[GRASS-SVN] r67694 - in grass/trunk: display/d.mon general/g.copy general/g.gisenv general/g.mapsets gui/wxpython/rlisetup imagery/i.his.rgb imagery/i.rgb.his raster/r.cross raster/r.his
svn_grass at osgeo.org
Thu Jan 28 03:21:35 PST 2016
Author: neteler
Date: 2016-01-28 03:21:34 -0800 (Thu, 28 Jan 2016)
New Revision: 67694
grass/trunk/display/d.mon/d.mon.html
grass/trunk/general/g.copy/g.copy.html
grass/trunk/general/g.gisenv/g.gisenv.html
grass/trunk/general/g.mapsets/g.mapsets.html
grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html
grass/trunk/imagery/i.his.rgb/i.his.rgb.html
grass/trunk/imagery/i.rgb.his/i.rgb.his.html
grass/trunk/raster/r.cross/r.cross.html
grass/trunk/raster/r.his/r.his.html
manual: avoid specific gender; HTML cosmetics
Modified: grass/trunk/display/d.mon/d.mon.html
--- grass/trunk/display/d.mon/d.mon.html 2016-01-27 23:49:21 UTC (rev 67693)
+++ grass/trunk/display/d.mon/d.mon.html 2016-01-28 11:21:34 UTC (rev 67694)
@@ -42,7 +42,7 @@
be selected for graphics output.
<p>The user can run multiple graphics monitors by simply starting each of
-the graphics monitors he wishes to direct output to.
+the graphics monitors the user wishes to direct output to.
<h3>Releasing (unselecting) a monitor</h3>
Modified: grass/trunk/general/g.copy/g.copy.html
--- grass/trunk/general/g.copy/g.copy.html 2016-01-27 23:49:21 UTC (rev 67693)
+++ grass/trunk/general/g.copy/g.copy.html 2016-01-28 11:21:34 UTC (rev 67694)
@@ -1,8 +1,8 @@
<h2>DESCRIPTION</h2>
-A user may access data stored under the other mapsets listed in his
+A user may access data stored under the other mapsets listed in their
mapset search path. However, the user may only modify data stored
-under his own current mapset. <em>g.copy</em> allows the user to copy
+under their own current mapset. <em>g.copy</em> allows the user to copy
existing data files <b>from</b> other mapsets <b>to</b> the user's
current mapset ($MAPSET). The files to be copied must exist in the
user's current mapset search path and location; output is sent to the
Modified: grass/trunk/general/g.gisenv/g.gisenv.html
--- grass/trunk/general/g.gisenv/g.gisenv.html 2016-01-27 23:49:21 UTC (rev 67693)
+++ grass/trunk/general/g.gisenv/g.gisenv.html 2016-01-28 11:21:34 UTC (rev 67694)
@@ -73,9 +73,9 @@
geographically relevant to the <em>LOCATION_NAME</em>, and all store
data in the same map coordinate system. Frequently, maps are placed
into different mapsets to distinguish file ownership - e.g., each user
-might have his own mapset, storing any maps that he has created and/or
-are relevant to his work.) During each GRASS session, the user must
-choose one mapset to be the <em>current mapset</em>; the current
+might have one or more own mapset(s), storing any maps that the user has
+created and/or are relevant to the own work.) During each GRASS session, the
+user must choose one mapset to be the <em>current mapset</em>; the current
mapset setting is given by <em>MAPSET</em>, and is a subdirectory
of <em>LOCATION_NAME</em>. During a single GRASS session, the user
can use available data in any of the mapsets stored under the
Modified: grass/trunk/general/g.mapsets/g.mapsets.html
--- grass/trunk/general/g.mapsets/g.mapsets.html 2016-01-27 23:49:21 UTC (rev 67693)
+++ grass/trunk/general/g.mapsets/g.mapsets.html 2016-01-28 11:21:34 UTC (rev 67694)
@@ -19,7 +19,7 @@
<p>
The user can add, modify, and delete data layers that exist under
-his <em>current mapset</em>. Although the user can
+their <em>current mapset</em>. Although the user can
also <em>access</em> (i.e., use) data that are stored under
<em>other</em> mapsets in the same GRASS location using the
<tt>mapname at mapsetname</tt> notation or mapset search path, the user
@@ -42,7 +42,7 @@
GRASS location, lists mapsets to which the user currently has access,
and lists the order in which accessible mapsets will be accessed by
GRASS programs searching for data files. The user is then given the
-opportunity to add or delete mapset names from his search path, or
+opportunity to add or delete mapset names from the search path, or
modify the order in which mapsets will be accessed.
<p>
Modified: grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html
--- grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html 2016-01-27 23:49:21 UTC (rev 67693)
+++ grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html 2016-01-28 11:21:34 UTC (rev 67694)
@@ -144,7 +144,7 @@
<li><em>Select areas from the overlaid vector map</em>:
the sample areas are defined by the vector map selected above.
For every cat in vector map, the procedure prompts the
- user if he wants to include it as sample area.
+ user if they want to include it as sample area.
The resulting configuration file can be used only with the
specified raster map, and the procedure can be used only if
whole map layer is selected as sampling frame.</li>
Modified: grass/trunk/imagery/i.his.rgb/i.his.rgb.html
--- grass/trunk/imagery/i.his.rgb/i.his.rgb.html 2016-01-27 23:49:21 UTC (rev 67693)
+++ grass/trunk/imagery/i.his.rgb/i.his.rgb.html 2016-01-28 11:21:34 UTC (rev 67694)
@@ -5,8 +5,8 @@
and saturation components and produces three output raster
map layers representing the red, green and blue components
of this data. The output raster map layers are created by
-a standard hue-intensity-saturation (his) to red-green-blue
-(rgb) color transformation. Each output raster map layer
+a standard hue-intensity-saturation (HIS) to red-green-blue
+(RGB) color transformation. Each output raster map layer
is given a linear gray scale color table. The current
geographic region and mask settings are respected.
Modified: grass/trunk/imagery/i.rgb.his/i.rgb.his.html
--- grass/trunk/imagery/i.rgb.his/i.rgb.his.html 2016-01-27 23:49:21 UTC (rev 67693)
+++ grass/trunk/imagery/i.rgb.his/i.rgb.his.html 2016-01-28 11:21:34 UTC (rev 67694)
@@ -5,8 +5,8 @@
blue components and produces three output raster map layers
representing the hue, intensity, and saturation of the
data. The output raster map layers are created by a
-standard red-green-blue (rgb) to hue-intensity-saturation
-(his) color transformation. Each output raster map layer
+standard red-green-blue (RGB) to hue-intensity-saturation
+(HIS) color transformation. Each output raster map layer
geographic region definition and mask settings are
respected.
Modified: grass/trunk/raster/r.cross/r.cross.html
--- grass/trunk/raster/r.cross/r.cross.html 2016-01-27 23:49:21 UTC (rev 67693)
+++ grass/trunk/raster/r.cross/r.cross.html 2016-01-28 11:21:34 UTC (rev 67694)
@@ -86,13 +86,8 @@
A random color table is also generated for the <em>output</em> map layer.
-<h2>NOTES</h2>
+<!-- TODO: add example -->
-When run non-interactively, <em>r.cross</em> will not protect existing
-files in the user's mapset. If the user specifies an <em>output</em>
-file name that already exists in his mapset, the existing file will
-be overwritten by the new <em>r.cross</em> output.
<h2>SEE ALSO</h2>
<em><a href="r.covar.html">r.covar</a></em>,
Modified: grass/trunk/raster/r.his/r.his.html
--- grass/trunk/raster/r.his/r.his.html 2016-01-27 23:49:21 UTC (rev 67693)
+++ grass/trunk/raster/r.his/r.his.html 2016-01-28 11:21:34 UTC (rev 67694)
@@ -105,7 +105,8 @@
<div class="code"><pre>
r.mapcalc "elevation_shaded_relief_bright_50 = #elevation_shaded_relief * 1.5"
r.colors elevation_shaded_relief_bright_50 color=grey255
-r.his hue=elevation intensity=elevation_shaded_relief_bright_50 red=shadedmap_r green=shadedmap_g blue=shadedmap_b
+r.his hue=elevation intensity=elevation_shaded_relief_bright_50 \
+ red=shadedmap_r green=shadedmap_g blue=shadedmap_b
d.mon wx1
d.rgb red=shadedmap_r green=shadedmap_g blue=shadedmap_b
