[GRASS-SVN] r67640 - in grass/trunk: gui/wxpython/gui_core lib/python/script
svn_grass at osgeo.org
Sat Jan 23 08:35:35 PST 2016
Author: martinl
Date: 2016-01-23 08:35:35 -0800 (Sat, 23 Jan 2016)
New Revision: 67640
grass/trunk/gui/wxpython/gui_core/vselect.py
grass/trunk/lib/python/script/vector.py
pythonlib: vector_what(): add new parameter to skip quering attributes (no backport is needed)
Modified: grass/trunk/gui/wxpython/gui_core/vselect.py
--- grass/trunk/gui/wxpython/gui_core/vselect.py 2016-01-23 15:49:49 UTC (rev 67639)
+++ grass/trunk/gui/wxpython/gui_core/vselect.py 2016-01-23 16:35:35 UTC (rev 67640)
@@ -273,7 +273,7 @@
try:
query = grass.vector_what(map=[self.mapName],
coord=self.mapWin.GetLastEN(),
- distance=threshold)
+ distance=threshold, skip_attributes=True)
except grass.ScriptError:
GError(parent=self,
message=_("Failed to query vector map(s) <%s>.") % self.map)
Modified: grass/trunk/lib/python/script/vector.py
--- grass/trunk/lib/python/script/vector.py 2016-01-23 15:49:49 UTC (rev 67639)
+++ grass/trunk/lib/python/script/vector.py 2016-01-23 16:35:35 UTC (rev 67640)
@@ -266,7 +266,7 @@
orderedDict = None
-def vector_what(map, coord, distance=0.0, ttype=None, encoding=None):
+def vector_what(map, coord, distance=0.0, ttype=None, encoding=None, skip_attributes=False):
"""Query vector map at given locations
To query one vector map at one location
@@ -322,6 +322,8 @@
:param distance: query threshold distance (in map units)
:param ttype: list of topology types (default of v.what are point, line,
area, face)
+ :param encoding: attributes encoding
+ :param skip_attributes: True to skip quering attributes
:return: parsed list
@@ -344,7 +346,7 @@
coord_list.append('%f,%f' % (e, n))
cmdParams = dict(quiet = True,
- flags = 'aj',
+ flags = 'j' if skip_attributes else 'aj',
map = ','.join(map_list),
layer = ','.join(layer_list),
coordinates = ','.join(coord_list),
