[GRASS-SVN] r67625 - grass-addons/grass7/imagery/i.ortho.corr
svn_grass at osgeo.org
Fri Jan 22 05:32:13 PST 2016
Author: neteler
Date: 2016-01-22 05:32:13 -0800 (Fri, 22 Jan 2016)
New Revision: 67625
grass-addons/grass7/imagery/i.ortho.corr/i.ortho.corr.html
i.ortho.cor manual: fix English
Modified: grass-addons/grass7/imagery/i.ortho.corr/i.ortho.corr.html
--- grass-addons/grass7/imagery/i.ortho.corr/i.ortho.corr.html 2016-01-22 13:17:11 UTC (rev 67624)
+++ grass-addons/grass7/imagery/i.ortho.corr/i.ortho.corr.html 2016-01-22 13:32:13 UTC (rev 67625)
@@ -1,30 +1,52 @@
<h2>DESCRIPTION</h2>
-<em>i.ortho.corr</em> create a new image, it search the images near the input map and the output contains part of near images where the camera angle value it's the best.
+<em>i.ortho.corr</em> allows to correct orthophotos using the camera
+angle map create by <em>i.ortho.photo</em>.
<p>
+It creates a new image by searching further images adjacent to the input
+image. The output contains part of near images where the camera angle
+value is optimal.
+<p>
<h2>NOTES</h2>
-You must create a tile index contains all the images to correct, you can use gdaltindex to create it
+It requires a tile index to be created containing all the images to be
+processed (e.g., GDAL's <em>gdaltindex</em> can create that):
<div class="code"><pre>
gdaltindex tile.shp $GRASSDATA/$LOCATION/$MAPSET/cellhd/*imagery.ortho
</pre></div>
-The <em>field</em> option it's used for the field's name which contain the path to the file, the default is <em>location</em> that it is used by gdaltindex
-The <em>exclude</em> option it serve to remove some tiles, for example you have tile of different flight, you can pass a string or a regex
+The <em>field</em> option is used for the field's name which contains the
+path to the file, the default is <em>location</em> that it is used by
+<em>gdaltindex</em>. The <em>exclude</em> option serves to remove some
+tiles, for example when having tiles from a different flight, they can be
+excluded by passing a string or a regular expression.
<h2>EXAMPLES</h2>
-Create tile index
+Create tile index:
</pre></div>
+<p>
Import tile index inside the mapset
v.in.ogr dns=tile.shp out=tile_images
</pre></div>
-Start i.ortho.corr with the default parameters, the output map's name it will be <em>image.ortho_corr</em>. You can use default parameters if you didn't change the output prefix in i.ortho.photo
+<p>
+Start <em>i.ortho.corr</em> with the default parameters, the output map's
+name will be <tt>image.ortho_corr</tt>. You can use default parameters if
+you didn't change the output prefix in i.ortho.photo:
i.ortho.corr input=image.ortho tiles=tile_images
</pre></div>
-Start i.ortho.corr with different parameters
+<p>
+Start <em>i.ortho.corr</em> with different parameters
i.ortho.corr input=image.photo tiles=tile_images osuffix=.photo csuffix=.camera
</pre></div>
