on sampled raster; check minimum number of points in each category (author: Paulo van Breugel)
Modified: grass-addons/grass7/raster/r.sample.category/r.sample.category.py
--- grass-addons/grass7/raster/r.sample.category/r.sample.category.py	2016-01-18 21:39:00 UTC (rev 67603)
+++ grass-addons/grass7/raster/r.sample.category/r.sample.category.py	2016-01-19 02:50:20 UTC (rev 67604)
@@ -44,11 +44,14 @@
 #% multiple: yes
 #% type: integer
 #%end
+#%flag
+#% key: s
+#% description: If number of cells in category < npoints, skip category
+#%end
 # TODO: Python tests for more advanced things such as overwrite or attributes
 # TODO: only optional sampling of the category raster
 # TODO: preserver original raster categories as vector point categories
-# TODO: ensure/check minimum number of points in each category
 # TODO: specify number of points and distribute them uniformly
 # TODO: specify number of points and distribute them according to histogram
 # TODO: ensure/check minimum and maximum number of of points when doing histogram
@@ -66,9 +69,9 @@
 def cleanup():
     if gscript.find_file(name='MASK', element='cell', mapset=gscript.gisenv()['MAPSET'])['name']:
-        gscript.run_command('r.mask', flags='r')
+        gscript.run_command('r.mask', flags='r', quiet=True)
     if TMP:
-        gscript.run_command('g.remove', flags='f', type=['raster', 'vector'], name=TMP)
+        gscript.run_command('g.remove', flags='f', type=['raster', 'vector'], name=TMP, quiet=True)
 def escape_sql_column(name):
@@ -102,6 +105,7 @@
     else:
         sampled_rasters = []
     npoints = [int(num) for num in options['npoints'].split(',')]
+    flag_s = flags['s']
         gscript.fatal(_("MASK is active. Please remove it before proceeding."))
@@ -114,19 +118,17 @@
     TMP.append(points_nocats)
     # input must be CELL
-    rdescribe = gscript.read_command('r.describe', map=input_raster, flags='d1', quiet=True)
-    categories = []
-    for line in rdescribe.splitlines():
-        try:
-            categories.append(int(line))
-        except ValueError:
-            pass
+    rdescribe = gscript.read_command('r.stats', flags='ln', input=input_raster, separator='pipe')
+    catlab = rdescribe.splitlines()
+    categories = map(int, [z.split('|')[0] for z in catlab])
+    catlab = dict([z.split('|') for z in catlab])
     if len(npoints) == 1:
         npoints = npoints * len(categories)
     else:
         if len(categories) != len(npoints):
             gscript.fatal(_("Number of categories in raster does not match the number of provided sampling points numbers."))
+    # Create sample points per category
     vectors = []
     for i, cat in enumerate(categories):
         # skip generating points if none are required
@@ -136,32 +138,57 @@
         # change mask to sample zeroes and then change again to sample ones
         # overwrite mask for an easy loop
         gscript.run_command('r.mask', raster=input_raster, maskcats=cat, overwrite=True, quiet=True)
+        # Check number of cells in category
+        nrc = int(gscript.parse_command('r.univar', map=input_raster, flags='g')['n'])
+        if nrc < npoints[i]:
+            if flag_s:
+                gscript.info(_("Not enough points in category {cat}. Skipping").format(cat=categories[i]))
+                continue
+            gscript.warning(_("Number of raster cells in category {cat} < {np}. Sampling {n} points").format(cat=categories[i], np=npoints[i], n=nrc))
+            npoints[i] = nrc
+        # Create the points
         vector = temp_name + str(cat)
         vectors.append(vector)
         gscript.run_command('r.random', input=input_raster, npoints=npoints[i], vector=vector, quiet=True)
         TMP.append(vector)
-    gscript.run_command('r.mask', flags='r', quiet=True)
     gscript.run_command('v.patch', input=vectors, output=points, quiet=True)
     # remove and add gain cats so that they are unique
     gscript.run_command('v.category', input=points, option='del', cat=-1, output=points_nocats, quiet=True)
     # overwrite to reuse the map
     gscript.run_command('v.category', input=points_nocats, option='add', output=points, overwrite=True, quiet=True)
+    # Sample layers
     columns = []
     column_names = []
     sampled_rasters.insert(0, input_raster)
     for raster in sampled_rasters:
         column = escape_sql_column(strip_mapset(raster).lower())
         column_names.append(column)
-        # TODO: column type according to map type
-        columns.append("{column} double precision".format(column=column))
+        datatype = gscript.parse_command('r.info', flags='g', map=raster)['datatype']
+        if datatype == 'CELL':
+            datatype = 'integer'
+        else:
+            datatype = 'double precision'
+        columns.append("{column} {datatype}".format(column=column, datatype=datatype))
     gscript.run_command('v.db.addtable', map=points, columns=','.join(columns), quiet=True)
     for raster, column in zip(sampled_rasters, column_names):
         gscript.info(_("Sampling raster map %s...") % raster)
         gscript.run_command('v.what.rast', map=points, type='point', raster=raster, column=column, quiet=True)
+    # Add category labels
+    if not list(set(catlab.values()))[0] and len(set(catlab.values())) == 1:
+        gscript.verbose(_("There are no category labels in the raster to add"))
+    else:
+        gscript.run_command("v.db.addcolumn", map=points, columns="label varchar(250)")
+        table_name = escape_sql_column(strip_mapset(points).lower())
+        for i in categories:
+            sqlstat = "UPDATE " + table_name + " SET label='" + catlab[str(i)] + "' WHERE " + column_names[0] + " == " + str(i)
+            gscript.run_command("db.execute", sql=sqlstat)
 if __name__ == '__main__':
     main()
