[GRASS-SVN] r68834 - grass-addons/grass7/vector/v.civil
Fri Jul 1 17:50:58 PDT 2016
Author: jfc
Date: 2016-07-01 17:50:57 -0700 (Fri, 01 Jul 2016)
New Revision: 68834
Added:
   grass-addons/grass7/vector/v.civil/v.civil.html
v.road updating html
Added: grass-addons/grass7/vector/v.civil/v.civil.html
--- grass-addons/grass7/vector/v.civil/v.civil.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.civil/v.civil.html	2016-07-02 00:50:57 UTC (rev 68834)
@@ -0,0 +1,828 @@
+<!-- <h2>DESCRIPTION</h2> -->
+<em>v.civil.road</em> generates a alignment for design roads, channels, ports...
+<h2>USAGE</h2>
+To run the program for the first time, a map with one horizontal polygon, is
+required.
+<p>
+There are three options:
+The flag <em>-r</em> for run the program,
+The flag <em>-p</em> Update solution from polygon (if you modific the polygon),
+The flag <em>-t</em> Update solution from table plan (walk with dc_ and lr_)
+<p>
+The other options are described below.
+<h2>Plan</h2>
+<h3>plan options</h3>
+<p>
+<em>plan</em> write the horizontal alignment.
+<p>
+<em>pks</em> write pk marks in horizontal.
+<p>
+<em>displ</em> write the displaced platform lines in horizontal.
+<p>
+<em>marks</em> write the marks in horizontal.
+<h3>options</h3>
+<p>
+<em>pkopt</em> define the distance between normal marks (npk),
+distance between principal marks (mpk), longitude of normal marks and
+longitude of principal marks.
+<p>
+<em>areaopt</em> write the areas defined with pairs of displaced lines.
+<h2>Vertical</h2>
+<h3>vert options</h3>
+<p>
+<em>vert</em>  write the vertical alignment in horizontal.
+<p>
+<em>profile</em> write longitudinal profile map.
+<h3>options</h3>
+<p>
+With the option <em>LPScale</em>, the vertical scale of the longitudinal
+profile can be given.
+<p>
+The <em>LPopt</em> option give the longitude of marks, distance between marks
+in axis x and y, and distance between lines of the guitar.
+<h2>Cross</h2>
+<h3>Cross options</h3>
+<p>
+<em>cross</em>  write cross section in horizontal
+<p>
+<em>sections</em> write cross sections map.
+<h3>options</h3>
+<p>
+With the option <em>LTScale</em>, the vertical scale of the longitudinal
+<p>
+The <em>LTopt</em> option give the longitude of marks, distance between marks
+<p>
+The <em>LTopt2</em> option give the number of rows of cross-section to display,
+distance between cross-section in axis x and y.
+<h2>Terrain</h2>
+<h3>Terr options</h3>
+<p>
+<em>slopes</em> flag write the slope soil lines calculated with the last
+displaced lines (perpendicular to the central axis).
+<p>
+<em>sareas</em> write the areas map with slope soil lines and the last
+displaced lines in horizontal.
+<p>
+<em>tri</em> write points, lines and hull area  map.
+<h2>Tools</h2>
+<p>
+The flag <em>-a</em> add a new table. Displ or Marks.
+<p>
+The flag <em>-i</em> insert a rows in table. List of pks for each row.
+<p>
+The flag <em>-n</em> add a new displ line, ei, a new column in displ table.
+You must give a start and end distances and height. And number of column
+and side to insert.
+<p>
+The flag <em>-d</em> del a displ line, ei, a column in displ table. A number
+of column and side is required.
+<h2>Tables</h2>
+<p>
+We have six parts: plant, vertical, displaced, terrain, tranversal and marks.
+<p>
+The tables stored in the polygon map are:
+<h3>Layer 1:</h3>
+<p>
+Created with only cat column (if not exist), is for free use to add columns
+with information of the road.
+<h3>Layer 2:</h3>
+<p>
+<b>"NameRoad"_Plan</b>, for insert the parameters of the horizontal
+alignment. This layer have all vertices and nodes of the horizontal polygon.
+No more points can be added to this layer with the insert point option.
+<p>
+The columns are:
+<ul>
+    <li><b>radio</b>: radio of curve
+        <p>+ for clockwise</p>
+        <p>- for anticlockwise</p>
+    </li>
+    <li><b>a_in</b>: Parameter A of input Clothoid</li>
+    <li><b>a_out</b>: Parameter A of output Clothoid</li>
+    <li><b>widening</b>: Widening of curve (where this widening is growing
+        in the clothoid, only in mode exact)</li>
+    <li><b>superelev</b>: Parameter A of input Clothoid</li>
+    <li><b>dc_</b>: longitude of curve. For use with flag <em>-t</em></li>
+    <li><b>lr_</b>: longitude of straight. For use with flag <em>-t</em></li>
+</ul>
+<h3>Layer 3:</h3>
+<p>
+<b>"NameRoad"_Vert</b>, for insert the parameters of the vertical
+alignment.This layer are created with the first an last vertices of the
+horizontal polygon. New point can be added by the flag 'e' TableTools option,
+or with edit gui. The added points, are inserted in the central axis
+referencing by pk.
+<p>
+The columns are:
+<ul>
+    <li><b>pk</b>: kilometric point of the central axis</li>
+    <li><b>elev</b>: Elevation of the vertice of the vertical alignment</li>
+    <li><b>kv</b>: Parameter Kv of the vertical alignment</li>
+    <li><b>l</b>: Leng of parabolic curve (no yet implemented)</li>
+    <li><b>B</b>: Height of vertice of vertical polygon to the parabolic
+                curve (no yet implemented)</li>
+</ul>
+<h3>Layer 4: </h3>
+<b>"NameRoad"_Displ</b>, for insert the parameters of the platform.
+This layer are created with the first an last vertices of the horizontal
+polygon. New point can be added by the flag 'e' TableTools option, or with edit
+gui. The added points, are inserted in the central axis referencing by pk.
+<p>
+The columns for editing by the user are:
+<ul>
+    <li><b>sec_left, sec_right</b>: For defining left and right platform lines
+        (distance and height to the central axis), separated by ";" </li>
+    <li><b>type_left, type_right</b>: Types of left and right lines
+        (types are: l,e,r,0). You can enter the type of multiple lines
+        separated by ";"
+        <b>l</b>: linear approximation between definition points.
+        <b>e</b>: displaced lines, mode exact.
+        <b>c</b>: ellipse between definition points.
+        <b>rR,A</b>: circle between definition points ((x-A)^2+y^2=R^2))</li>
+</ul>
+<p>
+Between two points, if the second input distance equal zero, the line will be
+stopped. If the second input distance equal -1, this point will not be processed
+and the next one will be considered.
+<h3>Layer 5: </h3>
+<b>"NameRoad"_Terr</b>, for insert the parameters for slopes.
+<p>
+<ul>
+    <li><b>cut_left</b>: Cut slope left</li>
+    <li><b>cut_right</b>: Cut slope right</li>
+    <li><b>fill_left</b>: Fill slope left</li>
+    <li><b>fill_right</b>: Fill slope right</li>
+</ul>
+<h3>Layer 6:</h3>
+<p>
+<b>"NameRoad"_Trans</b>, for insert the parameters of transects to the central
+axis.
+polygon. New point can be added by the flag 'e' TableTools option, or with edit gui.
+The added points, are inserted in the central axis referencing by pk.
+<p>
+<ul>
+    <li><b>dist_left,dist_right</b>: Distance left and right from the central
+axis</li>
+    <li><b>npk</b>: Distance between trans</li>
+</ul>
+<h3>Layer 7:</h3>
+<p>
+<b>"NameRoad"_Marks</b>, for insert the parameters of Marks.
+This layer are created with the first an last vertex of the horizontal
+<p>
+<ul>
+    <li><b>dist</b>: distance left and right from the central axis</li>
+    <li><b>elev</b>: Elevation left and right from the central
+axis</li>
+    <li><b>azi</b>: 1 for azimuth of the point of the road or -1</li>
+    <li><b>name</b>: Name of mark</li>
+    <li><b>cod</b>: Code of mark</li>
+</ul>
+<h2>Example:</h2>
+<p>
+This example is done in the North Carolina data set.
+</p>
+<p>
+At the end of this example, there is a backup that can be executed to play with this example.
+</p>
+<p>
+The example start creating a closed polygon with the editor, in a created map named Circuit.
+<p>
+<img src="./img1.png" width="500" height="406" alt="">
+<p>
+After that, run the next command to get all tables in the map Circuit
+<pre><code>
+v.road -r name=Circuit
+</code></pre>
+<p>
+<img src="./img_tables1.png" width="400" height="166" alt="">
+<!-- ########################## Plant ############################## -->
+<h3>Plant</h3>
+<p>
+For each vertex of the polygon we define a radio and in and out clothoids. So we can write the plant and pks maps.
+<p>
+<img src="./img_tables2.png" width="400" height="221" alt="">
+<p>
+<img src="./img_a_plan.png" width="300" height="241" alt="">
+<pre><code>
+v.road -r name=Circuit plan=plan,pks
+</code></pre>
+<p>
+And we obtain the map <em>Circuit__Plant</em> and <em>Circuit__Pks</em>, and their tables.
+<p>
+<img src="./img2.png" width="500" height="406" alt="">
+<p>
+<img src="./img_tables2_2.png" width="400" height="200" alt="">
+<p>
+If we move some vertex of polygon we must run with the flag 'p' to update the road.
+<p>
+<img src="./img2_1.png" width="500" height="406" alt="">
+<p>
+If we change some values of columns 'dc_' (long of circle) or 'lr_' (long of straight), or fill the last line (with 'dc_' and 'lr_' too,
+a new vertex are inserted and a new line) we must run with the flag 't' to update the road.
+<p>
+<img src="./img_tables2_3.png" width="400" height="200" alt="">
+<p>
+The distance between points of each alignments is of 1 meters by default, but this can be changed in the Interval in straights and Interval in curves options.
+<!-- ########################## Vertical ############################## -->
+<h3>Vertical</h3>
+At first, we have only the nodes of polygon, and if we set elev we will obtain a straight with slope. To get more
+vertices we have to add new rows to this table with <em>tabletools</em> giving the pk of the vertex.
+<p>
+<img src="./img_a_tooladdrow.png" width="300" height="229" alt="">
+<p>
+And now we have to set the elevation of those vertices and the <em>kv</em> parameter.
+<p>
+<img src="./img_tables3.png" width="400" height="166" alt="">
+<p>
+Now choose vertical option to get the vertical map in horizontal and the longitudinal profile, and give a
+<em>DEM</em> in the terrain option.
+<pre><code>
+v.road -r name=Circuit vert=vert,profile dem=elev_lid792_1m
+</code></pre>
+<p>
+And we obtain the map <em>Circuit__Vertical</em> and <em>Circuit__LongProfile </em>, and their tables.
+<p>
+<img src="./img3_2.png" width="500" height="406" alt="">
+<!-- ########################## Displaced ############################## -->
+<h3>Displaced</h3>
+<p>
+For first time, this table have two rows, who are the nodes of the polygon, and for that the first and the last points of the central axis.
+<p>
+The displaced lines are defined in sec_left,sec_right columns with a list separated with ";", starting from left to right in each side of the central axis.
+Each displaced line is defined with distance to the central axis and height to the central axis (d,h).
+<p>
+The mode to calculate the displaced lines is defined in the type_left,type_right columns,for each line separated by ";".
+<p>
+To get more vertices we have to add new rows to this table with <em>tabletools</em> giving the pk of the vertex.
+<p>
+In this example we are going to define two displaced lines in the left side to the central axis and two for right side with slope 2%  to out.
+<p>
+<img src="./img_tables4_1.png" width="400" height="166" alt="">
+<p>
+The platform lines define, the lanes of a road, the platform limits, ... Those lines can be parallel to the central axis of a road (or not).
+If it's so, we need to know that the parallel to a clothoid is not a clothoid. Then we have two ways to do the platform lines.
+<p>
+In the first way, mode exact "e", we need to calculate a new displaced central axis, e.i., a parallel to the polygon not to the central axis.
+The new alignment or displaced line created within the new polygon have new clothoids for the transitions.
+To run this mode, the first and the last points, of a section of the road, must have the same displaced distance.
+<p>
+The widening parameter of the section above, only will be calculate in this mode, because the widening growing in the clothoid,
+then is applied only to the displaced lines calculated with clothoid.
+<p>
+The second way, mode lineal "l", we calculate the perpendicular displaced distance to each point of the central axis,
+to obtain a parallel to it, where the transitions won't be clothoids. Then we can't know where are the tangents of transitions.
+But in this mode, the displaced distance for the first and the last points don't have to be the same in a section of the road. A lineal variation will be done between those points.
+<p>
+For this example, the first and last are defined as lineal and the rest are in mode exact.
+<p>
+Into this second way, the variation don't have to be only lineal. We can define a circumference in the displaced line with the option "rR,A".
+<p>
+Between two points, if the second input distance equal zero, the line will be stopped. If the second input distance equal -1, this point will not be processed and the next one will be considered.
+<pre><code>
+v.road -r name=Circuit plan=displ
+</code></pre>
+And we obtain the map Circuit__Displaced, and their tables.
+<p>
+<img src="./img4.png" width="500" height="406" alt="">
+<p>
+With distance to the central axis and height of the lines we can obtain different forms, that we'll see in the cross sections.
+<p>
+<img src="./img_a_vcivilroad_7.png" width="400" height="200" alt="">
+<p>
+Now we can add new lines by hand or with TableTools option.
+<pre><code>
+v.road -e name=Circuit displline=add side=left ncol=3 sedist="10 -0.2; 10 -0.2"
+v.road -e name=Circuit displline=add side=right ncol=3 sedist="10 -0.2; 10 -0.2"
+</code></pre>
+<p>
+And add new points. We are going to cut the last line in pk 900 and 1700.
+<pre><code>
+v.road -e name=Circuit at road add=row tab_type=Displ pklist=876,900,1074,1690,1700,1811
+</code></pre>
+<p>
+<img src="./img_tables4_2.png" width="400" height="166" alt="">
+<p>
+<img src="./img4_1.png" width="500" height="406" alt="">
+<p>
+Mode exact "e" in the first two lines, without widening and with widening set to 0.2.
+<p>
+<img src="./img4_2.png" width="350" height="275" alt="">
+<img src="./img4_3.png" width="350" height="275" alt="">
+<!-- ########################## Terr ############################## -->
+<h3>Terr</h3>
+<p>
+The cut/fill are calculated with the first displaced line of the left side and the last displaced line of the right side,
+and with the slope given in the columns cut_left, cut_right, fill_left, fill_right.
+<p>
+<p>
+<img src="./img_tables5_1.png" width="400" height="166" alt="">
+<p>
+We can generate points of the different alignments, breaklines and a hull of all points.
+<pre><code>
+v.road -r name=Circuit terr=slopes,sareas,topo dem=elev_lid792_1m
+</code></pre>
+<p>
+And we obtain the map Circuit__Slopes, Circuit__Slopes_Areas, Circuit__Topo and Circuit__Topo_Hull, and their tables.
+<p>
+<img src="./img5.png" width="500" height="406" alt="">
+<h3>Transversal</h3>
+<p>
+In this table where we are going to define transversals 2D lines to the central axis, to obtain later, the cross sections.
+<p>
+This lines contains the cutoff with the displaced lines.
+<p>
+When this table is created, have two rows, who are the first and the last points of the central axis.
+<p>
+In the columns dist_left, dist_right we can define the distance left and right to the central axis and in the column npk the distance between lines.
+<p>
+<img src="./img_tables6_1.png" width="400" height="166" alt="">
+<p>
+We can obtain the transversal profiles selecting it too.
+<pre><code>
+v.road -r name=Circuit trans=trans,profiles dem=elev_lid792_1m
+</code></pre>
+<p>
+And we obtain the map Circuit__Trans and Circuit__TransProfiles, and their tables.
+<p>
+<img src="./img6.png" width="500" height="406" alt="">
+<p>
+<img src="./img6_1.png" width="500" height="406" alt="">
+<h3>Marks</h3>
+We can define marks or road objects by pk.
+<p>
+<img src="./img_tables7_1.png" width="400" height="166" alt="">
+<p>
+<img src="./img7.png" width="500" height="406" alt="">
+<h3>TopoTools</h3>
+<p>
+With the Circuit_Topo map created, we can triangulate with triangle or delaunay, and obtain the curves.
+<p>
+In this example we must delete the points that cross the road, for a good triangulation. We can run this.
+<pre><code>
+v.edit map=Circuit__Topo type=point tool=delete ids=0-999999 where="pk > 876 AND pk < 1074"
+v.edit map=Circuit__Topo type=point tool=delete ids=0-999999 where="pk > 1690 AND pk < 1811"
+db.execute sql="DELETE FROM Circuit__Topo WHERE pk > 876 and pk < 1074"
+db.execute sql="DELETE FROM Circuit__Topo WHERE pk > 1690 and pk < 1811"
+</code></pre>
+<p>
+And obtain the Circuit__Topo like this. The hull must be changed too.
+<p>
+<img src="./img8_1.png" width="500" height="406" alt="">
+<p>
+<img src="./img_a_topotools_1.png" width="399" height="339" alt="">
+<pre><code>
+v.road -o name=Circuit dem=elev_lid792_1m topotools=delaunay,curved,cut_hull
+</code></pre>
+<p>
+And we obtain the map Circuit__Topo_Tin and Circuit__Topo_Curves, and their tables.
+<p>
+<img src="./img8_2.png" width="500" height="406" alt="">
+<h3>Backup</h3>
+<p>
+After run the backup you can run this to obtain all maps.
+<pre><code>
+v.road -r name=Circuit plan=plan,pks,displ,marks vert=vert,profile trans=trans,profiles terr=slopes,sareas,topo dem=elev_lid792_1m
+</code></pre>
+<pre><code>
+echo "L 15 1
+ 638602.453907 220281.587467
+ 638872.438983 220266.927644
+ 638731.321851 220395.256912
+ 638781.230311 220495.669832
+ 638890.64791 220489.728605
+ 638750.420421 220565.326292
+ 638662.05161 220298.095029
+ 638632.866458 220535.678384
+ 638483.222668 220543.750924
+ 638406.451001 220388.023737
+ 638502.195923 220398.284828
+ 638721.795144 220655.135048
+ 638656.193203 220404.828666
+ 638268.15133 220299.739643
+ 1  1
+P  1 1
+ 2    1
+P  1 1
+ 2    2
+P  1 1
+ 2    3
+P  1 1
+ 2    4
+P  1 1
+ 2    5
+P  1 1
+ 2    6
+P  1 1
+ 2    7
+P  1 1
+ 2    8
+P  1 1
+ 2    9
+P  1 1
+ 2    10
+P  1 1
+ 2    11
+P  1 1
+ 2    12
+P  1 1
+ 2    13
+P  1 1
+ 2    14
+P  1 1
+ 2    15
+P  1 1
+ 8    1
+P  1 1
+ 8    2
+P  1 1
+ 4    1
+P  1 1
+ 638634.426432 220500.061126
+ 4    2
+P  1 1
+ 638621.330858 220519.982685
+ 4    3
+P  1 1
+ 638465.368943 220506.786855
+ 4    4
+P  1 1
+ 638666.507984 220451.258691
+ 4    5
+P  1 1
+ 638662.328095 220442.177014
+ 4    6
+P  1 1
+ 638573.410617 220382.409616
+ 4    7
+P  1 1
+ 4    8
+P  1 1
+ 3    1
+P  1 1
+ 638794.637722 220294.628116
+ 3    2
+P  1 1
+ 638791.485541 220543.187779
+ 3    3
+P  1 1
+ 638641.56261 220464.886873
+ 3    4
+P  1 1
+ 638621.266312 220399.660839
+ 3    5
+P  1 1
+ 638406.371565 220315.000175
+ 3    6
+P  1 1
+ 3    7
+P  1 1
+ 7    1
+P  1 1
+ 638634.610948 220499.596419
+ 7    2
+P  1 1
+ 7    3
+P  1 1
+ 7    4
+P  1 1
+ 638654.577521 220429.350321
+ 7    5
+P  1 1
+ 638637.711356 220410.985026
+ 7    6
+P  1 1
+ 638616.836773 220397.342402
+ 7    7
+P  1 1
+ 638593.594427 220388.201219
+ 7    8
+P  1 1
+ 7    9
+P  1 1
+ 7    10
+P  1 1
+ 5    1
+P  1 1
+ 638693.765832 220585.688009
+ 5    2
+P  1 1
+ 638691.041172 220537.792247
+ 5    3
+P  1 1
+ 638535.766657 220372.214897
+ 5    4
+P  1 1
+ 5    5
+P  1 1
+ 6    1
+P  1 1
+ 6    2
+" | v.in.ascii -n input=- output=Circuit format=standard --o
+v.db.addtable map=Circuit table=Circuit_Plan layer=2 key=cat2 columns="pk_eje double precision,radio double precision,a_in double precision,a_out double precision,widening double precision,superelev varchar(25),dc_ double precision,lr_ double precision"
+v.db.addtable map=Circuit table=Circuit_Displ layer=8 key=cat8 columns="pk double precision,sec_left varchar(25),sec_right varchar(25),type_left varchar(25),type_right varchar(25)"
+v.db.addtable map=Circuit table=Circuit_Displ layer=4 key=cat4 columns="pk double precision,sec_left varchar(25),sec_right varchar(25),type_left varchar(25),type_right varchar(25)"
+v.db.addtable map=Circuit table=Circuit_Vert layer=3 key=cat3 columns="pk double precision,elev double precision,kv double precision,l double precision,b double precision"
+v.db.addtable map=Circuit table=Circuit_Marks layer=7 key=cat7 columns="pk double precision,dist varchar(25),elev varchar(25),azi varchar(25),name varchar(25),cod varchar(25)"
+v.db.addtable map=Circuit table=Circuit_Terr layer=5 key=cat5 columns="pk double precision,cut_left double precision,cut_right double precision,fill_left double precision,fill_right double precision,height double precision,leng double precision"
+v.db.addtable map=Circuit table=Circuit_Trans layer=6 key=cat6 columns="pk double precision,dist_left double precision,dist_right double precision,npk double precision"
+v.db.addtable map=Circuit table=Circuit layer=1 key=cat columns="name varchar(25)"
+echo "UPDATE Circuit_Plan SET pk_eje='0.0',radio='0.0',a_in='0.0',a_out='0.0',widening='0.0',superelev='',dc_='0.0',lr_='140.002162531' WHERE cat2=1;
+UPDATE Circuit_Plan SET pk_eje='270.382786955',radio='-40.0',a_in='35.0',a_out='35.0',widening='0.0',superelev='',dc_='67.689561716',lr_='18.521314174' WHERE cat2=2;
+UPDATE Circuit_Plan SET pk_eje='461.124617255',radio='40.0',a_in='30.0',a_out='30.0',widening='0.0',superelev='',dc_='29.2637172691',lr_='39.7863972502' WHERE cat2=3;
+UPDATE Circuit_Plan SET pk_eje='573.256721368',radio='30.0',a_in='25.0',a_out='25.0',widening='0.0',superelev='',dc_='14.0798000021',lr_='1.81890329525' WHERE cat2=4;
+UPDATE Circuit_Plan SET pk_eje='682.835501948',radio='-15.0',a_in='15.0',a_out='15.0',widening='0.0',superelev='',dc_='25.5209406839',lr_='47.3026773599' WHERE cat2=5;
+UPDATE Circuit_Plan SET pk_eje='842.142623261',radio='-20.0',a_in='20.0',a_out='20.0',widening='0.0',superelev='',dc_='14.9175006172',lr_='100.00718402' WHERE cat2=6;
+UPDATE Circuit_Plan SET pk_eje='1123.60593223',radio='30.0',a_in='25.0',a_out='25.0',widening='0.0',superelev='',dc_='60.1666666667',lr_='24.9072874929' WHERE cat2=7;
+UPDATE Circuit_Plan SET pk_eje='1362.97515278',radio='-60.0',a_in='45.0',a_out='45.0',widening='0.0',superelev='',dc_='49.9304491395',lr_='25.1574394299' WHERE cat2=8;
+UPDATE Circuit_Plan SET pk_eje='1512.8365209',radio='-60.0',a_in='45.0',a_out='45.0',widening='0.0',superelev='',dc_='36.2500000006',lr_='68.9069121541' WHERE cat2=9;
+UPDATE Circuit_Plan SET pk_eje='1686.45923111',radio='-20.0',a_in='20.0',a_out='20.0',widening='0.0',superelev='',dc_='22.711648047',lr_='24.7225033281' WHERE cat2=10;
+UPDATE Circuit_Plan SET pk_eje='1782.75242935',radio='-40.0',a_in='25.0',a_out='25.0',widening='0.0',superelev='',dc_='14.6414158745',lr_='213.435753539' WHERE cat2=11;
+UPDATE Circuit_Plan SET pk_eje='2120.68119964',radio='20.0',a_in='20.0',a_out='20.0',widening='0.0',superelev='',dc_='33.810837057',lr_='71.3354524078' WHERE cat2=12;
+UPDATE Circuit_Plan SET pk_eje='2379.441513',radio='100.0',a_in='75.0',a_out='75.0',widening='0.0',superelev='',dc_='48.75',lr_='140.918379815' WHERE cat2=13;
+UPDATE Circuit_Plan SET pk_eje='2781.46165959',radio='-25.0',a_in='25.0',a_out='25.0',widening='0.0',superelev='',dc_='45.5718116349',lr_='160.427746506' WHERE cat2=14;
+UPDATE Circuit_Plan SET pk_eje='3116.25669305',radio='0.0',a_in='0.0',a_out='0.0',widening='0.0',superelev='',dc_='0.0',lr_='0.0' WHERE cat2=15;
+UPDATE Circuit_Displ SET pk='0.0',sec_left='6 0;3.5 0',sec_right='3.5 0;6 0',type_left='',type_right='' WHERE cat8=1;
+UPDATE Circuit_Displ SET pk='2208.88779535',sec_left='6 0;3.5 0',sec_right='3.5 0;6 0',type_left='',type_right='' WHERE cat8=2;
+UPDATE Circuit_Displ SET pk='0.0',sec_left='10 -0.34;8 -0.19;6.5 -0.13;4 -0.08',sec_right='4 -0.08;6.5 -0.13;8 -0.19;10 -0.34',type_left='l;l;e;e',type_right='e;e;l;l' WHERE cat4=1;
+UPDATE Circuit_Displ SET pk='876.0',sec_left='10 -0.34;-1 0;-1 0;-1 0',sec_right='-1 0;-1 0;-1 0;10 -0.34',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=2;
+UPDATE Circuit_Displ SET pk='900.0',sec_left='0 0;-1 0;-1 0;-1 0',sec_right='-1 0;-1 0;-1 0;0 0',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=3;
+UPDATE Circuit_Displ SET pk='1074.0',sec_left='10 -0.34;-1 0;-1 0;-1 0',sec_right='-1 0;-1 0;-1 0;10 -0.34',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=4;
+UPDATE Circuit_Displ SET pk='1690.0',sec_left='10 -0.34;-1 0;-1 0;-1 0',sec_right='-1 0;-1 0;-1 0;10 -0.34',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=5;
+UPDATE Circuit_Displ SET pk='1700.0',sec_left='0 0;-1 0;-1 0;-1 0',sec_right='-1 0;-1 0;-1 0;0 0',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=6;
+UPDATE Circuit_Displ SET pk='1811.0',sec_left='10 -0.34;-1 0;-1 0;-1 0',sec_right='-1 0;-1 0;-1 0;10 -0.34',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=7;
+UPDATE Circuit_Displ SET pk='2208.88779535',sec_left=' 10 -0.34;8 -0.19;6.5 -0.13;4 -0.08',sec_right='4 -0.08;6.5 -0.13;8 -0.19; 10 -0.34',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=8;
+UPDATE Circuit_Vert SET pk='0.0',elev='118.0',kv='0.0',l='0.0',b='0.0' WHERE cat3=1;
+UPDATE Circuit_Vert SET pk='200.0',elev='116.0',kv='-2500.0',l='0.0',b='0.0' WHERE cat3=2;
+UPDATE Circuit_Vert SET pk='550.0',elev='133.0',kv='3000.0',l='0.0',b='0.0' WHERE cat3=3;
+UPDATE Circuit_Vert SET pk='840.0',elev='114.0',kv='-2000.0',l='0.0',b='0.0' WHERE cat3=4;
+UPDATE Circuit_Vert SET pk='1760.0',elev='133.0',kv='3000.0',l='0.0',b='0.0' WHERE cat3=5;
+UPDATE Circuit_Vert SET pk='2000.0',elev='121.0',kv='-2000.0',l='0.0',b='0.0' WHERE cat3=6;
+UPDATE Circuit_Vert SET pk='2208.88779535',elev='118.0',kv='0.0',l='0.0',b='0.0' WHERE cat3=7;
+UPDATE Circuit_Marks SET pk='0.0',dist='',elev='',azi='',name='',cod='' WHERE cat7=1;
+UPDATE Circuit_Marks SET pk='875.5',dist='0',elev='0',azi='1',name='Bridge1',cod='a1' WHERE cat7=2;
+UPDATE Circuit_Marks SET pk='1074.0',dist='0',elev='0',azi='-1',name='Bridge2',cod='a1' WHERE cat7=3;
+UPDATE Circuit_Marks SET pk='1690.0',dist='0',elev='0',azi='1',name='Tunel1',cod='a2' WHERE cat7=4;
+UPDATE Circuit_Marks SET pk='1715.0',dist='0',elev='0',azi='1',name='Pila',cod='' WHERE cat7=5;
+UPDATE Circuit_Marks SET pk='1740.0',dist='0',elev='0',azi='1',name='Pila',cod='' WHERE cat7=6;
+UPDATE Circuit_Marks SET pk='1765.0',dist='0',elev='0',azi='1',name='Pila',cod='' WHERE cat7=7;
+UPDATE Circuit_Marks SET pk='1790.0',dist='0',elev='0',azi='1',name='Pila',cod='' WHERE cat7=8;
+UPDATE Circuit_Marks SET pk='1811.0',dist='0',elev='0',azi='-1',name='Tunel2',cod='a2' WHERE cat7=9;
+UPDATE Circuit_Marks SET pk='2208.88779535',dist='',elev='',azi='',name='',cod='' WHERE cat7=10;
+UPDATE Circuit_Terr SET pk='0.0',cut_left='2.0',cut_right='2.0',fill_left='0.5',fill_right='0.5',height='0.0',leng='0.0' WHERE cat5=1;
+UPDATE Circuit_Terr SET pk='1550.0',cut_left='2.0',cut_right='2.0',fill_left='0.5',fill_right='0.5',height='0.0',leng='0.0' WHERE cat5=2;
+UPDATE Circuit_Terr SET pk='1600.0',cut_left='2.0',cut_right='2.0',fill_left='4.0',fill_right='4.0',height='0.0',leng='0.0' WHERE cat5=3;
+UPDATE Circuit_Terr SET pk='1850.0',cut_left='2.0',cut_right='2.0',fill_left='0.5',fill_right='0.5',height='0.0',leng='0.0' WHERE cat5=4;
+UPDATE Circuit_Terr SET pk='2208.88779535',cut_left='2.0',cut_right='2.0',fill_left='0.5',fill_right='0.5',height='0.0',leng='0.0' WHERE cat5=5;
+UPDATE Circuit_Trans SET pk='0.0',dist_left='20.0',dist_right='20.0',npk='20.0' WHERE cat6=1;
+UPDATE Circuit_Trans SET pk='2208.88779535',dist_left='20.0',dist_right='20.0',npk='20.0' WHERE cat6=2;
+UPDATE Circuit SET name='Circuit' WHERE cat=1;
+" | db.execute input=-
+</code></pre>
