[GRASS-SVN] r67628 - in grass/trunk/gui/wxpython: gui_core lmgr modules
svn_grass at osgeo.org
Sat Jan 23 01:23:15 PST 2016
Author: turek
Date: 2016-01-23 01:23:15 -0800 (Sat, 23 Jan 2016)
New Revision: 67628
grass/trunk/gui/wxpython/gui_core/widgets.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/modules/import_export.py
wx.import dialogs - added all flags and parameters of modules used for import
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py 2016-01-23 04:03:12 UTC (rev 67627)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py 2016-01-23 09:23:15 UTC (rev 67628)
@@ -1158,7 +1158,7 @@
wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY)
self.settingsBox = wx.StaticBox(parent=self, id=wx.ID_ANY,
- label=" %s " % _("Settings"))
+ label=" %s " % _("Profiles"))
self.settingsChoice = wx.Choice(parent=self, id=wx.ID_ANY)
self.settingsChoice.Bind(wx.EVT_CHOICE, self.OnSettingsChanged)
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2016-01-23 04:03:12 UTC (rev 67627)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2016-01-23 09:23:15 UTC (rev 67628)
@@ -56,7 +56,7 @@
from core.gconsole import GConsole, EVT_IGNORED_CMD_RUN
from core.giface import Notification
from gui_core.goutput import GConsoleWindow, GC_SEARCH, GC_PROMPT
-from modules.import_export import GdalOutputDialog, DxfImportDialog, GdalImportDialog
+from modules.import_export import GdalOutputDialog, DxfImportDialog, GdalImportDialog, OgrImportDialog
from gui_core.dialogs import LocationDialog, MapsetDialog, CreateNewVector, GroupDialog, MapLayersDialog, QuitDialog
from modules.colorrules import RasterColorTable, VectorColorTable
from gui_core.menu import Menu, SearchModuleWindow
@@ -1712,13 +1712,13 @@
def OnImportOgrLayers(self, event, cmd = None):
"""Convert multiple OGR layers to GRASS vector map layers"""
- dlg = GdalImportDialog(parent = self, giface = self._giface, ogr = True)
+ dlg = OgrImportDialog(parent = self, giface = self._giface)
dlg.CentreOnScreen()
dlg.Show()
def OnLinkOgrLayers(self, event, cmd = None):
"""Links multiple OGR layers to GRASS vector map layers"""
- dlg = GdalImportDialog(parent = self, giface = self._giface, ogr = True, link = True)
+ dlg = OgrImportDialog(parent = self, giface = self._giface, link = True)
dlg.Show()
Modified: grass/trunk/gui/wxpython/modules/import_export.py
--- grass/trunk/gui/wxpython/modules/import_export.py 2016-01-23 04:03:12 UTC (rev 67627)
+++ grass/trunk/gui/wxpython/modules/import_export.py 2016-01-23 09:23:15 UTC (rev 67628)
@@ -7,6 +7,7 @@
- :class:`ImportDialog`
- :class:`GdalImportDialog`
- :class:`GdalOutputDialog`
+ - :class:`OgrOutputDialog`
- :class:`DxfImportDialog`
- :class:`ReprojectionDialog`
@@ -22,6 +23,7 @@
import os
import wx
+import wx.lib.flatnotebook as FN
import wx.lib.filebrowsebutton as filebrowse
from grass.script import core as grass
@@ -29,8 +31,9 @@
from core import globalvar
from core.gcmd import RunCommand, GMessage, GWarning
+from gui_core.forms import CmdPanel
from gui_core.gselect import OgrTypeSelect, GdalSelect, SubGroupSelect
-from gui_core.widgets import LayersList, GListCtrl
+from gui_core.widgets import LayersList, GListCtrl, GNotebook
from core.utils import GetValidLayerName, _
from core.settings import UserSettings, GetDisplayVectSettings
@@ -73,43 +76,7 @@
self.list = LayersList(parent = self.panel, columns = columns)
self.list.LoadData()
- self.optionBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
- label = "%s" % _("Options"))
- cmd = self._getCommand()
- task = gtask.parse_interface(cmd)
- for f in task.get_options()['flags']:
- name = f.get('name', '')
- desc = f.get('label', '')
- if not desc:
- desc = f.get('description', '')
- if not name and not desc:
- continue
- if cmd == 'r.import':
- continue
- elif cmd == 'r.external' and name not in ('o', 'e', 'r', 'h', 'v'):
- continue
- elif cmd == 'v.in.ogr' and name not in ('c', 'z', 't', 'o', 'r', 'e', 'w'):
- continue
- elif cmd == 'v.external' and name not in ('b'):
- continue
- elif cmd == 'v.in.dxf' and name not in ('e', 't', 'b', 'f', 'i'):
- continue
- self.options[name] = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
- label = desc)
- for p in task.get_options()['params']:
- name = p.get('name', '')
- desc = p.get('label', '')
- if not desc:
- desc = p.get('description', '')
- continue
- if cmd == 'v.in.ogr' and name == 'encoding':
- self.options_par[name] = (_('Encoding'),
- wx.TextCtrl(parent = self.panel, id = wx.ID_ANY))
self.overwrite = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
label = _("Allow output files to overwrite existing files"))
self.overwrite.SetValue(UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'))
@@ -133,7 +100,33 @@
self.btn_run.Bind(wx.EVT_BUTTON, self.OnRun)
self.Bind(wx.EVT_CLOSE, lambda evt: self.Destroy())
+ self.notebook = GNotebook(parent = self,
+ style = FN.FNB_FANCY_TABS | FN.FNB_BOTTOM |
+ FN.FNB_NO_X_BUTTON)
+ self.notebook.AddPage(page = self.panel,
+ text=_('Source settings'),
+ name = 'source')
+ self.createSettingsPage()
+ def createSettingsPage(self):
+ self._blackList = { 'enabled' : True,
+ 'items' : {self._getCommand() : {'params' : self._getBlackListedParameters(),
+ 'flags' : self._getBlackListedFlags()}}}
+ grass_task = gtask.parse_interface(self._getCommand(),
+ blackList=self._blackList)
+ self.advancedPagePanel = CmdPanel(parent=self, giface=None, task=grass_task, frame=None)
+ self.notebook.AddPage(page = self.advancedPagePanel,
+ text=_('Import settings'),
+ name = 'settings')
def doLayout(self):
"""Do layout"""
dialogSizer = wx.BoxSizer(wx.VERTICAL)
@@ -152,28 +145,7 @@
dialogSizer.Add(item = layerSizer, proportion = 1,
flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 5)
- # options
- optionSizer = wx.StaticBoxSizer(self.optionBox, wx.VERTICAL)
- for key in self.options.keys():
- optionSizer.Add(item = self.options[key], proportion = 0)
- if self.options_par:
- gridBox = wx.GridBagSizer(vgap = 5, hgap = 5)
- row = 0
- for label, win in self.options_par.itervalues():
- gridBox.Add(item = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
- label = label + ':'),
- pos = (row, 0), flag = wx.ALIGN_CENTER_VERTICAL)
- gridBox.Add(item = win, pos = (row, 1), flag = wx.EXPAND)
- row += 1
- gridBox.AddGrowableCol(1)
- optionSizer.Add(item = gridBox, proportion = 0,
- flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 5)
- dialogSizer.Add(item = optionSizer, proportion = 0,
dialogSizer.Add(item = self.overwrite, proportion = 0,
flag = wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
@@ -214,8 +186,16 @@
def _getCommand(self):
"""Get command"""
- return ''
+ raise NotImplementedError()
+ def _getBlackListedParameters(self):
+ """Get parameters which will not be showed in Settings page"""
+ def _getBlackListedFlags(self):
+ """Get flags which will not be showed in Settings page"""
def OnClose(self, event = None):
"""Close dialog"""
self.Close()
@@ -292,39 +272,68 @@
"""Do what has to be done after importing"""
pass
+ def _getLayersToReprojetion(self, projMatch_idx, grassName_idx):
+ """If there are layers with different projection from loation projection,
+ show dialog to user to explicitly select layers which will be reprojected..."""
+ differentProjLayers = []
+ data = self.list.GetData(checked=True)
+ for itm in data:
+ layerId = itm[-1]
+ # select only layers with different projetion
+ if self.layersData[layerId][projMatch_idx] == 0:
+ dt = [itm[0], itm[grassName_idx]]
+ differentProjLayers.append(tuple(dt))
+ layers = self.list.GetLayers()
+ if differentProjLayers:
+ dlg = RerojectionDialog(
+ parent=self, giface=self._giface, data=differentProjLayers)
+ ret = dlg.ShowModal()
+ if ret == wx.ID_OK:
+ # do not import unchecked layers
+ for itm in reversed(list(dlg.GetData(checked=False))):
+ idx = itm[-1]
+ layers.pop(idx)
+ else:
+ return None;
+ return layers
+ def getSettingsPageCmd(self):
+ return self.advancedPagePanel.createCmd(ignoreErrors=True, ignoreRequired=True)
class GdalImportDialog(ImportDialog):
- def __init__(self, parent, giface, ogr = False, link = False):
- """Dialog for bulk import of various raster/vector data
+ def __init__(self, parent, giface, link=False):
+ """Dialog for bulk import of various raster data
.. todo::
- Split into GdalImportDialog and OgrImportDialog, split importing logic from gui code
+ split importing logic from gui code
:param parent: parent window
- :param ogr: True for OGR (vector) otherwise GDAL (raster)
:param link: True for linking data otherwise importing data
self._giface = giface
self.link = link
- self.ogr = ogr
self.layersData = []
- if ogr:
- ImportDialog.__init__(self, parent, giface=giface, itype='ogr')
- if link:
- self.SetTitle(_("Link external vector data"))
- else:
- self.SetTitle(_("Import vector data"))
+ ImportDialog.__init__(self, parent, giface=giface, itype='gdal')
+ if link:
+ self.SetTitle(_("Link external raster data"))
else:
- ImportDialog.__init__(self, parent, giface=giface, itype='gdal')
- if link:
- self.SetTitle(_("Link external raster data"))
- else:
- self.SetTitle(_("Import raster data"))
+ self.SetTitle(_("Import raster data"))
self.dsnInput = GdalSelect(parent = self, panel = self.panel,
- ogr = ogr, link = link)
+ ogr = False, link = link)
self.dsnInput.AttachSettings()
self.dsnInput.reloadDataRequired.connect(self.reload)
@@ -355,7 +364,7 @@
data = self.list.GetLayers()
- data = self._getLayersToReprojetion()
+ data = self._getLayersToReprojetion(2, 3)
if data is None:
return;
@@ -368,85 +377,38 @@
dsn = self.dsnInput.GetDsn()
ext = self.dsnInput.GetFormatExt()
- # determine data driver for PostGIS links
- self.popOGR = False
- if self.importType == 'ogr' and \
- self.dsnInput.GetType() == 'db' and \
- self.dsnInput.GetFormat() == 'PostgreSQL' and \
- 'GRASS_VECTOR_OGR' not in os.environ:
- self.popOGR = True
- os.environ['GRASS_VECTOR_OGR'] = '1'
for layer, output, listId in data:
userData = {}
- if self.importType == 'ogr':
+ if self.dsnInput.GetType() == 'dir':
+ idsn = os.path.join(dsn, layer)
+ else:
+ idsn = dsn
- if ext and layer.rfind(ext) > -1:
- layer = layer.replace('.' + ext, '')
- if '|' in layer:
- layer, geometry = layer.split('|', 1)
- else:
- geometry = None
- if self.link:
- cmd = ['v.external',
- 'input=%s' % dsn,
- 'output=%s' % output,
- 'layer=%s' % layer]
+ # check number of bands
+ nBandsStr = RunCommand('r.in.gdal',
+ flags = 'p',
+ input = idsn, read = True)
+ nBands = -1
+ if nBandsStr:
+ try:
+ nBands = int(nBandsStr.rstrip('\n'))
+ except:
+ pass
+ if nBands < 0:
+ GWarning(_("Unable to determine number of raster bands"),
+ parent = self)
+ nBands = 1
- elif self.layersData[listId][3] == 0:
- cmd = ['v.import',
- 'input=%s' % dsn,
- 'layer=%s' % layer,
- 'output=%s' % output]
- else:
- cmd = ['v.in.ogr',
- 'input=%s' % dsn,
- if geometry:
- cmd.append('geometry=%s' % geometry)
- else: # gdal
- if self.dsnInput.GetType() == 'dir':
- idsn = os.path.join(dsn, layer)
- else:
- idsn = dsn
- # check number of bands
- nBandsStr = RunCommand('r.in.gdal',
- flags = 'p',
- input = idsn, read = True)
- nBands = -1
- if nBandsStr:
- try:
- nBands = int(nBandsStr.rstrip('\n'))
- except:
- pass
- if nBands < 0:
- GWarning(_("Unable to determine number of raster bands"),
- parent = self)
- nBands = 1
- userData['nbands'] = nBands
- if self.link:
- cmd = ['r.external',
- 'input=%s' % idsn,
- else:
- cmd = ['r.import',
+ userData['nbands'] = nBands
+ cmd = self.getSettingsPageCmd()
+ cmd.append('input=%s' % dsn)
+ cmd.append('output=%s' % output)
if self.overwrite.IsChecked():
cmd.append('--overwrite')
- if self.options[key].IsChecked():
- cmd.append('-%s' % key)
- for key in self.options_par.keys():
- value = self.options_par[key][1].GetValue()
- if value:
- cmd.append('%s=%s' % (key, value))
if UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled') and \
'--overwrite' not in cmd:
@@ -454,49 +416,135 @@
# run in Layer Manager
self._giface.RunCmd(cmd, onDone = self.OnCmdDone, userData = userData)
+ def OnCmdDone(self, event):
+ """Load layers and close if required"""
+ if not hasattr(self, 'AddLayers'):
+ return
- def _getLayersToReprojetion(self):
- """If there are layers with different projection from loation projection,
- show dialog to user to explicitly select layers which will be reprojected..."""
- differentProjLayers = []
- data = self.list.GetData(checked=True)
+ self.AddLayers(event.returncode, event.cmd, event.userData)
- projMatch_idx = 3
- grassName_idx = 4
- else:#gdal
- projMatch_idx = 2
- grassName_idx = 3
+ if event.returncode == 0 and self.closeOnFinish.IsChecked():
+ self.Close()
- for itm in data:
+ def _getCommand(self):
+ """Get command"""
+ if self.link:
+ return 'r.external'
+ else:
+ return 'r.import'
- layerId = itm[-1]
+ return ['input', 'output']
- # select only layers with different projetion
- if self.layersData[layerId][projMatch_idx] == 0:
- dt = [itm[0], itm[grassName_idx]]
- differentProjLayers.append(tuple(dt))
+ return ['overwrite']
+class OgrImportDialog(ImportDialog):
+ """Dialog for bulk import of various vector data
+ .. todo::
+ :param parent: parent window
+ :param link: True for linking data otherwise importing data
+ self._giface = giface
+ self.link = link
+ self.layersData = []
+ ImportDialog.__init__(self, parent, giface=giface, itype='ogr')
+ if link:
+ self.SetTitle(_("Link external vector data"))
+ else:
+ self.SetTitle(_("Import vector data"))
- layers = self.list.GetLayers()
+ self.dsnInput = GdalSelect(parent = self, panel = self.panel,
+ ogr = True, link = link)
+ self.dsnInput.AttachSettings()
+ self.dsnInput.reloadDataRequired.connect(self.reload)
+ if link:
+ self.add.SetLabel(_("Add linked layers into layer tree"))
+ else:
+ self.add.SetLabel(_("Add imported layers into layer tree"))
- if differentProjLayers:
+ self.add.SetValue(UserSettings.Get(group = 'cmd', key = 'addNewLayer', subkey = 'enabled'))
- dlg = RerojectionDialog(
- parent=self, giface=self._giface, data=differentProjLayers)
- ret = dlg.ShowModal()
+ if link:
+ self.btn_run.SetLabel(_("&Link"))
+ self.btn_run.SetToolTipString(_("Link selected layers"))
+ else:
+ self.btn_run.SetLabel(_("&Import"))
+ self.btn_run.SetToolTipString(_("Import selected layers"))
- if ret == wx.ID_OK:
+ self.doLayout()
- # do not import unchecked layers
- for itm in reversed(list(dlg.GetData(checked=False))):
- idx = itm[-1]
- layers.pop(idx)
+ def reload(self, data, listData):
+ self.list.LoadData(listData);
+ self.layersData = data;
+ def OnRun(self, event):
+ """Import/Link data (each layes as separate vector map)"""
+ self.commandId = -1
+ data = self.list.GetLayers()
+ data = self._getLayersToReprojetion(3, 4)
+ if data is None:
+ return;
+ if not data:
+ GMessage(_("No layers selected. Operation canceled."),
+ parent = self)
+ return
+ dsn = self.dsnInput.GetDsn()
+ ext = self.dsnInput.GetFormatExt()
+ # determine data driver for PostGIS links
+ self.popOGR = False
+ if self.dsnInput.GetType() == 'db' and \
+ self.dsnInput.GetFormat() == 'PostgreSQL' and \
+ 'GRASS_VECTOR_OGR' not in os.environ:
+ self.popOGR = True
+ os.environ['GRASS_VECTOR_OGR'] = '1'
+ for layer, output, listId in data:
+ userData = {}
+ if ext and layer.rfind(ext) > -1:
+ layer = layer.replace('.' + ext, '')
+ if '|' in layer:
+ layer, geometry = layer.split('|', 1)
else:
- return None;
+ geometry = None
- return layers
+ #TODO
+ #if geometry:
+ # cmd.append('geometry=%s' % geometry)
+ cmd.append('layer=%s' % layer)
+ if self.overwrite.IsChecked():
+ cmd.append('--overwrite')
+ #TODO options
+ if UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled') and \
+ '--overwrite' not in cmd:
+ # run in Layer Manager
+ self._giface.RunCmd(cmd, onDone = self.OnCmdDone, userData = userData)
@@ -513,18 +561,18 @@
"""Get command"""
if self.link:
- if self.ogr:
- return 'v.external'
- else:
- return 'r.external'
+ return 'v.external'
else:
- if self.ogr:
- return 'v.in.ogr'
- else:
- return 'r.import'
- return ''
+ return 'v.import'
+ """Get parametrs which will not be showed in Settings page"""
+ return ['input', 'output', 'layer']
class GdalOutputDialog(wx.Dialog):
def __init__(self, parent, id = wx.ID_ANY, ogr = False,
style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, *kwargs):
@@ -638,6 +686,10 @@
"""Get command"""
return 'v.in.dxf'
+ return ['input', 'output', 'layers']
@@ -651,12 +703,13 @@
inputDxf = self.dsnInput.GetValue()
- for layer, output in data:
- cmd = ['v.in.dxf',
- 'input=%s' % inputDxf,
- 'layers=%s' % layer,
+ for layer, output, itemId in data:
+ cmd.append('input=%s' % inputDxf)
@@ -703,6 +756,19 @@
self.list.LoadData(data)
+ """Get command"""
+ return 'v.in.dxf'
class RerojectionDialog(wx.Dialog):
def __init__(self, parent, giface, data,
