[GRASS-SVN] r67646 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Sat Jan 23 14:16:31 PST 2016
Author: martinl
Date: 2016-01-23 14:16:31 -0800 (Sat, 23 Jan 2016)
New Revision: 67646
grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: msg fix (see r67645)
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2016-01-23 20:49:52 UTC (rev 67645)
+++ grass/trunk/vector/v.in.ogr/main.c 2016-01-23 22:16:31 UTC (rev 67646)
@@ -283,7 +283,7 @@
flag.over->label =
_("Override projection check (use current location's projection)");
flag.over->description =
- _("Assume that the dataset has same projection as the current location");
+ _("Assume that the dataset has the same projection as the current location");
flag.proj = G_define_flag();
flag.proj->key = 'j';
