[GRASS-SVN] r67705 - in grass/trunk/raster3d: . r3.in.lidar
Fri Jan 29 13:17:46 PST 2016
Author: wenzeslaus
Date: 2016-01-29 13:17:46 -0800 (Fri, 29 Jan 2016)
New Revision: 67705
Added:
   grass/trunk/raster3d/r3.in.lidar/
   grass/trunk/raster3d/r3.in.lidar/Makefile
   grass/trunk/raster3d/r3.in.lidar/main.c
   grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html
   grass/trunk/raster3d/r3.in.lidar/r3_in_lidar.png
   grass/trunk/raster3d/Makefile
   grass/trunk/raster3d/raster3dintro.html
r3.in.lidar: basic implementation [news]
Experimental, major limitations described in manual.
Modified: grass/trunk/raster3d/Makefile
--- grass/trunk/raster3d/Makefile	2016-01-29 09:56:07 UTC (rev 67704)
+++ grass/trunk/raster3d/Makefile	2016-01-29 21:17:46 UTC (rev 67705)
@@ -7,6 +7,7 @@
 	r3.gwflow \
 	r3.in.ascii \
 	r3.in.bin \
+	r3.in.lidar \
 	r3.in.v5d \
 	r3.info \
 	r3.mask \
Added: grass/trunk/raster3d/r3.in.lidar/Makefile
--- grass/trunk/raster3d/r3.in.lidar/Makefile	                        (rev 0)
+++ grass/trunk/raster3d/r3.in.lidar/Makefile	2016-01-29 21:17:46 UTC (rev 67705)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../..
+PGM = r3.in.lidar
+LIBES = $(RASTERLIB) $(RASTER3DLIB) $(GISLIB) $(MATHLIB) $(GPROJLIB) $(LASLIBS) $(SEGMENTLIB) $(VECTORLIB)
+DEPENDENCIES = $(RASTERDEP) $(RASTER3DDEP) $(GISDEP) $(SEGMENTDEP) $(VECTORDEP)
+EXTRA_INC = $(LASINC) $(VECT_INC) $(PROJINC)
+EXTRA_CFLAGS = $(VECT_CFLAGS) $(GDALCFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LIBLAS),)
+default: cmd
+endif
Property changes on: grass/trunk/raster3d/r3.in.lidar/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass/trunk/raster3d/r3.in.lidar/main.c
--- grass/trunk/raster3d/r3.in.lidar/main.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.in.lidar/main.c	2016-01-29 21:17:46 UTC (rev 67705)
@@ -0,0 +1,264 @@
+* MODULE:       r3.in.Lidar
+* AUTHOR(S):    Vaclav Petras
+* PURPOSE:      Imports LAS LiDAR point clouds to a 3D raster map using
+*               aggregate statistics.
+* COPYRIGHT:    (C) 2016 Vaclav Petras and the The GRASS Development Team
+*               This program is free software under the GNU General Public
+*               License (>=v2). Read the file COPYING that comes with GRASS
+*               for details.
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/raster3d.h>
+#include <grass/glocale.h>
+#include <liblas/capi/liblas.h>
+static void raster3d_set_value_float(RASTER3D_Map *raster, RASTER3D_Region *region, float value)
+    int col, row, depth;
+    for (depth = 0; depth < region->depths; depth++)
+        for (row = 0; row < region->rows; row++)
+            for (col = 0; col < region->cols; col++)
+                Rast3d_put_float(raster, col, row, depth, value);
+/* c = a / b */
+static void raster3d_divide(RASTER3D_Map *a, RASTER3D_Map *b, RASTER3D_Map *c, RASTER3D_Region *region)
+    double tmp;
+            for (col = 0; col < region->cols; col++) {
+                tmp = Rast3d_get_double(b, col, row, 0);
+                /* TODO: compare to epsilon */
+                if (tmp > 0) {
+                    tmp = Rast3d_get_double(a, col, row, depth) / tmp;
+                    Rast3d_put_double(c, col, row, depth, tmp);
+                else {
+                    /* TODO: check this implementation */
+                    Rast3d_set_null_value(&tmp, 1, DCELL_TYPE);
+/* c = a / b where b has depth 1 */
+static void raster3d_divide_by_flat(RASTER3D_Map *a, RASTER3D_Map *b, RASTER3D_Map *c, RASTER3D_Region *region)
+    double tmp;
+                /* since it is count, using cast to integer to check
+                   againts zero, limits the value to max of CELL */
+                if (((CELL) tmp) > 0) {
+                else {
+int main(int argc, char *argv[])
+    struct GModule *module;
+    struct Option *input_opt;
+    struct Option *count_output_opt, *sum_output_opt, *mean_output_opt;
+    struct Option *prop_count_output_opt, *prop_sum_output_opt;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("3D raster"));
+    G_add_keyword(_("import"));
+    G_add_keyword(_("LIDAR"));
+    module->description =
+        _("Creates a 3D raster map from LAS LiDAR points");
+    input_opt = G_define_standard_option(G_OPT_F_BIN_INPUT);
+    input_opt->required = YES;
+    input_opt->label = _("LAS input file");
+    input_opt->description = _("LiDAR input file in LAS format (*.las or *.laz)");
+    input_opt->guisection = _("Input");
+    count_output_opt = G_define_standard_option(G_OPT_R3_OUTPUT);
+    count_output_opt->key = "n";
+    count_output_opt->required = YES;
+    count_output_opt->label = _("Count of points per cell");
+    count_output_opt->guisection = _("Output");
+    sum_output_opt = G_define_standard_option(G_OPT_R3_OUTPUT);
+    sum_output_opt->key = "sum";
+    sum_output_opt->required = YES;
+    sum_output_opt->label = _("Sum of values of point intensities per cell");
+    sum_output_opt->guisection = _("Output");
+    mean_output_opt = G_define_standard_option(G_OPT_R3_OUTPUT);
+    mean_output_opt->key = "mean";
+    mean_output_opt->required = YES;
+    mean_output_opt->label = _("Mean of point intensities per cell");
+    mean_output_opt->guisection = _("Output");
+    /* TODO: proportional versus relative in naming */
+    prop_count_output_opt = G_define_standard_option(G_OPT_R3_OUTPUT);
+    prop_count_output_opt->key = "proportional_n";
+    prop_count_output_opt->required = YES;
+    prop_count_output_opt->label =
+        _("3D raster map of proportional point count");
+    prop_count_output_opt->description =
+        _("Point count per 3D cell divided by point count per vertical"
+          " column");
+    prop_count_output_opt->guisection = _("Proportional output");
+    prop_sum_output_opt = G_define_standard_option(G_OPT_R3_OUTPUT);
+    prop_sum_output_opt->key = "proportional_sum";
+    prop_sum_output_opt->required = YES;
+    prop_sum_output_opt->label =
+        _("3D raster map of proportional sum of values");
+    prop_sum_output_opt->description =
+        _("Sum of values per 3D cell divided by sum of values per"
+          " vertical column");
+    prop_sum_output_opt->guisection = _("Proportional output");
+    if (G_parser(argc, argv))
+        exit(EXIT_FAILURE);
+    LASReaderH LAS_reader;
+    LAS_reader = LASReader_Create(input_opt->answer);
+    if (LAS_reader == NULL)
+        G_fatal_error(_("Unable to open file <%s>"), input_opt->answer);
+    Rast3d_init_defaults();
+    Rast3d_set_error_fun(Rast3d_fatal_error_noargs);
+    RASTER3D_Region region, flat_region;
+    RASTER3D_Map *count_raster, *sum_raster, *mean_raster;
+    RASTER3D_Map *count_flat_raster, *sum_flat_raster;
+    RASTER3D_Map *prop_count_raster, *prop_sum_raster;
+    Rast3d_get_window(&region);
+    Rast3d_get_window(&flat_region);
+    flat_region.depths = 1;
+    Rast3d_adjust_region(&flat_region);
+    count_raster = Rast3d_open_new_opt_tile_size(count_output_opt->answer,
+                                           RASTER3D_USE_CACHE_DEFAULT,
+                                           &region, FCELL_TYPE, 32);
+    if (!count_raster)
+        Rast3d_fatal_error(_("Unable to create 3D raster map <%s>"),
+                           count_output_opt->answer);
+    sum_raster = Rast3d_open_new_opt_tile_size(sum_output_opt->answer,
+    if (!sum_raster)
+                           sum_output_opt->answer);
+    mean_raster = Rast3d_open_new_opt_tile_size(mean_output_opt->answer,
+    if (!mean_raster)
+                           mean_output_opt->answer);
+    count_flat_raster = Rast3d_open_new_opt_tile_size("r3_in_lidar_tmp_sum_flat",
+                                           &flat_region, FCELL_TYPE, 32);
+    if (!count_flat_raster)
+    sum_flat_raster = Rast3d_open_new_opt_tile_size("r3_in_lidar_tmp_count_flat",
+    if (!sum_flat_raster)
+    prop_count_raster = Rast3d_open_new_opt_tile_size(prop_count_output_opt->answer,
+    if (!prop_count_raster)
+                           prop_count_output_opt->answer);
+    prop_sum_raster = Rast3d_open_new_opt_tile_size(prop_sum_output_opt->answer,
+    if (!prop_sum_raster)
+                           prop_sum_output_opt->answer);
+    raster3d_set_value_float(count_raster, &region, 0);
+    raster3d_set_value_float(sum_raster, &region, 0);
+    raster3d_set_value_float(count_flat_raster, &flat_region, 0);
+    raster3d_set_value_float(sum_flat_raster, &flat_region, 0);
+    LASPointH LAS_point;
+    double east, north, top;
+    int row, col, depth;
+    double value;
+    double tmp;
+    /* TODO: use long long */
+    long unsigned inside = 0;
+    long unsigned outside = 0;
+    while ((LAS_point = LASReader_GetNextPoint(LAS_reader)) != NULL) {
+        if (!LASPoint_IsValid(LAS_point))
+            continue;
+        east = LASPoint_GetX(LAS_point);
+        north = LASPoint_GetY(LAS_point);
+        top = LASPoint_GetZ(LAS_point);
+        if (!Rast3d_is_valid_location(&region, north, east, top)) {
+            outside += 1;
+            continue;
+        Rast3d_location2coord(&region, north, east, top, &col, &row, &depth);
+        value = LASPoint_GetIntensity(LAS_point);
+        tmp = Rast3d_get_double(count_raster, col, row, depth);
+        Rast3d_put_double(count_raster, col, row, depth, tmp + 1);
+        tmp = Rast3d_get_double(count_flat_raster, col, row, 0);
+        Rast3d_put_double(count_flat_raster, col, row, 0, tmp + 1);
+        tmp = Rast3d_get_double(sum_raster, col, row, depth);
+        Rast3d_put_double(sum_raster, col, row, depth, tmp + value);
+        tmp = Rast3d_get_double(sum_flat_raster, col, row, 0);
+        Rast3d_put_double(sum_flat_raster, col, row, 0, tmp + value);
+        inside += 1;
+    raster3d_divide_by_flat(count_raster, count_flat_raster, prop_count_raster, &region);
+    raster3d_divide_by_flat(sum_raster, sum_flat_raster, prop_sum_raster, &region);
+    raster3d_divide(sum_raster, count_raster, mean_raster, &region);
+    G_message("Number of point inside: %lu", inside);
+    G_message("Number of point outside: %lu", outside);
+    Rast3d_close(prop_sum_raster);
+    Rast3d_close(prop_count_raster);
+    Rast3d_close(sum_flat_raster);  /* TODO: delete */
+    Rast3d_close(count_flat_raster);  /* TODO: delete */
+    Rast3d_close(mean_raster);
+    Rast3d_close(sum_raster);
+    Rast3d_close(count_raster);
+    exit(EXIT_SUCCESS);
Property changes on: grass/trunk/raster3d/r3.in.lidar/main.c
   + text/x-csrc
   + native
Added: grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html
--- grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html	                        (rev 0)
+++ grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html	2016-01-29 21:17:46 UTC (rev 67705)
@@ -0,0 +1,74 @@
+<h2>DESCRIPTION</h2>
+<p>
+<img src="r3_in_lidar.png">
+<p>
+<em>
+    Figure: Proportional count of points per 3D cell. When 50% of all
+    points in a vertical column fall into a given 3D cell, the value
+    is 0.5. Here, the green color was assigned to 0.5, red to 1 and
+    yellow to 0. The figure shows vertical slices and green color
+    indicates high vegetation while red color indicates bare ground.
+</em>
+0% 255:255:100
+50% green
+100% red
+<h2>NOTES</h2>
+<ul>
+    <li>
+        This module is highly experimental. Don't rely on its
+        functionality or interface. Please report issues on the mailing
+        list or in the bug tracker.
+    <li>
+        No projection check or reprojection is performed, make sure you
+        are using data in the right projection for your GRASS Location.
+    <li>
+        Selection of points according to return or class is not yet
+        supported.
+    <li>All outputs are currently mandatory.
+    <li>Some temporary maps are created but not cleaned up.
+    <li>
+        Expects points to have intensity (random result for related
+        outputs when they don't).
+</ul>
+<h2>EXAMPLES</h2>
+Set the region according to a 2D raster and adding 3D minimum
+(bottom), maximum (top) and vertical (top-bottom) resolution.
+<div class="code"><pre>
+g.region rast=secref b=80 t=160 tbres=5 -p3
+</pre></div>
+Now, <em>r3.in.lidar</em> will create the 3D raster of the size
+given by the computation region:
+r3.in.lidar input=points.las n=points_n sum=points_sum \
+    mean=points_mean proportional_n=points_n_prop \
+    proportional_sum=points_sum_prop
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r3.in.xyz.html">r3.in.xyz</a>,
+<a href="r.in.lidar.html">r.in.lidar</a>,
+<a href="v.in.lidar.html">v.in.lidar</a>,
+<a href="r.to.rast3.html">r.to.rast3</a>,
+<a href="r3.mapcalc.html">r3.mapcalc</a>,
+<a href="g.region.html">g.region</a>
+</em>
+<h2>AUTHOR</h2>
+Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU OSGeoREL</a>
Property changes on: grass/trunk/raster3d/r3.in.lidar/r3.in.lidar.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass/trunk/raster3d/r3.in.lidar/r3_in_lidar.png
(Binary files differ)
Property changes on: grass/trunk/raster3d/r3.in.lidar/r3_in_lidar.png
   + image/png
Modified: grass/trunk/raster3d/raster3dintro.html
--- grass/trunk/raster3d/raster3dintro.html	2016-01-29 09:56:07 UTC (rev 67704)
+++ grass/trunk/raster3d/raster3dintro.html	2016-01-29 21:17:46 UTC (rev 67705)
@@ -85,6 +85,13 @@
 2D rasters are considered as slices in this case and
 merged into one 3D raster map (<a href="r.to.rast3.html">r.to.rast3</a>).
+<p>
+Import of 3D points and their statistics can be done using
+<a href="r3.in.lidar.html">r3.in.lidar</a> for LiDAR data and
+<a href="r3.in.xyz.html">r3.in.xyz</a> for CSV and other ASCII text
+formats.
 <h3>3D region settings and 3D MASK</h3>
 GRASS GIS 3D raster map processing is always performed in the current 3D region
