[GRASS-SVN] r67620 - grass/trunk/raster/r.grow.distance
svn_grass at osgeo.org
Thu Jan 21 05:23:39 PST 2016
Author: neteler
Date: 2016-01-21 05:23:39 -0800 (Thu, 21 Jan 2016)
New Revision: 67620
grass/trunk/raster/r.grow.distance/
grass/trunk/raster/r.grow.distance/main.c
grass/trunk/raster/r.grow.distance/r.grow.distance.html
r.grow.distance: new flag to calculate distance to nearest NULL cell (trac #2368)
Property changes on: grass/trunk/raster/r.grow.distance
___________________________________________________________________
Modified: svn:ignore
- OBJ.*
+ OBJ.*
*.tmp.html
Modified: grass/trunk/raster/r.grow.distance/main.c
--- grass/trunk/raster/r.grow.distance/main.c 2016-01-21 11:46:54 UTC (rev 67619)
+++ grass/trunk/raster/r.grow.distance/main.c 2016-01-21 13:23:39 UTC (rev 67620)
@@ -128,7 +128,7 @@
} opt;
struct
- struct Flag *m;
+ struct Flag *m, *n;
} flag;
const char *in_name;
const char *dist_name;
@@ -144,6 +144,7 @@
DCELL min, max;
DCELL *out_row;
double scale = 1.0;
+ int invert;
G_gisinit(argv[0]);
@@ -180,6 +181,10 @@
flag.m->key = 'm';
flag.m->description = _("Output distances in meters instead of map units");
+ flag.n = G_define_flag();
+ flag.n->key = 'n';
+ flag.n->description = _("Calculate distance to nearest NULL cell");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -187,6 +192,15 @@
dist_name = opt.dist->answer;
val_name = opt.val->answer;
+ if ((invert = flag.n->answer)) {
+ if (!dist_name)
+ G_fatal_error(_("Distance output is required for distance to NULL cells"));
+ if (val_name) {
+ G_warning(_("Value output is meaningless for distance to NULL cells"));
+ val_name = NULL;
if (!dist_name && !val_name)
G_fatal_error(_("At least one of distance= and value= must be given"));
@@ -274,13 +288,14 @@
Rast_get_d_row(in_fd, in_row, irow);
- for (col = 0; col < ncols; col++)
- if (!Rast_is_d_null_value(&in_row[col])) {
+ for (col = 0; col < ncols; col++) {
+ if (Rast_is_d_null_value(&in_row[col]) == invert) {
new_x_row[col] = 0;
new_y_row[col] = 0;
dist_row[col] = 0;
new_val_row[col] = in_row[col];
check(irow, col, -1, 0);
Modified: grass/trunk/raster/r.grow.distance/r.grow.distance.html
--- grass/trunk/raster/r.grow.distance/r.grow.distance.html 2016-01-21 11:46:54 UTC (rev 67619)
+++ grass/trunk/raster/r.grow.distance/r.grow.distance.html 2016-01-21 13:23:39 UTC (rev 67620)
@@ -6,6 +6,9 @@
<h2>NOTES</h2>
+The flag <b>-n</b> calculates the respective pixel distances to the
+nearest NULL cell.
+<p>
The user has the option of specifying five different metrics which
control the geometry in which grown cells are created, (controlled by
the <b>metric</b> parameter): <i>Euclidean</i>, <i>Squared</i>,
