[GRASS-SVN] r67703 - in grass/trunk: general/g.proj gui/wxpython/lmgr imagery/i.landsat.acca lib/gis lib/imagery lib/ogsf lib/python/gunittest/testsuite lib/python/temporal lib/raster locale/po raster/r.mapcalc raster/r.neighbors raster/r.proj raster/r.resamp.stats raster/r.series raster/r.stream.extract raster/r.watershed/ram raster3d/r3.in.ascii raster3d/r3.neighbors scripts/r.in.aster vector/v.rectify vector/v.transform vector/v.vect.stats
Fri Jan 29 01:29:57 PST 2016
Author: mlennert
Date: 2016-01-29 01:29:57 -0800 (Fri, 29 Jan 2016)
New Revision: 67703
   grass/trunk/general/g.proj/g.proj.html
   grass/trunk/gui/wxpython/lmgr/frame.py
   grass/trunk/imagery/i.landsat.acca/i.landsat.acca.html
   grass/trunk/lib/gis/verbose.c
   grass/trunk/lib/imagery/iclass_statistics.c
   grass/trunk/lib/ogsf/gvld.c
   grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py
   grass/trunk/lib/python/temporal/open_stds.py
   grass/trunk/lib/python/temporal/temporal_algebra.py
   grass/trunk/lib/raster/range.c
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fi.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ro.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
   grass/trunk/raster/r.mapcalc/map.c
   grass/trunk/raster/r.mapcalc/map3.c
   grass/trunk/raster/r.neighbors/main.c
   grass/trunk/raster/r.proj/r.proj.html
   grass/trunk/raster/r.resamp.stats/main.c
   grass/trunk/raster/r.series/main.c
   grass/trunk/raster/r.series/r.series.html
   grass/trunk/raster/r.stream.extract/r.stream.extract.html
   grass/trunk/raster/r.watershed/ram/init_vars.c
   grass/trunk/raster3d/r3.in.ascii/r3.in.ascii.html
   grass/trunk/raster3d/r3.neighbors/main.c
   grass/trunk/scripts/r.in.aster/r.in.aster.html
   grass/trunk/vector/v.rectify/v.rectify.html
   grass/trunk/vector/v.transform/main.c
   grass/trunk/vector/v.vect.stats/main.c
Various typos (fixes #2882 Patch for various spelling errors (sebastic))
Modified: grass/trunk/general/g.proj/g.proj.html
--- grass/trunk/general/g.proj/g.proj.html	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/general/g.proj/g.proj.html	2016-01-29 09:29:57 UTC (rev 67703)
@@ -137,7 +137,7 @@
 </pre></div>
 <p>Create a new location with the co-ordinate system referred to by EPSG code
-4326 (Latitude-Longitude/WGS84), without explicitly specifiying datum
+4326 (Latitude-Longitude/WGS84), without explicitly specifying datum
 transformation parameters:<br>
 <div class="code"><pre>
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2016-01-29 09:29:57 UTC (rev 67703)
@@ -1583,7 +1583,7 @@
         The parameters of all handlers which are associated with module
         and contained in menu/toolboxes must be event and cmd.
         When called from menu event is always None and cmd is the
-        associated command (list containing a module name and paremeters).
+        associated command (list containing a module name and parameters).
         .. todo::
             This documentation is actually documentation of some
Modified: grass/trunk/imagery/i.landsat.acca/i.landsat.acca.html
--- grass/trunk/imagery/i.landsat.acca/i.landsat.acca.html	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/imagery/i.landsat.acca/i.landsat.acca.html	2016-01-29 09:29:57 UTC (rev 67703)
@@ -23,7 +23,7 @@
 Run the standard ACCA algorithm with filling of small cloud holes
 (the <b>-f</b> flag): With per-band reflectance raster maps
 named <tt>226_62.toar.1, 226_62.toar.2, </tt> [...] and LANDSAT-7
-thermal band <tt>226_62.toar.61</tt>, outputing to a new raster map
+thermal band <tt>226_62.toar.61</tt>, outputting to a new raster map
 named <tt>226_62.acca</tt>:
Modified: grass/trunk/lib/gis/verbose.c
--- grass/trunk/lib/gis/verbose.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/lib/gis/verbose.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -30,7 +30,7 @@
 #define MAXLEVEL 3
 /*! \brief Standard verbosity level */
 #define STDLEVEL 2
-/*! \brief Minumum verbosity level (quiet) */
+/*! \brief Minimum verbosity level (quiet) */
 #define MINLEVEL 0
 static struct state {
Modified: grass/trunk/lib/imagery/iclass_statistics.c
--- grass/trunk/lib/imagery/iclass_statistics.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/lib/imagery/iclass_statistics.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -723,7 +723,7 @@
    \param statistics pointer to statistics structure
    \param band band index
-   \param[out] min minumum value
+   \param[out] min minimum value
    \return 1 on success
    \return 0 band index out of range
Modified: grass/trunk/lib/ogsf/gvld.c
--- grass/trunk/lib/ogsf/gvld.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/lib/ogsf/gvld.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -240,7 +240,7 @@
 	nz[i] = 0;
-    G_debug(5, "  intialize OK");
+    G_debug(5, "  initialize OK");
     for (z = 0; z < depths - 1; z++) {
 	zc = z * zres;
@@ -695,7 +695,7 @@
     for (i = 0; i < gvl->n_slices; i++) {
 	slice = gvl->slice[i];
-	/* intialize correct coords */
+	/* initialize correct coords */
 	if (slice->dir == X) {
 	    resx = gvl->yres;
 	    resy = gvl->zres;
Modified: grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py
--- grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py	2016-01-29 09:29:57 UTC (rev 67703)
@@ -48,7 +48,7 @@
     bottom=0,
-# v.info schools -g and reduced to minumum
+# v.info schools -g and reduced to minimum
 V_UNIVAR_SCHOOLS_EXTENDED = dict(
     name='schools',
     level=2,
Modified: grass/trunk/lib/python/temporal/open_stds.py
--- grass/trunk/lib/python/temporal/open_stds.py	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/lib/python/temporal/open_stds.py	2016-01-29 09:29:57 UTC (rev 67703)
@@ -25,7 +25,7 @@
 def open_old_stds(name, type, dbif=None):
     """This function opens an existing space time dataset and return the
-       created and intialized object of the specified type.
+       created and initialized object of the specified type.
        This function will call exit() or raise a
        grass.pygrass.messages.FatalError in case the type is wrong,
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py	2016-01-29 09:29:57 UTC (rev 67703)
@@ -2151,7 +2151,7 @@
         t[0] = t[1]
     def p_expr_strds_function(self, t):
-        # Specifiy a explicitely a space time raster dataset
+        # Explicitly specify a space time raster dataset
         # R = A : strds(B)
         expr : STRDS LPAREN stds RPAREN
@@ -2164,7 +2164,7 @@
                 print "Opening STRDS: ",  t[0]
     def p_expr_str3ds_function(self, t):
         # R = A : str3ds(B)
         expr : STR3DS LPAREN stds RPAREN
@@ -2177,7 +2177,7 @@
                 print "Opening STR3DS: ",  t[0]
     def p_expr_stvds_function(self, t):
-        # Specifiy a explicitely a space time vector dataset
+        # Explicitly specify a space time vector dataset
         # R = A : stvds(B)
         expr : STVDS LPAREN stds RPAREN
Modified: grass/trunk/lib/raster/range.c
--- grass/trunk/lib/raster/range.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/lib/raster/range.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -542,7 +542,7 @@
- * \brief Get minumum and maximum value from fp range
+ * \brief Get minimum and maximum value from fp range
  * Extract the min/max from the range structure <i>range</i>.  If the
  * range structure has no defined min/max (first!=0) there will not be
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_ar.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -35656,7 +35656,7 @@
 #: ../vector/v.transform/main.c:277
 #, fuzzy
-msgid "Tranforming features..."
+msgid "Transforming features..."
 msgstr "التوقيع ..."
 #: ../vector/v.transform/main.c:290
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_cs.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -36019,7 +36019,7 @@
 #, fuzzy
 msgstr "Převádím prvky..."
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_de.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -36089,7 +36089,7 @@
 #, fuzzy
 msgstr "Transformiere Feature..."
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_el.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -34271,7 +34271,7 @@
 #, fuzzy
 msgstr "Εγγραφή %s από %s..."
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_es.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -36223,7 +36223,7 @@
 #, fuzzy
 msgstr "Trasponiendo la matriz de valores propios..."
Modified: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_fi.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -32835,7 +32835,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_fr.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -37868,7 +37868,7 @@
 #, fuzzy
 msgstr "Rotation des données ... "
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_it.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -35500,7 +35500,7 @@
 #, fuzzy
 msgstr "Trasformazione degli elementi in corso..."
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_ja.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -35481,7 +35481,7 @@
 #, fuzzy
 msgstr "フィーチャーを変換中、、、"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_ko.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -34460,7 +34460,7 @@
 #, fuzzy
 msgstr "출력할 격자지도"
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_lv.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -35454,7 +35454,7 @@
 #, fuzzy
 msgstr "Drukā ... "
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_pl.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -35570,7 +35570,7 @@
 #, fuzzy
 msgstr "Wczytywanie danych..."
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_pt.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -36575,7 +36575,7 @@
 #, fuzzy
 msgstr "Rotacionando dados ... "
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -36496,7 +36496,7 @@
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_ro.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -33404,7 +33404,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_ru.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -36142,7 +36142,7 @@
 #, fuzzy
 msgstr "Трансформирование объектов..."
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_sl.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -35923,7 +35923,7 @@
 #, fuzzy
 msgstr "Ri¹em ..."
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_th.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -35760,7 +35760,7 @@
 #, fuzzy
 msgstr "กำลังอ่านข้อมูล ..."
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_tr.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -35113,7 +35113,7 @@
 #, fuzzy
 msgstr "Veri okunuyor..."
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_vi.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -36149,7 +36149,7 @@
 #, fuzzy
 msgstr "Đang chuyển đổi các đối tượng..."
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/locale/po/grassmods_zh.po	2016-01-29 09:29:57 UTC (rev 67703)
@@ -35841,7 +35841,7 @@
 #, fuzzy
 msgstr "读取地图"
Modified: grass/trunk/raster/r.mapcalc/map.c
--- grass/trunk/raster/r.mapcalc/map.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/raster/r.mapcalc/map.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -309,7 +309,7 @@
  * to compute the key and the index
  * This uses the BTREE library to manage the tree itself
- * btree structure must already be intialized
+ * btree structure must already be initialized
  * pcats structure must already contain category labels
Modified: grass/trunk/raster/r.mapcalc/map3.c
--- grass/trunk/raster/r.mapcalc/map3.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/raster/r.mapcalc/map3.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -257,7 +257,7 @@
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/raster/r.neighbors/main.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -56,7 +56,7 @@
 static struct menu menu[] = {
     {c_ave, w_ave, NO_CATS, 1, 1, T_FLOAT, "average", "average value"},
     {c_median, w_median, NO_CATS, 1, 0, T_FLOAT, "median", "median value"},
-    {c_mode, w_mode, NO_CATS, 1, 0, T_COPY, "mode", "most frequently occuring value"},
+    {c_mode, w_mode, NO_CATS, 1, 0, T_COPY, "mode", "most frequently occurring value"},
     {c_min, NULL, NO_CATS, 1, 0, T_COPY, "minimum", "lowest value"},
     {c_max, NULL, NO_CATS, 1, 0, T_COPY, "maximum", "highest value"},
     {c_range, NULL, NO_CATS, 1, 0, T_COPY, "range", "range value"},
Modified: grass/trunk/raster/r.proj/r.proj.html
--- grass/trunk/raster/r.proj/r.proj.html	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/raster/r.proj/r.proj.html	2016-01-29 09:29:57 UTC (rev 67703)
@@ -316,6 +316,6 @@
 Martin Schroeder, University of Heidelberg, Germany<br>
 Man page text from S.J.D. Cox, AGCRC, CSIRO Exploration & Mining, Nedlands, WA<br>
 Updated by <a href="mailto:morten at untamo.net">Morten Hulden</a><br>
-Datum tranformation support and cleanup by Paul Kelly
+Datum transformation support and cleanup by Paul Kelly
 <p><i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.resamp.stats/main.c
--- grass/trunk/raster/r.resamp.stats/main.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/raster/r.resamp.stats/main.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -30,7 +30,7 @@
 } menu[] = {
     {c_ave,    w_ave,    "average",  "average (mean) value"},
     {c_median, w_median, "median",   "median value"},
-    {c_mode,   w_mode,   "mode",     "most frequently occuring value"},
+    {c_mode,   w_mode,   "mode",     "most frequently occurring value"},
     {c_min,    w_min,    "minimum",  "lowest value"},
     {c_max,    w_max,    "maximum",  "highest value"},
     {c_quart1, w_quart1, "quart1",   "first quartile"},
Modified: grass/trunk/raster/r.series/main.c
--- grass/trunk/raster/r.series/main.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/raster/r.series/main.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -32,7 +32,7 @@
     {c_ave,    0, "average",    "average value"},
     {c_count,  1, "count",      "count of non-NULL cells"},
     {c_median, 0, "median",     "median value"},
-    {c_mode,   0, "mode",       "most frequently occuring value"},
+    {c_mode,   0, "mode",       "most frequently occurring value"},
     {c_min,    0, "minimum",    "lowest value"},
     {c_minx,   1, "min_raster", "raster with lowest value"},
     {c_max,    0, "maximum",    "highest value"},
Modified: grass/trunk/raster/r.series/r.series.html
--- grass/trunk/raster/r.series/r.series.html	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/raster/r.series/r.series.html	2016-01-29 09:29:57 UTC (rev 67703)
@@ -9,7 +9,7 @@
  <li>average: average value
  <li>count: count of non-NULL cells
  <li>median: median value
- <li>mode: most frequently occuring value
+ <li>mode: most frequently occurring value
  <li>minimum: lowest value
  <li>maximum: highest value
  <li>range: range of values (max - min)
Modified: grass/trunk/raster/r.stream.extract/r.stream.extract.html
--- grass/trunk/raster/r.stream.extract/r.stream.extract.html	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/raster/r.stream.extract/r.stream.extract.html	2016-01-29 09:29:57 UTC (rev 67703)
@@ -25,7 +25,7 @@
 depression map is provided.
 <p>
-Option <b>threshold</b> defines the minumum (optionally modifed) flow
+Option <b>threshold</b> defines the minimum (optionally modifed) flow
 accumulation value that will initiate a new stream. If Montgomery's
 method for channel initiation is used, the cell value of the
 accumulation input map is multiplied by <tt>(tan(local
Modified: grass/trunk/raster/r.watershed/ram/init_vars.c
--- grass/trunk/raster/r.watershed/ram/init_vars.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/raster/r.watershed/ram/init_vars.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -186,7 +186,7 @@
 	ele_scale = 10000;
     /* read elevation input and mark NULL/masked cells */
-    /* intialize accumulation and drainage direction */
+    /* initialize accumulation and drainage direction */
     MASK_flag = 0;
     do_points = nrows * ncols;
     for (r = 0; r < nrows; r++) {
Modified: grass/trunk/raster3d/r3.in.ascii/r3.in.ascii.html
--- grass/trunk/raster3d/r3.in.ascii/r3.in.ascii.html	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/raster3d/r3.in.ascii/r3.in.ascii.html	2016-01-29 09:29:57 UTC (rev 67703)
@@ -46,7 +46,7 @@
 The version option is self explaining. The order option specifies the row
 and depth order of the data in the input file.
 The supported row/depth ordering is documented in the <em>r3.out.ascii</em>
-manual page. The order of the data in the input file does not specifiy the
+manual page. The order of the data in the input file does not specify the
 data order in the generated output 3D raster map which is in any case
 <em>north -> south, west -> east, bottom -> top</em> order.
 So dependent on the order information the data is automatically imported
Modified: grass/trunk/raster3d/r3.neighbors/main.c
--- grass/trunk/raster3d/r3.neighbors/main.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/raster3d/r3.neighbors/main.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -42,7 +42,7 @@
     c_ave, "average", "average value"}, {
     c_median, "median", "median value"}, {
-    c_mode, "mode", "most frequently occuring value"}, {
+    c_mode, "mode", "most frequently occurring value"}, {
     c_min, "minimum", "lowest value"}, {
     c_max, "maximum", "highest value"}, {
     c_range, "range", "range value"}, {
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.html
--- grass/trunk/scripts/r.in.aster/r.in.aster.html	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.html	2016-01-29 09:29:57 UTC (rev 67703)
@@ -7,7 +7,7 @@
   line. In either case, the user must specify an <b>input</b> *.hdf file name,
   the <b>type</b> of processing used, the image <b>band</b> to import, and an
   <b>output</b> GRASS raster map name.
-<p>The <b>type</b> paremeter can take values of L1A, L1B, or DEM.
+<p>The <b>type</b> parameter can take values of L1A, L1B, or DEM.
 <p>The <b>band</b> parameter can take values of 1, 2, 3n, 3b, 4-14
Modified: grass/trunk/vector/v.rectify/v.rectify.html
--- grass/trunk/vector/v.rectify/v.rectify.html	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/vector/v.rectify/v.rectify.html	2016-01-29 09:29:57 UTC (rev 67703)
@@ -9,7 +9,7 @@
 <p>
 The <em>-o</em> flag enforces orthogonal rotation (currently for 3D only)
 where the axes remain orthogonal to each other, e.g. a cube with right
-angles remains a cube with right angles after tranformation. This is not
+angles remains a cube with right angles after transformation. This is not
 guaranteed even with affine (1<sup>st</sup> order) 3D transformation.
 <p>
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/vector/v.transform/main.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -274,7 +274,7 @@
 	ztozero = 0;
     /* do the transformation */
-    G_important_message(_("Tranforming features..."));
+    G_important_message(_("Transforming features..."));
     transform_digit_file(&Old, &New,
 			 ztozero, swap_flag->answer, trans_params,
 			 columns_name, field);
Modified: grass/trunk/vector/v.vect.stats/main.c
--- grass/trunk/vector/v.vect.stats/main.c	2016-01-29 08:58:46 UTC (rev 67702)
+++ grass/trunk/vector/v.vect.stats/main.c	2016-01-29 09:29:57 UTC (rev 67703)
@@ -39,7 +39,7 @@
     {c_sum, 0, "sum", "sum of values"},
     {c_ave, 1, "average", "average value"},
     {c_minx, 0, "min_cat", "category number of lowest value"},
