[GRASS-SVN] r67644 - in grass/trunk/gui/wxpython: core modules
svn_grass at osgeo.org
Sat Jan 23 11:26:53 PST 2016
Author: annakrat
Date: 2016-01-23 11:26:53 -0800 (Sat, 23 Jan 2016)
New Revision: 67644
grass/trunk/gui/wxpython/core/gconsole.py
grass/trunk/gui/wxpython/modules/import_export.py
wxGUI: fix adding layers to tree in import dialog (#2860)
Modified: grass/trunk/gui/wxpython/core/gconsole.py
--- grass/trunk/gui/wxpython/core/gconsole.py 2016-01-23 18:10:26 UTC (rev 67643)
+++ grass/trunk/gui/wxpython/core/gconsole.py 2016-01-23 19:26:53 UTC (rev 67644)
@@ -116,7 +116,7 @@
os.environ['GRASS_MESSAGE_FORMAT'] = 'gui'
while True:
requestId, args, kwds = self.requestQ.get()
- for key in ('callable', 'onDone', 'onPrepare', 'userData', 'notification'):
+ for key in ('callable', 'onDone', 'onPrepare', 'userData', 'addLayer', 'notification'):
if key in kwds:
vars()[key] = kwds[key]
del kwds[key]
@@ -202,6 +202,7 @@
pid=requestId,
onDone=vars()['onDone'],
userData=vars()['userData'],
+ addLayer=vars()['addLayer'],
notification=vars()['notification'])
# send event
@@ -424,7 +425,8 @@
self.writeError.emit(text=text)
def RunCmd(self, command, compReg=True, skipInterface=False,
- onDone=None, onPrepare=None, userData=None, notification=Notification.MAKE_VISIBLE):
+ onDone=None, onPrepare=None, userData=None, addLayer=None,
+ notification=Notification.MAKE_VISIBLE):
"""Run command typed into console command prompt (GPrompt).
.. todo::
@@ -445,6 +447,7 @@
given
:param onDone: function to be called when command is finished
:param onPrepare: function to be called before command is launched
+ :param addLayer: to be passed in the mapCreated signal
:param userData: data defined for the command
if len(command) == 0:
@@ -531,7 +534,7 @@
stdout=self.cmdStdOut,
stderr=self.cmdStdErr,
onDone=onDone, onPrepare=onPrepare,
- userData=userData,
+ userData=userData, addLayer=addLayer,
env=os.environ.copy(),
notification=notification)
self.cmdOutputTimer.Start(50)
@@ -583,7 +586,7 @@
@@ -689,7 +692,7 @@
if '@' not in lname:
lname += '@' + grass.gisenv()['MAPSET']
if grass.find_file(lname, element=p.get('element'))['fullname']:
- self.mapCreated.emit(name=lname, ltype=prompt)
+ self.mapCreated.emit(name=lname, ltype=prompt, add=event.addLayer)
if name == 'r.mask':
self.updateMap.emit()
Modified: grass/trunk/gui/wxpython/modules/import_export.py
--- grass/trunk/gui/wxpython/modules/import_export.py 2016-01-23 18:10:26 UTC (rev 67643)
+++ grass/trunk/gui/wxpython/modules/import_export.py 2016-01-23 19:26:53 UTC (rev 67644)
@@ -411,7 +411,7 @@
cmd.append('--overwrite')
# run in Layer Manager
- self._giface.RunCmd(cmd, onDone = self.OnCmdDone, userData = userData)
+ self._giface.RunCmd(cmd, onDone=self.OnCmdDone, userData=userData, addLayer=False)
def OnCmdDone(self, event):
"""Load layers and close if required"""
