[GRASS-SVN] r67632 - grass/trunk/scripts/v.import
Sat Jan 23 04:33:29 PST 2016
Author: martinl
Date: 2016-01-23 04:33:29 -0800 (Sat, 23 Jan 2016)
New Revision: 67632
   grass/trunk/scripts/v.import/v.import.py
v.import: add -o flag
Modified: grass/trunk/scripts/v.import/v.import.py
--- grass/trunk/scripts/v.import/v.import.py	2016-01-23 12:30:10 UTC (rev 67631)
+++ grass/trunk/scripts/v.import/v.import.py	2016-01-23 12:33:29 UTC (rev 67632)
@@ -91,8 +91,12 @@
 #% key: l
 #% description: List available OGR layers in data source and exit
 #%end
+#%flag
+#% key: o
+#% label: Override projection check (use current location's projection)
+#% description: Assume that the dataset has same projection as the current location
+#%end
 import sys
 import os
 import atexit
@@ -134,9 +138,12 @@
     output = options['output']
     layers = options['layer']
-    vflags = None
+    vflags = ''
     if options['extent'] == 'region':
-        vflags = 'r'
+        vflags += 'r'
+    if flags['o']:
+        vflags += 'o'
     vopts = {}
     if options['encoding']:
         vopts['encoding'] = options['encoding']
@@ -193,8 +200,8 @@
     os.environ['GISRC'] = str(tgtgisrc)
     # try v.in.ogr directly
-    if grass.run_command('v.in.ogr', input=OGRdatasource, flags='j',
-                         errors='status', quiet=True) == 0:
+    if flags['o'] or grass.run_command('v.in.ogr', input=OGRdatasource, flags='j',
+                                       errors='status', quiet=True) == 0:
         try:
                               flags=vflags, **vopts)
