[GRASS-SVN] r68836 - grass/trunk/vector/v.outlier
svn_grass at osgeo.org
Sat Jul 2 06:47:29 PDT 2016
Author: martinl
Date: 2016-07-02 06:47:29 -0700 (Sat, 02 Jul 2016)
New Revision: 68836
grass/trunk/vector/v.outlier/main.c
v.outlier: define parser rule for -e flag, use standardized options
Modified: grass/trunk/vector/v.outlier/main.c
--- grass/trunk/vector/v.outlier/main.c 2016-07-02 01:39:06 UTC (rev 68835)
+++ grass/trunk/vector/v.outlier/main.c 2016-07-02 13:47:29 UTC (rev 68836)
@@ -78,26 +78,20 @@
spline_step_flag->label = _("Estimate point density and distance");
spline_step_flag->description =
_("Estimate point density and distance for the input vector points within the current region extends and quit");
+ spline_step_flag->suppress_required = YES;
in_opt = G_define_standard_option(G_OPT_V_INPUT);
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
- outlier_opt = G_define_option();
+ outlier_opt = G_define_standard_option(G_OPT_V_OUTPUT);
outlier_opt->key = "outlier";
- outlier_opt->type = TYPE_STRING;
- outlier_opt->key_desc = "name";
- outlier_opt->required = YES;
- outlier_opt->gisprompt = "new,vector,vector";
- outlier_opt->description = _("Name of output outlier vector map");
+ outlier_opt->description = _("Name for output outlier vector map");
- qgis_opt = G_define_option();
+ qgis_opt = G_define_standard_option(G_OPT_V_OUTPUT);
qgis_opt->key = "qgis";
- qgis_opt->type = TYPE_STRING;
- qgis_opt->key_desc = "name";
qgis_opt->required = NO;
- qgis_opt->gisprompt = "new,vector,vector";
- qgis_opt->description = _("Name of vector map for visualization in QGIS");
+ qgis_opt->description = _("Name for vector map for visualization in QGIS");
stepE_opt = G_define_option();
stepE_opt->key = "ew_step";
@@ -140,8 +134,10 @@
filter_opt->options = "both,positive,negative";
filter_opt->answer = "both";
- /* Parsing */
G_gisinit(argv[0]);
+ G_option_requires(spline_step_flag, in_opt, NULL);
+ /* Parsing */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -166,19 +162,22 @@
flag_auxiliar = FALSE;
/* Checking vector names */
- Vect_check_input_output_name(in_opt->answer, out_opt->answer,
- G_FATAL_EXIT);
+ if (out_opt->answer)
+ Vect_check_input_output_name(in_opt->answer, out_opt->answer,
+ G_FATAL_EXIT);
if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL) {
G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
/* Setting auxiliar table's name */
- if (G_name_is_fully_qualified(out_opt->answer, xname, xmapset)) {
- sprintf(table_name, "%s_aux", xname);
+ if (out_opt->answer) {
+ if (G_name_is_fully_qualified(out_opt->answer, xname, xmapset)) {
+ sprintf(table_name, "%s_aux", xname);
+ else
+ sprintf(table_name, "%s_aux", out_opt->answer);
- else
- sprintf(table_name, "%s_aux", out_opt->answer);
/* Something went wrong in a previous v.outlier execution */
if (db_table_exists(dvr, db, table_name)) {
